Bluetooth on i.MX8MP
476件の閲覧回数
wanggg
Hello, Expert,
I am testing the AW-CM358SM on the IMX8MP. The WiFi is working successfully, but when I test Bluetooth on UART3, it shows an error. The error message is as follows. I have tried many methods but still have not succeeded. Do you have any ideas on how to fix it? I would greatly appreciate your help.
error log:
Bluetooth: hci0: FW already running.
[   46.628430] Bluetooth: hci0: Opcode 0x0c03 failed: -110
dts:
&uart3 { /* BT */
    pinctrl-names = "default";
    pinctrl-0 = <&pinctrl_uart3 &pinctrl_bt_ctrl>;
    assigned-clocks = <&clk IMX8MP_CLK_UART3>;
    assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_80M>;
    uart-has-rtscts;
    status = "okay";
    bluetooth {
        compatible = "nxp,88w8987-bt";
        device-wakeup-gpios = <&gpio2 10 GPIO_ACTIVE_HIGH>;
pinctrl_uart3: uart3grp {
    fsl,pins = <
        MX8MP_IOMUXC_ECSPI1_SCLK__UART3_DCE_RX 0x140
        MX8MP_IOMUXC_ECSPI1_MOSI__UART3_DCE_TX 0x140
        MX8MP_IOMUXC_ECSPI1_MISO__UART3_DCE_CTS 0x140
        MX8MP_IOMUXC_ECSPI1_SS0__UART3_DCE_RTS 0x140
pinctrl_bt_ctrl: btctrlgrp {
    fsl,pins = <
        MX8MP_IOMUXC_SD1_RESET_B__GPIO2_IO10 0x10 /* HOST_WAKE_BT */
        MX8MP_IOMUXC_SD1_STROBE__GPIO2_IO11 0x140 /* BT_HOST_WAKE */
wifi_mod_para.conf
SD8987 = {
    cfg80211_wext=0xf
    wfd_name=p2p
    max_vir_bss=1
    cal_data_cfg=none
    drv_mode=7
    ps_mode=2
    auto_ds=2
    fw_name=nxp/sdiouart8987_combo_v0.bin
Kernel log
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.6.52-rt43-gd377c9049508-dirty (root@fbdebian) (aarch64-linux-gnu-gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Thu Jul 2 11:19:58 CST 2026
[ 0.000000] KASLR disabled due to lack of seed
[ 0.000000] Machine model: G3 i.MX8MPlus EVK board
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: unable to setup CMA region
[ 0.000000] OF: reserved mem: node linux,cma compatible matching fail
[ 0.000000] OF: reserved mem: 0x0000000000900000..0x000000000096ffff (448 KiB) nomap non-reusable ocram@900000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000013fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000013fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000013fffffff]
[ 0.000000] cma: Reserved 8 MiB at 0x00000000ff800000 on node -1
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 20 pages/cpu s43368 r8192 d30360 u81920
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: console=ttymxc1,115200 root=PARTUUID=6a120481-03 rw rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fb800000-0x00000000ff800000] (64MB)
[ 0.000000] Memory: 4012020K/4194304K available (16192K kernel code, 1688K rwdata, 5064K rodata, 3520K init, 541K bss, 174092K reserved, 8192K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 160 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000000] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.000475] Console: colour dummy device 80x25
[ 0.000519] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.000528] pid_max: default: 32768 minimum: 301
[ 0.000602] LSM: initializing lsm=capability,integrity
[ 0.000695] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000711] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002173] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.002240] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.002415] rcu: Hierarchical SRCU implementation.
[ 0.002418] rcu: Max phase no-delay instances is 1000.
[ 0.004206] EFI services will not be available.
[ 0.004444] smp: Bringing up secondary CPUs ...
[ 0.004903] Detected VIPT I-cache on CPU1
[ 0.004964] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.005000] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.005523] Detected VIPT I-cache on CPU2
[ 0.005565] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.005585] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.006045] Detected VIPT I-cache on CPU3
[ 0.006083] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.006100] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.006165] smp: Brought up 1 node, 4 CPUs
[ 0.006173] SMP: Total of 4 processors activated.
[ 0.006177] CPU features: detected: 32-bit EL0 Support
[ 0.006181] CPU features: detected: CRC32 instructions
[ 0.006243] CPU: All CPU(s) started at EL2
[ 0.006246] alternatives: applying system-wide alternatives
[ 0.008002] devtmpfs: initialized
[ 0.016979] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.017001] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.017422] pinctrl core: initialized pinctrl subsystem
[ 0.020051] DMI not present or invalid.
[ 0.020689] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.022304] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.023375] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.024665] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.024748] audit: initializing netlink subsys (disabled)
[ 0.024932] audit: type=2000 audit(0.024:1): state=initialized audit_enabled=0 res=1
[ 0.025352] thermal_sys: Registered thermal governor 'step_wise'
[ 0.025356] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.025401] cpuidle: using governor menu
[ 0.025566] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.025647] ASID allocator initialised with 65536 entries
[ 0.026696] Serial: AMBA PL011 UART driver
[ 0.026763] imx mu driver is registered.
[ 0.026785] imx rpmsg driver is registered.
[ 0.032936] platform soc@0: Fixed dependency cycle(s) with /soc@0/bus@30000000/efuse@30350000/unique-id@8
[ 0.035120] platform 30330000.pinctrl: Fixed dependency cycle(s) with /soc@0/bus@30000000/pinctrl@30330000/hoggrp
[ 0.035566] imx8mp-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[ 0.036067] platform 30350000.efuse: Fixed dependency cycle(s) with /soc@0/bus@30000000/clock-controller@30380000
[ 0.037099] platform 30350000.efuse: Fixed dependency cycle(s) with /soc@0/bus@30000000/clock-controller@30380000
[ 0.049206] Modules: 25968 pages in range for non-PLT usage
[ 0.049215] Modules: 517488 pages in range for PLT usage
[ 0.049877] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.049884] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.049889] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.049892] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.049896] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.049902] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.049909] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.049912] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.052093] iommu: Default domain type: Translated
[ 0.052102] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.052394] SCSI subsystem initialized
[ 0.052679] usbcore: registered new interface driver usbfs
[ 0.052709] usbcore: registered new interface driver hub
[ 0.052742] usbcore: registered new device driver usb
[ 0.053603] pps_core: LinuxPPS API ver. 1 registered
[ 0.053607] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.053619] PTP clock support registered
[ 0.053886] EDAC MC: Ver: 3.0.0
[ 0.054304] scmi_core: SCMI protocol bus registered
[ 0.055327] Bluetooth: Core ver 2.22
[ 0.055356] NET: Registered PF_BLUETOOTH protocol family
[ 0.055361] Bluetooth: HCI device and connection manager initialized
[ 0.055370] Bluetooth: HCI socket layer initialized
[ 0.055375] Bluetooth: L2CAP socket layer initialized
[ 0.055387] Bluetooth: SCO socket layer initialized
[ 0.055707] vgaarb: loaded
[ 0.056088] clocksource: Switched to clocksource arch_sys_counter
[ 0.056287] VFS: Disk quotas dquot_6.6.0
[ 0.056396] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.063310] NET: Registered PF_INET protocol family
[ 0.063495] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.066275] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.066325] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.066337] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.066585] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.067521] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.067635] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.067720] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.067927] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.068373] RPC: Registered named UNIX socket transport module.
[ 0.068379] RPC: Registered udp transport module.
[ 0.068381] RPC: Registered tcp transport module.
[ 0.068384] RPC: Registered tcp-with-tls transport module.
[ 0.068386] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.069403] PCI: CLS 0 bytes, default 64
[ 0.070488] Initialise system trusted keyrings
[ 0.070625] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.070895] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.071096] NFS: Registering the id_resolver key type
[ 0.071116] Key type id_resolver registered
[ 0.071120] Key type id_legacy registered
[ 0.071137] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.071142] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.071159] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.071346] 9p: Installing v9fs 9p2000 file system support
[ 0.100048] jitterentropy: Initialization failed with host not compliant with requirements: 9
[ 0.100055] Key type asymmetric registered
[ 0.100059] Asymmetric key parser 'x509' registered
[ 0.100104] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.100110] io scheduler mq-deadline registered
[ 0.100114] io scheduler kyber registered
[ 0.100139] io scheduler bfq registered
[ 0.115771] imx-sdma 30bd0000.dma-controller: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2
[ 0.115787] imx-sdma 30bd0000.dma-controller: Falling back to sysfs fallback for: imx/sdma/sdma-imx7d.bin
[ 0.117292] mxs-dma 33000000.dma-apbh: initialized
[ 0.118069] SoC: i.MX8MP revision 1.1
[ 0.118477] Bus freq driver module loaded
[ 0.135536] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.138454] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 16, base_baud = 5000000) is a IMX
[ 0.138703] serial serial0: tty port ttymxc2 registered
[ 0.139315] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 17, base_baud = 1500000) is a IMX
[ 0.139350] printk: legacy console [ttymxc1] enabled
[ 1.222791] loop: module loaded
[ 1.227149] of_reserved_mem_lookup() returned NULL
[ 1.237919] tun: Universal TUN/TAP device driver, 1.6
[ 1.244863] sky2: driver version 1.30
[ 1.249061] usbcore: registered new device driver r8152-cfgselector
[ 1.255367] usbcore: registered new interface driver r8152
[ 1.261230] VFIO - User Level meta-driver version: 0.3
[ 1.271293] usbcore: registered new interface driver uas
[ 1.276669] usbcore: registered new interface driver usb-storage
[ 1.282753] usbcore: registered new interface driver usbserial_generic
[ 1.289312] usbserial: USB Serial support registered for generic
[ 1.295346] usbcore: registered new interface driver ftdi_sio
[ 1.301121] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.308467] usbcore: registered new interface driver usb_serial_simple
[ 1.315022] usbserial: USB Serial support registered for carelink
[ 1.321145] usbserial: USB Serial support registered for flashloader
[ 1.327526] usbserial: USB Serial support registered for funsoft
[ 1.333554] usbserial: USB Serial support registered for google
[ 1.339503] usbserial: USB Serial support registered for hp4x
[ 1.345284] usbserial: USB Serial support registered for kaufmann
[ 1.351402] usbserial: USB Serial support registered for libtransistor
[ 1.357961] usbserial: USB Serial support registered for moto_modem
[ 1.364256] usbserial: USB Serial support registered for motorola_tetra
[ 1.370900] usbserial: USB Serial support registered for nokia
[ 1.376765] usbserial: USB Serial support registered for novatel_gps
[ 1.383149] usbserial: USB Serial support registered for siemens_mpi
[ 1.389527] usbserial: USB Serial support registered for suunto
[ 1.395476] usbserial: USB Serial support registered for vivopay
[ 1.401511] usbserial: USB Serial support registered for zio
[ 1.407203] usbcore: registered new interface driver usb_ehset_test
[ 1.413528] usbcore: registered new device driver onboard-usb-hub
[ 1.422006] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc0
[ 1.428227] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01T00:00:00 UTC (0)
[ 1.437427] i2c_dev: i2c /dev entries driver
[ 1.445729] Bluetooth: HCI UART driver ver 2.3
[ 1.450203] Bluetooth: HCI UART protocol H4 registered
[ 1.455351] Bluetooth: HCI UART protocol BCSP registered
[ 1.460695] Bluetooth: HCI UART protocol LL registered
[ 1.465847] Bluetooth: HCI UART protocol ATH3K registered
[ 1.471280] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 1.477642] Bluetooth: HCI UART protocol Broadcom registered
[ 1.483333] Bluetooth: HCI UART protocol QCA registered
[ 1.488739] EDAC MC: ECC not enabled
[ 1.493561] sdhci: Secure Digital Host Controller Interface driver
[ 1.499762] sdhci: Copyright(c) Pierre Ossman
[ 1.504580] Synopsys Designware Multimedia Card Interface Driver
[ 1.511193] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.519372] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.526326] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 1.535249] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.545746] platform soc@0: Fixed dependency cycle(s) with /soc@0/bus@30000000/efuse@30350000
[ 1.548948] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[ 1.555377] optee: probing for conduit method.
[ 1.565851] optee: api uid mismatch
[ 1.569678] optee: probe of firmware:optee failed with error -22
[ 1.576620] NET: Registered PF_LLC protocol family
[ 1.581492] u32 classifier
[ 1.584247] input device check on
[ 1.587910] Actions configured
[ 1.591634] NET: Registered PF_INET6 protocol family
[ 1.598148] Segment Routing with IPv6
[ 1.601891] In-situ OAM (IOAM) with IPv6
[ 1.605875] NET: Registered PF_PACKET protocol family
[ 1.610955] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.625927] Bluetooth: RFCOMM TTY layer initialized
[ 1.630834] Bluetooth: RFCOMM socket layer initialized
[ 1.634392] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[ 1.636001] Bluetooth: RFCOMM ver 1.11
[ 1.642888] mmcblk2: mmc2:0001 064G90 58.2 GiB
[ 1.646098] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.653585] mmcblk2: p1 p2 p3
[ 1.655851] Bluetooth: BNEP filters: protocol multicast
[ 1.661320] mmcblk2boot0: mmc2:0001 064G90 8.00 MiB
[ 1.664139] Bluetooth: BNEP socket layer initialized
[ 1.670589] mmcblk2boot1: mmc2:0001 064G90 8.00 MiB
[ 1.674997] 8021q: 802.1Q VLAN Support v1.8
[ 1.680430] mmcblk2rpmb: mmc2:0001 064G90 16.0 MiB, chardev (238:0)
[ 1.683109] lib80211: common routines for IEEE802.11 drivers
[ 1.695071] 9pnet: Installing 9P2000 support
[ 1.699490] Key type dns_resolver registered
[ 1.704490] NET: Registered PF_VSOCK protocol family
[ 1.719723] registered taskstats version 1
[ 1.723967] Loading compiled-in X.509 certificates
[ 1.751680] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.762305] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.772790] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.783311] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.793861] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.806692] i2c i2c-0: IMX I2C adapter registered
[ 1.813480] rtc-rx8111 2-0032: registered as rtc1
[ 1.820041] ina238 2-0043: power monitor ina237 (Rshunt = 50000 uOhm, gain = 4)
[ 1.821839] nxp-pca9450 0-0025: pca9450bc probed.
[ 1.827481] i2c i2c-2: IMX I2C adapter registered
[ 1.869694] usb251xb 3-002c: Hub configuration was successful.
[ 1.875553] usb251xb 3-002c: Hub probed successfully
[ 1.880583] i2c i2c-3: IMX I2C adapter registered
[ 1.885922] imx8mq-usb-phy 381f0040.usb-phy: supply vbus not found, using dummy regulator
[ 1.894643] imx8mq-usb-phy 382f0040.usb-phy: supply vbus not found, using dummy regulator
[ 1.912708] 30a60000.serial: ttymxc3 at MMIO 0x30a60000 (irq = 199, base_baud = 1500000) is a IMX
[ 1.922917] imx-dwmac 30bf0000.ethernet: IRQ eth_lpi not found
[ 1.929740] imx-dwmac 30bf0000.ethernet: User ID: 0x10, Synopsys ID: 0x51
[ 1.936555] imx-dwmac 30bf0000.ethernet: DWMAC4/5
[ 1.941361] imx-dwmac 30bf0000.ethernet: DMA HW capability register supported
[ 1.948509] imx-dwmac 30bf0000.ethernet: RX Checksum Offload Engine supported
[ 1.955650] imx-dwmac 30bf0000.ethernet: TX Checksum insertion supported
[ 1.962359] imx-dwmac 30bf0000.ethernet: Wake-Up On Lan supported
[ 1.968520] imx-dwmac 30bf0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.976199] imx-dwmac 30bf0000.ethernet: device MAC address 2a:c5:99:84:66:bb
[ 1.983350] imx-dwmac 30bf0000.ethernet: Enabled L3L4 Flow TC (entries=8)
[ 1.990152] imx-dwmac 30bf0000.ethernet: Enabled RFS Flow TC (entries=10)
[ 1.996965] imx-dwmac 30bf0000.ethernet: Enabling HW TC (entries=256, max_off=256)
[ 2.004554] imx-dwmac 30bf0000.ethernet: Using 34/40 bits DMA host/device width
[ 2.158192] realtek-mdio stmmac-1:00: found an RTL8363NB switch
[ 2.164168] realtek-mdio stmmac-1:00: unable to register switch ret = -517
[ 2.175037] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 2.180572] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 2.188568] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe6d hci version 0x110 quirks 0x000000a001000010
[ 2.198006] xhci-hcd xhci-hcd.1.auto: irq 203, io mem 0x38200000
[ 2.204153] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 2.209668] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 2.217339] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 2.226380] hub 1-0:1.0: USB hub found
[ 2.230477] hub 1-0:1.0: 1 port detected
[ 2.236611] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.246489] hub 2-0:1.0: USB hub found
[ 2.250581] hub 2-0:1.0: 1 port detected
[ 2.256296] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 5 mkt segment 0 supported-hw 0x20 0x1
[ 2.268964] sdhci-esdhc-imx 30b40000.mmc: allocated mmc-pwrseq
[ 2.269069] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
[ 2.313534] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[ 2.413613] mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA
[ 2.414283] realtek-mdio stmmac-1:00: found an RTL8363NB switch
[ 2.492421] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 2.540131] mmc0: new ultra high speed SDR104 SDIO card at address 0001
[ 2.600919] realtek-mdio stmmac-1:00: configuring for fixed/rgmii link mode
[ 2.610450] realtek-mdio stmmac-1:00: Link is Up - 1Gbps/Full - flow control off
[ 2.644563] realtek-mdio stmmac-1:00 eth1 (uninitialized): PHY [dsa-0.0:01] driver [Generic PHY] (irq=POLL)
[ 2.684441] realtek-mdio stmmac-1:00 eth2 (uninitialized): PHY [dsa-0.0:03] driver [Generic PHY] (irq=POLL)
[ 2.699335] DSA: tree 0 setup
[ 2.704695] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 2.704785] hub 1-1:1.0: USB hub found
[ 2.712031] input: cpu_inputs as /devices/platform/cpu_inputs/input/input1
[ 2.715286] hub 1-1:1.0: 4 ports detected
[ 2.722488] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.734966] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.741369] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 2.748657] clk: Disabling unused clocks
[ 2.752652] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.761287] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[ 2.865310] hub 1-1:1.0: USB hub found
[ 2.869427] hub 1-1:1.0: 4 ports detected
[ 3.269517] EXT4-fs (mmcblk2p3): recovery complete
[ 3.275227] EXT4-fs (mmcblk2p3): mounted filesystem 057d8de8-a7e7-4440-9fea-c9670c0c5df9 r/w with ordered data mode. Quota mode: none.
