Boot from NFS iMX93
Boot from NFS iMX93
1,791件の閲覧回数
gopal_rhsharma
We are Using iMX93Evk Boot from NFS with
Image  DISTRO=fsl-imx-xwayland MACHINE=imx93evk
But After Boot From NFS Some Services Not Work like
[FAILED] Failed to start Weston, a Wayland compositor, as a system service.
[FAILED] Failed to start Terminate Psplash Boot Screen.
Etc.
Please Kindly Help to Resolve.
Thank You
Gopal sharma
3 返答(返信)
1,763件の閲覧回数
Chavira
Hi @gopal_rhsharma!
What board are you uisng?
That is normal if you don't have any display connected to the processor.
Best Regards!
Chavira
1,729件の閲覧回数
gopal_rhsharma
We are using iMX93evk board and  LVDS Display EV121WXM-N10-1850.
1,708件の閲覧回数
Chavira
Hi @gopal_rhsharma!
By default our BSP don´t support that display, you should have to modify our BSP to support the display that you want to use.
Our board suppor the DY1212W-4856 display, and to use it you should set the fdtfile variable in uboot with imx93-11x11-evk-boe-wxga-lvds-panel.dtb.
Best Regards!
Chavira
