Bluetooth on i.MX8MP
469 次查看
wanggg
Hello, Expert,
I am testing the AW-CM358SM on the IMX8MP. The WiFi is working successfully, but when I test Bluetooth on UART3, it shows an error. The error message is as follows. I have tried many methods but still have not succeeded. Do you have any ideas on how to fix it? I would greatly appreciate your help.
error log:
Bluetooth: hci0: FW already running.
[   46.628430] Bluetooth: hci0: Opcode 0x0c03 failed: -110
dts:
&uart3 { /* BT */
    pinctrl-names = "default";
    pinctrl-0 = <&pinctrl_uart3 &pinctrl_bt_ctrl>;
    assigned-clocks = <&clk IMX8MP_CLK_UART3>;
    assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_80M>;
    uart-has-rtscts;
    status = "okay";
    bluetooth {
        compatible = "nxp,88w8987-bt";
        device-wakeup-gpios = <&gpio2 10 GPIO_ACTIVE_HIGH>;
pinctrl_uart3: uart3grp {
    fsl,pins = <
        MX8MP_IOMUXC_ECSPI1_SCLK__UART3_DCE_RX 0x140
        MX8MP_IOMUXC_ECSPI1_MOSI__UART3_DCE_TX 0x140
        MX8MP_IOMUXC_ECSPI1_MISO__UART3_DCE_CTS 0x140
        MX8MP_IOMUXC_ECSPI1_SS0__UART3_DCE_RTS 0x140
pinctrl_bt_ctrl: btctrlgrp {
    fsl,pins = <
        MX8MP_IOMUXC_SD1_RESET_B__GPIO2_IO10 0x10 /* HOST_WAKE_BT */
        MX8MP_IOMUXC_SD1_STROBE__GPIO2_IO11 0x140 /* BT_HOST_WAKE */
wifi_mod_para.conf
SD8987 = {
    cfg80211_wext=0xf
    wfd_name=p2p
    max_vir_bss=1
    cal_data_cfg=none
    drv_mode=7
    ps_mode=2
    auto_ds=2
    fw_name=nxp/sdiouart8987_combo_v0.bin
Kernel log
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.6.52-rt43-gd377c9049508-dirty (root@fbdebian) (aarch64-linux-gnu-gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Thu Jul 2 11:19:58 CST 2026
[ 0.000000] KASLR disabled due to lack of seed
[ 0.000000] Machine model: G3 i.MX8MPlus EVK board
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: unable to setup CMA region
[ 0.000000] OF: reserved mem: node linux,cma compatible matching fail
[ 0.000000] OF: reserved mem: 0x0000000000900000..0x000000000096ffff (448 KiB) nomap non-reusable ocram@900000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000013fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000013fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000013fffffff]
[ 0.000000] cma: Reserved 8 MiB at 0x00000000ff800000 on node -1
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 20 pages/cpu s43368 r8192 d30360 u81920
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: console=ttymxc1,115200 root=PARTUUID=6a120481-03 rw rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fb800000-0x00000000ff800000] (64MB)
[ 0.000000] Memory: 4012020K/4194304K available (16192K kernel code, 1688K rwdata, 5064K rodata, 3520K init, 541K bss, 174092K reserved, 8192K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 160 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000000] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.000475] Console: colour dummy device 80x25
[ 0.000519] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.000528] pid_max: default: 32768 minimum: 301
[ 0.000602] LSM: initializing lsm=capability,integrity
[ 0.000695] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000711] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002173] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.002240] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.002415] rcu: Hierarchical SRCU implementation.
[ 0.002418] rcu: Max phase no-delay instances is 1000.
[ 0.004206] EFI services will not be available.
[ 0.004444] smp: Bringing up secondary CPUs ...
[ 0.004903] Detected VIPT I-cache on CPU1
[ 0.004964] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.005000] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.005523] Detected VIPT I-cache on CPU2
[ 0.005565] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.005585] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.006045] Detected VIPT I-cache on CPU3
[ 0.006083] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.006100] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.006165] smp: Brought up 1 node, 4 CPUs
[ 0.006173] SMP: Total of 4 processors activated.
[ 0.006177] CPU features: detected: 32-bit EL0 Support
[ 0.006181] CPU features: detected: CRC32 instructions
[ 0.006243] CPU: All CPU(s) started at EL2
[ 0.006246] alternatives: applying system-wide alternatives
[ 0.008002] devtmpfs: initialized
[ 0.016979] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.017001] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.017422] pinctrl core: initialized pinctrl subsystem
[ 0.020051] DMI not present or invalid.
[ 0.020689] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.022304] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.023375] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.024665] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.024748] audit: initializing netlink subsys (disabled)
[ 0.024932] audit: type=2000 audit(0.024:1): state=initialized audit_enabled=0 res=1
[ 0.025352] thermal_sys: Registered thermal governor 'step_wise'
[ 0.025356] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.025401] cpuidle: using governor menu
[ 0.025566] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.025647] ASID allocator initialised with 65536 entries
[ 0.026696] Serial: AMBA PL011 UART driver
[ 0.026763] imx mu driver is registered.
[ 0.026785] imx rpmsg driver is registered.
[ 0.032936] platform soc@0: Fixed dependency cycle(s) with /soc@0/bus@30000000/efuse@30350000/unique-id@8
[ 0.035120] platform 30330000.pinctrl: Fixed dependency cycle(s) with /soc@0/bus@30000000/pinctrl@30330000/hoggrp
[ 0.035566] imx8mp-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[ 0.036067] platform 30350000.efuse: Fixed dependency cycle(s) with /soc@0/bus@30000000/clock-controller@30380000
[ 0.037099] platform 30350000.efuse: Fixed dependency cycle(s) with /soc@0/bus@30000000/clock-controller@30380000
[ 0.049206] Modules: 25968 pages in range for non-PLT usage
[ 0.049215] Modules: 517488 pages in range for PLT usage
[ 0.049877] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.049884] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.049889] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.049892] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.049896] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.049902] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.049909] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.049912] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.052093] iommu: Default domain type: Translated
[ 0.052102] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.052394] SCSI subsystem initialized
[ 0.052679] usbcore: registered new interface driver usbfs
[ 0.052709] usbcore: registered new interface driver hub
[ 0.052742] usbcore: registered new device driver usb
[ 0.053603] pps_core: LinuxPPS API ver. 1 registered
[ 0.053607] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.053619] PTP clock support registered
[ 0.053886] EDAC MC: Ver: 3.0.0
[ 0.054304] scmi_core: SCMI protocol bus registered
[ 0.055327] Bluetooth: Core ver 2.22
[ 0.055356] NET: Registered PF_BLUETOOTH protocol family
[ 0.055361] Bluetooth: HCI device and connection manager initialized
[ 0.055370] Bluetooth: HCI socket layer initialized
[ 0.055375] Bluetooth: L2CAP socket layer initialized
[ 0.055387] Bluetooth: SCO socket layer initialized
[ 0.055707] vgaarb: loaded
[ 0.056088] clocksource: Switched to clocksource arch_sys_counter
[ 0.056287] VFS: Disk quotas dquot_6.6.0
[ 0.056396] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.063310] NET: Registered PF_INET protocol family
[ 0.063495] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.066275] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.066325] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.066337] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.066585] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.067521] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.067635] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.067720] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.067927] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.068373] RPC: Registered named UNIX socket transport module.
[ 0.068379] RPC: Registered udp transport module.
[ 0.068381] RPC: Registered tcp transport module.
[ 0.068384] RPC: Registered tcp-with-tls transport module.
[ 0.068386] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.069403] PCI: CLS 0 bytes, default 64
[ 0.070488] Initialise system trusted keyrings
[ 0.070625] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.070895] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.071096] NFS: Registering the id_resolver key type
[ 0.071116] Key type id_resolver registered
[ 0.071120] Key type id_legacy registered
[ 0.071137] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.071142] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.071159] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.071346] 9p: Installing v9fs 9p2000 file system support
[ 0.100048] jitterentropy: Initialization failed with host not compliant with requirements: 9
[ 0.100055] Key type asymmetric registered
[ 0.100059] Asymmetric key parser 'x509' registered
[ 0.100104] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.100110] io scheduler mq-deadline registered
[ 0.100114] io scheduler kyber registered
[ 0.100139] io scheduler bfq registered
[ 0.115771] imx-sdma 30bd0000.dma-controller: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2
[ 0.115787] imx-sdma 30bd0000.dma-controller: Falling back to sysfs fallback for: imx/sdma/sdma-imx7d.bin
[ 0.117292] mxs-dma 33000000.dma-apbh: initialized
[ 0.118069] SoC: i.MX8MP revision 1.1
[ 0.118477] Bus freq driver module loaded
[ 0.135536] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.138454] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 16, base_baud = 5000000) is a IMX
[ 0.138703] serial serial0: tty port ttymxc2 registered
[ 0.139315] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 17, base_baud = 1500000) is a IMX
[ 0.139350] printk: legacy console [ttymxc1] enabled
[ 1.222791] loop: module loaded
[ 1.227149] of_reserved_mem_lookup() returned NULL
[ 1.237919] tun: Universal TUN/TAP device driver, 1.6
[ 1.244863] sky2: driver version 1.30
[ 1.249061] usbcore: registered new device driver r8152-cfgselector
[ 1.255367] usbcore: registered new interface driver r8152
[ 1.261230] VFIO - User Level meta-driver version: 0.3
[ 1.271293] usbcore: registered new interface driver uas
[ 1.276669] usbcore: registered new interface driver usb-storage
[ 1.282753] usbcore: registered new interface driver usbserial_generic
[ 1.289312] usbserial: USB Serial support registered for generic
[ 1.295346] usbcore: registered new interface driver ftdi_sio
[ 1.301121] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.308467] usbcore: registered new interface driver usb_serial_simple
[ 1.315022] usbserial: USB Serial support registered for carelink
[ 1.321145] usbserial: USB Serial support registered for flashloader
[ 1.327526] usbserial: USB Serial support registered for funsoft
[ 1.333554] usbserial: USB Serial support registered for google
[ 1.339503] usbserial: USB Serial support registered for hp4x
[ 1.345284] usbserial: USB Serial support registered for kaufmann
[ 1.351402] usbserial: USB Serial support registered for libtransistor
[ 1.357961] usbserial: USB Serial support registered for moto_modem
[ 1.364256] usbserial: USB Serial support registered for motorola_tetra
[ 1.370900] usbserial: USB Serial support registered for nokia
[ 1.376765] usbserial: USB Serial support registered for novatel_gps
[ 1.383149] usbserial: USB Serial support registered for siemens_mpi
[ 1.389527] usbserial: USB Serial support registered for suunto
[ 1.395476] usbserial: USB Serial support registered for vivopay
[ 1.401511] usbserial: USB Serial support registered for zio
[ 1.407203] usbcore: registered new interface driver usb_ehset_test
[ 1.413528] usbcore: registered new device driver onboard-usb-hub
[ 1.422006] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc0
[ 1.428227] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01T00:00:00 UTC (0)
[ 1.437427] i2c_dev: i2c /dev entries driver
[ 1.445729] Bluetooth: HCI UART driver ver 2.3
[ 1.450203] Bluetooth: HCI UART protocol H4 registered
[ 1.455351] Bluetooth: HCI UART protocol BCSP registered
[ 1.460695] Bluetooth: HCI UART protocol LL registered
[ 1.465847] Bluetooth: HCI UART protocol ATH3K registered
[ 1.471280] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 1.477642] Bluetooth: HCI UART protocol Broadcom registered
[ 1.483333] Bluetooth: HCI UART protocol QCA registered
[ 1.488739] EDAC MC: ECC not enabled
[ 1.493561] sdhci: Secure Digital Host Controller Interface driver
[ 1.499762] sdhci: Copyright(c) Pierre Ossman
[ 1.504580] Synopsys Designware Multimedia Card Interface Driver
[ 1.511193] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.519372] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.526326] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 1.535249] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.545746] platform soc@0: Fixed dependency cycle(s) with /soc@0/bus@30000000/efuse@30350000
[ 1.548948] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[ 1.555377] optee: probing for conduit method.