[ 3.287379] VFS: Mounted root (ext4 filesystem) on device 179:3.
[ 3.294319] devtmpfs: mounted
[ 3.298268] Freeing unused kernel memory: 3520K
[ 3.302934] Run /sbin/init as init process
[ 3.423469] systemd[1]: System time before build time, advancing clock.
[ 3.450897] systemd[1]: systemd 252.39-1~deb12u2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 3.483986] systemd[1]: Detected architecture arm64.
Welcome to Debian GNU/Linux 12 (bookworm)!
[ 3.506158] systemd[1]: Hostname set to <localhost>.
[ 3.512764] systemd[1]: Initializing machine ID from random generator.
[ 3.558947] systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 3.931119] systemd[1]: Queued start job for default target graphical.target.
[ 3.968011] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[ OK ] Created slice system-getty.slice - Slice /system/getty.
[ 3.993796] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[ OK ] Created slice system-modpr…lice - Slice /system/modprobe.
[ 4.022309] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[ OK ] Created slice system-seria… - Slice /system/serial-getty.
[ 4.049678] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[ OK ] Created slice system-syste… - Slice /system/systemd-fsck.
[ 4.077353] systemd[1]: Created slice user.slice - User and Session Slice.
[ OK ] Created slice user.slice - User and Session Slice.
[ 4.100497] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[ OK ] Started systemd-ask-passwo…quests to Console Directory Watch.
[ 4.128453] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[ OK ] Started systemd-ask-passwo… Requests to Wall Directory Watch.
[ 4.156396] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
[ 4.175866] systemd[1]: Expecting device dev-mmcblk2p1.device - /dev/mmcblk2p1...
[ 4.200472] systemd[1]: Expecting device dev-ttymxc1.device - /dev/ttymxc1...
[ 4.224224] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[ OK ] Reached target cryptsetup.…get - Local Encrypted Volumes.
[ 4.248610] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[ OK ] Reached target integrityse…Local Integrity Protected Volumes.
[ 4.276289] systemd[1]: Reached target paths.target - Path Units.
[ OK ] Reached target paths.target - Path Units.
[ 4.296264] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[ OK ] Reached target remote-fs.target - Remote File Systems.
[ 4.320247] systemd[1]: Reached target slices.target - Slice Units.
[ OK ] Reached target slices.target - Slice Units.
[ 4.340224] systemd[1]: Reached target swap.target - Swaps.
[ OK ] Reached target swap.target - Swaps.
[ 4.360269] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[ OK ] Reached target veritysetup… - Local Verity Protected Volumes.
[ 4.384758] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[ OK ] Listening on systemd-fsckd…sck to fsckd communication Socket.
[ 4.412536] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[ OK ] Listening on systemd-initc… initctl Compatibility Named Pipe.
[ 4.441749] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[ OK ] Listening on systemd-journ…socket - Journal Audit Socket.
[ 4.468740] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[ OK ] Listening on systemd-journ…t - Journal Socket (/dev/log).
[ 4.496878] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[ OK ] Listening on systemd-journald.socket - Journal Socket.
[ 4.520946] systemd[1]: Listening on systemd-networkd.socket - Network Service Netlink Socket.
[ OK ] Listening on systemd-netwo… - Network Service Netlink Socket.
[ 4.557127] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[ OK ] Listening on systemd-udevd….socket - udev Control Socket.
[ 4.584722] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ OK ] Listening on systemd-udevd…l.socket - udev Kernel Socket.
[ 4.624665] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[ 4.651859] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
Mounting dev-mqueue.mount▒▒POSIX Message Queue File System...
[ 4.680049] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
Mounting sys-kernel-debug.… - Kernel Debug File System...
[ 4.709270] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[ 4.724518] systemd[1]: kmod-static-nodes.service - Create List of Static Device Nodes was skipped because of an unmet condition check (ConditionFileNotEmpty=/lib/modules/6.6.52-rt43-gd377c9049508-dirty/modules.devname).
[ 4.757545] systemd[1]: Starting [email protected] - Load Kernel Module configfs...
Starting modprobe@configfs…m - Load Kernel Module configfs...
[ 4.788352] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
Starting modprobe@dm_mod.s…[0m - Load Kernel Module dm_mod...
[ 4.816731] systemd[1]: Starting [email protected] - Load Kernel Module drm...
[ 4.848481] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
Starting modprobe@efi_psto…- Load Kernel Module efi_pstore...
[ 4.876748] systemd[1]: Starting [email protected] - Load Kernel Module fuse...
Starting [email protected]…e - Load Kernel Module fuse...
[ 4.904963] systemd[1]: Starting [email protected] - Load Kernel Module loop...
Starting [email protected]…e - Load Kernel Module loop...
[ 4.928580] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 4.968886] systemd[1]: Starting systemd-journald.service - Journal Service...
[ 5.004486] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
Starting systemd-modules-l…rvice - Load Kernel Modules...
[ 5.031531] systemd[1]: Starting systemd-network-generator.service - Generate network units from Kernel command line...
Starting systemd-network-g… units from Kernel command line...
[ 5.084818] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
Starting systemd-remount-f…nt Root and Kernel File Systems...
[ 5.115743] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
Starting systemd-udev-trig…[0m - Coldplug All udev Devices...
[ 5.136505] EXT4-fs (mmcblk2p3): re-mounted 057d8de8-a7e7-4440-9fea-c9670c0c5df9 r/w. Quota mode: none.
[ 5.153130] systemd[1]: Started systemd-journald.service - Journal Service.
[ OK ] Started systemd-journald.service - Journal Service.
[ OK ] Mounted dev-hugepages.mount - Huge Pages File System.
[ OK ] Mounted dev-mqueue.mount▒▒- POSIX Message Queue File System.
[ OK ] Mounted sys-kernel-debug.m…nt - Kernel Debug File System.
[ OK ] Finished modprobe@configfs…[0m - Load Kernel Module configfs.
[ OK ] Finished modprobe@dm_mod.s…e - Load Kernel Module dm_mod.
[ OK ] Finished [email protected] - Load Kernel Module drm.
[ OK ] Finished modprobe@efi_psto…m - Load Kernel Module efi_pstore.
[ OK ] Finished [email protected] - Load Kernel Module fuse.
[ OK ] Finished [email protected] - Load Kernel Module loop.
[ OK ] Finished systemd-modules-l…service - Load Kernel Modules.
[ OK ] Finished systemd-network-g…rk units from Kernel command line.
[ OK ] Finished systemd-remount-f…ount Root and Kernel File Systems.
[ OK ] Reached target network-pre…get - Preparation for Network.
Mounting sys-kernel-config…ernel Configuration File System...
Starting systemd-journal-f…h Journal to Persistent Storage...
[ 5.501074] systemd-journald[137]: Received client request to flush runtime journal.
Starting systemd-random-se…ice - Load/Save Random Seed...
Starting systemd-sysctl.se…ce - Apply Kernel Variables...
Starting systemd-sysusers.…rvice - Create System Users...
[ OK ] Finished systemd-udev-trig…e - Coldplug All udev Devices.
[ OK ] Mounted sys-kernel-config.… Kernel Configuration File System.
[ OK ] Finished systemd-journal-f…ush Journal to Persistent Storage.
[ OK ] Finished systemd-sysctl.service - Apply Kernel Variables.
Starting ifupdown-pre.serv…ynchronize boot up for ifupdown...
[ OK ] Finished systemd-sysusers.service - Create System Users.
Starting systemd-tmpfiles-…ate Static Device Nodes in /dev...
[ OK ] Finished systemd-tmpfiles-…reate Static Device Nodes in /dev.
[ OK ] Reached target local-fs-pr…reparation for Local File Systems.
[ OK ] Reached target local-fs.target - Local File Systems.
Starting systemd-tmpfiles-…te System Files and Directories...
Starting systemd-udevd.ser…ger for Device Events and Files...
[ OK ] Finished systemd-tmpfiles-…eate System Files and Directories.
Starting systemd-timesyncd… - Network Time Synchronization...
Starting systemd-update-ut…rd System Boot/Shutdown in UTMP...
[ OK ] Finished systemd-update-ut…cord System Boot/Shutdown in UTMP.
[ OK ] Started systemd-udevd.serv…nager for Device Events and Files.
Starting systemd-networkd.…ice - Network Configuration...
[ OK ] Found device dev-ttymxc1.device - /dev/ttymxc1.
[ OK ] Started systemd-timesyncd.…0m - Network Time Synchronization.
[ OK ] Reached target sysinit.target - System Initialization.
[ OK ] Started systemd-tmpfiles-c… Cleanup of Temporary Directories.
[ OK ] Reached target time-set.target - System Time Set.
[ OK ] Started apt-daily.timer - Daily apt download activities.
[ OK ] Started apt-daily-upgrade.… apt upgrade and clean activities.
[ OK ] Started dpkg-db-backup.tim… Daily dpkg database backup timer.
[ OK ] Started e2scrub_all.timer▒▒etadata Check for All Filesystems.
[ OK ] Started fstrim.timer - Discard unused blocks once a week.
[ OK ] Started logrotate.timer - Daily rotation of log files.
[ OK ] Started man-db.timer - Daily man-db regeneration.
[ OK ] Started sysstat-collect.ti… accounting tool every 10 minutes.
[ OK ] Started sysstat-summary.ti…of yesterday's process accounting.
[ OK ] Reached target timers.target - Timer Units.
[ OK ] Listening on dbus.socket▒▒- D-Bus System Message Bus Socket.
[ OK ] Reached targe[ 6.421751] cfg80211: failed to load regulatory.db
t sockets.target - Socket Units.
[ OK ] Reached target basic.target - Basic System.
[ OK ] Started cron.service -…kground program processing daemon.
Starting dbus.service - D-Bus System Message Bus...
[ 6.524255] imx-sdma 30bd0000.dma-controller: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2
[ 6.537384] imx-sdma 30bd0000.dma-controller: Falling back to sysfs fallback for: imx/sdma/sdma-imx7d.bin
[ OK ] Started firmwared.service - Linux Firmware Loader Daemon.
[ 6.563260] imx-sdma 30bd0000.dma-controller: external firmware not found, using ROM firmware
Starting kexec-load.servic…B: Load kernel image with kexec...
Starting lm-sensors.servic…ize hardware monitoring sensors...
Starting platcfg.service▒▒r various NXP i.MX/LS platforms...
[ OK ] Started seatd.service - Seat management daemon.
[ OK ] Started strongswan-starter…Ev1/IKEv2 daemon using ipsec.conf.
Starting sysstat.service - Resets System Activity Logs...
Starting systemd-logind.se…ice - User Login Management...
[ OK ] Started systemd-networkd.service - Network Configuration.
[ OK ] Finished ifupdown-pre.serv… synchronize boot up for ifupdown.
[ OK ] Finished e2scrub_reap.serv…ine ext4 Metadata Check Snapshots.
[ OK ] Finished sysstat.service - Resets System Activity Logs.
[ OK ] Finished lm-sensors.servic…alize hardware monitoring sensors.
[ OK ] Started kexec-load.service…LSB: Load kernel image with kexec.
[ OK ] Found device dev-mmcblk2p1.device - /dev/mmcblk2p1.
[ OK ] Reached target usb-gadget.…m - Hardware activated USB gadget.
Starting networking.service - Raise network interfaces...
Starting systemd-fsck@dev-… System Check on /dev/mmcblk2p1...
[ OK ] Started systemd-fsckd.serv…tem Check Daemon to report status.
[ OK ] Finished systemd-fsck@dev-…le System Check on /dev/mmcblk2p1.
[ 7.297245] imx-dwmac 30bf0000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[ 7.305583] imx-dwmac 30bf0000.ethernet eth0: No Safety Features support found
[ 7.312850] imx-dwmac 30bf0000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
Mounting boot.mount - /boot...
[ 7.324878] imx-dwmac 30bf0000.ethernet eth0: registered PTP clock
[ 7.336555] imx-dwmac 30bf0000.ethernet eth0: FPE workqueue start
[ 7.343570] imx-dwmac 30bf0000.ethernet eth0: configuring for fixed/rgmii-id link mode
[ 7.353100] imx-dwmac 30bf0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 7.353244] EXT4-fs (mmcblk2p1): mounted filesystem 45d36d6d-da2c-4fa0-ae4f-46086176bf89 r/w with ordered data mode. Quota mode: none.
[ 7.354853] 8021q: adding VLAN 0 to HW filter on device eth0
[ OK ] Mounted boot.mount - /boot.
[ 7.484902] realtek-mdio stmmac-1:00 eth1: configuring for phy/gmii link mode
[ 7.499221] 8021q: adding VLAN 0 to HW filter on device eth1
[ 7.722835] realtek-mdio stmmac-1:00 eth2: configuring for phy/gmii link mode
[ 7.758421] 8021q: adding VLAN 0 to HW filter on device eth2
[ OK ] Finished networking.service - Raise network interfaces.
[ 7.988116] random: crng init done
[ OK ] Finished systemd-random-se…rvice - Load/Save Random Seed.
[ OK ] Started dbus.service - D-Bus System Message Bus.
Starting wpa_supplicant.service - WPA supplicant...
[ OK ] Started systemd-logind.service - User Login Management.
[ OK ] Started wpa_supplicant.service - WPA supplicant.
[ OK ] Reached target network.target - Network.
Starting mosquitto.service - Mosquitto MQTT Broker...
Starting ssh.service - OpenBSD Secure Shell server...
Starting systemd-hostnamed.service - Hostname Service...
Starting systemd-user-sess…vice - Permit User Sessions...
[ OK ] Finished systemd-user-sess…ervice - Permit User Sessions.
[ OK ] Started [email protected] - Getty on tty1.
[ OK ] Started serial-getty@ttymx…ice - Serial Getty on ttymxc1.
[ OK ] Reached target getty.target - Login Prompts.
[ OK ] Started systemd-hostnamed.service - Hostname Service.
[ OK ] Started ssh.service - OpenBSD Secure Shell server.
[ OK ] Started mosquitto.service - Mosquitto MQTT Broker.
[ OK ] Reached target multi-user.target - Multi-User System.
[ OK ] Reached target graphical.target - Graphical Interface.
Starting systemd-update-ut… Record Runlevel Change in UTMP...
[ OK ] Finished platcfg.service▒▒for various NXP i.MX/LS platforms.
[ OK ] Finished systemd-update-ut… - Record Runlevel Change in UTMP.
Debian GNU/Linux 12 imx8mpevk ttymxc1
NXP Linux SDK 2506 Debian Server (optimized with NXP-specific hardware acceleration)
imx8mpevk login: root
Password:
Linux imx8mpevk 6.6.52-rt43-gd377c9049508-dirty #1 SMP PREEMPT Thu Jul 2 11:19:58 CST 2026 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@imx8mpevk:~#
root@imx8mpevk:~# modprobe moal mod_para=nxp/wifi_mod_para.conf
[ 27.658951] mlan: loading out-of-tree module taints kernel.
[ 27.688908] wlan: Loading MWLAN driver
[ 27.693279] wlan: Register to Bus Driver...
[ 27.697621] vendor=0x02DF device=0x9149 class=0 function=1
[ 27.703270] Attach moal handle ops, card interface type: 0x105
[ 27.709133] rps set to 0 from module param
[ 27.713466] SD8987: init module param from usr cfg
[ 27.718305] card_type: SD8987, config block: 0
[ 27.722765] cfg80211_wext=0xf
[ 27.725757] max_vir_bss=1
[ 27.728391] cal_data_cfg=none
[ 27.731362] ps_mode = 1
[ 27.733821] auto_ds = 1
[ 27.736295] host_mlme=enable
[ 27.739186] fw_name=nxp/sdiouart8987_combo_v0.bin
[ 27.743918] SDIO: max_segs=128 max_seg_size=65535
[ 27.748647] rx_work=1 cpu_num=4
[ 27.751795] Enable moal_recv_amsdu_packet
[ 27.755832] Attach mlan adapter operations.card_type is 0x105.
