Building Linux Kernel
3,058 次查看
thejeswarareddy
I am using the below link to build the Linux Image for IMX283
Building Linux Kernel  and
Yocto Training - HOME
and facing some errors in
Task #2 - First build
at bitbake command;
$ bitbake core-image-minimal
WARNING: Host distribution "Ubuntu-16.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
WARNING: Unable to get checksum for linux-boundary SRC_URI entry defconfig: file could not be found####### | ETA:  00:00:00
Parsing recipes: 100% |####################################################################################| Time: 00:00:21
Parsing of 1343 .bb files complete (0 cached, 1343 parsed). 1736 targets, 81 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION        = "1.20.0"
BUILD_SYS         = "x86_64-linux"
NATIVELSBSTRING   = "Ubuntu-16.04"
TARGET_SYS        = "arm-poky-linux-gnueabi"
MACHINE           = "imx6qsabresd"
DISTRO            = "poky"
DISTRO_VERSION    = "1.5.4"
TUNE_FEATURES     = "armv7a vfp neon callconvention-hard cortexa9"
TARGET_FPU        = "vfp-neon"
meta
meta-yocto        = "(nobranch):8e9e7e8def9b0b728937d34115f7165677c31bed"
meta-oe           = "(nobranch):e75ae8f50af3effe560c43fc63cfd1f39395f011"
meta-fsl-arm      = "(nobranch):5fdb620c09df11e70434092f675c891e0ba84108"
meta-fsl-arm-extra = "(nobranch):375f89b70655be2a17bbde36de6adb4e4a5a6975"
meta-fsl-demos    = "(nobranch):5a12677ad000a926d23c444266722a778ea228a7"
NOTE: Preparing runqueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: Function failed: do_compile (log file is located at /home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/temp/log.do_compile.24688)
ERROR: Logfile of failure stored in: /home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/temp/log.do_compile.24688
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 4
| make  all-recursive
| make[1]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build'
| Making all in tests
| make[2]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests'
| Making all in .
| make[3]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests'
| make[3]: Nothing to be done for 'all-am'.
| make[3]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests'
| Making all in devel
| make[3]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests/devel'
| make[3]: Nothing to be done for 'all'.
| make[3]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests/devel'
| Making all in mpn
| make[3]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests/mpn'
| make[3]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests/mpn'
| Making all in mpz
| make[3]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests/mpz'
| make[3]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests/mpz'
| Making all in mpq
| make[3]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests/mpq'
| make[3]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests/mpq'
| Making all in mpf
| make[3]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests/mpf'
| make[3]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests/mpf'
| Making all in rand
| make[3]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests/rand'
| make[3]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests/rand'
| Making all in misc
| make[3]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests/misc'
| make[3]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests/misc'
| Making all in cxx
| make[3]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests/cxx'
| make[3]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests/cxx'
| make[2]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tests'
| Making all in mpn
| make[2]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/mpn'
| make[2]: Nothing to be done for 'all'.
| make[2]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/mpn'
| Making all in mpz
| make[2]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/mpz'
| make[2]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/mpz'
| Making all in mpq
| make[2]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/mpq'
| make[2]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/mpq'
| Making all in mpf
| make[2]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/mpf'
| make[2]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/mpf'
| Making all in printf
| make[2]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/printf'
| make[2]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/printf'
| Making all in scanf
| make[2]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/scanf'
| make[2]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/scanf'
| Making all in rand
| make[2]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/rand'
| make[2]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/rand'
| Making all in cxx
| make[2]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/cxx'
| make[2]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/cxx'
| Making all in demos
| make[2]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/demos'
| Making all in calc
| make[3]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/demos/calc'
| make  all-am
| make[4]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/demos/calc'
| make[4]: Nothing to be done for 'all-am'.