[ 1.565851] optee: api uid mismatch
[ 1.569678] optee: probe of firmware:optee failed with error -22
[ 1.576620] NET: Registered PF_LLC protocol family
[ 1.581492] u32 classifier
[ 1.584247] input device check on
[ 1.587910] Actions configured
[ 1.591634] NET: Registered PF_INET6 protocol family
[ 1.598148] Segment Routing with IPv6
[ 1.601891] In-situ OAM (IOAM) with IPv6
[ 1.605875] NET: Registered PF_PACKET protocol family
[ 1.610955] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.625927] Bluetooth: RFCOMM TTY layer initialized
[ 1.630834] Bluetooth: RFCOMM socket layer initialized
[ 1.634392] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[ 1.636001] Bluetooth: RFCOMM ver 1.11
[ 1.642888] mmcblk2: mmc2:0001 064G90 58.2 GiB
[ 1.646098] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.653585] mmcblk2: p1 p2 p3
[ 1.655851] Bluetooth: BNEP filters: protocol multicast
[ 1.661320] mmcblk2boot0: mmc2:0001 064G90 8.00 MiB
[ 1.664139] Bluetooth: BNEP socket layer initialized
[ 1.670589] mmcblk2boot1: mmc2:0001 064G90 8.00 MiB
[ 1.674997] 8021q: 802.1Q VLAN Support v1.8
[ 1.680430] mmcblk2rpmb: mmc2:0001 064G90 16.0 MiB, chardev (238:0)
[ 1.683109] lib80211: common routines for IEEE802.11 drivers
[ 1.695071] 9pnet: Installing 9P2000 support
[ 1.699490] Key type dns_resolver registered
[ 1.704490] NET: Registered PF_VSOCK protocol family
[ 1.719723] registered taskstats version 1
[ 1.723967] Loading compiled-in X.509 certificates
[ 1.751680] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.762305] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.772790] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.783311] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.793861] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.806692] i2c i2c-0: IMX I2C adapter registered
[ 1.813480] rtc-rx8111 2-0032: registered as rtc1
[ 1.820041] ina238 2-0043: power monitor ina237 (Rshunt = 50000 uOhm, gain = 4)
[ 1.821839] nxp-pca9450 0-0025: pca9450bc probed.
[ 1.827481] i2c i2c-2: IMX I2C adapter registered
[ 1.869694] usb251xb 3-002c: Hub configuration was successful.
[ 1.875553] usb251xb 3-002c: Hub probed successfully
[ 1.880583] i2c i2c-3: IMX I2C adapter registered
[ 1.885922] imx8mq-usb-phy 381f0040.usb-phy: supply vbus not found, using dummy regulator
[ 1.894643] imx8mq-usb-phy 382f0040.usb-phy: supply vbus not found, using dummy regulator
[ 1.912708] 30a60000.serial: ttymxc3 at MMIO 0x30a60000 (irq = 199, base_baud = 1500000) is a IMX
[ 1.922917] imx-dwmac 30bf0000.ethernet: IRQ eth_lpi not found
[ 1.929740] imx-dwmac 30bf0000.ethernet: User ID: 0x10, Synopsys ID: 0x51
[ 1.936555] imx-dwmac 30bf0000.ethernet: DWMAC4/5
[ 1.941361] imx-dwmac 30bf0000.ethernet: DMA HW capability register supported
[ 1.948509] imx-dwmac 30bf0000.ethernet: RX Checksum Offload Engine supported
[ 1.955650] imx-dwmac 30bf0000.ethernet: TX Checksum insertion supported
[ 1.962359] imx-dwmac 30bf0000.ethernet: Wake-Up On Lan supported
[ 1.968520] imx-dwmac 30bf0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.976199] imx-dwmac 30bf0000.ethernet: device MAC address 2a:c5:99:84:66:bb
[ 1.983350] imx-dwmac 30bf0000.ethernet: Enabled L3L4 Flow TC (entries=8)
[ 1.990152] imx-dwmac 30bf0000.ethernet: Enabled RFS Flow TC (entries=10)
[ 1.996965] imx-dwmac 30bf0000.ethernet: Enabling HW TC (entries=256, max_off=256)
[ 2.004554] imx-dwmac 30bf0000.ethernet: Using 34/40 bits DMA host/device width
[ 2.158192] realtek-mdio stmmac-1:00: found an RTL8363NB switch
[ 2.164168] realtek-mdio stmmac-1:00: unable to register switch ret = -517
[ 2.175037] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 2.180572] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 2.188568] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe6d hci version 0x110 quirks 0x000000a001000010
[ 2.198006] xhci-hcd xhci-hcd.1.auto: irq 203, io mem 0x38200000
[ 2.204153] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 2.209668] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 2.217339] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 2.226380] hub 1-0:1.0: USB hub found
[ 2.230477] hub 1-0:1.0: 1 port detected
[ 2.236611] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.246489] hub 2-0:1.0: USB hub found
[ 2.250581] hub 2-0:1.0: 1 port detected
[ 2.256296] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 5 mkt segment 0 supported-hw 0x20 0x1
[ 2.268964] sdhci-esdhc-imx 30b40000.mmc: allocated mmc-pwrseq
[ 2.269069] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
[ 2.313534] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[ 2.413613] mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA
[ 2.414283] realtek-mdio stmmac-1:00: found an RTL8363NB switch
[ 2.492421] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 2.540131] mmc0: new ultra high speed SDR104 SDIO card at address 0001
[ 2.600919] realtek-mdio stmmac-1:00: configuring for fixed/rgmii link mode
[ 2.610450] realtek-mdio stmmac-1:00: Link is Up - 1Gbps/Full - flow control off
[ 2.644563] realtek-mdio stmmac-1:00 eth1 (uninitialized): PHY [dsa-0.0:01] driver [Generic PHY] (irq=POLL)
[ 2.684441] realtek-mdio stmmac-1:00 eth2 (uninitialized): PHY [dsa-0.0:03] driver [Generic PHY] (irq=POLL)
[ 2.699335] DSA: tree 0 setup
[ 2.704695] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 2.704785] hub 1-1:1.0: USB hub found
[ 2.712031] input: cpu_inputs as /devices/platform/cpu_inputs/input/input1
[ 2.715286] hub 1-1:1.0: 4 ports detected
[ 2.722488] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.734966] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.741369] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 2.748657] clk: Disabling unused clocks
[ 2.752652] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.761287] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[ 2.865310] hub 1-1:1.0: USB hub found
[ 2.869427] hub 1-1:1.0: 4 ports detected
[ 3.269517] EXT4-fs (mmcblk2p3): recovery complete
[ 3.275227] EXT4-fs (mmcblk2p3): mounted filesystem 057d8de8-a7e7-4440-9fea-c9670c0c5df9 r/w with ordered data mode. Quota mode: none.
[ 3.287379] VFS: Mounted root (ext4 filesystem) on device 179:3.
[ 3.294319] devtmpfs: mounted
[ 3.298268] Freeing unused kernel memory: 3520K
[ 3.302934] Run /sbin/init as init process
[ 3.423469] systemd[1]: System time before build time, advancing clock.
[ 3.450897] systemd[1]: systemd 252.39-1~deb12u2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 3.483986] systemd[1]: Detected architecture arm64.
Welcome to Debian GNU/Linux 12 (bookworm)!
[ 3.506158] systemd[1]: Hostname set to <localhost>.
[ 3.512764] systemd[1]: Initializing machine ID from random generator.
[ 3.558947] systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 3.931119] systemd[1]: Queued start job for default target graphical.target.
[ 3.968011] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[ OK ] Created slice system-getty.slice - Slice /system/getty.
[ 3.993796] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[ OK ] Created slice system-modpr…lice - Slice /system/modprobe.
[ 4.022309] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[ OK ] Created slice system-seria… - Slice /system/serial-getty.