[ 27.762044] wlan: Enable TX SG mode
[ 27.765551] wlan: Enable RX SG mode
[ 27.776176] Request firmware: nxp/sdiouart8987_combo_v0.bin
[ 28.073628] Wlan: FW download over, firmwarelen=626584 downloaded 617556
[ 28.944747] WLAN FW is active
[ 28.947734] on_time is 28943658375
[ 29.003401] VDLL image: len=9028
[ 29.006743] FW country code WW does not match with US
[ 29.012026] fw_cap_info=0x181d6f03, dev_cap_mask=0xffffffff
[ 29.017672] max_p2p_conn = 8, max_sta_conn = 8
[ 29.022438] SDIO rx aggr: 1 block_size=512
[ 29.026600] wlan: Enable RX SG mode
[ 29.030117] mpa_rx_buf_size=65280
[ 29.054744] Register NXP 802.11 Adapter mlan0
[ 29.061163] Register NXP 802.11 Adapter uap0
[ 29.069437] Register NXP 802.11 Adapter wfd0
[ 29.073887] wlan: version = SD8987----16.92.21.p142.3-MM6X16505.p4-GPL-(FP92)
[ 29.083234] wlan: Register to Bus Driver Done
[ 29.088229] wlan: Driver loaded successfully
root@imx8mpevk:~# [ 29.430504] wlan: mlan0 START SCAN
[ 33.741685] wlan: SCAN COMPLETED: scanned AP count=6
root@imx8mpevk:~#
root@imx8mpevk:~# mod[ 38.754412] wlan: mlan0 START SCAN
probe btnxpuart
[ 43.549431] btnxpuart serial0-0: ipg clock enabled, rate=80000000
[ 43.555634] btnxpuart serial0-0: per clock enabled, rate=80000000
root@imx8mpevk:~# [ 43.743746] wlan: SCAN COMPLETED: scanned AP count=14
[ 44.580103] Bluetooth: hci0: FW already running.
[ 48.756247] wlan: mlan0 START SCAN
[ 53.744943] wlan: SCAN COMPLETED: scanned AP count=16
[ 53.753462] wlan: sched scan start
3 返答(返信)
423件の閲覧回数
shaun_wu
Hello @wanggg
Which 8MP board you currently using? Could you share hardware connection?
Best Regards
Shaun
405件の閲覧回数
wanggg
Hello @shaun_wu
I have already identified the hardware problem. Thank you for your help.
204件の閲覧回数
Sanjiv_Mns
Hi @wanggg
Can i know what is the issue here... I am also facing the same issue..
%3CLINGO-SUB%20id%3D%22lingo-sub-2390760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8MP%E3%81%AEBluetooth%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A8%E3%82%AD%E3%82%B9%E3%83%91%E3%83%BC%E3%83%88%E3%81%95%E3%82%93%E3%80%81%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AFIMX8MP%E4%B8%8A%E3%81%A7AW-CM358SM%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Wi-Fi%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81UART3%E3%81%A7Bluetooth%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E3%81%84%E3%82%8D%E3%81%84%E3%82%8D%E3%81%AA%E6%96%B9%E6%B3%95%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A0%E6%88%90%E5%8A%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BD%95%E3%81%8B%E7%9B%B4%E3%81%99%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%A4%A7%E5%A4%89%E3%81%82%E3%82%8A%E3%81%8C%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%AD%E3%82%B0%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3EBluetooth%3A%20hci0%3A%20FW%20already%20running.%0A%5B%20%20%2046.628430%5D%20Bluetooth%3A%20hci0%3A%20Opcode%200x0c03%20failed%3A%20-110%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3Edts%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26amp%3Buart3%20%7B%20%2F*%20BT%20*%2F%3CBR%20%2F%3E%20pinctrl-names%20%3D%20%22default%22%3B%3CBR%20%2F%3E%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_uart3%20%26amp%3Bpinctrl_bt_ctrl%26gt%3B%3B%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_UART3%26gt%3B%3B%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E8%A6%AA%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_SYS_PLL1_80M%26gt%3B%3B%3CBR%20%2F%3E%20uart-has-rtscts%3B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%AB%E3%83%BC%E3%83%88%E3%82%A5%E3%83%BC%E3%82%B9%20%7B%3CBR%20%2F%3E%20compatible%20%3D%20%22nxp%2C88w8987-bt%22%3B%3CBR%20%2F%3E%20device-wakeup-gpios%20%3D%20%26lt%3B%26amp%3Bgpio2%2010%20GPIO_ACTIVE_HIGH%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3Epinctrl_uart3%3A%20uart3grp%20%7B%3CBR%20%2F%3E%20fsl%E3%80%81pins%20%3D%20%26lt%3B%3CBR%20%2F%3E%20MX8MP_IOMUXC_ECSPI1_SCLK__UART3_DCE_RX%200x140%3CBR%20%2F%3E%20MX8MP_IOMUXC_ECSPI1_MOSI__UART3_DCE_TX%200x140%3CBR%20%2F%3E%20MX8MP_IOMUXC_ECSPI1_MISO__UART3_DCE_CTS%200x140%3CBR%20%2F%3E%20MX8MP_IOMUXC_ECSPI1_SS0__UART3_DCE_RTS%200x140%3CBR%20%2F%3E%20%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3Epinctrl_bt_ctrl%3A%20btctrlgrp%20%7B%3CBR%20%2F%3E%20fsl%E3%80%81pins%20%3D%20%26lt%3B%3CBR%20%2F%3E%20MX8MP_IOMUXC_SD1_RESET_B__GPIO2_IO10%200x10%20%2F*%20HOST_WAKE_BT%20*%2F%3CBR%20%2F%3E%20MX8MP_IOMUXC_SD1_STROBE__GPIO2_IO11%200x140%20%2F*%20BT_HOST_WAKE%20*%2F%3CBR%20%2F%3E%20%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3Ewifi_mod_para.conf%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3ESD8987%20%3D%20%7B%3CBR%20%2F%3E%20cfg80211_wext%3D0xf%3CBR%20%2F%3E%20wfd_name%3Dp2p%3CBR%20%2F%3E%20max_vir_bss%3D1%3CBR%20%2F%3E%20cal_data_cfg%3D%E3%81%AA%E3%81%97%3CBR%20%2F%3Edrv_mode%3D7%3CBR%20%2F%3E%20ps_mode%3D2%3CBR%20%2F%3E%20auto_ds%3D2%3CBR%20%2F%3E%20fw_name%3Dnxp%2Fsdiouart8987_combo_v0.bin%3CBR%20%2F%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%AD%E3%82%B0%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FP%3E%3CP%3E%5B%200.000000%5D%20%E7%89%A9%E7%90%86CPU%E3%81%A7Linux%E3%82%92%E8%B5%B7%E5%8B%950x0000000000%20%5B0x410fd034%5D%3CBR%20%2F%3E%5B%200.000000%5D%20Linux%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%206.6.52-rt43-gd377c9049508-dirty(root%40fbdebian)(aarch64-linux-gnu-gcc%20(Debian%2012.2.0-14)12.2.0%E3%80%81GNU%20ld(Debian%E7%94%A8GNU%20Binutils)2.40)%20%231%20SMP%20PREEMPT%202026%E5%B9%B47%E6%9C%882%E6%97%A5(%E6%9C%A8)11%3A19%3A58%20CST%3CBR%20%2F%3E%5B%200.00000%5D%20KASLR%E3%81%8C%E3%82%B7%E3%83%BC%E3%83%89%E4%B8%8D%E8%B6%B3%E3%81%A7%E7%84%A1%E5%8A%B9%E5%8C%96%3CBR%20%2F%3E%5B%200.000000%5D%20%E6%A9%9F%E6%A2%B0%E3%83%A2%E3%83%87%E3%83%AB%3AG3%20i.MX8MPlus%20EVK%E3%83%9C%E3%83%BC%E3%83%89%3CBR%20%2F%3E%5B%200.000000%5D%20EFI%3A%20UEFI%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20%E4%BA%88%E7%B4%84%E3%83%A1%E3%83%A2%E3%83%AA%3ACMA%E3%83%AA%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B%200.000000%5D%20OF%3A%20reserved%20mem%3A%20node%20Linux%2C%20cma%20compatible%20matching%20fail%3CBR%20%2F%3E%5B%200.000000%5D%20OF%3A%20%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%9F%E8%A8%98%E6%86%B6%3A%200x0000000000900000...0x000000000096ffff(448%20KiB)%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%83%E3%83%97%20%E5%86%8D%E5%88%A9%E7%94%A8%E4%B8%8D%E5%8F%AFocram%40900000%3CBR%20%2F%3E%5B%200.000000%5D%20%E3%82%BE%E3%83%BC%E3%83%B3%E7%AF%84%E5%9B%B2%3A%3CBR%20%2F%3E%5B0.000000%5D%20DMA%20%5B%E8%A8%98%E6%86%B60x0000000040000000-0x00000000ffffffff%5D%3CBR%20%2F%3E%5B%200.000000%5D%20DMA32%20%E7%A9%BA%3CBR%20%2F%3E%5B0.000000%5D%20%E6%AD%A3%E5%B8%B8%20%5B%E8%A8%98%E6%86%B60x0000000100000000-0x000000013fffffff%5D%3CBR%20%2F%3E%5B%200.000000%5D%20%E5%90%84%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%E5%8F%AF%E5%8B%95%E5%9F%9F%E9%96%8B%E5%A7%8B%3CBR%20%2F%3E%5B%200.000000%5D%20%E5%88%9D%E6%9C%9F%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%8E%E3%83%BC%E3%83%89%E7%AF%84%E5%9B%B2%3CBR%20%2F%3E%5B%200.000000%5D%20%E3%83%8E%E3%83%BC%E3%83%890%3A%20%5B%E8%A8%98%E6%86%B6%200x0000000040000000-0x000000013fffffff%5D%3CBR%20%2F%3E%5B%200.000000%5D%20%E3%82%A4%E3%83%8B%E3%82%B7%E3%83%86%E3%83%A0%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%83%8E%E3%83%BC%E3%83%890%20%5B%E3%83%A1%E3%83%A2%E3%83%AA0x0000000040000000-0x000000013fffffff%5D%3CBR%20%2F%3E%5B%200.000000%5D%20CMA%3A%E3%83%8E%E3%83%BC%E3%83%89-1%E3%81%AE0x00000000ff800000%E3%81%A78%20MiB%E3%82%92%E4%BA%88%E7%B4%84%3CBR%20%2F%3E%5B%200.000000%5D%20PSCI%3ADT%E3%81%8B%E3%82%89%E3%81%AE%E5%B0%8E%E7%AE%A1%E3%81%AE**%E6%96%B9%E6%B3%95**%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%93%E3%83%B3%E3%82%B0%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20PSCI%3A%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7PSCIv1.1%E3%82%92%E6%A4%9C%E5%87%BA%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20psci%3A%20%E6%A8%99%E6%BA%96%E3%81%AEPSCI%20v0.2%E9%96%A2%E6%95%B0ID%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%200.000000%5D%20psci%3A%20MIGRATE_INFO_TYPE%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%5B%200.00000%5D%20psci%3A%20SMC%20Calling%20Convention%20v1.4%3CBR%20%2F%3E%5B%200.000000%5D%20percpu%3A%20%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%2020%E3%83%9A%E3%83%BC%E3%82%B8%2Fcpu%20s43368%20r8192%20d30360%20u81920%3CBR%20%2F%3E%5B%200.000000%5D%20CPU0%E3%81%A7VIPT%20I%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%A4%9C%E5%87%BA%3CBR%20%2F%3E%5B%200.000000%5D%20CPU%E6%A9%9F%E8%83%BD%3A%E6%A4%9C%E5%87%BA%3AGIC%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFCPU%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3CBR%20%2F%3E%5B%200.000000%5D%20CPU%E6%A9%9F%E8%83%BD%3A%E6%A4%9C%E5%87%BA%3AARM%E3%82%A8%E3%83%A9%E3%82%BF%E3%83%A0845719%3CBR%20%2F%3E%5B%200.00000%5D%20%E4%BB%A3%E6%9B%BF%E6%89%8B%E6%AE%B5%3A%E3%83%96%E3%83%BC%E3%83%88%E4%BB%A3%E6%9B%BF%E3%81%AE%E9%81%A9%E7%94%A8%3CBR%20%2F%3E%5B%200.000000%5D%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3A%20console%3Dttymxc1%2C115200%20root%3DPARTUUID%3D6a120481-03%20rw%20rootwait%3CBR%20%2F%3E%5B%200.00000%5D%20Dentry%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A524288(%E9%A0%86%E5%BA%8F%3A10%E3%80%814194304%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E7%B7%9A%E5%BD%A2)%3CBR%20%2F%3E%5B%200.000000%5D%20Inode%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A262144(%E9%A0%86%E5%BA%8F%3A9%E3%80%812097152%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E7%B7%9A%E5%BD%A2)%3CBR%20%2F%3E%5B%200.00000%5D%20%E3%82%BE%E3%83%BC%E3%83%B3%E3%83%AA%E3%82%B9%E3%83%88%E3%82%921%E3%81%A4%E4%BD%9C%E6%88%90%E3%80%81%E3%83%A2%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%82%AA%E3%83%B3%E3%80%82%E7%B7%8F%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%3A1032192%3CBR%20%2F%3E%5B%200.000000%5D%20mem%20auto-init%3A%20stack%3Aall(zero)%2C%20heap%20alloc%3Aoff%E3%80%81heap%20free%3Aoff%3CBR%20%2F%3E%5B%200.000000%5D%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20IO%20TLB%3A%20%E3%82%A8%E3%83%AA%E3%82%A2%E7%95%AA%E5%8F%B74%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2IO%20TLB%3A%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E6%B8%88%E3%81%BF%5B%E8%A8%98%E6%86%B6%200x00000000fb800000-0x00000000ff800000%5D%20(64MB)%3CBR%20%2F%3E%5B%200.000000%5D%20%E3%83%A1%E3%83%A2%E3%83%AA%3A4012020K%2F4194304K%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD(%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%8916192K%E3%80%81rwdata1688K%E3%80%81rodata5064K%E3%80%813520K%E5%88%9Dinit%E3%80%81541K%20bss%E3%80%81174092K%E3%83%AA%E3%82%B6%E3%83%BC%E3%83%96%E3%80%818192K%20cma%E3%83%AA%E3%82%B6%E3%83%BC%E3%83%96)%3CBR%20%2F%3E%5B%200.000000%5D%20SLUB%3A%20HWalign%3D64%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3CBR%20%2F%3E%5B%200.000000%5D%20rcu%3A%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%83%86%E3%82%A3%E3%83%96%E9%9A%8E%E5%B1%A4%E7%9A%84RCU%E5%AE%9F%E8%A3%85%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20rcu%3A%20RCU%20%E3%81%AF%20CPU%20%E3%82%92%20NR_CPUS%3D256%20%E3%81%8B%E3%82%89%20nr_cpu_ids%3D4%20%E3%81%AB%E5%88%B6%E9%99%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20%E3%82%BF%E3%82%B9%E3%82%AF%20RCU%20%E3%81%AE%E3%83%88%E3%83%A9%E3%83%B3%E3%83%9D%E3%83%AA%E3%83%B3%20%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20%E3%82%BF%E3%82%B9%E3%82%AF%20RCU%20%E3%81%AE%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20rcu%3A%20RCU%20%E3%81%8C%E8%A8%88%E7%AE%97%E3%81%97%E3%81%9F%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E7%99%BB%E9%8C%B2%E9%81%85%E5%BB%B6%E3%81%AE%E5%80%A4%E3%81%AF%2025%20%E3%82%B8%E3%83%95%E3%82%A3%E3%83%BC%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20rcu%3A%20rcu_fanout_leaf%3D16%E3%80%81nr_cpu_ids%3D4%20%E3%81%AE%E3%82%B8%E3%82%AA%E3%83%A1%E3%83%88%E3%83%AA%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%200.000000%5D%20NR_IRQS%3A%2064%E3%80%81nr_irqs%3A%2064%E3%80%81%E4%BA%8B%E5%89%8D%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BFirqs%3A%200%3CBR%20%2F%3E%20%5B%200.000000%5D%20GICv3%3A%20GIC%3A%20%E5%88%86%E5%89%B2EOI%2F%E9%9D%9E%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E%5B%200.000000%5D%20GICv3%3A%20160%20%E3%81%AE%20SPI%20%E3%81%8C%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.000000%5D%20GICv3%3A%200%E5%80%8B%E3%81%AE%E6%8B%A1%E5%BC%B5SPI%E3%81%8C%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.000000%5D%20%E3%83%AB%E3%83%BC%E3%83%88IRQ%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%3A%20gic_handle_irq%3CBR%20%2F%3E%20%5B%200.000000%5D%20GICv3%3A%20GICv3%20%E6%A9%9F%E8%83%BD%3A%2016%20PPI%3CBR%20%2F%3E%20%5B%200.000000%5D%20GICv3%3A%20CPU0%3A%20%E5%86%8D%E5%88%86%E9%85%8D%E5%99%A8%200%20%E9%A0%98%E5%9F%9F%200%3A0x0000000038880000%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.000000%5D%20ITS%3A%20ITS%E3%81%8C%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81LPI%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B%200.000000%5D%20rcu%3A%20srcu_init%3A%20%E7%AB%B6%E5%90%88%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%20srcu_struct%20%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20arch_timer%3A%20cp15%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%8C%208.00MHz%20(%E7%89%A9%E7%90%86)%20%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20clocksource%3A%20arch_sys_counter%3A%20mask%3A%200xffffffffffffff%20max_cycles%3A%200x1d854df40%2C%20max_idle_ns%3A%20440795202120%20ns%3CBR%20%2F%3E%20%5B%200.000000%5D%20sched_clock%3A%2056%E3%83%93%E3%83%83%E3%83%88%E3%80%818MHz%E3%80%81%E5%88%86%E8%A7%A3%E8%83%BD125ns%E3%80%812199023255500ns%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A9%E3%83%83%E3%83%97%E3%82%A2%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%3CBR%20%2F%3E%5B%200.000475%5D%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%20%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2080x25%3CBR%20%2F%3E%20%5B%200.000519%5D%20%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%88%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%EF%BC%89%E3%80%81%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%9F%E5%80%A4%E3%80%8216.00%20BogoMIPS%20(lpj%3D32000)%3CBR%20%2F%3E%20%5B%200.000528%5D%20pid_max%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E5%80%A4%3A%2032768%20%E6%9C%80%E5%B0%8F%E5%80%A4%3A%20301%3CBR%20%2F%3E%20%5B%200.000602%5D%20LSM%3A%20lsm%3Dcapability%2Cintegrity%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%200.000695%5D%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E6%95%B0%3A%208192%20(%E6%AC%A1%E6%95%B0%3A%204%E3%80%8165536%20%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E7%B7%9A%E5%BD%A2)%3CBR%20%2F%3E%20%5B%200.000711%5D%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E6%95%B0%3A%208192%20(%E6%AC%A1%E6%95%B0%3A%204%E3%80%8165536%20%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E7%B7%9A%E5%BD%A2)%3CBR%20%2F%3E%20%5B%200.002173%5D%20RCU%E3%82%BF%E3%82%B9%E3%82%AF%3A%20%E3%82%B7%E3%83%95%E3%83%88%E3%82%922%E3%80%81%E3%83%AA%E3%83%9F%E3%83%83%E3%83%88%E3%82%921%E3%81%AB%E8%A8%AD%E5%AE%9A%20rcu_task_cb_adjust%3D1%E3%80%82%3CBR%20%2F%3E%20%5B%200.002240%5D%20RCU%E3%82%BF%E3%82%B9%E3%82%AF%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%3A%20%E3%82%B7%E3%83%95%E3%83%88%E3%82%922%E3%80%81%E3%83%AA%E3%83%9F%E3%83%83%E3%83%88%E3%82%921%E3%81%AB%E8%A8%AD%E5%AE%9A%20rcu_task_cb_adjust%3D1%E3%80%82%3CBR%20%2F%3E%20%5B%200.002415%5D%20rcu%3A%20%E9%9A%8E%E5%B1%A4%E5%9E%8B%20SRCU%20%E5%AE%9F%E8%A3%85%E3%80%82%3CBR%20%2F%3E%5B%200.002418%5D%20rcu%3A%20%E6%9C%80%E5%A4%A7%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E9%81%85%E5%BB%B6%E3%81%AA%E3%81%97%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E6%95%B0%E3%81%AF%201000%20%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%200.004206%5D%20EFI%20%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%AF%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%5B%200.0044444%5D%20smp%3A%20%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AACPU%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%3CBR%20%2F%3E%5B%200.004903%5D%20CPU1%E3%81%A7VIPT%20I%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%A4%9C%E5%87%BA%3CBR%20%2F%3E%5B%200.004964%5D%20GICv3%3A%20CPU1%3A%20%E3%83%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC1%20%E3%83%AA%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B30%3A0x00000000388a0000%3CBR%20%2F%3E%5B%200.005000%5D%20CPU1%3A%20%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E8%B5%B7%E5%8B%950x0000000001%20%5B0x410fd034%5D%3CBR%20%2F%3E%5B%200.005523%5D%20CPU2%E3%81%A7VIPT%20I%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%A4%9C%E5%87%BA%3CBR%20%2F%3E%5B%200.005565%5D%20GICv3%3A%20CPU2%3A%20%E3%83%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC2%20%E3%83%AA%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B30%3A0x00000000388c0000%3CBR%20%2F%3E%5B%200.005585%5D%20CPU2%3A%20%E8%B5%B7%E5%8B%95%E6%B8%88%E3%81%BF%E3%81%AE%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B50x0000000002%20%5B0x410fd034%5D%3CBR%20%2F%3E%5B%200.006045%20CPU3%E3%81%A7VIPT%20I%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%A4%9C%E5%87%BA%3CBR%20%2F%3E%5B%200.006083%5D%20GICv3%3A%20CPU3%3A%20%E3%83%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC3%20%E3%83%AA%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B30%3A0x00000000388e0000%3CBR%20%2F%3E%5B%200.006100%5D%20CPU3%3A%20%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%200x0000000003%20%5B0x410fd034%5D%3CBR%20%2F%3E%5B%200.006165%5D%20smp%3A%20%E3%83%8E%E3%83%BC%E3%83%891%E5%8F%B0%E3%80%81CPU4%E5%8F%B0%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.006173%5D%20SMP%3A%E5%90%88%E8%A8%884%E3%81%A4%