| make[4]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/demos/calc'
| make[3]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/demos/calc'
| Making all in expr
| make[3]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/demos/expr'
| make[3]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/demos/expr'
| make[3]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/demos'
| make[3]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/demos'
| make[2]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/demos'
| Making all in tune
| make[2]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tune'
| make[2]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/tune'
| Making all in doc
| make[2]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/doc'
| make[2]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build/doc'
| make[2]: Entering directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build'
| ./x86_64-linux-libtool --tag=CC   --mode=link gcc   -isystem/home/user/fsl-community-bsp/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe   -version-info 11:1:1 -L/home/user/fsl-community-bsp/build/tmp/sysroots/x86_64-linux/usr/lib -L/home/user/fsl-community-bsp/build/tmp/sysroots/x86_64-linux/lib -Wl,-rpath-link,/home/user/fsl-community-bsp/build/tmp/sysroots/x86_64-linux/usr/lib -Wl,-rpath-link,/home/user/fsl-community-bsp/build/tmp/sysroots/x86_64-linux/lib -Wl,-rpath,/home/user/fsl-community-bsp/build/tmp/sysroots/x86_64-linux/usr/lib -Wl,-rpath,/home/user/fsl-community-bsp/build/tmp/sysroots/x86_64-linux/lib -Wl,-O1 -o libgmp.la -rpath /home/user/fsl-community-bsp/build/tmp/sysroots/x86_64-linux/usr/lib assert.lo compat.lo errno.lo extract-dbl.lo invalid.lo memory.lo mp_bpl.lo mp_clz_tab.lo mp_dv_tab.lo mp_minv_tab.lo mp_get_fns.lo mp_set_fns.lo version.lo nextprime.lo primesieve.lo tal-reent.lo mpf/init.lo mpf/init2.lo mpf/inits.lo mpf/set.lo mpf/set_ui.lo mpf/set_si.lo mpf/set_str.lo mpf/set_d.lo mpf/set_z.lo mpf/iset.lo mpf/iset_ui.lo mpf/iset_si.lo mpf/iset_str.lo mpf/iset_d.lo mpf/clear.lo mpf/clears.lo mpf/get_str.lo mpf/dump.lo mpf/size.lo mpf/eq.lo mpf/reldiff.lo mpf/sqrt.lo mpf/random2.lo mpf/inp_str.lo mpf/out_str.lo mpf/add.lo mpf/add_ui.lo mpf/sub.lo mpf/sub_ui.lo mpf/ui_sub.lo mpf/mul.lo mpf/mul_ui.lo mpf/div.lo mpf/div_ui.lo mpf/cmp.lo mpf/cmp_d.lo mpf/cmp_ui.lo mpf/cmp_si.lo mpf/mul_2exp.lo mpf/div_2exp.lo mpf/abs.lo mpf/neg.lo mpf/set_q.lo mpf/get_d.lo mpf/get_d_2exp.lo mpf/set_dfl_prec.lo mpf/set_prc.lo mpf/set_prc_raw.lo mpf/get_dfl_prec.lo mpf/get_prc.lo mpf/ui_div.lo mpf/sqrt_ui.lo mpf/ceilfloor.lo mpf/trunc.lo mpf/pow_ui.lo mpf/urandomb.lo mpf/swap.lo mpf/fits_sint.lo mpf/fits_slong.lo mpf/fits_sshort.lo mpf/fits_uint.lo mpf/fits_ulong.lo mpf/fits_ushort.lo mpf/get_si.lo mpf/get_ui.lo mpf/int_p.lo mpz/abs.lo mpz/add.lo mpz/add_ui.lo mpz/aorsmul.lo mpz/aorsmul_i.lo mpz/and.lo mpz/array_init.lo mpz/bin_ui.lo mpz/bin_uiui.lo mpz/cdiv_q.lo mpz/cdiv_q_ui.lo mpz/cdiv_qr.lo mpz/cdiv_qr_ui.lo mpz/cdiv_r.lo mpz/cdiv_r_ui.lo mpz/cdiv_ui.lo mpz/cfdiv_q_2exp.lo mpz/cfdiv_r_2exp.lo mpz/clear.lo mpz/clears.lo mpz/clrbit.lo mpz/cmp.lo mpz/cmp_d.lo mpz/cmp_si.lo mpz/cmp_ui.lo mpz/cmpabs.lo