Build optee-examples in NXP Yocto project
ソリューションへジャンプ
2,000件の閲覧回数
Helpi90
Hi all,
I have been trying to include optee-examples in the NXP Yocto project for several hours now. The normal build for my imx6qpsabresd board works great. I have then added the examples according to the instructions from @Zhiming_Liu  (https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Build-optee-examples-in-yocto-hardkott/t...), but unfortunately the build process seems to have problems with the ta files. These cannot be copied because they do not exist. Can someone help me here?
The log is attached to the post. I use the manifest imx-linux-zeus -> imx-5.4.70-2.3.4.xml
ラベル(3)
1,968件の閲覧回数
Zhiming_Liu
You need use optee-examples of zeus, that link is tested under hardkott
2 返答(返信)
1,969件の閲覧回数
Zhiming_Liu
1,962件の閲覧回数
Helpi90
Thanks for your answer. I had already found the error with the wrong version.