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E8%B5%B7%E5%8B%95%E3%80%82%3CBR%20%2F%3E%5B%200.006177%5D%20CPU%E6%A9%9F%E8%83%BD%3A%E6%A4%9C%E5%87%BA%3A32%E3%83%93%E3%83%83%E3%83%88EL0%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%200.006181%5D%20CPU%E6%A9%9F%E8%83%BD%3A%E6%A4%9C%E5%87%BA%E6%B8%88%E3%81%BF%3ACRC32%E5%91%BD%E4%BB%A4%3CBR%20%2F%3E%5B%200.006243%5D%20CPU%3A%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AECPU%E3%81%AFEL2%E3%81%8B%E3%82%89%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.006246%5D%20%E4%BB%A3%E6%9B%BF%E6%A1%88%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%85%A8%E4%BD%93%E3%81%AE%E4%BB%A3%E6%9B%BF%E6%A1%88%E3%81%AE%E9%81%A9%E7%94%A8%3CBR%20%2F%3E%5B%200.008002%5D%20devtmpfs%3A%20initialized%3CBR%20%2F%3E%5B%200.016979%5D%20%E6%99%82%E8%A8%88%E3%82%BD%E3%83%BC%E3%82%B9%3A%E3%82%B8%E3%83%95%E3%82%A3%E3%83%BC%E3%82%BA%3A%E3%83%9E%E3%82%B9%E3%82%AF%3A0xffffffff%20max_cycles%3A0xffffffff%E3%80%81max_idle_ns%3A7645041785100000%20NS%3CBR%20%2F%3E%5B%200.017001%5D%20Futex%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E6%95%B0%3A1024(%E9%A0%86%E5%BA%8F%3A4%E3%80%8165536%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E7%B7%9A%E5%BD%A2)%3CBR%20%2F%3E%5B%200.017422%5D%20pinCtrl%20%E3%82%B3%E3%82%A2%3A%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9FpinCtrl%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3E%5B%200.020051%5D%20DMI%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%8B%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%200.020689%5D%20NET%3A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BFPF_NETLINK%2FPF_ROUTE%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%3CBR%20%2F%3E%5B%200.022304%5D%20DMA%3A%E5%8E%9F%E5%AD%90%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E7%94%A8%E3%81%AB%E4%BA%8B%E5%89%8D%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%95%E3%82%8C%E3%81%9F512%20KiB%20GFP_KERNEL%E3%83%97%E3%83%BC%E3%83%AB%3CBR%20%2F%3E%5B%200.023375%5D%20DMA%3A%20%E4%BA%8B%E5%89%8D%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6512%20KiB%20GFP_KERNEL%7CGFP_DMA%E5%8E%9F%E5%AD%90%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%83%97%E3%83%BC%E3%83%AB%3CBR%20%2F%3E%5B%200.024665%5D%20DMA%3A%20%E4%BA%8B%E5%89%8D%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6512%20KiB%20GFP_KERNEL%7CGFP_DMA32%E5%8E%9F%E5%AD%90%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%83%97%E3%83%BC%E3%83%AB%3CBR%20%2F%3E%5B%200.024748%5D%20%E7%9B%A3%E6%9F%BB%3ANetLink%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96(%E7%84%A1%E5%8A%B9)%3CBR%20%2F%3E%5B%200.024932%5D%20%E7%9B%A3%E6%9F%BB%3Atype%3D2000%20%E7%9B%A3%E6%9F%BB(0.024%3A1)%3Astate%3Dinitialized%20audit_enabled%3D0%20res%3D1%3CBR%20%2F%3E%20%5B%200.025352%5D%20thermal_sys%3A%20%E3%82%B5%E3%83%BC%E3%83%9E%E3%83%AB%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%80%8Cstep_wise%E3%80%8D%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.025356%5D%20thermal_sys%3A%20%E3%82%B5%E3%83%BC%E3%83%9E%E3%83%AB%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%80%8Cpower_allocator%E3%80%8D%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.025401%5D%20cpuidle%3A%20%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%200.025566%5D%20hw-breakpoint%3A%20%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%206%20%E3%81%A4%E3%80%81%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%204%20%E3%81%A4%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%200.025647%5D%20ASID%E3%82%A2%E3%83%AD%E3%82%B1%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C65536%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%81%A7%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3E%5B%200.026696%5D%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%3AAMBA%20PL011%20UART%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3E%5B%200.026763%5D%20IMX%20MU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%200.026785%5D%20IMX%20RPMSG%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%200.032936%5D%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0soc%400%3A%E5%9B%BA%E5%AE%9A%E4%BE%9D%E5%AD%98%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB(%2Fsoc%400%2Fbus%4030000000%2Fefuse%4030350000%2Funique-id%408%3CBR%20%2F%3E%5B%200.035120%5D%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2030330000.pinctrl%3A%2Fsoc%400%2Fbus%4030000000%2Fpinctrl%4030330000%2Fhoggrp%20%E3%81%A8%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.035566%5D%20imx8mp-pinctrl%2030330000.pinctrl%3AIMX%20pinCtrl%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.036067%5D%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2030350000.efuse%3A%2Fsoc%400%2Fbus%4030000000%2F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AFcontroller%4030380000%E3%81%AE%E5%9B%BA%E5%AE%9A%E4%BE%9D%E5%AD%98%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%3CBR%20%2F%3E%5B%200.037099%5D%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A030350000.efuse%3A%2Fsoc%400%2Fbus%4030000000%2F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AFcontroller%4030380000%E3%81%AE%E5%9B%BA%E5%AE%9A%E4%BE%9D%E5%AD%98%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%3CBR%20%2F%3E%5B%200.049206%5D%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3A%E9%9D%9EPLT%E7%94%A8%E9%80%94%E3%81%AE%E7%AF%84%E5%9B%B2%E5%86%8525968%E3%83%9A%E3%83%BC%E3%82%B8%3CBR%20%2F%3E%5B%200.049215%5D%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3APLT%E4%BD%BF%E7%94%A8%E7%AF%84%E5%9B%B2%E5%86%85%E3%81%AE517488%E3%83%9A%E3%83%BC%E3%82%B8%3CBR%20%2F%3E%5B%200.049877%5D%20HugeTLB%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF1.00%20GiB%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%B5%E3%82%A4%E3%82%BA%E3%80%81%E4%BA%8B%E5%89%8D%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A60%E3%83%9A%E3%83%BC%E3%82%B8%3CBR%20%2F%3E%5B%200.049884%5D%20HugeTLB%3A%200%20KiB%20vmemmap%E3%82%921.00%20GiB%E3%83%9A%E3%83%BC%E3%82%B8%E7%94%A8%E3%81%AB%E8%A7%A3%E6%94%BE%E5%8F%AF%E8%83%BD%3CBR%20%2F%3E%5B%200.049889%5D%20HugeTLB%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF32.0%20MiB%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%B5%E3%82%A4%E3%82%BA%E3%80%81%E4%BA%8B%E5%89%8D%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A60%E3%83%9A%E3%83%BC%E3%82%B8%3CBR%20%2F%3E%5B%200.049892%5D%20HugeTLB%3A%200%20KiB%20vmemmap%E3%82%9232.0%20MiB%E3%83%9A%E3%83%BC%E3%82%B8%E7%94%A8%E3%81%AB%E8%A7%A3%E6%94%BE%E5%8F%AF%E8%83%BD%3CBR%20%2F%3E%5B%200.049896%5D%20HugeTLB%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF2.00%20MiB%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%B5%E3%82%A4%E3%82%BA%E3%80%81%E4%BA%8B%E5%89%8D%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A60%E3%83%9A%E3%83%BC%E3%82%B8%3CBR%20%2F%3E%5B%200.049902%5D%20HugeTLB%3A%200%20KiB%20vmemmap%E3%82%922.00%20MiB%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%A7%E8%A7%A3%E6%94%BE%E5%8F%AF%E8%83%BD%3CBR%20%2F%3E%5B%200.049909%5D%20HugeTLB%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%2064.0%20KiB%20%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%B5%E3%82%A4%E3%82%BA%E3%80%81%E4%BA%8B%E5%89%8D%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%200%E3%83%9A%E3%83%BC%E3%82%B8%3CBR%20%2F%3E%5B%200.049912%5D%20HugeTLB%3A%200%20KiB%20vmemmap%E3%82%9264.0%20KiB%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AB%E8%A7%A3%E6%94%BE%E5%8F%AF%E8%83%BD%3CBR%20%2F%3E%5B%200.052093%5D%20iommu%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%97%3A%20%E7%BF%BB%E8%A8%B3%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%5B%200.052102%5D%20iommu%3A%20DMA%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3TLB%E7%84%A1%E5%8A%B9%E5%8C%96%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%3A%E5%8E%B3%E6%A0%BC%E3%83%A2%E3%83%BC%E3%83%89%3CBR%20%2F%3E%5B%200.052394%5D%20SCSI%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.052679%5D%20USB%E3%82%B3%E3%82%A2%3A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20USBFS%3CBR%20%2F%3E%5B%200.052709%5D%20USBCORE%3A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%8F%E3%83%96%3CBR%20%2F%3E%5B%200.052742%5D%20usbcore%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20USB%3CBR%20%2F%3E%5B%200.053603%5D%20pps_core%3A%20LinuxPPS%20API%20ver.%201%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%5B%200.053607%20%5D%20pps_core%3A%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E7%89%885.3.6%20-%20Copyright%202005-2007%20Rodolfo%20Giometti%20%3CGIOMETTI%3E%3CBR%20%2F%3E%5B%200.053619%20%5D%20PTP%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%200.053886%5D%20EDAC%20MC%3A%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%203.0.0%3CBR%20%2F%3E%5B%200.054304%5D%20scmi_core%3A%20SCMI%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%90%E3%82%B9%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%5B%200.055327%5D%20Bluetooth%3A%20Core%20ver%202.22%3CBR%20%2F%3E%5B0.055356%5D%20NET%3A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BFPF_BLUETOOTH%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%3CBR%20%2F%3E%5B%200.055361%5D%20Bluetooth%3AHCI%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E6%8E%A5%E7%B6%9A%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3E%5B%200.055370%5D%20Bluetooth%3AHCI%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E5%B1%A4%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3E%5B%200.055375%5D%20Bluetooth%3AL2CAP%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E5%B1%A4%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%5B%200.055387%5D%20Bluetooth%3ASCO%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E5%B1%A4%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%5B%200.055707%5D%20vgaarb%3A%20loaded%3CBR%20%2F%3E%5B%200.056088%5D%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%3A%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9arch_sys_counter%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.056287%5D%20VFS%3A%20%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%82%AF%E3%82%A9%E3%83%BC%E3%82%BF%20dquot_6.6.0%3CBR%20%2F%3E%5B%200.056396%5D%20VFS%3A%20Dquot%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A512(%E6%AC%A1%E6%95%B00%E3%80%814096%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3E%5B%200.063310%5D%20NET%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BFPF_INET%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%3CBR%20%2F%3E%5B%200.063495%5D%20IP%E3%81%8C%E8%AD%98%E5%88%A5%E3%81%99%E3%82%8B%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A65536(%E9%A0%86%E5%BA%8F%3A7%E3%80%81524288%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E7%B7%9A%E5%BD%A2)%3CBR%20%2F%3E%5B%200.066275%5D%20tcp_listen_portaddr_hash%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E6%95%B0%3A2048(%E9%A0%86%E5%BA%8F%3A3%E3%80%8132768%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E7%B7%9A%E5%BD%A2)%3CBR%20%2F%3E%5B%200.066325%5D%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%83%BB%E3%83%91%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%96%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E6%95%B0%3A65536(%E9%A0%86%E5%BA%8F%3A6%E3%80%81262144%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E7%B7%9A%E5%BD%A2)%3CBR%20%2F%3E%5B%200.066337%5D%20TCP%E3%81%AF%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E7%A2%BA%E7%AB%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A32768(%E9%A0%86%E5%BA%8F%3A6%E3%80%81262144%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E7%B7%9A%E5%BD%A2)%3CBR%20%2F%3E%5B%200.066585%5D%20TCP%20%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A32768(%E9%A0%86%E5%BA%8F%3A8%E3%80%811048576%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E7%B7%9A%E5%BD%A2)%3CBR%20%2F%3E%5B%200.067521%5D%20TCP%3A%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%E6%B8%88%E3%81%BF(%E7%A2%BA%E7%AB%8B%E6%B8%88%E3%81%BF%2032768%20bind%2032768)%3CBR%20%2F%3E%5B%200.067635%5D%20UDP%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E6%95%B0%3A2048(%E9%A0%86%E5%BA%8F%3A4%2C65536%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E7%B7%9A%E5%BD%A2)%3CBR%20%2F%3E%5B%200.067720%5D%20UDP-Lite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tcp-with-tls%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%200.068386%5D%20RPC%3A%20tcp%20NFSv4.1%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%200.069403%5D%20PCI%3A%20CLS%200%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%8864%3CBR%20%2F%3E%5B%200.070488%5D%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E4%BF%A1%E9%A0%BC%E3%82%AD%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%200.070625%5D%20%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%E3%82%BB%E3%83%83%E3%83%88%3A%20timestamp_bits%3D46%20max_order%3D20%20bucket_order%3D0%3CBR%20%2F%3E%5B%200.070895%5D%20%E3%82%B9%E3%82%AB%E3%83%83%E3%82%B7%E3%83%A5%E3%83%95%E3%82%B9%3A%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.0(2009%E5%B9%B41%E6%9C%8831%E6%97%A5)%20%E3%83%95%E3%82%A3%E3%83%AA%E3%83%83%E3%83%97%E3%83%BB%E3%83%A9%E3%82%A6%E3%82%A2%E3%83%BC%3CBR%20%2F%3E%5B%200.071096%5D%20NFS%3A%20id_resolver%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%5B%200.071116%20%E7%99%BB%E9%8C%B2%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97id_resolver%3CBR%20%2F%3E%5B%200.071120%20%E7%99%BB%E9%8C%B2%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97id_legacy%3CBR%20%2F%3E%5B%200.071137%5D%20nfs4filelayout_init%3A%20NFSv4%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E7%99%BB%E9%8C%B2%E4%B8%AD...%3CBR%20%2F%3E%5B%200.071142%5D%20nfs4flexfilelayout_init%3A%20NFSv4%20Flexfile%20%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E7%99%BB%E9%8C%B2%E4%B8%AD...%3CBR%20%2F%3E%5B%200.071159%5D%20JFFS2%3A%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32.2%E3%80%82(NAND)%20%C2%A9%202001-2006%E5%B9%B4%20%E3%83%AC%E3%83%83%E3%83%89%E3%83%8F%E3%83%83%E3%83%88%E7%A4%BE%3CBR%20%2F%3E%5B%200.071346%5D%209p%3A%20v9fs%209p2000%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3CBR%20%2F%3E%5B%200.100048%5D%20%E3%82%B8%E3%83%83%E3%82%BF%E3%83%BC%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AD%E3%83%94%E3%83%BC%3A%E3%83%9B%E3%82%B9%E3%83%88%E3%81%8C%E8%A6%81%E4%BB%B6%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E5%88%9D%E6%9C%9F%E5%8C%96%E5%A4%B1%E6%95%97%3A9%3CBR%20%2F%3E%5B%200.100055%5D%20%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%E9%9D%9E%E5%AF%BE%E7%A7%B0%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%5B%200.100059%5D%20%E9%9D%9E%E5%AF%BE%E7%A7%B0%E3%82%AD%E3%83%BC%E3%83%91%E3%83%BC%E3%82%B5%E3%83%BC%20'x509'%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%5B%200.100104%5D%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%B1%A4%20SCSI%20%E3%82%B8%E3%82%A7%E3%83%8D%E3%83%AA%E3%83%83%E3%82%AF(BSG)%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B30.4%20%E3%83%AD%E3%83%BC%E3%83%89(%E3%83%A1%E3%82%B8%E3%83%A3%E3%83%BC246)%3CBR%20%2F%3E%5B%200.100110%5D%20IO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%83%BCMQ-%E6%9C%9F%E9%99%90%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%5B%200.100114%5D%20IO%20%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%83%BC%20%E3%82%AB%E3%82%A4%E3%83%90%E3%83%BC%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%5B%200.100139%5D%20IO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%83%BCBFQ%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%5B%200.115771%5D%20IMX-SDMA%2030BD0000.DMA-%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%3Aimx%2Fsdma%2Fsdma-imx7d.bin%E3%81%AE%E7%9B%B4%E6%8E%A5%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC-2%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.115787%5D%20imx-sdma%2030bd0000.dma-%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3Aimx%2Fsdma%2Fsdma-imx7d.bin%20%E3%81%AEsysfs%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%200.117292%5D%20mxs-dma%2033000000.dma-apbh%3A%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3E%5B%200.118069%5D%20SoC%3A%20i.MX8MP%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B31.1%3CBR%20%2F%3E%5B%200.118477%5D%20%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%5B%200.135536%5D%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3A8250%2F16550%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%80%814%E3%83%9D%E3%83%BC%E3%83%88%E3%80%81IRQ%E5%85%B1%E6%9C%89%E6%9C%89%E5%8A%B9%3CBR%20%2F%3E%5B%200.138454%5D%2030880000.serial%3Attymxc2%20(MMIO%200x30880000%E3%80%81irq%20%3D%2016%E3%80%81base_baud%20%3D%205000000)%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%3CBR%20%2F%3E%5B%200.138703%5D%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20serial0%3A%20tty%20%E3%83%9D%E3%83%BC%E3%83%88%20ttymxc2%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%200.139315%5D%2030890000.serial%3Attymxc1%20%E3%81%AF%20MMIO%200x30890000(irq%20%3D%2017%E3%80%81base_baud%20%3D%201500000)%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%20IMX%20%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%200.139350%5D%20Printk%3A%20%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc1%5D%20%E6%9C%89%E5%8A%B9%E5%8C%96%3CBR%20%2F%3E%5B%201.222791%5D%20%E3%83%AB%E3%83%BC%E3%83%97%3A%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%AD%E3%83%BC%E3%83%89%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%5B%201.227149%5D%20of_reserved_mem_lookup()%20NULL%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%201.237919%5D%20tun%3A%20Universal%20TUN%2FTAP%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%80%811.6%3CBR%20%2F%3E%5B%201.244863%5D%20Sky2%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.30%3CBR%20%2F%3E%5B%201.249061%5D%20USBCORE%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20R8152-CFG%E3%82%BB%E3%83%AC%E3%82%AF%E3%82%BF%E3%83%BC%3CBR%20%2F%3E%5B%201.255367%5D%20