mpz/cmpabs_d.lo mpz/cmpabs_ui.lo mpz/com.lo mpz/combit.lo mpz/cong.lo mpz/cong_2exp.lo mpz/cong_ui.lo mpz/divexact.lo mpz/divegcd.lo mpz/dive_ui.lo mpz/divis.lo mpz/divis_ui.lo mpz/divis_2exp.lo mpz/dump.lo mpz/export.lo mpz/mfac_uiui.lo mpz/2fac_ui.lo mpz/fac_ui.lo mpz/oddfac_1.lo mpz/prodlimbs.lo mpz/fdiv_q_ui.lo mpz/fdiv_qr.lo mpz/fdiv_qr_ui.lo mpz/fdiv_r.lo mpz/fdiv_r_ui.lo mpz/fdiv_q.lo mpz/fdiv_ui.lo mpz/fib_ui.lo mpz/fib2_ui.lo mpz/fits_sint.lo mpz/fits_slong.lo mpz/fits_sshort.lo mpz/fits_uint.lo mpz/fits_ulong.lo mpz/fits_ushort.lo mpz/gcd.lo mpz/gcd_ui.lo mpz/gcdext.lo mpz/get_d.lo mpz/get_d_2exp.lo mpz/get_si.lo mpz/get_str.lo mpz/get_ui.lo mpz/getlimbn.lo mpz/hamdist.lo mpz/import.lo mpz/init.lo mpz/init2.lo mpz/inits.lo mpz/inp_raw.lo mpz/inp_str.lo mpz/invert.lo mpz/ior.lo mpz/iset.lo mpz/iset_d.lo mpz/iset_si.lo mpz/iset_str.lo mpz/iset_ui.lo mpz/jacobi.lo mpz/kronsz.lo mpz/kronuz.lo mpz/kronzs.lo mpz/kronzu.lo mpz/lcm.lo mpz/lcm_ui.lo mpz/lucnum_ui.lo mpz/lucnum2_ui.lo mpz/millerrabin.lo mpz/mod.lo mpz/mul.lo mpz/mul_2exp.lo mpz/mul_si.lo mpz/mul_ui.lo mpz/n_pow_ui.lo mpz/neg.lo mpz/nextprime.lo mpz/out_raw.lo mpz/out_str.lo mpz/perfpow.lo mpz/perfsqr.lo mpz/popcount.lo mpz/pow_ui.lo mpz/powm.lo mpz/powm_sec.lo mpz/powm_ui.lo mpz/primorial_ui.lo mpz/pprime_p.lo mpz/random.lo mpz/random2.lo mpz/realloc.lo mpz/realloc2.lo mpz/remove.lo mpz/root.lo mpz/rootrem.lo mpz/rrandomb.lo mpz/scan0.lo mpz/scan1.lo mpz/set.lo mpz/set_d.lo mpz/set_f.lo mpz/set_q.lo mpz/set_si.lo mpz/set_str.lo mpz/set_ui.lo mpz/setbit.lo mpz/size.lo mpz/sizeinbase.lo mpz/sqrt.lo mpz/sqrtrem.lo mpz/sub.lo mpz/sub_ui.lo mpz/swap.lo mpz/tdiv_ui.lo mpz/tdiv_q.lo mpz/tdiv_q_2exp.lo mpz/tdiv_q_ui.lo mpz/tdiv_qr.lo mpz/tdiv_qr_ui.lo mpz/tdiv_r.lo mpz/tdiv_r_2exp.lo mpz/tdiv_r_ui.lo mpz/tstbit.lo mpz/ui_pow_ui.lo mpz/ui_sub.lo mpz/urandomb.lo mpz/urandomm.lo mpz/xor.lo mpq/abs.lo mpq/aors.lo mpq/canonicalize.lo mpq/clear.lo mpq/clears.lo mpq/cmp.lo mpq/cmp_si.lo mpq/cmp_ui.lo mpq/div.lo mpq/get_d.lo mpq/get_den.lo mpq/get_num.lo mpq/get_str.lo mpq/init.lo mpq/inits.lo mpq/inp_str.lo mpq/inv.lo mpq/md_2exp.lo mpq/mul.lo mpq/neg.lo mpq/out_str.lo mpq/set.lo mpq/set_den.lo mpq/set_num.lo mpq/set_si.lo mpq/set_str.lo mpq/set_ui.lo mpq/equal.lo mpq/set_z.lo mpq/set_d.lo mpq/set_f.lo mpq/swap.lo mpn/fib_table.lo mpn/mp_bases.lo  mpn/invert_limb_table.lo mpn/add.lo mpn/add_1.lo mpn/add_n.lo mpn/sub.lo mpn/sub_1.lo mpn/sub_n.lo mpn/addcnd_n.lo mpn/subcnd_n.lo mpn/neg.lo mpn/com.lo mpn/mul_1.lo mpn/addmul_1.lo mpn/submul_1.lo mpn/add_err1_n.lo mpn/add_err2_n.lo mpn/add_err3_n.lo mpn/sub_err1_n.lo mpn/sub_err2_n.lo mpn/sub_err3_n.lo mpn/lshift.lo mpn/rshift.lo mpn/dive_1.lo mpn/diveby3.lo mpn/divis.lo mpn/divrem.lo mpn/divrem_1.lo mpn/divrem_2.lo mpn/fib2_ui.lo mpn/mod_1.lo mpn/mod_34lsub1.lo mpn/mode1o.lo mpn/pre_mod_1.lo mpn/dump.lo mpn/mod_1_1.lo mpn/mod_1_2.lo mpn/mod_1_3.lo mpn/mod_1_4.lo mpn/lshiftc.lo mpn/mul.lo mpn/mul_fft.lo mpn/mul_n.lo mpn/sqr.lo mpn/mul_basecase.lo mpn/sqr_basecase.lo mpn/nussbaumer_mul.lo mpn/mulmid_basecase.lo mpn/toom42_mulmid.lo mpn/mulmid_n.lo mpn/mulmid.lo mpn/random.lo mpn/random2.lo mpn/pow_1.lo mpn/rootrem.lo mpn/sqrtrem.lo