[ 4.049678] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[ OK ] Created slice system-syste… - Slice /system/systemd-fsck.
[ 4.077353] systemd[1]: Created slice user.slice - User and Session Slice.
[ OK ] Created slice user.slice - User and Session Slice.
[ 4.100497] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[ OK ] Started systemd-ask-passwo…quests to Console Directory Watch.
[ 4.128453] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[ OK ] Started systemd-ask-passwo… Requests to Wall Directory Watch.
[ 4.156396] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
[ 4.175866] systemd[1]: Expecting device dev-mmcblk2p1.device - /dev/mmcblk2p1...
[ 4.200472] systemd[1]: Expecting device dev-ttymxc1.device - /dev/ttymxc1...
[ 4.224224] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[ OK ] Reached target cryptsetup.…get - Local Encrypted Volumes.
[ 4.248610] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[ OK ] Reached target integrityse…Local Integrity Protected Volumes.
[ 4.276289] systemd[1]: Reached target paths.target - Path Units.
[ OK ] Reached target paths.target - Path Units.
[ 4.296264] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[ OK ] Reached target remote-fs.target - Remote File Systems.
[ 4.320247] systemd[1]: Reached target slices.target - Slice Units.
[ OK ] Reached target slices.target - Slice Units.
[ 4.340224] systemd[1]: Reached target swap.target - Swaps.
[ OK ] Reached target swap.target - Swaps.
[ 4.360269] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[ OK ] Reached target veritysetup… - Local Verity Protected Volumes.
[ 4.384758] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[ OK ] Listening on systemd-fsckd…sck to fsckd communication Socket.
[ 4.412536] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[ OK ] Listening on systemd-initc… initctl Compatibility Named Pipe.
[ 4.441749] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[ OK ] Listening on systemd-journ…socket - Journal Audit Socket.
[ 4.468740] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[ OK ] Listening on systemd-journ…t - Journal Socket (/dev/log).
[ 4.496878] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[ OK ] Listening on systemd-journald.socket - Journal Socket.
[ 4.520946] systemd[1]: Listening on systemd-networkd.socket - Network Service Netlink Socket.
[ OK ] Listening on systemd-netwo… - Network Service Netlink Socket.
[ 4.557127] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[ OK ] Listening on systemd-udevd….socket - udev Control Socket.
[ 4.584722] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ OK ] Listening on systemd-udevd…l.socket - udev Kernel Socket.
[ 4.624665] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[ 4.651859] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
Mounting dev-mqueue.mount▒▒POSIX Message Queue File System...
[ 4.680049] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
Mounting sys-kernel-debug.… - Kernel Debug File System...
[ 4.709270] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[ 4.724518] systemd[1]: kmod-static-nodes.service - Create List of Static Device Nodes was skipped because of an unmet condition check (ConditionFileNotEmpty=/lib/modules/6.6.52-rt43-gd377c9049508-dirty/modules.devname).
[ 4.757545] systemd[1]: Starting [email protected] - Load Kernel Module configfs...
Starting modprobe@configfs…m - Load Kernel Module configfs...
[ 4.788352] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
Starting modprobe@dm_mod.s…[0m - Load Kernel Module dm_mod...
[ 4.816731] systemd[1]: Starting [email protected] - Load Kernel Module drm...
[ 4.848481] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
Starting modprobe@efi_psto…- Load Kernel Module efi_pstore...
[ 4.876748] systemd[1]: Starting [email protected] - Load Kernel Module fuse...
Starting [email protected]…e - Load Kernel Module fuse...
[ 4.904963] systemd[1]: Starting [email protected] - Load Kernel Module loop...
Starting [email protected]…e - Load Kernel Module loop...
[ 4.928580] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 4.968886] systemd[1]: Starting systemd-journald.service - Journal Service...
[ 5.004486] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
Starting systemd-modules-l…rvice - Load Kernel Modules...
[ 5.031531] systemd[1]: Starting systemd-network-generator.service - Generate network units from Kernel command line...
Starting systemd-network-g… units from Kernel command line...
[ 5.084818] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
Starting systemd-remount-f…nt Root and Kernel File Systems...
[ 5.115743] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
Starting systemd-udev-trig…[0m - Coldplug All udev Devices...
[ 5.136505] EXT4-fs (mmcblk2p3): re-mounted 057d8de8-a7e7-4440-9fea-c9670c0c5df9 r/w. Quota mode: none.
[ 5.153130] systemd[1]: Started systemd-journald.service - Journal Service.
[ OK ] Started systemd-journald.service - Journal Service.
[ OK ] Mounted dev-hugepages.mount - Huge Pages File System.
[ OK ] Mounted dev-mqueue.mount▒▒- POSIX Message Queue File System.
[ OK ] Mounted sys-kernel-debug.m…nt - Kernel Debug File System.
[ OK ] Finished modprobe@configfs…[0m - Load Kernel Module configfs.
[ OK ] Finished modprobe@dm_mod.s…e - Load Kernel Module dm_mod.
[ OK ] Finished [email protected] - Load Kernel Module drm.
[ OK ] Finished modprobe@efi_psto…m - Load Kernel Module efi_pstore.
[ OK ] Finished [email protected] - Load Kernel Module fuse.
[ OK ] Finished [email protected] - Load Kernel Module loop.
[ OK ] Finished systemd-modules-l…service - Load Kernel Modules.
[ OK ] Finished systemd-network-g…rk units from Kernel command line.
[ OK ] Finished systemd-remount-f…ount Root and Kernel File Systems.
[ OK ] Reached target network-pre…get - Preparation for Network.
Mounting sys-kernel-config…ernel Configuration File System...
Starting systemd-journal-f…h Journal to Persistent Storage...
[ 5.501074] systemd-journald[137]: Received client request to flush runtime journal.
Starting systemd-random-se…ice - Load/Save Random Seed...
Starting systemd-sysctl.se…ce - Apply Kernel Variables...
Starting systemd-sysusers.…rvice - Create System Users...
[ OK ] Finished systemd-udev-trig…e - Coldplug All udev Devices.
[ OK ] Mounted sys-kernel-config.… Kernel Configuration File System.
[ OK ] Finished systemd-journal-f…ush Journal to Persistent Storage.
[ OK ] Finished systemd-sysctl.service - Apply Kernel Variables.
Starting ifupdown-pre.serv…ynchronize boot up for ifupdown...
[ OK ] Finished systemd-sysusers.service - Create System Users.
Starting systemd-tmpfiles-…ate Static Device Nodes in /dev...
[ OK ] Finished systemd-tmpfiles-…reate Static Device Nodes in /dev.
[ OK ] Reached target local-fs-pr…reparation for Local File Systems.
[ OK ] Reached target local-fs.target - Local File Systems.
Starting systemd-tmpfiles-…te System Files and Directories...
Starting systemd-udevd.ser…ger for Device Events and Files...
[ OK ] Finished systemd-tmpfiles-…eate System Files and Directories.
Starting systemd-timesyncd… - Network Time Synchronization...
Starting systemd-update-ut…rd System Boot/Shutdown in UTMP...
[ OK ] Finished systemd-update-ut…cord System Boot/Shutdown in UTMP.
[ OK ] Started systemd-udevd.serv…nager for Device Events and Files.
Starting systemd-networkd.…ice - Network Configuration...
[ OK ] Found device dev-ttymxc1.device - /dev/ttymxc1.
[ OK ] Started systemd-timesyncd.…0m - Network Time Synchronization.
[ OK ] Reached target sysinit.target - System Initialization.
[ OK ] Started systemd-tmpfiles-c… Cleanup of Temporary Directories.
[ OK ] Reached target time-set.target - System Time Set.
[ OK ] Started apt-daily.timer - Daily apt download activities.
[ OK ] Started apt-daily-upgrade.… apt upgrade and clean activities.
[ OK ] Started dpkg-db-backup.tim… Daily dpkg database backup timer.
[ OK ] Started e2scrub_all.timer▒▒etadata Check for All Filesystems.
[ OK ] Started fstrim.timer - Discard unused blocks once a week.
[ OK ] Started logrotate.timer - Daily rotation of log files.
[ OK ] Started man-db.timer - Daily man-db regeneration.
[ OK ] Started sysstat-collect.ti… accounting tool every 10 minutes.
[ OK ] Started sysstat-summary.ti…of yesterday's process accounting.
[ OK ] Reached target timers.target - Timer Units.
[ OK ] Listening on dbus.socket▒▒- D-Bus System Message Bus Socket.
[ OK ] Reached targe[ 6.421751] cfg80211: failed to load regulatory.db
t sockets.target - Socket Units.
[ OK ] Reached target basic.target - Basic System.
[ OK ] Started cron.service -…kground program processing daemon.
Starting dbus.service - D-Bus System Message Bus...
[ 6.524255] imx-sdma 30bd0000.dma-controller: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2
[ 6.537384] imx-sdma 30bd0000.dma-controller: Falling back to sysfs fallback for: imx/sdma/sdma-imx7d.bin
[ OK ] Started firmwared.service - Linux Firmware Loader Daemon.
[ 6.563260] imx-sdma 30bd0000.dma-controller: external firmware not found, using ROM firmware
Starting kexec-load.servic…B: Load kernel image with kexec...
Starting lm-sensors.servic…ize hardware monitoring sensors...
Starting platcfg.service▒▒r various NXP i.MX/LS platforms...
[ OK ] Started seatd.service - Seat management daemon.
[ OK ] Started strongswan-starter…Ev1/IKEv2 daemon using ipsec.conf.
Starting sysstat.service - Resets System Activity Logs...
Starting systemd-logind.se…ice - User Login Management...
[ OK ] Started systemd-networkd.service - Network Configuration.
[ OK ] Finished ifupdown-pre.serv… synchronize boot up for ifupdown.
[ OK ] Finished e2scrub_reap.serv…ine ext4 Metadata Check Snapshots.
[ OK ] Finished sysstat.service - Resets System Activity Logs.
[ OK ] Finished lm-sensors.servic…alize hardware monitoring sensors.