USB%E3%82%B3%E3%82%A2%3A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCR8152%3CBR%20%2F%3E%5B%201.261230%5D%20VFIO%20-%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E3%83%A1%E3%82%BF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A0.3%3CBR%20%2F%3E%5B%201.271293%5D%20USB%E3%82%B3%E3%82%A2%3A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCUAS%3CBR%20%2F%3E%5B%201.276669%5D%20USB%E3%82%B3%E3%82%A2%3A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCUSB%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%3CBR%20%2F%3E%5B%201.282753%5D%20USB%E3%82%B3%E3%82%A2%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E7%99%BB%E9%8C%B2usbserial_generic%3CBR%20%2F%3E%5B%201.289312%5D%20usbserial%3A%20%E6%B1%8E%E7%94%A8%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FUSB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%201.295346%5D%20USBCORE%3A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20ftdi_sio%3CBR%20%2F%3E%5B%201.301121%5D%20usbserial%3A%20FTDI%20USB%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FUSB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%201.308467%5D%20USB%E3%82%B3%E3%82%A2%3A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usb_serial_simple%3CBR%20%2F%3E%5B%201.315022%5D%20usbserial%3A%20carelink%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FUSB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%201.321145%5D%20USB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3A%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FUSB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%201.327526%5D%20usbserial%3A%20Funsoft%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FUSB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%201.333554%5D%20usbserial%3A%20Google%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FUSB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%201.339503%5D%20usbserial%3A%20hp4x%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FUSB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%201.345284%5D%20usbserial%3A%20%E3%82%AB%E3%82%A6%E3%83%95%E3%83%9E%E3%83%B3%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FUSB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%201.351402%5D%20USB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3AUSB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E5%AF%BE%E5%BF%9C%20LibTransistor%E3%81%AB%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%5B%201.357961%5D%20usbserial%3A%20USB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%20moto_modem%3CBR%20%2F%3E%5B%201.364256%5D%20usbserial%3A%20USB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%20motorola_tetra%3CBR%20%2F%3E%5B%201.370900%5D%20usbserial%3A%20Nokia%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FUSB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%201.376765%5D%20usbserial%3A%20USB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%20novatel_gps%3CBR%20%2F%3E%5B%201.383149%5D%20usbserial%3A%20siemens_mpi%20%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FUSB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%201.389527%5D%20usbserial%3A%20suunto%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FUSB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%201.395476%5D%20usbserial%3A%20vivopay%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FUSB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%201.401511%5D%20usbserial%3A%20zio%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FUSB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%201.407203%5D%20USB%E3%82%B3%E3%82%A2%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E7%99%BB%E9%8C%B2usb_ehset_test%3CBR%20%2F%3E%5B%201.413528%5D%20USBCORE%3A%E3%82%AA%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%5B%201.422006%5D%20snvs_rtc%2030370000.snvs%3Asnvs-rtc-lp%3Artc0%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%201.428227%5D%20snvs_rtc%2030370000.snvs%3Asnvs-rtc-lp%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%921970-01-01T00%3A00%3A00%20UTC(0)%E3%81%AB%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3E%5B%201.437427%5D%20i2c_dev%3A%20i2c%20%2Fdev%20ententry%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3E%5B%201.445729%5D%20Bluetooth%3A%20HCI%20UART%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32.3%3CBR%20%2F%3E%5B%201.450203%20%5D%20Bluetooth%3A%20HCI%20UART%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%ABH4%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%5B%201.455351%5D%20Bluetooth%3A%20HCI%20UART%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%ABBCSP%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%5B%201.460695%5D%20Bluetooth%3A%20HCI%20UART%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%ABLL%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%5B%201.465847%5D%20Bluetooth%3A%20HCI%20UART%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%ABATH3K%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%5B%201.471280%20Bluetooth%3A%20HCI%20UART%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%203%E7%B7%9A%E5%BC%8F(H5)%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%5B%201.477642%20Bluetooth%3A%20HCI%20UART%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20Broadcom%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%5B%201.483333%5D%20Bluetooth%3A%20HCI%20UART%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%ABQCA%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%5B%201.488739%5D%20EDAC%20MC%3A%20ECC%E3%81%8C%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B%201.493561%5D%20sdhci%3A%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%BB%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3E%5B%201.499762%5D%20SDHCI%3A%20%E8%91%97%E4%BD%9C%E6%A8%A9(c)%20%E3%83%94%E3%82%A8%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AA%E3%82%B9%E3%83%9E%E3%83%B3%3CBR%20%2F%3E%5B%201.504580%20Synopsys%20Designware%20%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%82%AB%E3%83%BC%E3%83%89%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3E%5B%201.511193%5D%20SDHCI-pltfm%3ASDHCI%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%8A%E3%82%88%E3%81%B3OF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%98%E3%83%AB%E3%83%91%E3%83%BC%3CBR%20%2F%3E%5B%201.519372%5D%20ledtrig-cpu%3A%20CPU%E3%81%AE%E6%B4%BB%E5%8B%95%E3%82%92%E7%A4%BA%E3%81%99%E3%81%9F%E3%82%81%E3%81%AB%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%5B%201.526326%5D%20SMCCC%3A%20SOC_ID%3A%20ARCH_SOC_ID%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97...%3CBR%20%2F%3E%5B%201.535249%5D%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%80%A7%E8%83%BD%3Aarmv8_cortex_a53%20PMU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A7%E6%9C%89%E5%8A%B9%E3%80%817%E3%81%A4%E3%81%AE%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%82%92%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%3CBR%20%2F%3E%5B%201.545746%5D%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0soc%400%3A%E5%9B%BA%E5%AE%9A%E4%BE%9D%E5%AD%98%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB(%2Fsoc%400%2Fbus%4030000000%2Fefuse%4030350000%3CBR%20%2F%3E%5B%201.548948%5D%20mmc2%3A%2030b60000.mmc%20%E4%B8%8A%E3%81%AESDHCI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20%5B30b60000.mmc%5DADMA%E3%81%AE%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E%5B%201.555377%5D%20%E8%A2%AB%E4%BE%9D%E9%A0%BC%E8%80%85%3A%E5%B0%8E%E7%AE%A1%E6%B3%95%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%93%E3%83%B3%E3%82%B0%E3%80%82%3CBR%20%2F%3E%5B%201.565851%5D%20OPEE%3AAPI%20UID%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%3CBR%20%2F%3E%5B%201.569678%5D%20optee%3A%20Probe%20of%20firmware%3Aoptee%20%E3%82%A8%E3%83%A9%E3%83%BC%20-22%20%E3%81%A7%E5%A4%B1%E6%95%97%3CBR%20%2F%3E%5B%201.576620%20%5D%20NET%3A%20%E7%99%BB%E9%8C%B2PF_LLC%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%3CBR%20%2F%3E%5B%201.581492%5D%20U32%20%E5%88%86%E9%A1%9E%E5%99%A8%3CBR%20%2F%3E%5B%201.584247%5D%20%E5%85%A5%E5%8A%9B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%AA%E3%83%B3%3CBR%20%2F%3E%5B%201.587910%5D%20%E3%82%A2%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E6%A7%8B%E6%88%90%3CBR%20%2F%3E%5B%201.591634%5D%20NET%3A%E7%99%BB%E9%8C%B2PF_INET6%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%3CBR%20%2F%3E%5B%201.598148%5D%20IPv6%E3%81%AB%E3%82%88%E3%82%8B%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%3CBR%20%2F%3E%5B%201.601891%5D%20IPv6%E3%82%92%E7%94%A8%E3%81%84%E3%81%9F%E7%8F%BE%E5%9C%B0OAM(IOAM)%3CBR%20%2F%3E%5B%201.605875%5D%20NET%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BFPF_PACKET%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%3CBR%20%2F%3E%5B%201.610955%5D%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%3AARP%2FIP%2FIPv6Tables%E3%81%AB%E3%82%88%E3%82%8B%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AF%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%89%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6br_netfilter%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%5B%201.625927%5D%20Bluetooth%3A%20RFCOMM%20TTY%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3E%5B%201.630834%5D%20Bluetooth%3ARFCOMM%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E5%B1%A4%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3E%5B%201.634392%20%5D%20MMC2%3A%E6%96%B0%E3%81%97%E3%81%84HS400%E5%BC%B7%E5%8C%96%E3%82%B9%E3%83%88%E3%83%AD%E3%83%9CMMC%E3%82%AB%E3%83%BC%E3%83%89%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90001%3CBR%20%2F%3E%5B%201.636001%5D%20Bluetooth%3A%20RFCOMM%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.11%3CBR%20%2F%3E%5B%201.642888%20%5D%20mmcblk2%3A%20mmc2%3A0001%20064G90%2058.2%20GiB%3CBR%20%2F%3E%5B%201.646098%5D%20Bluetooth%3A%20BNEP(%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.3%3CBR%20%2F%3E%5B%201.653585%5D%20MMCBLK2%3A%20P1%20P2%20P3%3CBR%20%2F%3E%5B%201.655851%5D%20Bluetooth%3A%20BNEP%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%3CBR%20%2F%3E%5B%201.661320%20%5D%20mmcblk2boot0%3A%20mmc2%3A0001%20064G90%208.00%20MiB%3CBR%20%2F%3E%5B%201.664139%5D%20Bluetooth%3ABNEP%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E5%B1%A4%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3E%5B%201.670589%20%5D%20mmcblk2boot1%3A%20mmc2%3A0001%20064G90%208.00%20MiB%3CBR%20%2F%3E%5B%201.674997%5D%208021q%3A%20802.1Q%20VLAN%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v1.8%3CBR%20%2F%3E%5B%201.680430%20%5D%20mmcblk2rpmb%3A%20mmc2%3A0001%20064G90%2016.0%20MiB%2C%20chardev%20(238%3A0)%3CBR%20%2F%3E%5B%201.683109%5D%20lib80211%3AIEEE802.11%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%85%B1%E9%80%9A%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3CBR%20%2F%3E%5B%201.695071%5D%209pnet%3A%209P2000%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3CBR%20%2F%3E%5B%201.699490%20%E7%99%BB%E9%8C%B2%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97dns_resolver%3CBR%20%2F%3E%5B%201.704490%5D%20NET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%20PF_VSOCK%3CBR%20%2F%3E%5B%201.719723%5D%20%E7%99%BB%E9%8C%B2%E3%82%BF%E3%82%B9%E3%82%AF%E7%B5%B1%E8%A8%88%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31%3CBR%20%2F%3E%5B%201.723967%5D%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9FX.509%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3CBR%20%2F%3E%5B%201.751680%5D%20GPIO%20gpiochip0%3A%20GPIO%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E9%9D%99%E7%9A%84%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AF%E5%BB%83%E6%AD%A2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8B%95%E7%9A%84%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%5B%201.762305%5D%20gpio%20gpiochip1%3A%20GPIO%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E9%9D%99%E7%9A%84%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AF%E9%9D%9E%E6%8E%A8%E5%A5%A8%E3%81%A7%E3%81%99%E3%80%82%E5%8B%95%E7%9A%84%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%5B%201.772790%5D%20gpio%20gpiochip2%3A%20GPIO%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E9%9D%99%E7%9A%84%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AF%E9%9D%9E%E6%8E%A8%E5%A5%A8%E3%81%A7%E3%81%99%E3%80%82%E5%8B%95%E7%9A%84%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%5B%201.783311%5D%20gpio%20gpiochip3%3A%20GPIO%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E9%9D%99%E7%9A%84%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AF%E9%9D%9E%E6%8E%A8%E5%A5%A8%E3%81%A7%E3%81%99%E3%80%82%E5%8B%95%E7%9A%84%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%5B%201.793861%5D%20gpio%20gpiochip4%3A%20GPIO%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E9%9D%99%E7%9A%84%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AF%E9%9D%9E%E6%8E%A8%E5%A5%A8%E3%81%A7%E3%81%99%E3%80%82%E5%8B%95%E7%9A%84%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%5B%201.806692%5D%20i2c%20i2c-0%3A%20IMX%20I2C%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%201.813480%5D%20rtc-rx8111%202-0032%3A%20rtc1%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%201.820041%5D%20ina238%202-0043%3A%20%E9%9B%BB%E5%8A%9B%E3%83%A2%E3%83%8B%E3%82%BF%20ina237%20(Rshunt%20%3D%2050000%20u%CE%A9%E3%80%81%E3%82%B2%E3%82%A4%E3%83%B3%20%3D%204)%3CBR%20%2F%3E%20%5B%201.821839%5D%20nxp-pca9450%200-0025%3A%20pca9450bc%20%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%201.827481%5D%20i2c%20i2c-2%3A%20IMX%20I2C%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%201.869694%5D%20usb251xb%203-002c%3A%20%E3%83%8F%E3%83%96%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%201.875553%5D%20usb251xb%203-002c%3A%20%E3%83%8F%E3%83%96%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%201.880583%5D%20i2c%20i2c-3%3A%20IMX%20I2C%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%201.885922%5D%20imx8mq-usb-phy%20381f0040.usb-phy%3A%E9%9B%BB%E6%BA%90Vbus%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B%201.894643%5D%20imx8mq-usb-phy%20382f0040.usb-phy%3A%E9%9B%BB%E6%BA%90Vbus%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B%201.912708%5D%2030a60000.serial%3Attymxc3%E3%81%AFMMIO%200x30a60000(irq%20%3D%20199%E3%80%81base_baud%20%3D%201500000)%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6IMX%E3%81%A7%E3%81%99%3CBR%20%2F%3E%5B%201.922917%5D%20IMX-DWMAC%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%3AIRQ%20eth_lpi%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B%201.929740%5D%20imx-dwmac%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%3A%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BCID%3A0x10%E3%80%81Synopsys%20ID%3A0x51%3CBR%20%2F%3E%5B%201.936555%5D%20IMX-DWMAC%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%3ADWMAC4%2F5%3CBR%20%2F%3E%5B%201.941361%5D%20imx-dwmac%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%3ADMA%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%A9%9F%E8%83%BD%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%201.948509%5D%20IMX-DWMAC%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%3ARX%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E3%82%AA%E3%83%95%E3%83%AD%E3%83%BC%E3%83%89%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%201.955650%5D%20IMX-DWMAC%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%3ATX%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E6%8C%BF%E5%85%A5%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%5B%201.962359%5D%20IMX-DWMAC%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%3A%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%BB%E3%82%AA%E3%83%B3%E3%83%BB%E3%83%A9%E3%83%B3%E6%94%AF%E6%8F%B4%3CBR%20%2F%3E%5B%201.968520%5D%20IMX-DWMAC%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%3A%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%AB%E3%82%88%E3%82%8BRX%E8%BB%BD%E6%B8%9B%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%201.976199%5D%20IMX-DWMAC%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9MAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B92a%3Ac5%3A99%3A84%3A66%3Abb%3CBR%20%2F%3E%5B%201.983350%5D%20IMX-DWMAC%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%3A%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9FL3L4%E3%83%95%E3%83%AD%E3%83%BCTC(%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3D8)%3CBR%20%2F%3E%5B%201.990152%5D%20imx-dwmac%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%3A%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9FRFS%E3%83%95%E3%83%AD%E3%83%BCTC(%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3D10)%3CBR%20%2F%3E%5B%201.996965%5D%20IMX-DWMAC%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%3A%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2TC%E3%81%AE%E6%9C%89%E5%8A%B9%E5%8C%96(%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3D256%E3%80%81%20max_off%3D256)%3CBR%20%2F%3E%5B%202.004554%5D%20imx-dwmac%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%3A34%2F40%E3%83%93%E3%83%83%E3%83%88DMA%E3%83%9B%E3%82%B9%E3%83%88%2F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%B9%85%E3%81%AE%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E%5B%202.158192%20Realtek-MDIO%20STMMAC-1%3A00%3ARTL8363NB%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92%E7%99%BA%E8%A6%8B%3CBR%20%2F%3E%5B%202.164168%20Realtek-MDIO%20STMMAC-1%3A00%3A%20%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20ret%20%3D%20-517%3CBR%20%2F%3E%5B%202.175037%5D%20XHCi-HCD.1.auto%3AxHCI%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3CBR%20%2F%3E%5B%202.180572%5D%20XHCi-HCD.1.auto%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B71%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.188568%5D%20XHCi-HCD.1.auto%3AHCC%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF0x0220fe6d%20HCI%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B30x110%E3%82%AF%E3%83%AF%E3%83%BC%E3%82%AF0x000000a001000010%3CBR%20%2F%3E%5B%202.198006%20%5D%20XHCI-HCD%E3%80%81XHCI-HCD.1.