Boot U-Boot from ECSPI on i.MX6ULL
1,100件の閲覧回数
zard
I am developing a device based on the imx6ull chip and need to use nor flash to store the firmware. The nor uses the ecspi1 pin. Is there a uboot startup example on ecspi1 and the startup parameters of uboot startup kernel for reference?
3 返答(返信)
1,071件の閲覧回数
Chavira
Hi @zard!
Thank you for contacting NXP Support!
You can get based on the iMX6ULL-EVK board you can see the schematics and our BSP to compile successful booting from QSPI in your custom board.
https://www.nxp.com/design/design-center/development-boards-and-designs/i-mx-evaluation-and-developm...
https://www.nxp.com/design/design-center/software/embedded-software/i-mx-software/embedded-linux-for...
Best Regards!
Chavira
1,043件の閲覧回数
zard
Hi Chavira, thank you for your reply. Perhaps my question has led to some misunderstanding. My current issue is booting from ecspi, not qspi. Thank you.
1,029件の閲覧回数
Chavira
Hi @zard!
Unfortunately, our hardware is not prepared for that, and I can't provide you with examples for that.
Sorry for the mistake!
