Boot Android on imx8mm evk board not working
1,453 次查看
avijitnsec
Hi, I am trying to build Android for imx8mm evk board.
I have tried the default Android image available in the website mentioned bellow. Seems like the user-space is crashing continuously and the device is stuck at the Android boot screen.
repo location -
https://www.nxp.com/design/software/embedded-software/i-mx-software/android-os-for-i-mx-applications...
Build info - Android 11.0.0_1.2.1 (Linux 5.4.70 kernel)
Run the following commands to build Android for imx8mm_evk
$ tar xf imx-android-11.0.0_1.2.1.tar.gz
$ source imx-android-11.0.0_1.2.1/imx_android_setup.sh
$ source build/envsetup.sh
$ lunch 47 (evk_8mm-userdebug)
$ time ./imx-make.sh 2>&1 | tee build_imx8mm.log
Got the following compilation error in the Kernel, see the attached build log.
Can you please verify ?
1 回复
1,443 次查看
Bio_TICFSL
Hello avijitnsec,
The patch you mentioned is for MX8MPlus and has nothing on MX8MM, you should download and install the Android 11.0.0_2.0.0 (Linux 5.10.9 kernel).