mpn/get_str.lo mpn/set_str.lo mpn/scan0.lo mpn/scan1.lo mpn/popcount.lo mpn/hamdist.lo mpn/cmp.lo mpn/perfsqr.lo mpn/perfpow.lo mpn/gcd_1.lo mpn/gcd.lo mpn/gcdext_1.lo mpn/gcdext.lo mpn/gcd_subdiv_step.lo mpn/gcdext_lehmer.lo mpn/div_q.lo mpn/tdiv_qr.lo mpn/jacbase.lo mpn/jacobi_2.lo mpn/jacobi.lo mpn/get_d.lo mpn/matrix22_mul.lo mpn/matrix22_mul1_inverse_vector.lo mpn/hgcd_matrix.lo mpn/hgcd2.lo mpn/hgcd_step.lo mpn/hgcd_reduce.lo mpn/hgcd.lo mpn/hgcd_appr.lo mpn/hgcd2_jacobi.lo mpn/hgcd_jacobi.lo mpn/mullo_n.lo mpn/mullo_basecase.lo mpn/toom22_mul.lo mpn/toom32_mul.lo mpn/toom42_mul.lo mpn/toom52_mul.lo mpn/toom62_mul.lo mpn/toom33_mul.lo mpn/toom43_mul.lo mpn/toom53_mul.lo mpn/toom54_mul.lo mpn/toom63_mul.lo mpn/toom44_mul.lo mpn/toom6h_mul.lo mpn/toom6_sqr.lo mpn/toom8h_mul.lo mpn/toom8_sqr.lo mpn/toom_couple_handling.lo mpn/toom2_sqr.lo mpn/toom3_sqr.lo mpn/toom4_sqr.lo mpn/toom_eval_dgr3_pm1.lo mpn/toom_eval_dgr3_pm2.lo mpn/toom_eval_pm1.lo mpn/toom_eval_pm2.lo mpn/toom_eval_pm2exp.lo mpn/toom_eval_pm2rexp.lo mpn/toom_interpolate_5pts.lo mpn/toom_interpolate_6pts.lo mpn/toom_interpolate_7pts.lo mpn/toom_interpolate_8pts.lo mpn/toom_interpolate_12pts.lo mpn/toom_interpolate_16pts.lo mpn/invertappr.lo mpn/invert.lo mpn/binvert.lo mpn/mulmod_bnm1.lo mpn/sqrmod_bnm1.lo mpn/div_qr_2.lo mpn/div_qr_2n_pi1.lo mpn/div_qr_2u_pi1.lo mpn/sbpi1_div_q.lo mpn/sbpi1_div_qr.lo mpn/sbpi1_divappr_q.lo mpn/dcpi1_div_q.lo mpn/dcpi1_div_qr.lo mpn/dcpi1_divappr_q.lo mpn/mu_div_qr.lo mpn/mu_divappr_q.lo mpn/mu_div_q.lo mpn/bdiv_q_1.lo mpn/sbpi1_bdiv_q.lo mpn/sbpi1_bdiv_qr.lo mpn/dcpi1_bdiv_q.lo mpn/dcpi1_bdiv_qr.lo mpn/mu_bdiv_q.lo mpn/mu_bdiv_qr.lo mpn/bdiv_q.lo mpn/bdiv_qr.lo mpn/broot.lo mpn/brootinv.lo mpn/bsqrt.lo mpn/bsqrtinv.lo mpn/divexact.lo mpn/bdiv_dbm1c.lo mpn/redc_1.lo mpn/redc_2.lo mpn/redc_n.lo mpn/powm.lo mpn/powlo.lo mpn/powm_sec.lo mpn/sb_div_qr_sec.lo mpn/sb_div_r_sec.lo mpn/sbpi1_div_qr_sec.lo mpn/sbpi1_div_r_sec.lo mpn/trialdiv.lo mpn/remove.lo mpn/and_n.lo mpn/andn_n.lo mpn/nand_n.lo mpn/ior_n.lo mpn/iorn_n.lo mpn/nior_n.lo mpn/xor_n.lo mpn/xnor_n.lo mpn/copyi.lo mpn/copyd.lo mpn/zero.lo mpn/tabselect.lo mpn/comb_tables.lo mpn/invert_limb.lo mpn/mul_2.lo mpn/addmul_2.lo mpn/addlsh1_n.lo mpn/sublsh1_n.lo mpn/rsblsh1_n.lo mpn/rsh1add_n.lo mpn/rsh1sub_n.lo mpn/addlsh2_n.lo mpn/rsblsh2_n.lo mpn/addlsh_n.lo mpn/rsblsh_n.lo mpn/add_n_sub_n.lo mpn/addaddmul_1msb0.lo printf/asprintf.lo printf/asprntffuns.lo printf/doprnt.lo printf/doprntf.lo printf/doprnti.lo printf/fprintf.lo printf/obprintf.lo printf/obvprintf.lo printf/obprntffuns.lo printf/printf.lo printf/printffuns.lo printf/snprintf.lo printf/snprntffuns.lo printf/sprintf.lo printf/sprintffuns.lo printf/vasprintf.lo printf/vfprintf.lo printf/vprintf.lo printf/vsnprintf.lo printf/vsprintf.lo printf/repl-vsnprintf.lo  scanf/doscan.lo scanf/fscanf.lo scanf/fscanffuns.lo scanf/scanf.lo scanf/sscanf.lo scanf/sscanffuns.lo scanf/vfscanf.lo scanf/vscanf.lo scanf/vsscanf.lo rand/rand.lo rand/randclr.lo rand/randdef.lo rand/randiset.lo rand/randlc2s.lo rand/randlc2x.lo rand/randmt.lo rand/randmts.lo rand/rands.lo rand/randsd.lo rand/randsdui.lo rand/randbui.lo rand/randmui.lo