%E3%82%AA%E3%83%BC%E3%83%88%3AIRQ%20203%E3%80%81IO%20MEM%200x38200000%3CBR%20%2F%3E%5B%202.204153%5D%20XHCI-HCD-HCD.1.auto%3AxHCI%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3CBR%20%2F%3E%5B%202.209668%5D%20XHCi-HCD%E3%80%81XHCI-HCD.1.auto%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B72%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.217339%5D%20XHCi-HCD.1.auto%3A%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AFUSB%203.0%20SuperSpeed%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%202.226380%5D%20%E3%83%8F%E3%83%96%201-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.230477%5D%20%E3%83%8F%E3%83%96%201-0%3A1.0%3A%201%E3%81%A4%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.236611%5D%20usb%20usb2%3A%20%E3%81%93%E3%81%AE%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AE%20LPM%20%E3%81%AE%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81LPM%20%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B%202.246489%5D%20%E3%83%8F%E3%83%96%202-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.250581%5D%20%E3%83%8F%E3%83%96%202-0%3A1.0%3A%201%E3%81%A4%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.256296%5D%20imx-cpufreq-dt%20imx-cpufreq-dt%3A%20CPU%20%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89%20%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%205%20mkt%20%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%200%20supported-hw%200x20%200x1%3CBR%20%2F%3E%20%5B%202.268964%5D%20sdhci-esdhc-imx%2030b40000.mmc%3Ammc-pwrseq%20%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.269069%5D%20sdhci-esdhc-imx%2030b50000.mmc%3ACD%20GPIO%E3%82%92%E5%85%A5%E6%89%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.313534%5D%20mmc1%3A%2030b50000.mmc%20%E4%B8%8A%E3%81%AESDHCI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20%5B30b50000.mmc%5DADMA%E3%81%AE%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E%5B%202.413613%5D%20mmc0%3A%2030b40000.mmc%20%E4%B8%8A%E3%81%AESDHCI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20%5B30b40000.mmc%5DADMA%E3%81%AE%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E%5B%202.414283%20Realtek-MDIO%20STMMAC-1%3A00%3ARTL8363NB%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92%E7%99%BA%E8%A6%8B%3CBR%20%2F%3E%5B%202.492421%5D%20USB%201-1%3AXHCI-HCD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9FUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B72%3CBR%20%2F%3E%5B%202.540131%5D%20MMC0%3A%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90001%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E8%B6%85%E9%AB%98%E9%80%9FSDR104%20SDIO%E3%82%AB%E3%83%BC%E3%83%89%3CBR%20%2F%3E%5B%202.600919%5D%20Realtek-MDIO%20STMMAC-1%3A00%3A%20%E5%9B%BA%E5%AE%9A%2FRGMII%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3E%5B%202.610450%5D%20realtek-mdio%20stmmac-1%3A00%3A%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E7%A8%BC%E5%83%8D%E4%B8%AD%20-%201Gbps%2F%E3%83%95%E3%83%AB%20-%20%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E3%82%AA%E3%83%95%3CBR%20%2F%3E%5B%202.644563%5D%20realtek-mdio%20stmmac-1%3A00%20eth1%20(%E6%9C%AA%E5%88%9D%E6%9C%9F%E5%8C%96)%3A%20PHY%20%5Bdsa-0.0%3A01%5D%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BGeneric%20PHY%5D%20(irq%3DPOLL)%3CBR%20%2F%3E%5B%202.684441%5D%20realtek-mdio%20stmmac-1%3A00%20eth2(%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84)%3APHY%20%5Bdsa-0.0%3A03%5D%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BGeneric%20PHY%5D%20(irq%3DPOLL)%3CBR%20%2F%3E%5B%202.699335%5D%20DSA%3A%20%E3%83%84%E3%83%AA%E3%83%BC0%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3CBR%20%2F%3E%5B%202.704695%5D%20%E5%85%A5%E5%8A%9B%3AGPIO-keys%2F%2Fdevice%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3CBR%20%2F%3E%5B%202.704785%5D%20%E3%83%8F%E3%83%96%201-1%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%81%A3%E3%81%9F%3CBR%20%2F%3E%5B%202.712031%5D%20%E5%85%A5%E5%8A%9B%3Acpu_inputs%20%2Fdevices%2Fplatform%2Fcpu_inputs%2Finput%2Finput1%3CBR%20%2F%3E%5B%202.715286%5D%20%E3%83%8F%E3%83%96%201-1%3A1.0%3A4%E3%83%9D%E3%83%BC%E3%83%88%E6%A4%9C%E5%87%BA%3CBR%20%2F%3E%5B%202.722488%5D%20cfg80211%3A%20%E8%A6%8F%E5%88%B6%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%E7%94%A8%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%B8%88%E3%81%BFX.509%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3CBR%20%2F%3E%5B%202.734966%5D%20%E8%A3%85%E8%BC%89%E6%B8%88%E3%81%BF%20X.509%20cert%20'sforshee%3A%2000b28ddf47aef9cea7'%3CBR%20%2F%3E%5B%202.741369%5D%20Loaded%20X.509%20cert%20'wens%3A%2061c038651aabdcf94bd0ac7ff06c7248db18c600'%3CBR%20%2F%3E%5B%202.748657%5D%20clk%3A%20%E6%9C%AA%E4%BD%BF%E7%94%A8%E6%99%82%E8%A8%88%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%3CBR%20%2F%3E%5B%202.752652%5D%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20regulatory.0%3Aregulatory.db%E3%81%AE%E7%9B%B4%E6%8E%A5%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC-2%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%202.761287%5D%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20regulatory.0%3Aregulatory.db%20%E3%81%AE%20sysfs%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%202.865310%5D%20%E3%83%8F%E3%83%96%201-1%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%202.869427%5D%20%E3%83%8F%E3%83%96%201-1%3A1.0%3A%204%E3%81%A4%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%203.269517%5D%20EXT4-fs%20(mmcblk2p3)%3A%20%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%5B%203.275227%5D%20EXT4-fs%20(mmcblk2p3)%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20057d8de8-a7e7-4440-9fea-c9670c0c5df9%20%E3%82%92%E9%A0%86%E5%BA%8F%E4%BB%98%E3%81%8D%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E5%8F%AF%E8%83%BD%E3%81%AB%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%AF%E3%82%A9%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%BC%E3%83%89%EF%BC%9A%E3%81%AA%E3%81%97%E3%80%82%3CBR%20%2F%3E%5B%203.287379%5D%20VFS%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20179%3A3%20%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%88%20(ext4%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0)%20%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%203.294319%5D%20devtmpfs%3A%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%203.298268%5D%20%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E8%A7%A3%E6%94%BE%E4%B8%AD%3A%203520K%3CBR%20%2F%3E%20%5B%203.302934%5D%20%2Fsbin%2Finit%20%E3%82%92%20init%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%5B%203.423469%5D%20systemd%5B1%5D%3A%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E6%99%82%E5%88%BB%E3%81%8C%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E5%88%BB%E3%82%88%E3%82%8A%E5%89%8D%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E9%80%B2%E3%82%81%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%203.450897%5D%20systemd%5B1%5D%3A%20systemd%20252.39-1~deb12u2%20%E3%81%8C%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%2BPAM%20%2BAUDIT%20%2BSELINUX%20%2BAPPARMOR%20%2BIMA%20%2BSMACK%20%2BSECCOMP%20%2BGCRYPT%20-GNUTLS%20%2BOPENSSL%20%2BACL%20%2BBLKID%20%2BCURL%20%2BELFUTILS%20%2BFIDO2%20%2BIDN2%20-IDN%20%2BIPTC%20%2BKMOD%20%2BLIBCRYPTSETUP%20%2BLIBFDISK%20%2BPCRE2%20-PWQUALITY%20%2BP11KIT%20%2BQRENCODE%20%2BTPM2%20%2BBZIP2%20%2BLZ4%20%2BXZ%20%2BZLIB%20%2BZSTD%20-BPF_FRAMEWORK%20-XKBCOMMON%20%2BUTMP%20%2BSYSVINIT%20default-hierarchy%3Dunified)%3CBR%20%2F%3E%20%5B%203.483986%5D%20systemd%5B1%5D%3A%20%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%20arm64%20%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FGIOMETTI%3E%3C%2FP%3E%3CP%3EDebian%20GNU%2FLinux%2012(%E3%83%96%E3%83%83%E3%82%AF%E3%83%AF%E3%83%BC%E3%83%A0)%E3%81%B8%E3%82%88%E3%81%86%E3%81%93%E3%81%9D!%3C%2FP%3E%3CP%3E%5B%203.506158%5D%20systemd%5B1%5D%3A%20%E3%83%9B%E3%82%B9%E3%83%88%E5%90%8D%E3%81%8C%20%3CLOCALHOST%3E%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20%5B%203.512764%5D%20systemd%5B1%5D%3A%20%E4%B9%B1%E6%95%B0%E7%94%9F%E6%88%90%E5%99%A8%E3%81%8B%E3%82%89%E3%83%9E%E3%82%B7%E3%83%B3ID%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%203.558947%5D%20systemd%5B1%5D%3A%20memfd_create()%20%E3%81%8C%20MFD_EXEC%20%E3%81%BE%E3%81%9F%E3%81%AF%20MFD_NOEXEC_SEAL%20%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E7%8A%B6%E6%85%8B%E3%81%A7%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%203.931119%5D%20systemd%5B1%5D%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20graphical.target%20%E3%81%AE%E9%96%8B%E5%A7%8B%E3%82%B8%E3%83%A7%E3%83%96%E3%82%92%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%203.968011%5D%20systemd%5B1%5D%3A%20%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%B9%20system-getty.slice%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%B9%20%2Fsystem%2Fgetty%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%B9%20system-getty.slice%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%B9%20%2Fsystem%2Fgetty%E3%80%82%3CBR%20%2F%3E%5B%203.993796%5D%20systemd%5B1%5D%3A%20%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%B9%20system-modprobe.slice%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%B9%20%2Fsystem%2Fmodprobe%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%B9%20system-modpr%E2%80%A6lice%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%B9%20%2Fsystem%2Fmodprobe%E3%80%82%3CBR%20%2F%3E%5B%204.022309%5D%20systemd%5B1%5D%3A%20system-serial%5Cx2dgetty.slice%20-%20%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%B9%20%2Fsystem%2Fserial-getty%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5DCreated%20slice%20system-seria...%20-%20Slice%20%2Fsystem%2Fserial-getty.%3CBR%20%2F%3E%5B%204.049678%5D%20systemd%5B1%5D%3A%20system-systemd%5Cx2dfsck.slice%20-%20%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%B9%20%2Fsystem%2Fsystemd-fsck%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%B9%20system-syste%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F...%20-%20%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%B9%20%2Fsystem%2Fsystemd-fsck%E3%80%82%3CBR%20%2F%3E%5B%204.077353%5D%20systemd%5B1%5D%3A%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8A%E3%82%88%E3%81%B3%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%B9%E3%82%92%20user.slice%20%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%A8%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%B9%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%204.100497%5D%20systemd%5B1%5D%3A%20systemd-ask-password-console.path%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E8%A6%81%E6%B1%82%E3%82%92%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E7%9B%A3%E8%A6%96%E3%81%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%83%91%E3%83%83%E3%83%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E7%9B%A3%E8%A6%96%E3%81%B8%E3%81%AE%20systemd-ask-passwo%E2%80%A6quests%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%204.128453%5D%20systemd%5B1%5D%3A%20systemd-ask-password-wall.path%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E8%A6%81%E6%B1%82%E3%82%92%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E7%9B%A3%E8%A6%96%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-ask-passwo%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E2%80%A6%20Wall%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E7%9B%A3%E8%A6%96%E3%81%B8%E3%81%AE%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%80%82%3CBR%20%2F%3E%5B%204.156396%5D%20systemd%5B1%5D%3A%20proc-sys-fs-binfmt_misc.automount%20-%20%E6%9D%A1%E4%BB%B6%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%8C%E6%BA%80%E3%81%9F%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%BD%A2%E5%BC%8F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E8%87%AA%E5%8B%95%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%8C%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(ConditionPathExists%3D%2Fproc%2Fsys%2Ffs%2Fbinfmt_misc)%E3%80%82%3CBR%20%2F%3E%5B%204.175866%5D%20systemd%5B1%5D%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20dev-mmcblk2p1.device%20-%20%2Fdev%2Fmmcblk2p1...%20%E3%82%92%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20dev-mmcblk2p1.device%20-%20%2Fdev%2Fmmcblk2p1%20%E3%82%92%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20%5B%204.200472%5D%20systemd%5B1%5D%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20dev-ttymxc1.device%20-%20%2Fdev%2Fttymxc1%20%E3%82%92%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20dev-ttymxc1.device%20-%20%2Fdev%2Fttymxc1%20%E3%82%92%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20%5B%204.224224%5D%20systemd%5B1%5D%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20cryptsetup.target%20-%20Local%20Encrypted%20Volumes%20%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20cryptsetup.%E2%80%A6get%20%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F-%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E6%9A%97%E5%8F%B7%E5%8C%96%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%E3%80%82%3CBR%20%2F%3E%5B%204.248610%5D%20systemd%5B1%5D%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20integritysetup.target%20-%20Local%20Integrity%20Protected%20Volumes%20%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E7%9B%AE%E6%A8%99%E3%81%AE%E6%95%B4%E5%90%88%E6%80%A7%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E2%80%A6%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E6%95%B4%E5%90%88%E6%80%A7%E4%BF%9D%E8%AD%B7%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%E3%80%82%3CBR%20%2F%3E%5B%204.276289%5D%20systemd%5B1%5D%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20paths.target%20-%20Path%20Units%20%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20paths.target%20-%20%E3%83%91%E3%82%B9%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%204.296264%5D%20systemd%5B1%5D%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20remote-fs.target%20-%20Remote%20File%20Systems%20%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20remote-fs.target%20-%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%204.320247%5D%20systemd%5B1%5D%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20slices.target%20-%20Slice%20Units%20%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E7%9B%AE%E6%A8%99%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%B9%E6%95%B0%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82target%20-%20%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%B9%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%80%82%3CBR%20%2F%3E%5B%204.340224%5D%20systemd%5B1%5D%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20swap.target%20-%20Swaps%20%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20%5B%20OK%20%5D%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20swap.target%20-%20Swaps%20%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20%5B%204.360269%5D%20systemd%5B1%5D%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20veritysetup.target%20-%20Local%20Verity%20Protected%20Volumes%20%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20veritysetup%20%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E2%80%A6%20-%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%20Verity%20%E4%BF%9D%E8%AD%B7%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%E3%80%82%3CBR%20%2F%3E%5B%204.384758%5D%20systemd%5B1%5D%3A%20systemd-fsckd.socket%20%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20fsck%20%E3%81%8B%E3%82%89%20fsckd%20%E3%81%B8%E3%81%AE%E9%80%9A%E4%BF%A1%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-fsckd%E2%80%A6sck%20%E3%81%8B%E3%82%89%20fsckd%20%E3%81%B8%E3%81%AE%E9%80%9A%E4%BF%A1%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%204.412536%5D%20systemd%5B1%5D%3A%20systemd-initctl.socket%20-%20initctl%20%E4%BA%92%E6%8F%9B%E6%80%A7%E5%90%8D%E5%89%8D%E4%BB%98%E3%81%8D%E3%83%91%E3%82%A4%E3%83%97%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B%20OK%20%5D%20systemd-initc%20%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6%20initctl%20%E4%BA%92%E6%8F%9B%E6%80%A7%E5%90%8D%E5%89%8D%E4%BB%98%E3%81%8D%E3%83%91%E3%82%A4%E3%83%97%E3%80%82%3CBR%20%2F%3E%20%5B%204.441749%5D%20systemd%5B1%5D%3A%20systemd-journald-audit.socket%20-%20Journal%20Audit%20Socket%20%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-journ%E2%80%A6socket%20-%20Journal%20Audit%20Socket%20%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%204.468740%5D%20systemd%5B1%5D%3A%20systemd-journald-dev-log.socket%20%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%20(%2Fdev%2Flog)%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-journ%E2%80%A6t%20-%20Journal%20Socket%20(%2Fdev%2Flog)%20%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%204.496878%5D%20systemd%5B1%5D%3A%20systemd-journald.socket%20-%20Journal%20Socket%20%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-journald.socket%20-%20%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%204.520946%5D%20systemd%5B1%5D%3A%20systemd-networkd.socket%20-%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%20Netlink%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-netwo%20%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6%20-%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%20%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%20Netlink%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%80%82%3CBR%20%2F%3E%5B%204.557127%5D%20systemd%5B1%5D%3A%20systemd-udevd-control.socket%20-%20udev%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-udevd%E2%80%A6%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99-%20udev%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%80%82%3CBR%20%2F%3E%5B%204.584722%5D%20systemd%5B1%5D%3A%20systemd-udevd-kernel.socket%20-%20udev%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-udevd%E2%80%A6l.socket%20%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99-%20udev%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%80%82%3CBR%20%2F%3E%5B%204.624665%5D%20systemd%5B1%5D%3A%20dev-hugepages.mount%20%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20Huge%20Pages%20File%20System...