[ OK ] Started kexec-load.service…LSB: Load kernel image with kexec.
[ OK ] Found device dev-mmcblk2p1.device - /dev/mmcblk2p1.
[ OK ] Reached target usb-gadget.…m - Hardware activated USB gadget.
Starting networking.service - Raise network interfaces...
Starting systemd-fsck@dev-… System Check on /dev/mmcblk2p1...
[ OK ] Started systemd-fsckd.serv…tem Check Daemon to report status.
[ OK ] Finished systemd-fsck@dev-…le System Check on /dev/mmcblk2p1.
[ 7.297245] imx-dwmac 30bf0000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[ 7.305583] imx-dwmac 30bf0000.ethernet eth0: No Safety Features support found
[ 7.312850] imx-dwmac 30bf0000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
Mounting boot.mount - /boot...
[ 7.324878] imx-dwmac 30bf0000.ethernet eth0: registered PTP clock
[ 7.336555] imx-dwmac 30bf0000.ethernet eth0: FPE workqueue start
[ 7.343570] imx-dwmac 30bf0000.ethernet eth0: configuring for fixed/rgmii-id link mode
[ 7.353100] imx-dwmac 30bf0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 7.353244] EXT4-fs (mmcblk2p1): mounted filesystem 45d36d6d-da2c-4fa0-ae4f-46086176bf89 r/w with ordered data mode. Quota mode: none.
[ 7.354853] 8021q: adding VLAN 0 to HW filter on device eth0
[ OK ] Mounted boot.mount - /boot.
[ 7.484902] realtek-mdio stmmac-1:00 eth1: configuring for phy/gmii link mode
[ 7.499221] 8021q: adding VLAN 0 to HW filter on device eth1
[ 7.722835] realtek-mdio stmmac-1:00 eth2: configuring for phy/gmii link mode
[ 7.758421] 8021q: adding VLAN 0 to HW filter on device eth2
[ OK ] Finished networking.service - Raise network interfaces.
[ 7.988116] random: crng init done
[ OK ] Finished systemd-random-se…rvice - Load/Save Random Seed.
[ OK ] Started dbus.service - D-Bus System Message Bus.
Starting wpa_supplicant.service - WPA supplicant...
[ OK ] Started systemd-logind.service - User Login Management.
[ OK ] Started wpa_supplicant.service - WPA supplicant.
[ OK ] Reached target network.target - Network.
Starting mosquitto.service - Mosquitto MQTT Broker...
Starting ssh.service - OpenBSD Secure Shell server...
Starting systemd-hostnamed.service - Hostname Service...
Starting systemd-user-sess…vice - Permit User Sessions...
[ OK ] Finished systemd-user-sess…ervice - Permit User Sessions.
[ OK ] Started [email protected] - Getty on tty1.
[ OK ] Started serial-getty@ttymx…ice - Serial Getty on ttymxc1.
[ OK ] Reached target getty.target - Login Prompts.
[ OK ] Started systemd-hostnamed.service - Hostname Service.
[ OK ] Started ssh.service - OpenBSD Secure Shell server.
[ OK ] Started mosquitto.service - Mosquitto MQTT Broker.
[ OK ] Reached target multi-user.target - Multi-User System.
[ OK ] Reached target graphical.target - Graphical Interface.
Starting systemd-update-ut… Record Runlevel Change in UTMP...
[ OK ] Finished platcfg.service▒▒for various NXP i.MX/LS platforms.
[ OK ] Finished systemd-update-ut… - Record Runlevel Change in UTMP.
Debian GNU/Linux 12 imx8mpevk ttymxc1
NXP Linux SDK 2506 Debian Server (optimized with NXP-specific hardware acceleration)
imx8mpevk login: root
Password:
Linux imx8mpevk 6.6.52-rt43-gd377c9049508-dirty #1 SMP PREEMPT Thu Jul 2 11:19:58 CST 2026 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@imx8mpevk:~#
root@imx8mpevk:~# modprobe moal mod_para=nxp/wifi_mod_para.conf
[ 27.658951] mlan: loading out-of-tree module taints kernel.
[ 27.688908] wlan: Loading MWLAN driver
[ 27.693279] wlan: Register to Bus Driver...
[ 27.697621] vendor=0x02DF device=0x9149 class=0 function=1
[ 27.703270] Attach moal handle ops, card interface type: 0x105
[ 27.709133] rps set to 0 from module param
[ 27.713466] SD8987: init module param from usr cfg
[ 27.718305] card_type: SD8987, config block: 0
[ 27.722765] cfg80211_wext=0xf
[ 27.725757] max_vir_bss=1
[ 27.728391] cal_data_cfg=none
[ 27.731362] ps_mode = 1
[ 27.733821] auto_ds = 1
[ 27.736295] host_mlme=enable
[ 27.739186] fw_name=nxp/sdiouart8987_combo_v0.bin
[ 27.743918] SDIO: max_segs=128 max_seg_size=65535
[ 27.748647] rx_work=1 cpu_num=4
[ 27.751795] Enable moal_recv_amsdu_packet
[ 27.755832] Attach mlan adapter operations.card_type is 0x105.
[ 27.762044] wlan: Enable TX SG mode
[ 27.765551] wlan: Enable RX SG mode
[ 27.776176] Request firmware: nxp/sdiouart8987_combo_v0.bin
[ 28.073628] Wlan: FW download over, firmwarelen=626584 downloaded 617556
[ 28.944747] WLAN FW is active
[ 28.947734] on_time is 28943658375
[ 29.003401] VDLL image: len=9028
[ 29.006743] FW country code WW does not match with US
[ 29.012026] fw_cap_info=0x181d6f03, dev_cap_mask=0xffffffff
[ 29.017672] max_p2p_conn = 8, max_sta_conn = 8
[ 29.022438] SDIO rx aggr: 1 block_size=512
[ 29.026600] wlan: Enable RX SG mode
[ 29.030117] mpa_rx_buf_size=65280
[ 29.054744] Register NXP 802.11 Adapter mlan0
[ 29.061163] Register NXP 802.11 Adapter uap0
[ 29.069437] Register NXP 802.11 Adapter wfd0
[ 29.073887] wlan: version = SD8987----16.92.21.p142.3-MM6X16505.p4-GPL-(FP92)
[ 29.083234] wlan: Register to Bus Driver Done
[ 29.088229] wlan: Driver loaded successfully
root@imx8mpevk:~# [ 29.430504] wlan: mlan0 START SCAN
[ 33.741685] wlan: SCAN COMPLETED: scanned AP count=6
root@imx8mpevk:~#
root@imx8mpevk:~# mod[ 38.754412] wlan: mlan0 START SCAN
probe btnxpuart
[ 43.549431] btnxpuart serial0-0: ipg clock enabled, rate=80000000
[ 43.555634] btnxpuart serial0-0: per clock enabled, rate=80000000
root@imx8mpevk:~# [ 43.743746] wlan: SCAN COMPLETED: scanned AP count=14
[ 44.580103] Bluetooth: hci0: FW already running.
[ 48.756247] wlan: mlan0 START SCAN
[ 53.744943] wlan: SCAN COMPLETED: scanned AP count=16
[ 53.753462] wlan: sched scan start
416 次查看
shaun_wu
Hello @wanggg
Which 8MP board you currently using? Could you share hardware connection?
Best Regards
Shaun
398 次查看
wanggg
Hello @shaun_wu
I have already identified the hardware problem. Thank you for your help.
197 次查看
Sanjiv_Mns
Hi @wanggg
Can i know what is the issue here... I am also facing the same issue..