| x86_64-linux-libtool: link: gcc  -shared  -fPIC -DPIC  .libs/assert.o .libs/compat.o .libs/errno.o .libs/extract-dbl.o .libs/invalid.o .libs/memory.o .libs/mp_bpl.o .libs/mp_clz_tab.o .libs/mp_dv_tab.o .libs/mp_minv_tab.o .libs/mp_get_fns.o .libs/mp_set_fns.o .libs/version.o .libs/nextprime.o .libs/primesieve.o .libs/tal-reent.o mpf/.libs/init.o mpf/.libs/init2.o mpf/.libs/inits.o mpf/.libs/set.o mpf/.libs/set_ui.o mpf/.libs/set_si.o mpf/.libs/set_str.o mpf/.libs/set_d.o mpf/.libs/set_z.o mpf/.libs/iset.o mpf/.libs/iset_ui.o mpf/.libs/iset_si.o mpf/.libs/iset_str.o mpf/.libs/iset_d.o mpf/.libs/clear.o mpf/.libs/clears.o mpf/.libs/get_str.o mpf/.libs/dump.o mpf/.libs/size.o mpf/.libs/eq.o mpf/.libs/reldiff.o mpf/.libs/sqrt.o mpf/.libs/random2.o mpf/.libs/inp_str.o mpf/.libs/out_str.o mpf/.libs/add.o mpf/.libs/add_ui.o mpf/.libs/sub.o mpf/.libs/sub_ui.o mpf/.libs/ui_sub.o mpf/.libs/mul.o mpf/.libs/mul_ui.o mpf/.libs/div.o mpf/.libs/div_ui.o mpf/.libs/cmp.o mpf/.libs/cmp_d.o mpf/.libs/cmp_ui.o mpf/.libs/cmp_si.o mpf/.libs/mul_2exp.o mpf/.libs/div_2exp.o mpf/.libs/abs.o mpf/.libs/neg.o mpf/.libs/set_q.o mpf/.libs/get_d.o mpf/.libs/get_d_2exp.o mpf/.libs/set_dfl_prec.o mpf/.libs/set_prc.o mpf/.libs/set_prc_raw.o mpf/.libs/get_dfl_prec.o mpf/.libs/get_prc.o mpf/.libs/ui_div.o mpf/.libs/sqrt_ui.o mpf/.libs/ceilfloor.o mpf/.libs/trunc.o mpf/.libs/pow_ui.o mpf/.libs/urandomb.o mpf/.libs/swap.o mpf/.libs/fits_sint.o mpf/.libs/fits_slong.o mpf/.libs/fits_sshort.o mpf/.libs/fits_uint.o mpf/.libs/fits_ulong.o mpf/.libs/fits_ushort.o mpf/.libs/get_si.o mpf/.libs/get_ui.o mpf/.libs/int_p.o mpz/.libs/abs.o mpz/.libs/add.o mpz/.libs/add_ui.o mpz/.libs/aorsmul.o mpz/.libs/aorsmul_i.o mpz/.libs/and.o mpz/.libs/array_init.o mpz/.libs/bin_ui.o mpz/.libs/bin_uiui.o mpz/.libs/cdiv_q.o mpz/.libs/cdiv_q_ui.o mpz/.libs/cdiv_qr.o mpz/.libs/cdiv_qr_ui.o mpz/.libs/cdiv_r.o mpz/.libs/cdiv_r_ui.o mpz/.libs/cdiv_ui.o mpz/.libs/cfdiv_q_2exp.o mpz/.libs/cfdiv_r_2exp.o mpz/.libs/clear.o mpz/.libs/clears.o mpz/.libs/clrbit.o mpz/.libs/cmp.o mpz/.libs/cmp_d.o mpz/.libs/cmp_si.o mpz/.libs/cmp_ui.o mpz/.libs/cmpabs.o mpz/.libs/cmpabs_d.o mpz/.libs/cmpabs_ui.o mpz/.libs/com.o mpz/.libs/combit.o mpz/.libs/cong.o mpz/.libs/cong_2exp.o mpz/.libs/cong_ui.o mpz/.libs/divexact.o mpz/.libs/divegcd.o mpz/.libs/dive_ui.o mpz/.libs/divis.o mpz/.libs/divis_ui.o mpz/.libs/divis_2exp.o mpz/.libs/dump.o mpz/.libs/export.o mpz/.libs/mfac_uiui.o mpz/.libs/2fac_ui.o mpz/.libs/fac_ui.o mpz/.libs/oddfac_1.o mpz/.libs/prodlimbs.o mpz/.libs/fdiv_q_ui.o mpz/.libs/fdiv_qr.o mpz/.libs/fdiv_qr_ui.o mpz/.libs/fdiv_r.o mpz/.libs/fdiv_r_ui.o mpz/.libs/fdiv_q.o mpz/.libs/fdiv_ui.o mpz/.libs/fib_ui.o mpz/.libs/fib2_ui.o mpz/.libs/fits_sint.o mpz/.libs/fits_slong.o mpz/.libs/fits_sshort.o mpz/.libs/fits_uint.o mpz/.libs/fits_ulong.o mpz/.libs/fits_ushort.o mpz/.libs/gcd.o mpz/.libs/gcd_ui.o mpz/.libs/gcdext.o mpz/.libs/get_d.o mpz/.libs/get_d_2exp.o mpz/.libs/get_si.o mpz/.libs/get_str.o mpz/.libs/get_ui.o mpz/.libs/getlimbn.o mpz/.libs/hamdist.o mpz/.libs/import.o mpz/.libs/init.o mpz/.libs/init2.o mpz/.libs/inits.o mpz/.libs/inp_raw.o mpz/.libs/inp_str.o mpz/.libs/invert.o mpz/.libs/ior.o mpz/.libs/iset.o