Boot kernel and filesystem from u-boot-2013
6,545件の閲覧回数
manjunathjoshi
Hello All,
I have configured the u-boot 2013.04 to detect USB at u-boot. I am getting the following logs,
U-Boot > usb start
(Re)start USB...
USB0:   USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
       scanning usb for ethernet devices... 0 Ethernet Device(s) found
Even though there is a USB i can't access it. Please let me know if anybody has had this issue and please reply ASAP.
The most important thing is this port is USB OTG.
ラベル(2)
5,865件の閲覧回数
manjunathjoshi
Hello All,
The issue was power sequence in module in which PMIC PFUZE100 chip had to be powered on (connected by i2c lines), before checking for USB.
It is purely power issue. If power is not proper to USB, the above issue arises. that is the reason why i never faced the above problem when i did a soft "reboot" but on hard power off and on this issue was seen every time.
That was my final conclusion. Thank you all for helping out. Specially igorpadykov.
Manju
10 返答(返信)
5,866件の閲覧回数
manjunathjoshi
Hello All,
Manju
5,865件の閲覧回数
manjunathjoshi
Hello Igor,
This issue is not solved.
I have tried using debug prints and below are the logs,
U-Boot > usb start
(Re)start USB...
USB0:   USB EHCI 1.00
scanning bus 0 for devices... New Device 0
usb_control_msg: request: 0x6, requesttype: 0x80, value 0x100 index 0x0 length 0x40
set address 1
usb_control_msg: request: 0x5, requesttype: 0x0, value 0x1 index 0x0 length 0x0
usb_control_msg: request: 0x6, requesttype: 0x80, value 0x100 index 0x0 length 0x12
usb_control_msg: request: 0x6, requesttype: 0x80, value 0x200 index 0x0 length 0x9
usb_control_msg: request: 0x6, requesttype: 0x80, value 0x200 index 0x0 length 0x19
get_conf_no 0 Result 25, wLength 25
if 0, ep 0
##EP epmaxpacketin[1] = 8
set configuration 1
usb_control_msg: request: 0x9, requesttype: 0x0, value 0x1 index 0x0 length 0x0
new device strings: Mfr=1, Product=2, SerialNumber=0
usb_control_msg: request: 0x6, requesttype: 0x80, value 0x300 index 0x0 length 0xFF
USB device number 1 default language ID 0x1
usb_control_msg: request: 0x6, requesttype: 0x80, value 0x301 index 0x1 length 0xFF
usb_control_msg: request: 0x6, requesttype: 0x80, value 0x302 index 0x1 length 0xFF
Manufacturer u-boot
Product      EHCI Host Controller
SerialNumber
usb_control_msg: request: 0x6, requesttype: 0xA0, value 0x2900 index 0x0 length 0x4
usb_control_msg: request: 0x6, requesttype: 0xA0, value 0x2900 index 0x0 length 0x8
usb_control_msg: request: 0x0, requesttype: 0xA0, value 0x0 index 0x0 length 0x4
usb_control_msg: request: 0x3, requesttype: 0x23, value 0x8 index 0x1 length 0x0
usb_control_msg: request: 0x0, requesttype: 0xA3, value 0x0 index 0x1 length 0x4
usb_control_msg: request: 0x1, requesttype: 0x23, value 0x10 index 0x1 length 0x0
usb_control_msg: request: 0x3, requesttype: 0x23, value 0x4 index 0x1 length 0x0
usb_control_msg: request: 0x1, requesttype: 0x23, value 0x14 index 0x1 length 0x0
New Device 1
set address 2
usb_control_msg: request: 0x5, requesttype: 0x0, value 0x2 index 0x0 length 0x0
usb_control_msg: request: 0x6, requesttype: 0x80, value 0x200 index 0x0 length 0x20
get_conf_no 0 Result 32, wLength 32
if 0, ep 0
if 0, ep 1
##EP epmaxpacketin[1] = 512
##EP epmaxpacketout[2] = 512
set configuration 1