%3CLINGO-SUB%20id%3D%22lingo-sub-2390760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8MP%20%E7%9A%84%E8%93%9D%E7%89%99%E5%8A%9F%E8%83%BD%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E4%B8%93%E5%AE%B6%EF%BC%81%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%88%91%E6%AD%A3%E5%9C%A8%20IMX8MP%20%E4%B8%8A%E6%B5%8B%E8%AF%95%20AW-CM358SM%E3%80%82WiFi%20%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E5%9C%A8%20UART3%20%E4%B8%8A%E6%B5%8B%E8%AF%95%E8%93%9D%E7%89%99%E6%97%B6%EF%BC%8C%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%E3%80%82%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%E5%A6%82%E4%B8%8B%E3%80%82%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E5%BE%88%E5%A4%9A%E6%96%B9%E6%B3%95%EF%BC%8C%E4%BD%86%E4%BB%8D%E7%84%B6%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E3%80%82%E4%BD%A0%E6%9C%89%E4%BB%80%E4%B9%88%E5%8A%9E%E6%B3%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E9%94%99%E8%AF%AF%E6%97%A5%E5%BF%97%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3EBluetooth%3A%20hci0%3A%20FW%20already%20running.%0A%5B%20%20%2046.628430%5D%20Bluetooth%3A%20hci0%3A%20Opcode%200x0c03%20failed%3A%20-110%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3Edts%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26amp%3Buart3%20%7B%20%2F*%20BT%20*%2F%3CBR%20%2F%3E%20pinctrl-names%20%3D%20%22default%22%3B%3CBR%20%2F%3E%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_uart3%20%26amp%3Bpinctrl_bt_ctrl%26gt%3B%3B%3CBR%20%2F%3E%E5%B7%B2%E5%88%86%E9%85%8D%E6%97%B6%E9%92%9F%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_UART3%26gt%3B%3B%3CBR%20%2F%3E%E5%B7%B2%E5%88%86%E9%85%8D%E6%97%B6%E9%92%9F%E7%88%B6%E7%BA%A7%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_SYS_PLL1_80M%26gt%3B%3B%3CBR%20%2F%3E%20uart-has-rtscts%EF%BC%9B%3CBR%20%2F%3E%E7%8A%B6%E6%80%81%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%20%7B%3CBR%20%2F%3E%E5%85%BC%E5%AE%B9%20%3D%20%22nxp%2C88w8987-bt%22%3B%3CBR%20%2F%3E%20device-wakeup-gpios%20%3D%20%26lt%3B%26amp%3Bgpio2%2010%20GPIO_ACTIVE_HIGH%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3Epinctrl_uart3%EF%BC%9Auart3grp%20%7B%3CBR%20%2F%3E%20fsl%2Cpins%20%3D%20%26lt%3B%3CBR%20%2F%3E%20MX8MP_IOMUXC_ECSPI1_SCLK__UART3_DCE_RX%200x140%3CBR%20%2F%3E%20MX8MP_IOMUXC_ECSPI1_MOSI__UART3_DCE_TX%200x140%3CBR%20%2F%3E%20MX8MP_IOMUXC_ECSPI1_MISO__UART3_DCE_CTS%200x140%3CBR%20%2F%3E%20MX8MP_IOMUXC_ECSPI1_SS0__UART3_DCE_RTS%200x140%3CBR%20%2F%3E%20%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3Epinctrl_bt_ctrl%3A%20btctrlgrp%20%7B%3CBR%20%2F%3E%20fsl%2Cpins%20%3D%20%26lt%3B%3CBR%20%2F%3E%20MX8MP_IOMUXC_SD1_RESET_B__GPIO2_IO10%200x10%20%2F*%20HOST_WAKE_BT%20*%2F%3CBR%20%2F%3E%20MX8MP_IOMUXC_SD1_STROBE__GPIO2_IO11%200x140%20%2F*%20BT_HOST_WAKE%20*%2F%3CBR%20%2F%3E%20%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3Ewifi_mod_para.conf%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3ESD8987%20%3D%20%7B%3CBR%20%2F%3E%20cfg80211_wext%3D0xf%3CBR%20%2F%3E%20wfd_name%3Dp2p%3CBR%20%2F%3E%20max_vir_bss%3D1%3CBR%20%2F%3E%20cal_data_cfg%3Dnone%3CBR%20%2F%3E%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%BC%8F%3D7%3CBR%20%2F%3E%20ps_mode%3D2%3CBR%20%2F%3E%20auto_ds%3D2%3CBR%20%2F%3E%20fw_name%3Dnxp%2Fsdiouart8987_combo_v0.bin%3CBR%20%2F%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E5%86%85%E6%A0%B8%E6%97%A5%E5%BF%97%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FP%3E%3CP%3E%5B%200.000000%5D%20%E5%9C%A8%E7%89%A9%E7%90%86%20CPU%200x0000000000%20%E4%B8%8A%E5%90%AF%E5%8A%A8%20Linux%20%5B0x410fd034%5D%3CBR%20%2F%3E%20%5B%200.000000%5D%20Linux%20%E7%89%88%E6%9C%AC%206.6.52-rt43-gd377c9049508-dirty(root%40fbdebian)%20(aarch64-linux-gnu-gcc%20(Debian%2012.2.0-14)12.2.0%EF%BC%8CGNU%20ld%EF%BC%88Debian%20%E7%89%88%20GNU%20Binutils%EF%BC%892.40%EF%BC%89%231%20SMP%20PREEMPT%202026%20%E5%B9%B4%207%20%E6%9C%88%202%20%E6%97%A5%E6%98%9F%E6%9C%9F%E5%9B%9B%2011%3A19%3A58%20CST%3CBR%20%2F%3E%20%5B%200.000000%5D%20%E7%94%B1%E4%BA%8E%E7%BC%BA%E5%B0%91%E7%A7%8D%E5%AD%90%EF%BC%8CKASLR%20%E5%B7%B2%E7%A6%81%E7%94%A8%3CBR%20%2F%3E%5B%200.000000%5D%20%E6%9C%BA%E5%99%A8%E5%9E%8B%E5%8F%B7%EF%BC%9AG3%20i.MX8MPlus%20EVK%20%E6%9D%BF%3CBR%20%2F%3E%5B%200.000000%5D%20efi%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%20UEFI%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20%E4%BF%9D%E7%95%99%E5%86%85%E5%AD%98%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AE%BE%E7%BD%AE%20CMA%20%E5%8C%BA%E5%9F%9F%3CBR%20%2F%3E%5B%200.000000%5D%20OF%3A%20%E4%BF%9D%E7%95%99%E5%86%85%E5%AD%98%3A%20%E8%8A%82%E7%82%B9%20linux%2Ccma%20%E5%85%BC%E5%AE%B9%E5%8C%B9%E9%85%8D%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3E%5B%200.000000%5D%20OF%3A%20%E4%BF%9D%E7%95%99%E5%86%85%E5%AD%98%3A%200x0000000000900000..0x000000000096ffff%20(448%20KiB)%20nomap%20%E4%B8%8D%E5%8F%AF%E9%87%8D%E7%94%A8%20ocram%40900000%3CBR%20%2F%3E%20%5B%200.000000%5D%20%E5%8C%BA%E5%9F%9F%E8%8C%83%E5%9B%B4%EF%BC%9A%3CBR%20%2F%3E%20%5B%200.000000%5D%20DMA%20%5B%E5%86%85%E5%AD%98%200x0000000040000000-0x00000000ffffffff%5D%3CBR%20%2F%3E%20%5B%200.000000%5D%20DMA32%20%E4%B8%BA%E7%A9%BA%3CBR%20%2F%3E%5B%200.000000%5D%20%E6%AD%A3%E5%B8%B8%20%5B%E5%86%85%E5%AD%98%200x0000000100000000-0x000000013fffffff%5D%3CBR%20%2F%3E%20%5B%200.000000%5D%20%E6%AF%8F%E4%B8%AA%E8%8A%82%E7%82%B9%E7%9A%84%E5%8F%AF%E7%A7%BB%E5%8A%A8%E5%8C%BA%E5%9F%9F%E8%B5%B7%E5%A7%8B%E4%BD%8D%E7%BD%AE%3CBR%20%2F%3E%5B%200.000000%5D%20%E6%97%A9%E6%9C%9F%E5%86%85%E5%AD%98%E8%8A%82%E7%82%B9%E8%8C%83%E5%9B%B4%3CBR%20%2F%3E%5B%200.000000%5D%20%E8%8A%82%E7%82%B9%200%3A%20%5B%E5%86%85%E5%AD%98%200x0000000040000000-0x000000013fffffff%5D%3CBR%20%2F%3E%20%5B%200.000000%5D%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%86%85%E5%AD%98%E8%AE%BE%E7%BD%AE%E8%8A%82%E7%82%B9%200%20%5B%E5%86%85%E5%AD%98%200x0000000040000000-0x000000013fffffff%5D%3CBR%20%2F%3E%20%5B%200.000000%5D%20cma%EF%BC%9A%E5%9C%A8%E8%8A%82%E7%82%B9%20-1%20%E7%9A%84%200x00000000ff800000%20%E5%A4%84%E4%BF%9D%E7%95%99%208%20MiB%20%E7%A9%BA%E9%97%B4%3CBR%20%2F%3E%5B%200.000000%5D%20psci%EF%BC%9A%E4%BB%8E%20DT%20%E6%8E%A2%E6%B5%8B%E7%AE%A1%E9%81%93%E6%96%B9%E6%B3%95%E3%80%82%3CBR%20%2F%3E%20%5B%200.000000%5D%20psci%3A%20%E5%9B%BA%E4%BB%B6%E4%B8%AD%E6%A3%80%E6%B5%8B%E5%88%B0%20PSCIv1.1%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20psci%EF%BC%9A%E4%BD%BF%E7%94%A8%E6%A0%87%E5%87%86%20PSCI%20v0.2%20%E5%87%BD%E6%95%B0%20ID%3CBR%20%2F%3E%20%5B%200.000000%5D%20psci%EF%BC%9A%