Boot success. thanks
jonazkln31
Just wanted to share that I finally got the i.MX board to boot properly after a few rounds of trial and error. Turned out to be a small config issue in the device tree, but thanks to some helpful threads here and a bit of digging through the docs, everything's running now. U-Boot is behaving as expected, and the kernel's coming up clean. Always a good feeling when the serial console finally shows what you want to see.
That said, after hours of flashing images, debugging boot logs, and rechecking pin configurations, it definitely takes a toll on your focus. I've been leaning on a few wellness habits lately to stay mentally sharp—things like short breaks, functional blends, and the occasional low-key edible have actually helped keep me in the zone. I found a few solid options over at area52.com that have made a difference during those long dev sessions. Might be worth a look if you’re in the same boat.