new device strings: Mfr=1, Product=2, SerialNumber=3
USB device number 2 default language ID 0x409
usb_control_msg: request: 0x6, requesttype: 0x80, value 0x301 index 0x409 length 0xFF
usb_control_msg: request: 0x6, requesttype: 0x80, value 0x302 index 0x409 length 0xFF
usb_control_msg: request: 0x6, requesttype: 0x80, value 0x303 index 0x409 length 0xFF
Manufacturer JetFlash
Product      Mass Storage Device
SerialNumber 99TL2DWA1OQMAIUS
2 USB Device(s) found
USB1:   USB EHCI 1.00
scanning bus 1 for devices... New Device 2
set address 3
usb_control_msg: request: 0x5, requesttype: 0x0, value 0x3 index 0x0 length 0x0
if 0, ep 0
set configuration 1
USB device number 3 default language ID 0x1
Manufacturer u-boot
SerialNumber
New Device 3
set address 4
usb_control_msg: request: 0x5, requesttype: 0x0, value 0x4 index 0x0 length 0x0
if 0, ep 0
if 0, ep 1
set configuration 1
USB device number 4 default language ID 0x409
scan end
       scanning usb for storage devices... usb_control_msg: request: 0xFE, requesttype: 0xA1, value 0x0 index 0x0 length 0x1
EHCI timed out on TD - token=0x80008c80
usb_control_msg: request: 0xFF, requesttype: 0x21, value 0x0 index 0x0 length 0x0
EHCI timed out on TD - token=0x80008d80
error in inquiry
1 Storage Device(s) found
Above logs are for successful usb detection. But the problem is next time when i use the same pendrive, i am unable to get the usb working.
Manju
5,865件の閲覧回数
5,865件の閲覧回数
manjunathjoshi
Hello Igor,
Thanks for your replies. Now i am able to detect and boot from USB.
But only the first time usb is detected. Second time when it boots there is an error. Have you seen this error before,
First time:
U-Boot > usb start
(Re)start USB...
USB0:   USB EHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
USB1:   USB EHCI 1.00
scanning bus 1 for devices... 2 USB Device(s) found
       scanning usb for storage devices... EHCI timed out on TD - token=0x80008c80
error in inquiry
Second time:
U-Boot > usb start
(Re)start USB...
USB0:   USB EHCI 1.00
USB1:   USB EHCI 1.00
scanning bus 1 for devices... 1 USB Device(s) found
U-Boot > usb start
(Re)start USB...
USB0:   USB EHCI 1.00
USB1:   USB EHCI 1.00
5,865件の閲覧回数
manjunathjoshi
Hello All,
I am consistently getting this ehci timeout error. I googled a lot and i found that this is a bug from u-boot. Is there any patch that solves this issue?
I can't migrate to newer version since u-boot has some other changes as well which would be time consuming.
Manju
5,865件の閲覧回数
one can post it to uboot mail list
U-Boot Info Page
or use newer uboot versions
~igor
5,865件の閲覧回数
Hi Manjunath
there are other commands which could be used, as:
usb start
fatls usb 0:1
fatload usb 0:1 0x80800000 filename
usb read 0x80800000 0 10
for details please refer to descriptions on p.22 document
http://cache.freescale.com/files/32bit/doc/quick_ref_guide/MEDIA5200UBPG/MEDIA5200UBPG.pdf
or
http://stackoverflow.com/questions/30488942/how-to-boot-linux-kernel-from-u-boot
5,865件の閲覧回数
manjunathjoshi
Hello igorpadykov,
If i do fatls usb 0:1 i am getting,
U-Boot > fatls usb 0:1
** Bad device usb 0 **
Meanwhile the USB is not blinking.
5,865件の閲覧回数
if usb otg is used please check that ID signal
is grounded.
~igor
5,865件の閲覧回数
manjunathjoshi
Hello igorpadykov,
I am really sorry, but i didn't get what is ID signal ?
Manju