%3CBR%20%2F%3E%20dev-hugepages.mount%20%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20Huge%20Pages%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0...%3CBR%20%2F%3E%20%5B%204.651859%5D%20systemd%5B1%5D%3A%20dev-mqueue.mount%20-%20POSIX%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%AD%E3%83%A5%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20dev-mqueue.mount%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%96%92%E2%96%92POSIX%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%AD%E3%83%A5%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0...%3CBR%20%2F%3E%20%5B%204.680049%5D%20systemd%5B1%5D%3A%20sys-kernel-debug.mount%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20sys-kernel-debug.%E2%80%A6%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20%5B%204.709270%5D%20systemd%5B1%5D%3A%20sys-kernel-tracing.mount%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E3%80%81%E6%9D%A1%E4%BB%B6%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%8C%E6%BA%80%E3%81%9F%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(ConditionPathExists%3D%2Fsys%2Fkernel%2Ftracing)%E3%80%82%3CBR%20%2F%3E%5B%204.724518%5D%20systemd%5B1%5D%3A%20kmod-static-nodes.service%20-%20%E6%9D%A1%E4%BB%B6%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%8C%E6%BA%80%E3%81%9F%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E9%9D%99%E7%9A%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%8C%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(ConditionFileNotEmpty%3D%2Flib%2Fmodules%2F6.6.52-rt43-gd377c9049508-dirty%2Fmodules.devname)%E3%80%82%3CBR%20%2F%3E%5B%204.757545%5D%20systemd%5B1%5D%3A%20modprobe%40configfs.service%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20configfs%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20modprobe%40configfs%E2%80%A6m%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20configfs%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20%5B%204.788352%5D%20systemd%5B1%5D%3A%20modprobe%40dm_mod.service%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20dm_mod%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20modprobe%40dm_mod.s%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6%5B0m-%20%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%ABdm_mod...%3CBR%20%2F%3E%5B%204.816731%5D%20systemd%5B1%5D%3A%20modprobe%40drm.service%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%ABDRM%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E9%96%8B%E5%A7%8B...%3CBR%20%2F%3Emodprobe%40drm.service%20%E9%96%8B%E5%A7%8B%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%ABDRM%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89...%3CBR%20%2F%3E%5B%204.848481%5D%20systemd%5B1%5D%3A%20modprobe%40efi_pstore.service%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%ABefi_pstore%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89...%3CBR%20%2F%3Emodprobe%40efi_psto%E9%96%8B%E5%A7%8B...-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%ABefi_pstore%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89...%3CBR%20%2F%3E%5B%204.876748%5D%20systemd%5B1%5D%3A%20modprobe%40fuse.service%20%E9%96%8B%E5%A7%8B%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89...%3CBR%20%2F%3Emodprobe%40fuse%E3%80%81%E5%A7%8B%E3%82%81%E3%81%A6...e%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89...%3CBR%20%2F%3E%5B%204.904963%5D%20systemd%5B1%5D%3A%20modprobe%40loop.service%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E9%96%8B%E5%A7%8B...%3CBR%20%2F%3Emodprobe%40loop.ser%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%A6...e%20-%20%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%AB%E3%83%BC%E3%83%97...%3CBR%20%2F%3E%5B%204.928580%5D%20systemd%5B1%5D%3A%20systemd-fsck-root.service%20-%20%E3%83%AB%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%8A%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%AF%E6%9D%A1%E4%BB%B6%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%8C%E6%BA%80%E3%81%9F%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F(ConditionPathIsReadWrite%3D!%2F)%E3%80%82%3CBR%20%2F%3E%5B%204.968886%5D%20systemd%5B1%5D%3A%20systemd-journald.service%20-%20%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9...%3CBR%20%2F%3Esystemd-journald.service%20-%20%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9...%3CBR%20%2F%3E%5B%205.004486%5D%20systemd%5B1%5D%3A%20systemd-modules-load.service%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%3CBR%20%2F%3Esystemd-modules-l...rvice%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89...%3CBR%20%2F%3E%5B%205.031531%5D%20systemd%5B1%5D%3A%20systemd-network-generator.service%20%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8B%E3%82%89%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%82%92%E7%94%9F%E6%88%90...%3CBR%20%2F%3Esystemd-network-g%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88...%3CBR%20%2F%3E%5B%205.084818%5D%20systemd%5B1%5D%3A%20systemd-remount-fs.service%20-%20%E3%83%AB%E3%83%BC%E3%83%88%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E5%86%8D%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B...%3CBR%20%2F%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%89%E3%83%AA%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E9%96%8B%E5%A7%8B%E4%B8%AD...%E3%83%AB%E3%83%BC%E3%83%88%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0...%3CBR%20%2F%3E%5B%205.115743%5D%20systemd%5B1%5D%3A%20systemd-udev-trigger.service%20-%20%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%89%E3%83%97%E3%83%A9%E3%82%B0%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEudev%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9...%3CBR%20%2F%3Esystemd-udev-trig%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%5B0m%20-%20%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%89%E3%83%97%E3%83%A9%E3%82%B0%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEudev%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9...%3CBR%20%2F%3E%5B%205.136505%5D%20EXT4-fs(MMCBLK2P3)%3A%E5%86%8D%E8%A3%85%E7%9D%80%20057D8DE8-A7E7-4440-9FEA-C9670C0C5DF9%20R%2FW%E3%80%82%E3%82%AF%E3%82%A9%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%BC%E3%83%89%EF%BC%9A%E3%81%AA%E3%81%97%E3%80%82%3CBR%20%2F%3E%5B%205.153130%5D%20systemd%5B1%5D%3A%20systemd-journald.service%20-%20%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-journald.service%20-%20%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20dev-hugepages.mount%20-%20Huge%20Pages%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20dev-mqueue.mount%20%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E2%96%92%E2%96%92-POSIX%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%AD%E3%83%A5%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9Fsys-kernel-debug.m...nt%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20modprobe%40configfs%20%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E2%80%A6%5B0m%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20configfs%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20modprobe%40dm_mod.s%E2%80%A6e%20%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20dm_mod%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20modprobe%40drm.service%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20drm%20%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20%5B%20OK%20%5D%20modprobe%40efi_psto%E2%80%A6m%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20efi_pstore%20%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20modprobe%40fuse.service%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20fuse%20%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20modprobe%40loop.service%20-%20Load%20Kernel%20Module%20loop%20%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-modules-l%E2%80%A6service%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8B%E3%82%89%20systemd-network-g%E2%80%A6rk%20%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%AE%E5%87%A6%E7%90%86%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-remount-f%E2%80%A6%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A8%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20network-pre%E2%80%A6get%20%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E6%BA%96%E5%82%99%E3%80%82%3CBR%20%2F%3Esys-kernel-config%E2%80%A6%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6%3CBR%20%2F%3E%20systemd-journal-f%E2%80%A6h%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%92%E6%B0%B8%E7%B6%9A%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6%3CBR%20%2F%3E%20%5B%205.501074%5D%20systemd-journald%5B137%5D%3A%20%E3%83%A9%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E8%A6%81%E6%B1%82%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Esystemd-random-se%E2%80%A6ice%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20%E4%B9%B1%E6%95%B0%E3%82%B7%E3%83%BC%E3%83%89%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%2F%E4%BF%9D%E5%AD%98...%3CBR%20%2F%3E%20systemd-sysctl.se%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6ce-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E5%A4%89%E6%95%B0%E3%81%AE%E9%81%A9%E7%94%A8...%3CBR%20%2F%3Esystemd-sysuser%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99...rvice%20-%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AE%E4%BD%9C%E6%88%90...%3CBR%20%2F%3E%5B%20OK%20%5Dsystemd-udev-trig%E3%82%92%E7%B5%82%E3%81%88%E3%81%9F...e%20-%20Coldplug%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEudev%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20sys-kernel-config%20%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-journal-f%E2%80%A6%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%92%E6%B0%B8%E7%B6%9A%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E5%87%A6%E7%90%86%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-sysctl.service%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E5%A4%89%E6%95%B0%E3%81%AE%E9%81%A9%E7%94%A8%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Eifupdown-pre.serv%20%E3%81%AE%E5%90%8C%E6%9C%9F%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6IF%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E4%B8%8A%E4%B8%8B...%3CBR%20%2F%3E%5B%20OK%20%5Dsystemd-sysusers.service%20-%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E4%BD%9C%E6%88%90%E3%82%92%E5%AE%8C%E4%BA%86%E3%80%82%3CBR%20%2F%3Esystemd-tmpfiles-%E2%80%A6ate%20%E3%81%AE%20%2Fdev%20%E5%86%85%E3%81%AE%E9%9D%99%E7%9A%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20%5B%20OK%20%5D%20systemd-tmpfiles-%E2%80%A6%2Fdev%20%E3%81%AB%E9%9D%99%E7%9A%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%87%A6%E7%90%86%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E4%BF%AE%E5%BE%A9%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20local-fs-pr%20%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20local-fs.target%20-%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Esystemd-tmp%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E8%B5%B7%E5%8B%95%E4%B8%AD-...%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA...%3CBR%20%2F%3E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E4%B8%ADsystemd-udevd.ser...%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%81%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AEger...%3CBR%20%2F%3E%5B%20OK%20%5Dsystemd-tmp%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F-...eate%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8A%E3%82%88%E3%81%B3%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%80%82%3CBR%20%2F%3Esystemd-timesyncd%E9%96%8B%E5%A7%8B%E4%B8%AD...%20-%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E6%99%82%E9%96%93%E5%90%8C%E6%9C%9F...%3CBR%20%2F%3Esystemd-update-ut%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...UTMP%E3%81%A7%E3%81%AERD%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%96%E3%83%BC%E3%83%88%2F%E3%82%B7%E3%83%A3%E3%83%83%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3...%3CBR%20%2F%3E%5B%20OK%20%5Dsystemd-update-ut...UTMP%E3%81%A7%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E8%B5%B7%E5%8B%95%2F%E3%82%B7%E3%83%A3%E3%83%83%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5Dsystemd-udevd.serv%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F...%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%84%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%80%82%3CBR%20%2F%3Esystemd-networkd.ice%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E8%A8%AD%E5%AE%9A...%3CBR%20%2F%3E%20%5B%20OK%20%5D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20dev-ttymxc1.device%20-%20%2Fdev%2Fttymxc1%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-timesyncd%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E2%80%A60m%20-%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E6%99%82%E5%88%BB%E5%90%8C%E6%9C%9F%E3%80%82%3CBR%20%2F%3E%20%5B%20OK%20%5D%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20sysinit.target%20-%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-tmpfiles-c%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E2%80%A6%20%E4%B8%80%E6%99%82%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AE%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E7%9B%AE%E6%A8%99%E6%99%82%E5%88%BB%20time-set.target%20%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E6%99%82%E5%88%BB%E8%A8%AD%E5%AE%9A%E3%80%82%3CBR%20%2F%3E%20%5B%20OK%20%5D%20apt-daily.timer%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E6%AF%8E%E6%97%A5%E3%81%AE%20apt%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%80%82%3CBR%20%2F%3E%5BOK%5D%20apt-daily-upgrade%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E9%81%A9%E5%88%87%E3%81%AA%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%A8%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%AA%E6%B4%BB%E5%8B%95%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20dpkg-db-backup.tim%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E2%80%A6dpkg%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%87%E3%82%A4%E3%83%AA%E3%83%BC%E3%83%90%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20e2scrub_all.timer%E2%96%92%E2%96%92etadata%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20fstrim.timer%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E9%80%B1%E3%81%AB%E4%B8%80%E5%BA%A6%E7%A0%B4%E6%A3%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20logrotate.timer%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E6%AF%8E%E6%97%A5%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20man-db.timer%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20man-db%20%E3%81%AE%E6%AF%8E%E6%97%A5%E3%81%AE%E5%86%8D%E7%94%9F%E6%88%90%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20sysstat-collect.ti%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E2%80%A6%E4%BC%9A%E8%A8%88%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF10%E5%88%86%E3%81%94%E3%81%A8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20sysstat-summary.ti%E2%80%A6%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E6%98%A8%E6%97%A5%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E4%BC%9A%E8%A8%88%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E7%9B%AE%E6%A8%99%E3%81%AE%20timers.target%20-%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20dbus.socket%E2%96%92%E2%96%92%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E4%B8%ADD-Bus%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%82%B9%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%5B%206.421751%5D%20cfg80211%3A%20regulatory.db%20%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Et%20sockets.target%20-%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20basic.target%20-%20%E5%9F%BA%E6%9C%AC%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20Started%20cron.service%20-%E2%80%A6kground%20program%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%20daemon.%3CBR%20%2F%3Edbus.service%20-%20D-Bus%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%82%B9%E9%96%8B%E5%A7%8B%E4%B8%AD...%3CBR%20%2F%3E%5B%206.524255%5D%20IMX-SDMA%2030BD0000.DMA-%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%3Aimx%2Fsdma%2Fsdma-imx7d.bin%20%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E7%9B%B4%E6%8E%A5%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-2%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLOCALHOST%3E%3C%2FP%3E%3CP%3E%5B%206.537384%5D%20IMX-SDMA%2030BD0000.DMA-%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%3Asysfs%E3%81%B8%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%3Aimx%2Fsdma%2Fsdma-imx7d.bin%3CBR%20%2F%3E%5B%20OK%20%5Dfirmwared.service%20-%20Linux%20Firmware%20Loader%20Daemon%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%206.563260%5D%20IMX-SDMA%2030BD0000.DMA-%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%3A%E5%A4%96%E9%83%A8%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82ROM%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20kexec-load.servic%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6B%3Akexec...%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3Elm-%E3%82%BB%E3%83%B3%E3%82%B5.servic%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...ize%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%81%E3%82%BB%E3%83%B3%E3%82%B5...%3CBR%20%2F%3Eplatcfg.service%20%E9%96%8B%E5%A7%8B%E4%B8%AD%E2%96%92%E2%96%92r%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AANXP%20i.MX%2FLS%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0...