E4%B8%8D%E6%94%AF%E6%8C%81%20MIGRATE_INFO_TYPE%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20psci%EF%BC%9ASMC%20%E8%B0%83%E7%94%A8%E7%BA%A6%E5%AE%9A%20v1.4%3CBR%20%2F%3E%20%5B%200.000000%5D%20percpu%EF%BC%9A%E5%B5%8C%E5%85%A5%E5%BC%8F%2020%20%E9%A1%B5%2FCPU%20s43368%20r8192%20d30360%20u81920%3CBR%20%2F%3E%20%5B%200.000000%5D%20%E5%9C%A8%20CPU0%20%E4%B8%8A%E6%A3%80%E6%B5%8B%E5%88%B0%20VIPT%20%E6%8C%87%E4%BB%A4%E7%BC%93%E5%AD%98%3CBR%20%2F%3E%20%5B%200.000000%5D%20CPU%20%E7%89%B9%E6%80%A7%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%EF%BC%9AGIC%20%E7%B3%BB%E7%BB%9F%E5%AF%84%E5%AD%98%E5%99%A8%20CPU%20%E6%8E%A5%E5%8F%A3%3CBR%20%2F%3E%5B%200.000000%5D%20CPU%20%E7%89%B9%E6%80%A7%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%EF%BC%9AARM%20%E5%8B%98%E8%AF%AF%20845719%3CBR%20%2F%3E%20%5B%200.000000%5D%20%E6%9B%BF%E4%BB%A3%E6%96%B9%E6%A1%88%EF%BC%9A%E5%BA%94%E7%94%A8%E5%90%AF%E5%8A%A8%E6%9B%BF%E4%BB%A3%E6%96%B9%E6%A1%88%3CBR%20%2F%3E%5B0.000000%5D%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9Aconsole%3Dttymxc1%2C115200%20root%3DPARTUUID%3D6a120481-03%20rw%20rootwait%3CBR%20%2F%3E%20%5B%200.000000%5D%20%E7%9B%AE%E5%BD%95%E9%A1%B9%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A524288%EF%BC%88%E9%98%B6%E6%95%B0%EF%BC%9A10%EF%BC%8C4194304%20%E5%AD%97%E8%8A%82%EF%BC%8C%E7%BA%BF%E6%80%A7%EF%BC%89%3CBR%20%2F%3E%20%5B%200.000000%5D%20Inode%20%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A262144%EF%BC%88%E9%98%B6%E6%95%B0%EF%BC%9A9%EF%BC%8C2097152%20%E5%AD%97%E8%8A%82%EF%BC%8C%E7%BA%BF%E6%80%A7%EF%BC%89%3CBR%20%2F%3E%20%5B%200.000000%5D%20%E5%B7%B2%E6%9E%84%E5%BB%BA%201%20%E4%B8%AA%E5%8C%BA%E5%9F%9F%E5%88%97%E8%A1%A8%EF%BC%8C%E7%A7%BB%E5%8A%A8%E6%80%A7%E5%88%86%E7%BB%84%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%E6%80%BB%E9%A1%B5%E6%95%B0%EF%BC%9A1032192%3CBR%20%2F%3E%20%5B%200.000000%5D%20%E5%86%85%E5%AD%98%E8%87%AA%E5%8A%A8%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9A%E6%A0%88%EF%BC%9A%E5%85%A8%E9%83%A8%EF%BC%88%E9%9B%B6%EF%BC%89%EF%BC%8C%E5%A0%86%E5%88%86%E9%85%8D%EF%BC%9A%E5%85%B3%E9%97%AD%EF%BC%8C%E5%A0%86%E9%87%8A%E6%94%BE%EF%BC%9A%E5%85%B3%E9%97%AD%3CBR%20%2F%3E%5B%200.000000%5D%20%E8%BD%AF%E4%BB%B6%20IO%20TLB%EF%BC%9A%E5%8C%BA%E5%9F%9F%E7%BC%96%E5%8F%B7%204%E3%80%82%3CBR%20%2F%3E%20%5B%200.000000%5D%20%E8%BD%AF%E4%BB%B6%20IO%20TLB%EF%BC%9A%E5%B7%B2%E6%98%A0%E5%B0%84%20%5B%E5%86%85%E5%AD%98%200x00000000fb800000-0x00000000ff800000%5D%20(64MB)%3CBR%20%2F%3E%20%5B%200.000000%5D%20%E5%86%85%E5%AD%98%EF%BC%9A%E5%8F%AF%E7%94%A8%204012020K%2F4194304K%EF%BC%8816192K%20%E5%86%85%E6%A0%B8%E4%BB%A3%E7%A0%81%EF%BC%8C1688K%20%E8%AF%BB%E5%86%99%E6%95%B0%E6%8D%AE%EF%BC%8C5064K%20%E5%8F%AA%E8%AF%BB%E6%95%B0%E6%8D%AE%EF%BC%8C3520K%20%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%8C541K%20bss%EF%BC%8C174092K%20%E4%BF%9D%E7%95%99%EF%BC%8C8192K%20cma%20%E4%BF%9D%E7%95%99%EF%BC%89%3CBR%20%2F%3E%20%5B%200.000000%5D%20SLUB%EF%BC%9A%E7%A1%AC%E4%BB%B6%E5%AF%B9%E9%BD%90%3D64%EF%BC%8C%E9%A1%BA%E5%BA%8F%3D0-3%EF%BC%8C%E6%9C%80%E5%B0%8F%E5%AF%B9%E8%B1%A1%E6%95%B0%3D0%EF%BC%8CCPU%E6%95%B0%3D4%EF%BC%8C%E8%8A%82%E7%82%B9%E6%95%B0%3D1%3CBR%20%2F%3E%20%5B%200.000000%5D%20rcu%EF%BC%9A%E5%8F%AF%E6%8A%A2%E5%8D%A0%E5%BC%8F%E5%88%86%E5%B1%82%20RCU%20%E5%AE%9E%E7%8E%B0%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20rcu%3A%20RCU%20%E5%B0%86%20CPU%20%E6%95%B0%E9%87%8F%E4%BB%8E%20NR_CPUS%3D256%20%E9%99%90%E5%88%B6%E4%B8%BA%20nr_cpu_ids%3D4%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20%E5%B7%B2%E5%90%AF%E7%94%A8%20Tasks%20RCU%20%E7%9A%84%20Trampoline%20%E5%8F%98%E4%BD%93%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20%E4%BB%BB%E5%8A%A1%20RCU%20%E7%9A%84%E8%B7%9F%E8%B8%AA%E5%8F%98%E4%BD%93%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20rcu%3A%20RCU%20%E8%AE%A1%E7%AE%97%E5%87%BA%E7%9A%84%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%E6%B3%A8%E5%86%8C%E5%BB%B6%E8%BF%9F%E5%80%BC%E4%B8%BA%2025%20jiffies%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20rcu%EF%BC%9A%E6%AD%A3%E5%9C%A8%E8%B0%83%E6%95%B4%20rcu_fanout_leaf%3D16%E3%80%81nr_cpu_ids%3D4%20%E7%9A%84%E5%87%A0%E4%BD%95%E7%BB%93%E6%9E%84%3CBR%20%2F%3E%5B%200.000000%5D%20NR_IRQS%EF%BC%9A64%EF%BC%8Cnr_irqs%EF%BC%9A64%EF%BC%8C%E9%A2%84%E5%88%86%E9%85%8D%E4%B8%AD%E6%96%AD%EF%BC%9A0%3CBR%20%2F%3E%20%5B%200.000000%5D%20GICv3%EF%BC%9AGIC%EF%BC%9A%E4%BD%BF%E7%94%A8%E5%88%86%E7%A6%BB%E5%BC%8F%20EOI%2F%E5%81%9C%E7%94%A8%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%200.000000%5D%20GICv3%EF%BC%9A%E5%AE%9E%E6%96%BD%E4%BA%86%20160%20%E4%B8%AA%20SPI%3CBR%20%2F%3E%20%5B%200.000000%5D%20GICv3%EF%BC%9A%E5%B7%B2%E5%AE%9E%E7%8E%B0%200%20%E4%B8%AA%E6%89%A9%E5%B1%95%20SPI%3CBR%20%2F%3E%20%5B%200.000000%5D%20%E6%A0%B9%E4%B8%AD%E6%96%AD%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%EF%BC%9Agic_handle_irq%3CBR%20%2F%3E%20%5B%200.000000%5D%20GICv3%EF%BC%9AGICv3%20%E7%89%B9%E5%BE%81%EF%BC%9A16%20PPI%3CBR%20%2F%3E%20%5B%200.000000%5D%20GICv3%3A%20CPU0%3A%20%E6%89%BE%E5%88%B0%E5%88%86%E5%8F%91%E5%99%A8%200%20%E5%8C%BA%E5%9F%9F%200%3A0x0000000038880000%3CBR%20%2F%3E%20%5B%200.000000%5D%20ITS%EF%BC%9A%E6%97%A0%E5%8F%AF%E7%94%A8%20ITS%EF%BC%8C%E4%B8%8D%E5%90%AF%E7%94%A8%20LPI%3CBR%20%2F%3E%20%5B%200.000000%5D%20rcu%3A%20srcu_init%3A%20%E6%A0%B9%E6%8D%AE%E4%BA%89%E7%94%A8%E6%83%85%E5%86%B5%E8%AE%BE%E7%BD%AE%20srcu_struct%20%E5%A4%A7%E5%B0%8F%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20arch_timer%3A%20cp15%20%E5%AE%9A%E6%97%B6%E5%99%A8%E4%BB%A5%208.00MHz%20(phys)%20%E8%BF%90%E8%A1%8C%E3%80%82%3CBR%20%2F%3E%5B%200.000000%5D%20%E6%97%B6%E9%92%9F%E6%BA%90%EF%BC%9Aarch_sys_counter%EF%BC%9A%E6%8E%A9%E7%A0%81%EF%BC%9A0xffffffffffffff%20%E6%9C%80%E5%A4%A7%E5%91%A8%E6%9C%9F%E6%95%B0%EF%BC%9A0x1d854df40%EF%BC%8C%E6%9C%80%E5%A4%A7%E7%A9%BA%E9%97%B2%E6%97%B6%E9%97%B4%EF%BC%88%E7%BA%B3%E7%A7%92%EF%BC%89%EF%BC%9A440795202120%20%E7%BA%B3%E7%A7%92%3CBR%20%2F%3E%5B%200.000000%5D%20%E8%B0%83%E5%BA%A6%E6%97%B6%E9%92%9F%EF%BC%9A56%20%E4%BD%8D%EF%BC%8C%E9%A2%91%E7%8E%87%208MHz%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%87%20125ns%EF%BC%8C%E6%AF%8F%202199023255500ns%20%E6%BA%A2%E5%87%BA%E4%B8%80%E6%AC%A1%3CBR%20%2F%3E%5B%200.000475%5D%20%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%BD%A9%E8%89%B2%E8%99%9A%E6%8B%9F%E8%AE%BE%E5%A4%87%2080x25%3CBR%20%2F%3E%20%5B%200.000519%5D%20%E6%A0%A1%E5%87%86%E5%BB%B6%E8%BF%9F%E5%BE%AA%E7%8E%AF%EF%BC%88%E5%B7%B2%E8%B7%B3%E8%BF%87%EF%BC%89%EF%BC%8C%E8%AF%A5%E5%80%BC%E4%BD%BF%E7%94%A8