mpz/.libs/iset_d.o mpz/.libs/iset_si.o mpz/.libs/iset_str.o mpz/.libs/iset_ui.o mpz/.libs/jacobi.o mpz/.libs/kronsz.o mpz/.libs/kronuz.o mpz/.libs/kronzs.o mpz/.libs/kronzu.o mpz/.libs/lcm.o mpz/.libs/lcm_ui.o mpz/.libs/lucnum_ui.o mpz/.libs/lucnum2_ui.o mpz/.libs/millerrabin.o mpz/.libs/mod.o mpz/.libs/mul.o mpz/.libs/mul_2exp.o mpz/.libs/mul_si.o mpz/.libs/mul_ui.o mpz/.libs/n_pow_ui.o mpz/.libs/neg.o mpz/.libs/nextprime.o mpz/.libs/out_raw.o mpz/.libs/out_str.o mpz/.libs/perfpow.o mpz/.libs/perfsqr.o mpz/.libs/popcount.o mpz/.libs/pow_ui.o mpz/.libs/powm.o mpz/.libs/powm_sec.o mpz/.libs/powm_ui.o mpz/.libs/primorial_ui.o mpz/.libs/pprime_p.o mpz/.libs/random.o mpz/.libs/random2.o mpz/.libs/realloc.o mpz/.libs/realloc2.o mpz/.libs/remove.o mpz/.libs/root.o mpz/.libs/rootrem.o mpz/.libs/rrandomb.o mpz/.libs/scan0.o mpz/.libs/scan1.o mpz/.libs/set.o mpz/.libs/set_d.o mpz/.libs/set_f.o mpz/.libs/set_q.o mpz/.libs/set_si.o mpz/.libs/set_str.o mpz/.libs/set_ui.o mpz/.libs/setbit.o mpz/.libs/size.o mpz/.libs/sizeinbase.o mpz/.libs/sqrt.o mpz/.libs/sqrtrem.o mpz/.libs/sub.o mpz/.libs/sub_ui.o mpz/.libs/swap.o mpz/.libs/tdiv_ui.o mpz/.libs/tdiv_q.o mpz/.libs/tdiv_q_2exp.o mpz/.libs/tdiv_q_ui.o mpz/.libs/tdiv_qr.o mpz/.libs/tdiv_qr_ui.o mpz/.libs/tdiv_r.o mpz/.libs/tdiv_r_2exp.o mpz/.libs/tdiv_r_ui.o mpz/.libs/tstbit.o mpz/.libs/ui_pow_ui.o mpz/.libs/ui_sub.o mpz/.libs/urandomb.o mpz/.libs/urandomm.o mpz/.libs/xor.o mpq/.libs/abs.o mpq/.libs/aors.o mpq/.libs/canonicalize.o mpq/.libs/clear.o mpq/.libs/clears.o mpq/.libs/cmp.o mpq/.libs/cmp_si.o mpq/.libs/cmp_ui.o mpq/.libs/div.o mpq/.libs/get_d.o mpq/.libs/get_den.o mpq/.libs/get_num.o mpq/.libs/get_str.o mpq/.libs/init.o mpq/.libs/inits.o mpq/.libs/inp_str.o mpq/.libs/inv.o mpq/.libs/md_2exp.o mpq/.libs/mul.o mpq/.libs/neg.o mpq/.libs/out_str.o mpq/.libs/set.o mpq/.libs/set_den.o mpq/.libs/set_num.o mpq/.libs/set_si.o mpq/.libs/set_str.o mpq/.libs/set_ui.o mpq/.libs/equal.o mpq/.libs/set_z.o mpq/.libs/set_d.o mpq/.libs/set_f.o mpq/.libs/swap.o mpn/.libs/fib_table.o mpn/.libs/mp_bases.o mpn/.libs/invert_limb_table.o mpn/.libs/add.o mpn/.libs/add_1.o mpn/.libs/add_n.o mpn/.libs/sub.o mpn/.libs/sub_1.o mpn/.libs/sub_n.o mpn/.libs/addcnd_n.o mpn/.libs/subcnd_n.o mpn/.libs/neg.o mpn/.libs/com.o mpn/.libs/mul_1.o mpn/.libs/addmul_1.o mpn/.libs/submul_1.o mpn/.libs/add_err1_n.o mpn/.libs/add_err2_n.o mpn/.libs/add_err3_n.o mpn/.libs/sub_err1_n.o mpn/.libs/sub_err2_n.o mpn/.libs/sub_err3_n.o mpn/.libs/lshift.o mpn/.libs/rshift.o mpn/.libs/dive_1.o mpn/.libs/diveby3.o mpn/.libs/divis.o mpn/.libs/divrem.o mpn/.libs/divrem_1.o mpn/.libs/divrem_2.o mpn/.libs/fib2_ui.o mpn/.libs/mod_1.o mpn/.libs/mod_34lsub1.o mpn/.libs/mode1o.o mpn/.libs/pre_mod_1.o mpn/.libs/dump.o mpn/.libs/mod_1_1.o mpn/.libs/mod_1_2.o mpn/.libs/mod_1_3.o mpn/.libs/mod_1_4.o mpn/.libs/lshiftc.o mpn/.libs/mul.o mpn/.libs/mul_fft.o mpn/.libs/mul_n.o mpn/.libs/sqr.o mpn/.libs/mul_basecase.o mpn/.libs/sqr_basecase.o mpn/.libs/nussbaumer_mul.o mpn/.libs/mulmid_basecase.o mpn/.libs/toom42_mulmid.o mpn/.libs/mulmid_n.o mpn/.libs/mulmid.o mpn/.libs/random.o mpn/.libs/random2.o mpn/.libs/pow_1.o mpn/.libs/rootrem.o mpn/.libs/sqrtrem.o