Bootloader issue on MIMXRT1176
2,050件の閲覧回数
smartpavan333
I am working on bootloader in MIMXRT1176-EVK and referred these two examples for OTA update through bootloader.
Eg 1 : "mcuboot_opensource"
Eg 2 : "lwip_httpscli_ota_enet"
I tried on "led_blinky.bin" upload through OTA update, its working fine but, I tried on "sd_jpeg.bin" it's not working.
I assuming that "sd_jpeg.icf" needs to change according to the"lwip_httpscli_ota_enet.icf".
Please find the attachments below.
Can you help me this issue?
Thanks.
2,010件の閲覧回数
jingpan
Hi @smartpavan333 ,
The sd_jpeg.txt put code in ITCM and data in SDRAM. But the opensource_mcuboot will not copy code to ITCM and will not initialize SDRAM. So you must add these function to it.
Jing