%E5%AE%9A%E6%97%B6%E5%99%A8%E9%A2%91%E7%8E%87%E8%AE%A1%E7%AE%97%E5%BE%97%E5%87%BA%E3%80%8216.00%20BogoMIPS%20(lpj%3D32000)%3CBR%20%2F%3E%20%5B%200.000528%5D%20pid_max%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%9A32768%20%E6%9C%80%E5%B0%8F%E5%80%BC%EF%BC%9A301%3CBR%20%2F%3E%20%5B%200.000602%5D%20LSM%EF%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96%20lsm%3D%E8%83%BD%E5%8A%9B%E3%80%81%E5%AE%8C%E6%95%B4%E6%80%A7%3CBR%20%2F%3E%5B%200.000695%5D%20%E6%8C%82%E8%BD%BD%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A8192%EF%BC%88%E9%98%B6%E6%95%B0%EF%BC%9A4%EF%BC%8C65536%20%E5%AD%97%E8%8A%82%EF%BC%8C%E7%BA%BF%E6%80%A7%EF%BC%89%3CBR%20%2F%3E%20%5B%200.000711%5D%20%E6%8C%82%E8%BD%BD%E7%82%B9%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A8192%EF%BC%88%E9%98%B6%E6%95%B0%EF%BC%9A4%EF%BC%8C65536%20%E5%AD%97%E8%8A%82%EF%BC%8C%E7%BA%BF%E6%80%A7%EF%BC%89%3CBR%20%2F%3E%20%5B%200.002173%5D%20RCU%20%E4%BB%BB%E5%8A%A1%EF%BC%9A%E5%B0%86%20shift%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%202%EF%BC%8Clim%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%201%20rcu_task_cb_adjust%3D1%E3%80%82%3CBR%20%2F%3E%20%5B%200.002240%5D%20RCU%20%E4%BB%BB%E5%8A%A1%E8%B7%9F%E8%B8%AA%EF%BC%9A%E5%B0%86%20shift%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%202%EF%BC%8C%E5%B0%86%20lim%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%201%20rcu_task_cb_adjust%3D1%E3%80%82%3CBR%20%2F%3E%20%5B0.002415%5D%20rcu%EF%BC%9A%E5%88%86%E5%B1%82SRCU%E5%AE%9E%E7%8E%B0%E3%80%82%3CBR%20%2F%3E%5B%200.002418%5D%20rcu%EF%BC%9A%E6%9C%80%E5%A4%A7%E7%9B%B8%E4%BD%8D%E6%97%A0%E5%BB%B6%E8%BF%9F%E5%AE%9E%E4%BE%8B%E6%95%B0%E4%B8%BA%201000%E3%80%82%3CBR%20%2F%3E%5B%200.004206%5D%20EFI%20%E6%9C%8D%E5%8A%A1%E5%B0%86%E4%B8%8D%E5%8F%AF%E7%94%A8%E3%80%82%3CBR%20%2F%3E%5B%200.004444%5D%20smp%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E8%BE%85%E5%8A%A9%20CPU...%3CBR%20%2F%3E%20%5B%200.004903%5D%20%E5%9C%A8%20CPU1%20%E4%B8%8A%E6%A3%80%E6%B5%8B%E5%88%B0%20VIPT%20%E6%8C%87%E4%BB%A4%E7%BC%93%E5%AD%98%3CBR%20%2F%3E%5B%200.004964%5D%20GICv3%EF%BC%9ACPU1%EF%BC%9A%E6%89%BE%E5%88%B0%E9%87%8D%E6%96%B0%E5%88%86%E5%8F%91%E5%99%A8%201%20%E5%8C%BA%E5%9F%9F%200%3A0x00000000388a0000%3CBR%20%2F%3E%20%5B%200.005000%5D%20CPU1%EF%BC%9A%E5%B7%B2%E5%90%AF%E5%8A%A8%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%200x0000000001%20%5B0x410fd034%5D%3CBR%20%2F%3E%20%5B%200.005523%5D%20%E5%9C%A8%20CPU2%20%E4%B8%8A%E6%A3%80%E6%B5%8B%E5%88%B0%20VIPT%20%E6%8C%87%E4%BB%A4%E7%BC%93%E5%AD%98%3CBR%20%2F%3E%5B%200.005565%5D%20GICv3%EF%BC%9ACPU2%EF%BC%9A%E6%89%BE%E5%88%B0%E5%88%86%E5%B8%83%E5%BC%8F%E5%86%85%E5%AD%98%E5%88%86%E9%85%8D%E5%99%A8%202%20%E5%8C%BA%E5%9F%9F%200%3A0x00000000388c0000%3CBR%20%2F%3E%20%5B%200.005585%5D%20CPU2%EF%BC%9A%E5%B7%B2%E5%90%AF%E5%8A%A8%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%200x0000000002%20%5B0x410fd034%5D%3CBR%20%2F%3E%20%5B%200.006045%5D%20%E5%9C%A8%20CPU3%20%E4%B8%8A%E6%A3%80%E6%B5%8B%E5%88%B0%20VIPT%20%E6%8C%87%E4%BB%A4%E7%BC%93%E5%AD%98%3CBR%20%2F%3E%5B%200.006083%5D%20GICv3%3A%20CPU3%3A%20%E6%89%BE%E5%88%B0%E5%88%86%E5%8F%91%E5%99%A8%203%20%E5%8C%BA%E5%9F%9F%200%3A0x00000000388e0000%3CBR%20%2F%3E%20%5B%200.006100%5D%20CPU3%EF%BC%9A%E5%B7%B2%E5%90%AF%E5%8A%A8%E8%BE%85%E5%8A%A9%E5%A4%84%E7%90%86%E5%99%A8%200x0000000003%20%5B0x410fd034%5D%3CBR%20%2F%3E%20%5B%200.006165%5D%20smp%EF%BC%9A%E5%B7%B2%E5%90%AF%E5%8A%A8%201%20%E4%B8%AA%E8%8A%82%E7%82%B9%EF%BC%8C4%20%E4%B8%AA%20CPU%3CBR%20%2F%3E%20%5B%200.006173%5D%20SMP%EF%BC%9A%E5%85%B1%E6%BF%80%E6%B4%BB%E4%BA%86%204%20%E4%B8%AA%E5%A4%84%E7%90%86%E5%99%A8%E3%80%82%3CBR%20%2F%3E%5B%200.006177%5D%20CPU%20%E7%89%B9%E6%80%A7%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%EF%BC%9A32%20%E4%BD%8D%20EL0%20%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%200.006181%5D%20CPU%20%E7%89%B9%E6%80%A7%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%EF%BC%9ACRC32%20%E6%8C%87%E4%BB%A4%3CBR%20%2F%3E%5B%200.006243%5D%20CPU%EF%BC%9A%E6%89%80%E6%9C%89%20CPU%20%E5%9D%87%E5%B7%B2%E5%9C%A8%20EL2%20%E7%BA%A7%E5%88%AB%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%5B%200.006246%5D%20%E6%9B%BF%E4%BB%A3%E6%96%B9%E6%A1%88%EF%BC%9A%E5%BA%94%E7%94%A8%E7%B3%BB%E7%BB%9F%E6%80%A7%E6%9B%BF%E4%BB%A3%E6%96%B9%E6%A1%88%3CBR%20%2F%3E%5B%200.008002%5D%20devtmpfs%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%5B%200.016979%5D%20%E6%97%B6%E9%92%9F%E6%BA%90%EF%BC%9Ajiffies%EF%BC%9A%E6%8E%A9%E7%A0%81%EF%BC%9A0xffffffff%20%E6%9C%80%E5%A4%A7%E5%91%A8%E6%9C%9F%E6%95%B0%EF%BC%9A0xffffffff%EF%BC%8C%E6%9C%80%E5%A4%A7%E7%A9%BA%E9%97%B2%E6%97%B6%E9%97%B4%EF%BC%88%E7%BA%B3%E7%A7%92%EF%BC%89%EF%BC%9A7645041785100000%20%E7%BA%B3%E7%A7%92%3CBR%20%2F%3E%5B%200.017001%5D%20futex%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%98%B6%E6%95%B0%EF%BC%9A4%EF%BC%8C65536%20%E5%AD%97%E8%8A%82%EF%BC%8C%E7%BA%BF%E6%80%A7%EF%BC%89%3CBR%20%2F%3E%20%5B%200.017422%5D%20pinctrl%20%E6%A0%B8%E5%BF%83%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20pinctrl%20%E5%AD%90%E7%B3%BB%E7%BB%9F%3CBR%20%2F%3E%5B%200.020051%5D%20DMI%20%E4%B8%8D%E5%AD%98%E5%9C%A8%E6%88%96%E6%97%A0%E6%95%88%E3%80%82%3CBR%20%2F%3E%5B%200.020689%5D%20NET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20PF_NETLINK%2FPF_ROUTE%20%E5%8D%8F%E8%AE%AE%E6%97%8F%3CBR%20%2F%3E%5B%200.022304%5D%20DMA%EF%BC%9A%E5%B7%B2%E9%A2%84%E5%88%86%E9%85%8D%20512%20KiB%20GFP_KERNEL%20%E6%B1%A0%E7%94%A8%E4%BA%8E%E5%8E%9F%E5%AD%90%E5%88%86%E9%85%8D%3CBR%20%2F%3E%5B%200.023375%5D%20DMA%EF%BC%9A%E5%B7%B2%E4%B8%BA%E5%8E%9F%E5%AD%90%E5%88%86%E9%85%8D%E9%A2%84%E5%88%86%E9%85%8D%20512%20KiB%20GFP_KERNEL%7CGFP_DMA%20%E6%B1%A0%3CBR%20%2F%3E%5B%200.024665%5D%20DMA%EF%BC%9A%E5%B7%B2%E4%B8%BA%E5%8E%9F%E5%AD%90%E5%88%86%E9%85%8D%E9%A2%84%E5%88%86%E9%85%8D%20512%20KiB%20GFP_KERNEL%7CGFP_DMA32%20%E6%B1%A0%3CBR%20%2F%3E%5B%200.024748%5D%20%E5%AE%A1%E8%AE%A1%EF%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96%20netlink%20%E5%AD%90%E7%B3%BB%E7%BB%9F%EF%BC%88%E5%B7%B2%E7%A6%81%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%20%5B%200.024932%5D%20%E5%AE%A1%E8%AE%A1%EF%BC%9A%E7%B1%BB%E5%9E%8B%3D2000%20%E5%AE%A1%E8%AE%A1(0.024%3A1)%3A%E7%8A%B6%E6%80%81%3D%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20%E5%AE%A1%E8%AE%A1%E5%B7%B2%E5%90%AF%E7%94%A8%3D0%20%E7%BB%93%E6%9E%9C%3D1%3CBR%20%2F%3E%20%5B%200.025352%5D%20thermal_sys%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E7%83%AD%E8%B0%83%E9%80%9F%E5%99%A8%E2%80%9Cstep_wise%E2%80%9D%3CBR%20%2F%3E%20%5B%