mpn/.libs/get_str.o mpn/.libs/set_str.o mpn/.libs/scan0.o mpn/.libs/scan1.o mpn/.libs/popcount.o mpn/.libs/hamdist.o mpn/.libs/cmp.o mpn/.libs/perfsqr.o mpn/.libs/perfpow.o mpn/.libs/gcd_1.o mpn/.libs/gcd.o mpn/.libs/gcdext_1.o mpn/.libs/gcdext.o mpn/.libs/gcd_subdiv_step.o mpn/.libs/gcdext_lehmer.o mpn/.libs/div_q.o mpn/.libs/tdiv_qr.o mpn/.libs/jacbase.o mpn/.libs/jacobi_2.o mpn/.libs/jacobi.o mpn/.libs/get_d.o mpn/.libs/matrix22_mul.o mpn/.libs/matrix22_mul1_inverse_vector.o mpn/.libs/hgcd_matrix.o mpn/.libs/hgcd2.o mpn/.libs/hgcd_step.o mpn/.libs/hgcd_reduce.o mpn/.libs/hgcd.o mpn/.libs/hgcd_appr.o mpn/.libs/hgcd2_jacobi.o mpn/.libs/hgcd_jacobi.o mpn/.libs/mullo_n.o mpn/.libs/mullo_basecase.o mpn/.libs/toom22_mul.o mpn/.libs/toom32_mul.o mpn/.libs/toom42_mul.o mpn/.libs/toom52_mul.o mpn/.libs/toom62_mul.o mpn/.libs/toom33_mul.o mpn/.libs/toom43_mul.o mpn/.libs/toom53_mul.o mpn/.libs/toom54_mul.o mpn/.libs/toom63_mul.o mpn/.libs/toom44_mul.o mpn/.libs/toom6h_mul.o mpn/.libs/toom6_sqr.o mpn/.libs/toom8h_mul.o mpn/.libs/toom8_sqr.o mpn/.libs/toom_couple_handling.o mpn/.libs/toom2_sqr.o mpn/.libs/toom3_sqr.o mpn/.libs/toom4_sqr.o mpn/.libs/toom_eval_dgr3_pm1.o mpn/.libs/toom_eval_dgr3_pm2.o mpn/.libs/toom_eval_pm1.o mpn/.libs/toom_eval_pm2.o mpn/.libs/toom_eval_pm2exp.o mpn/.libs/toom_eval_pm2rexp.o mpn/.libs/toom_interpolate_5pts.o mpn/.libs/toom_interpolate_6pts.o mpn/.libs/toom_interpolate_7pts.o mpn/.libs/toom_interpolate_8pts.o mpn/.libs/toom_interpolate_12pts.o mpn/.libs/toom_interpolate_16pts.o mpn/.libs/invertappr.o mpn/.libs/invert.o mpn/.libs/binvert.o mpn/.libs/mulmod_bnm1.o mpn/.libs/sqrmod_bnm1.o mpn/.libs/div_qr_2.o mpn/.libs/div_qr_2n_pi1.o mpn/.libs/div_qr_2u_pi1.o mpn/.libs/sbpi1_div_q.o mpn/.libs/sbpi1_div_qr.o mpn/.libs/sbpi1_divappr_q.o mpn/.libs/dcpi1_div_q.o mpn/.libs/dcpi1_div_qr.o mpn/.libs/dcpi1_divappr_q.o mpn/.libs/mu_div_qr.o mpn/.libs/mu_divappr_q.o mpn/.libs/mu_div_q.o mpn/.libs/bdiv_q_1.o mpn/.libs/sbpi1_bdiv_q.o mpn/.libs/sbpi1_bdiv_qr.o mpn/.libs/dcpi1_bdiv_q.o mpn/.libs/dcpi1_bdiv_qr.o mpn/.libs/mu_bdiv_q.o mpn/.libs/mu_bdiv_qr.o mpn/.libs/bdiv_q.o mpn/.libs/bdiv_qr.o mpn/.libs/broot.o mpn/.libs/brootinv.o mpn/.libs/bsqrt.o mpn/.libs/bsqrtinv.o mpn/.libs/divexact.o mpn/.libs/bdiv_dbm1c.o mpn/.libs/redc_1.o mpn/.libs/redc_2.o mpn/.libs/redc_n.o mpn/.libs/powm.o mpn/.libs/powlo.o mpn/.libs/powm_sec.o mpn/.libs/sb_div_qr_sec.o mpn/.libs/sb_div_r_sec.o mpn/.libs/sbpi1_div_qr_sec.o mpn/.libs/sbpi1_div_r_sec.o mpn/.libs/trialdiv.o mpn/.libs/remove.o mpn/.libs/and_n.o mpn/.libs/andn_n.o mpn/.libs/nand_n.o mpn/.libs/ior_n.o mpn/.libs/iorn_n.o mpn/.libs/nior_n.o mpn/.libs/xor_n.o mpn/.libs/xnor_n.o mpn/.libs/copyi.o mpn/.libs/copyd.o mpn/.libs/zero.o mpn/.libs/tabselect.o mpn/.libs/comb_tables.o mpn/.libs/invert_limb.o mpn/.libs/mul_2.o mpn/.libs/addmul_2.o mpn/.libs/addlsh1_n.o mpn/.libs/sublsh1_n.o mpn/.libs/rsblsh1_n.o mpn/.libs/rsh1add_n.o mpn/.libs/rsh1sub_n.o mpn/.libs/addlsh2_n.o mpn/.libs/rsblsh2_n.o mpn/.libs/addlsh_n.o mpn/.libs/rsblsh_n.o mpn/.libs/add_n_sub_n.o mpn/.libs/addaddmul_1msb0.o printf/.libs/asprintf.o printf/.libs/asprntffuns.o printf/.libs/doprnt.o printf/.libs/doprntf.o printf/.libs/doprnti.o