%3CBR%20%2F%3E%5B%20OK%20%5D%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%9Fseatd.service%20-%20%E3%82%B7%E3%83%BC%E3%83%88%E7%AE%A1%E7%90%86%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20strongswan-starter%E2%80%A6Ev1%2FIKEv2%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%82%92ipsec.conf%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Esysstat.service%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%83%AD%E3%82%B0%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20systemd-logind.se%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6ice-%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%83%9E%E3%83%8D%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88...%3CBR%20%2F%3E%5B%20OK%20%5D%20Started%20systemd-networkd.service%20-%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5Dupup-down.serv...ifupdown%20%E3%81%AE%E8%B5%B7%E5%8B%95%E3%82%92%E5%90%8C%E6%9C%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20e2scrub_reap.serv%E2%80%A6ine%20%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9Fext4%E3%83%A1%E3%82%BF%E3%83%87%E3%83%BC%E3%82%BF%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B9%E3%83%8A%E3%83%83%E3%83%97%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5Dsysstat.service%20%E3%82%92%E5%AE%8C%E4%BA%86%20-%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%83%AD%E3%82%B0%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5Dlm-%E3%82%BB%E3%83%B3%E3%82%B5.servic%E3%82%92%E7%B5%82%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F...%E3%82%A2%E3%83%A9%E3%82%A4%E3%82%BC%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E7%9B%A3%E8%A6%96%E3%82%BB%E3%83%B3%E3%82%B5%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20kexec-load.service%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E2%80%A6LSB%3Akexec%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20dev-mmcblk2p1.device%20-%20%2Fdev%2Fmmcblk2p1%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%20usb-gadget%20%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82-%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8BUSB%E3%82%AC%E3%82%B8%E3%82%A7%E3%83%83%E3%83%88%E3%80%82%3CBR%20%2F%3Enetworking.service%20%E8%B5%B7%E5%8B%95%E4%B8%AD%20-%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E8%B5%B7%E5%8B%95...%3CBR%20%2F%3Esystemd-fsck%40dev-...%E9%96%8B%E5%A7%8B%2Fdev%2Fmmcblk2p1%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF...%3CBR%20%2F%3E%5B%20OK%20%5Dsystemd-fsckd.serv%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F...%E3%83%86%E3%83%A0%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%81%AE%E7%8A%B6%E6%85%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%2Fdev%2Fmmcblk2p1%20%E3%81%AE%20systemd-fsck%40dev-%E2%80%A6le%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%207.297245%5D%20imx-dwmac%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20eth0%3A%20Register%20MEM_TYPE_PAGE_POOL%20RxQ-0%3CBR%20%2F%3E%5B%207.305583%5D%20imx-dwmac%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20eth0%3A%20%E3%82%BB%E3%83%BC%E3%83%95%E3%83%86%E3%82%A3%E6%A9%9F%E8%83%BD%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AA%E3%81%97%3CBR%20%2F%3E%5B%207.312850%5D%20imx-dwmac%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20eth0%3A%20IEEE%201588-2008%20Advanced%20Timestamp%20supported%3CBR%20%2F%3EMounting%20boot.mount%20-%20%2Fboot...%3CBR%20%2F%3E%5B%207.324878%5D%20imx-dwmac%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20eth0%3A%20registered%20PTP%20clock%3CBR%20%2F%3E%5B%207.336555%5D%20imx-dwmac%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20eth0%3A%20FPE%20workqueue%20start%3CBR%20%2F%3E%5B%207.343570%5D%20imx-dwmac%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20eth0%3A%20configuring%20for%20fixed%2Frgmii-id%20link%20mode%3CBR%20%2F%3E%5B%207.353100%5D%20imx-dwmac%2030bf0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20eth0%3A%20Link%20is%20Up%20-%201Gbps%2FFull%20-%20flow%20control%20off%3CBR%20%2F%3E%5B%207.353244%5D%20EXT4-fs%20(mmcblk2p1)%3A%20mounted%20filesystem%2045d36d6d-da2c-4fa0-ae4f-46086176bf89%20r%2Fw%20with%20ordered%20data%20mode.%20%E3%82%AF%E3%82%A9%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%BC%E3%83%89%EF%BC%9A%E3%81%AA%E3%81%97%E3%80%82%3CBR%20%2F%3E%5B%207.354853%5D%208021q%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9eth0%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%81%ABVLAN%200%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E%5B%20OK%20%5D%20boot.mount%20-%20%2Fboot%20%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%207.484902%20Realtek-MDIO%20STMMAC-1%3A00%20ETH1%3A%20PHY%2FGMII%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3E%5B%207.499221%5D%208021q%3A%20eth1%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%8A%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%E3%81%ABVLAN%200%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%207.722835%5D%20Realtek-MDIO%20STMMAC-1%3A00%20ETH2%3A%20PHY%2FGMII%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3E%5B%207.758421%5D%208021q%3A%20eth2%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%8A%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%E3%81%ABVLAN%200%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%20OK%20%5Dnetworking.service%20%E3%82%92%E5%AE%8C%E4%BA%86%20-%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%B8%8A%E3%81%92%E3%82%8B%E3%80%82%3CBR%20%2F%3E%5B%207.988116%5D%20%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%3ACRNG%20init%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%5B%20OK%20%5Dsystemd-random-se%E3%82%92%E7%B5%82%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F...rvice%20-%20%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%82%B7%E3%83%BC%E3%83%89%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%2F%E3%82%BB%E3%83%BC%E3%83%96%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5Ddbus.service%20-%20D-Bus%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%82%B9%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Ewpa_supplicant.service%20%E9%96%8B%E5%A7%8B%20-%20WPA%E3%81%AE%E8%AB%8B%E9%A1%98%E8%80%85...%3CBR%20%2F%3E%5B%20OK%20%5Dsystemd-logind.service%20-%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%20%E3%83%9E%E3%83%8D%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5Dwpa_supplicant.service%E3%82%92%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%81%9F%20-%20WPA%E3%81%AE%E8%AB%8B%E6%B1%82%E8%80%85%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%E7%9B%AE%E6%A8%99%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20network.target%20-%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%80%82%3CBR%20%2F%3Emosquitto.service%20-%20Mosquitto%20MQTT%20Broker%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%3CBR%20%2F%3Essh.service%20-%20OpenBSD%20Secure%20Shell%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%3CBR%20%2F%3EStarting%20systemd-hostnamed.service%20-%20Hostname%20Service...%3CBR%20%2F%3Esystemd-user-sess%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...vice%20-%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A8%B1%E5%8F%AF...%3CBR%20%2F%3E%5B%20OK%20%5Dsystemd-user-sess%E3%82%92%E7%B5%82%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F...ervice%20-%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A8%B1%E5%8F%AF%E3%81%99%E3%82%8B%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20getty%40tty1.service%20-%20Getty%20on%20tty1%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20serial-getty%40ttymx%E2%80%A6ice%20-%20Serial%20Getty%20%E3%82%92%20ttymxc1%20%E3%81%A7%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20getty.target%20-%20%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-hostnamed.service%20-%20%E3%83%9B%E3%82%B9%E3%83%88%E5%90%8D%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20ssh.service%20-%20OpenBSD%20Secure%20Shell%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20mosquitto.service%20-%20Mosquitto%20MQTT%20%E3%83%96%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%BC%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20multi-user.target%20-%20%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20graphical.target%20-%20%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%82%AB%E3%83%AB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%80%82%3CBR%20%2F%3Esystemd-update-ut%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6%20UTMP%20%E3%81%A7%E3%83%A9%E3%83%B3%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E8%A8%98%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%99%E2%80%A6%3CBR%20%2F%3E%20%5B%20OK%20%5D%20platcfg.service%E2%96%92%E2%96%92%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AANXP%20i.MX%2FLS%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20systemd-update-ut%20%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E2%80%A6%20-%20UTMP%20%E3%81%A7%E3%83%A9%E3%83%B3%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E8%A8%98%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EDebian%20GNU%2FLinux%2012%20imx8mpevk%20ttymxc1%3C%2FP%3E%3CP%3ENXP%20Linux%20SDK%202506%20Debian%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC(NXP%E7%89%B9%E6%9C%89%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E6%9C%80%E9%81%A9%E5%8C%96)%3CBR%20%2F%3Eimx8mpevk%20login%3A%20root%3CBR%20%2F%3E%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%3A%3CBR%20%2F%3ELinux%20imx8mpevk%206.6.52-rt43-gd377c9049508-dirty%231%20SMP%20PREEMPT%202026%E5%B9%B47%E6%9C%882%E6%97%A5(%E6%9C%A8)%2011%3A19%3A58%20CST%20aarch64%3C%2FP%3E%3CP%3EDebian%20GNU%2FLinux%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%3CBR%20%2F%3E%E5%90%84%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%E6%AD%A3%E7%A2%BA%E3%81%AA%E5%88%86%E5%B8%83%E9%A0%85%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%2Fusr%2Fshare%2Fdoc%2F*%2Fcopyright%20%E3%81%AE%E5%80%8B%E5%88%A5%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3EDebian%20GNU%2FLinux%E3%81%AB%E3%81%AF%E3%80%81%E4%BF%9D%E8%A8%BC%E3%81%8C%E5%85%A8%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E9%81%A9%E7%94%A8%E6%B3%95%E3%81%A7%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%80%82%3CBR%20%2F%3Eroot%40imx8mpevk%3A~%23%3CBR%20%2F%3E%20root%40imx8mpevk%3A~%23%20modprobe%20moal%20mod_para%3Dnxp%2Fwifi_mod_para.conf%3CBR%20%2F%3E%5B%2027.658951%5D%20mlan%3A%20%E3%83%84%E3%83%AA%E3%83%BC%E5%A4%96%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AB%E3%82%88%E3%82%8A%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%8C%E6%B1%9A%E6%9F%93%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%2027.688908%5D%20wlan%3A%20MWLAN%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%3CBR%20%2F%3E%5B%2027.693279%5D%20WLAN%3A%20%E3%83%90%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%B8%E7%99%BB%E9%8C%B2...%3CBR%20%2F%3E%5B%2027.697621%5D%20vendor%3D0x02DF%20device%3D0x9149%20class%3D0%20function%3D1%3CBR%20%2F%3E%5B%2027.703270%5D%20%E3%83%A2%E3%82%A2%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%E6%93%8D%E4%BD%9C%E3%82%92%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%81%A6%E3%80%81%E3%82%AB%E3%83%BC%E3%83%89%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%97%3A0x105%3CBR%20%2F%3E%5B%2027.709133%5D%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8B%E3%82%89RPS%E3%82%920%E3%81%AB%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3E%5B%2027.713466%5D%20SD8987%3A%20usr%20cfg%20%E3%81%8B%E3%82%89%E3%81%AE%20init%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%3CBR%20%2F%3E%5B%2027.718305%20%5D%20card_type%3A%20SD8987%E3%80%81%E8%A8%AD%E5%AE%9A%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%3A%200%3CBR%20%2F%3E%5B%2027.722765%5D%20cfg80211_wext%3D0xf%3CBR%20%2F%3E%5B%2027.725757%5D%20max_vir_bss%3D1%3CBR%20%2F%3E%5B%2027.728391%5D%20cal_data_cfg%3D%E3%81%AA%E3%81%97%3CBR%20%2F%3E%5B%2027.731362%20ps_mode%20%3D%201%3CBR%20%2F%3E%5B%2027.733821%20auto_ds%20%3D%201%3CBR%20%2F%3E%5B%2027.736295%5D%20host_mlme%3Denable%3CBR%20%2F%3E%5B%2027.739186%5D%20fw_name%3DNXP%2Fsdiouart8987_combo_v0.bin%3CBR%20%2F%3E%5B%2027.743918%5D%20SDIO%3A%20max_segs%3D128%20max_seg_size%3D65535%3CBR%20%2F%3E%20%5B%2027.748647%5D%20rx_work%3D1%20cpu_num%3D4%3CBR%20%2F%3E%20%5B%2027.751795%5D%20moal_recv_amsdu_packet%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%2027.755832%5D%20MLAN%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E6%93%8D%E4%BD%9C%E3%82%92%E3%82%A2%E3%82%BF%E3%83%83%E3%83%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82card_type%E3%81%AF0x105%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%2027.762044%5D%20wlan%3A%20TX%20SG%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%2027.765551%5D%20wlan%3A%20RX%20SG%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%2027.776176%5D%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%3A%20nxp%2Fsdiouart8987_combo_v0.bin%3CBR%20%2F%3E%20%5B%2028.073628%5D%20Wlan%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E9%95%B7%E3%81%95%3D626584%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E6%B8%88%E3%81%BF617556%3CBR%20%2F%3E%20%5B%2028.944747%5D%20WLAN%20FW%20%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%A7%E3%81%99%3CBR%20%2F%3E%5B%2028.947734%5D%20on_time%20%E3%81%AF%2028943658375%20%E3%81%A7%E3%81%99%3CBR%20%2F%3E%5B%2029.003401%5D%20VDLL%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3A%20%E9%95%B7%E3%81%95%3D9028%3CBR%20%2F%3E%20%5B29.006743%5D%20FW%E3%81%AE%E5%9B%BD%E3%82%B3%E3%83%BC%E3%83%89WW%E3%81%AFUS%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B%2029.012026%5D%20fw_cap_info%3D0x181d6f03%E3%80%81dev_cap_mask%3D0xffffffff%3CBR%20%2F%3E%20%5B%2029.017672%5D%20max_p2p_conn%20%3D%208%E3%80%81max_sta_conn%20%3D%208%3CBR%20%2F%3E%20%5B%2029.022438%5D%20SDIO%20rx%20aggr%3A%201%20block_size%3D512%3CBR%20%2F%3E%20%5B%2029.026600%5D%20wlan%3A%20RX%20SG%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%2029.030117%5D%20mpa_rx_buf_size%3D65280%3CBR%20%2F%3E%20%5B%2029.054744%5D%20NXP%20802.11%E3%82%A2%E3%83%80%E3%83%97%E3%82%BFmlan0%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%5B%2029.061163%5D%20NXP%20802.11%E3%82%A2%E3%83%80%E3%83%97%E3%82%BFuap0%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%5B%2029.069437%5D%20NXP%20802.11%E3%82%A2%E3%83%80%E3%83%97%E3%82%BFwfd0%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%5B%2029.073887%5D%20wlan%3A%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20%3D%20SD8987----16.92.21.p142.3-MM6X16505.p4-GPL-(FP92)%3CBR%20%2F%3E%5B%2029.083234%5D%20wlan%3A%20%E3%83%90%E3%82%B9%E9%81%8B%E8%BB%A2%E6%89%8B%E3%81%B8%E3%81%AE%E7%99%BB%E9%8C%B2%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%5B%2029.088229%5D%20wlan%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%3CBR%20%2F%3Eroot%40imx8mpevk%3A~%23%20%5B%2029.430504%5D%20WLAN%3A%20mlan0%20%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E9%96%8B%E5%A7%8B%3CBR%20%2F%3E%5B%2033.741685%5D%20WLAN%3A%20%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E5%AE%8C%E4%BA%86%3A%20%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E6%B8%88%E3%81%BF%20AP%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3D6%3C%2FP%3E%3CP%3Eroot%40imx8mpevk%3A~%23%3CBR%20%2F%3E%20root%40imx8mpevk%3A~%23%20mod%5B%2038.754412%5D%20wlan%3A%20mlan0%20%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E9%96%8B%E5%A7%8B%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20btnxpuart%3CBR%20%2F%3E%20%5B%2043.549431%5D%20btnxpuart%20serial0-0%3A%20ipg%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E6%9C%89%E5%8A%B9%E3%80%81%E3%83%AC%E3%83%BC%E3%83%88%3D80000000%3CBR%20%2F%3E%20%5B%2043.555634%5D%20btnxpuart%20serial0-0%3A%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%94%E3%81%A8%E3%81%AE%E6%9C%89%E5%8A%B9%E3%80%81%E3%83%AC%E3%83%BC%E3%83%88%3D80000000%3CBR%20%2F%3E%20root%40imx8mpevk%3A~%23%20%5B%2043.743746%5D%20wlan%3A%20%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E5%AE%8C%E4%BA%86%3A%20%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%97%E3%81%9FAP%E6%95%B0%3D14%3CBR%20%2F%3E%20%5B%2044.580103%5D%20Bluetooth%3A%20hci0%3A%20FW%20%E3%81%AF%E6%97%A2%E3%81%AB%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%2046.628430%5D%20Bluetooth%3A%20hci0%3A%20%E3%82%AA%E3%83%9A%E3%82%B3%E3%83%BC%E3%83%89%200x0c03%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20-110%3CBR%20%2F%3E%20%5B%2048.756247%5D%20wlan%3A%20mlan0%20%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E9%96%8B%E5%A7%8B%3CBR%20%2F%3E%5B%2053.744943%5D%20wlan%3A%20%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E5%AE%8C%E4%BA%86%3A%20%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%97%E3%81%9FAP%E6%95%B0%3D16%3CBR%20%2F%3E%20%5B%2053.753462%5D%20wlan%3A%20%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E9%96%8B%E5%A7%8B%E3%81%AE%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Bluetooth%20on%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259019%22%20target%3D%22_blank%22%3E%40wanggg%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%8F%BE%E5%9C%A8%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B8MP%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%8E%A5%E7%B6%9A%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2391403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Bluetooth%20on%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2391403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F186613%22%20target%3D%22_blank%22%3E%40shaun_wu%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E6%97%A2%E3%81%AB%E7%89%B9%E5%AE%9A%E6%B8%88%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Bluetooth%20on%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259019%22%20target%3D%22_blank%22%3E%40wanggg%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%93%E3%81%A7%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B...%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