printf/.libs/fprintf.o printf/.libs/obprintf.o printf/.libs/obvprintf.o printf/.libs/obprntffuns.o printf/.libs/printf.o printf/.libs/printffuns.o printf/.libs/snprintf.o printf/.libs/snprntffuns.o printf/.libs/sprintf.o printf/.libs/sprintffuns.o printf/.libs/vasprintf.o printf/.libs/vfprintf.o printf/.libs/vprintf.o printf/.libs/vsnprintf.o printf/.libs/vsprintf.o printf/.libs/repl-vsnprintf.o scanf/.libs/doscan.o scanf/.libs/fscanf.o scanf/.libs/fscanffuns.o scanf/.libs/scanf.o scanf/.libs/sscanf.o scanf/.libs/sscanffuns.o scanf/.libs/vfscanf.o scanf/.libs/vscanf.o scanf/.libs/vsscanf.o rand/.libs/rand.o rand/.libs/randclr.o rand/.libs/randdef.o rand/.libs/randiset.o rand/.libs/randlc2s.o rand/.libs/randlc2x.o rand/.libs/randmt.o rand/.libs/randmts.o rand/.libs/rands.o rand/.libs/randsd.o rand/.libs/randsdui.o rand/.libs/randbui.o rand/.libs/randmui.o   -L/home/user/fsl-community-bsp/build/tmp/sysroots/x86_64-linux/usr/lib -L/home/user/fsl-community-bsp/build/tmp/sysroots/x86_64-linux/lib  -O2 -Wl,-rpath-link -Wl,/home/user/fsl-community-bsp/build/tmp/sysroots/x86_64-linux/usr/lib -Wl,-rpath-link -Wl,/home/user/fsl-community-bsp/build/tmp/sysroots/x86_64-linux/lib -Wl,-rpath -Wl,/home/user/fsl-community-bsp/build/tmp/sysroots/x86_64-linux/usr/lib -Wl,-rpath -Wl,/home/user/fsl-community-bsp/build/tmp/sysroots/x86_64-linux/lib -Wl,-O1   -Wl,-soname -Wl,libgmp.so.10 -o .libs/libgmp.so.10.1.1
| /usr/bin/ld: mpn/.libs/invert_limb.o: relocation R_X86_64_PC32 against protected symbol `__gmpn_invert_limb_table' can not be used when making a shared object
| /usr/bin/ld: final link failed: Bad value
| collect2: error: ld returned 1 exit status
| Makefile:748: recipe for target 'libgmp.la' failed
| make[2]: *** [libgmp.la] Error 1
| make[2]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build'
| Makefile:837: recipe for target 'all-recursive' failed
| make[1]: *** [all-recursive] Error 1
| make[1]: Leaving directory '/home/user/fsl-community-bsp/build/tmp/work/x86_64-linux/gmp-native/5.1.1-r0/build'
| Makefile:658: recipe for target 'all' failed
| make: *** [all] Error 2
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
ERROR: Task 1133 (virtual:native:/home/user/fsl-community-bsp/sources/poky/meta/recipes-support/gmp/gmp_5.1.1.bb, do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 124 tasks of which 116 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There were 2 WARNING messages shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
Thanks in Advance!
2,385 次查看
Yuri
   You may try the recent NXP BSP. Use instructions in "i.MX_Yocto_Project_User's_Guide.pdf".
According to section 3 (Host Setup):
The recommended minimum Ubuntu version is 14.04 but builds for Jethro works on 12.04 or later.
Ubuntu 16.04 users have commented on errors during build for SDL. To fix this comment out in
local.conf the following lines as such adding # character
#PACKAGECONFIG_append_pn-qemu-native = " sdl"
#PACKAGECONFIG_append_pn-nativesdk-qemu = " sdl"
https://www.nxp.com/webapp/Download?colCode=L4.9.11_1.0.0_LINUX_DOCS
i.MX 6 / i.MX 7 Series Software and Development Tool|NXP
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