200.025356%5D%20thermal_sys%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E7%83%AD%E8%B0%83%E8%8A%82%E5%99%A8%E2%80%9Cpower_allocator%E2%80%9D%3CBR%20%2F%3E%20%5B%200.025401%5D%20cpuidle%EF%BC%9A%E4%BD%BF%E7%94%A8%E8%B0%83%E9%80%9F%E5%99%A8%E8%8F%9C%E5%8D%95%3CBR%20%2F%3E%5B%200.025566%5D%20%E7%A1%AC%E4%BB%B6%E6%96%AD%E7%82%B9%EF%BC%9A%E6%89%BE%E5%88%B0%206%20%E4%B8%AA%E6%96%AD%E7%82%B9%E5%AF%84%E5%AD%98%E5%99%A8%E5%92%8C%204%20%E4%B8%AA%E7%9B%91%E8%A7%86%E7%82%B9%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3CBR%20%2F%3E%5B%200.025647%5D%20ASID%20%E5%88%86%E9%85%8D%E5%99%A8%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%8C%E5%8C%85%E5%90%AB%2065536%20%E4%B8%AA%E6%9D%A1%E7%9B%AE%3CBR%20%2F%3E%5B%200.026696%5D%20%E4%B8%B2%E5%8F%A3%EF%BC%9AAMBA%20PL011%20UART%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%5B%200.026763%5D%20imx%20mu%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%3CBR%20%2F%3E%5B%200.026785%5D%20imx%20rpmsg%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%3CBR%20%2F%3E%5B%200.032936%5D%20platform%20soc%400%3A%20%E4%BF%AE%E5%A4%8D%E4%BA%86%E4%B8%8E%20%2Fsoc%400%2Fbus%4030000000%2Fefuse%4030350000%2Funique-id%408%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%200.035120%5D%20%E5%B9%B3%E5%8F%B0%2030330000.pinctrl%3A%E4%BF%AE%E5%A4%8D%E4%BA%86%E4%B8%8E%20%2Fsoc%400%2Fbus%4030000000%2Fpinctrl%4030330000%2Fhoggrp%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%200.035566%5D%20imx8mp-pinctrl%2030330000.pinctrl%3A%E5%88%9D%E5%A7%8B%E5%8C%96%20IMX%20pinctrl%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%5B%200.036067%5D%20%E5%B9%B3%E5%8F%B0%2030350000.efuse%3A%E4%BF%AE%E5%A4%8D%E4%BA%86%E4%B8%8E%20%2Fsoc%400%2Fbus%4030000000%2Fclock-controller%4030380000%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%200.037099%5D%20%E5%B9%B3%E5%8F%B0%2030350000.efuse%3A%E4%BF%AE%E5%A4%8D%E4%BA%86%E4%B8%8E%20%2Fsoc%400%2Fbus%4030000000%2Fclock-controller%4030380000%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%200.049206%5D%20%E6%A8%A1%E5%9D%97%EF%BC%9A25968%20%E4%B8%AA%E9%A1%B5%E9%9D%A2%E7%AC%A6%E5%90%88%E9%9D%9E%20PLT%20%E4%BD%BF%E7%94%A8%E8%8C%83%E5%9B%B4%3CBR%20%2F%3E%5B%200.049215%5D%20%E6%A8%A1%E5%9D%97%EF%BC%9APLT%20%E4%BD%BF%E7%94%A8%E8%8C%83%E5%9B%B4%E5%86%85%E7%9A%84%E6%A8%A1%E5%9D%97%E6%9C%89%20517488%20%E4%B8%AA%E3%80%82%3CBR%20%2F%3E%20%5B%200.049877%5D%20HugeTLB%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%201.00%20GiB%20%E9%A1%B5%E9%9D%A2%E5%A4%A7%E5%B0%8F%EF%BC%8C%E9%A2%84%E5%88%86%E9%85%8D%200%20%E4%B8%AA%E9%A1%B5%E9%9D%A2%3CBR%20%2F%3E%5B%200.049884%5D%20HugeTLB%EF%BC%9A%E5%8F%AF%E9%87%8A%E6%94%BE%200%20KiB%20%E8%99%9A%E6%8B%9F%E5%86%85%E5%AD%98%E6%98%A0%E5%B0%84%EF%BC%8C%E7%94%A8%E4%BA%8E%201.00%20GiB%20%E7%9A%84%E9%A1%B5%E9%9D%A2%3CBR%20%2F%3E%5B%200.049889%5D%20HugeTLB%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%2032.0%20MiB%20%E9%A1%B5%E9%9D%A2%E5%A4%A7%E5%B0%8F%EF%BC%8C%E9%A2%84%E5%88%86%E9%85%8D%200%20%E9%A1%B5%3CBR%20%2F%3E%5B%200.049892%5D%20HugeTLB%EF%BC%9A%E5%8F%AF%E9%87%8A%E6%94%BE%200%20KiB%20vmemmap%20%E4%BB%A5%E5%A4%84%E7%90%86%2032.0%20MiB%20%E7%9A%84%E9%A1%B5%E9%9D%A2%3CBR%20%2F%3E%5B%200.049896%5D%20HugeTLB%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%202.00%20MiB%20%E9%A1%B5%E9%9D%A2%E5%A4%A7%E5%B0%8F%EF%BC%8C%E9%A2%84%E5%88%86%E9%85%8D%200%20%E4%B8%AA%E9%A1%B5%E9%9D%A2%3CBR%20%2F%3E%5B%200.049902%5D%20HugeTLB%EF%BC%9A%E5%8F%AF%E9%87%8A%E6%94%BE%200%20KiB%20vmemmap%20%E4%BB%A5%E5%A4%84%E7%90%86%202.00%20MiB%20%E7%9A%84%E9%A1%B5%E9%9D%A2%3CBR%20%2F%3E%5B%200.049909%5D%20HugeTLB%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%2064.0%20KiB%20%E9%A1%B5%E9%9D%A2%E5%A4%A7%E5%B0%8F%EF%BC%8C%E9%A2%84%E5%88%86%E9%85%8D%200%20%E9%A1%B5%3CBR%20%2F%3E%5B%200.049912%5D%20HugeTLB%EF%BC%9A%E5%8F%AF%E9%87%8A%E6%94%BE%200%20KiB%20%E8%99%9A%E6%8B%9F%E5%86%85%E5%AD%98%E6%98%A0%E5%B0%84%EF%BC%8C%E7%94%A8%E4%BA%8E%2064.0%20KiB%20%E7%9A%84%E9%A1%B5%E9%9D%A2%3CBR%20%2F%3E%5B%200.052093%5D%20iommu%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%9F%9F%E7%B1%BB%E5%9E%8B%EF%BC%9A%E5%B7%B2%E7%BF%BB%E8%AF%91%3CBR%20%2F%3E%5B%200.052102%5D%20iommu%EF%BC%9ADMA%20%E5%9F%9F%20TLB%20%E5%A4%B1%E6%95%88%E7%AD%96%E7%95%A5%EF%BC%9A%E4%B8%A5%E6%A0%BC%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%200.052394%5D%20SCSI%20%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%5B%200.052679%5D%20usbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usbfs%3CBR%20%2F%3E%20%5B%200.052709%5D%20usbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3E%5B%200.052742%5D%20usbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb%3CBR%20%2F%3E%20%5B%200.053603%5D%20pps_core%EF%BC%9ALinuxPPS%20API%20%E7%89%88%E6%9C%AC%201%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%200.053607%5D%20pps_core%EF%BC%9A%E8%BD%AF%E4%BB%B6%E7%89%88%E6%9C%AC%E3%80%825.3.6%20-%20%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%202005-2007%20Rodolfo%20Giometti%20%3CGIOMETTI%3E%3CBR%20%2F%3E%5B%200.053619%5D%20%E5%B7%B2%E6%B3%A8%E5%86%8C%20PTP%20%E6%97%B6%E9%92%9F%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%200.053886%5D%20EDAC%20MC%EF%BC%9A%E7%89%88%E6%9C%AC%EF%BC%9A3.0.0%3CBR%20%2F%3E%5B%200.054304%5D%20scmi_core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vgaarb%EF%BC%9A%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3E%5B%200.056088%5D%20%E6%97%B6%E9%92%9F%E6%BA%90%EF%BC%9A%E5%B7%B2%E5%88%87%E6%8D%A2%E5%88%B0%E6%97%B6%E9%92%9F%E6%BA%90%20arch_sys_counter%3CBR%20%2F%3E%20%5B%200.056287%5D%20VFS%EF%BC%9A%E7%A3%81%E7%9B%98%E9%85%8D%E9%A2%9D%20dquot_6.6.0%3CBR%20%2F%3E%5B%200.056396%5D%20VFS%EF%BC%9ADquot%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%880%E9%98%B6%EF%BC%8C4096%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%20%5B%200.063310%5D%20NET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20PF_INET%20%E5%8D%8F%E8%AE%AE%E6%97%8F%3CBR%20%2F%3E%5B%200.063495%5D%20IP%20%E6%A0%87%E8%AF%86%E7%AC%A6%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A65536%EF%BC%88%E9%98%B6%E6%95%B0%EF%BC%9A7%EF%BC%8C524288%20%E5%AD%97%E8%8A%82%EF%BC%8C%E7%BA%BF%E6%80%A7%EF%BC%89%3CBR%20%2F%3E%20%5B%200.066275%5D%20tcp_listen_portaddr_hash%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A2048%EF%BC%88%E9%98%B6%E6%95%B0%EF%BC%9A3%EF%BC%8C32768%20%E5%AD%97%E8%8A%82%EF%BC%8C%E7%BA%BF%E6%80%A7%EF%BC%89%3CBR%20%2F%3E%20%5B%200.066325%5D%20%E8%A1%A8%E6%89%B0%E5%8A%A8%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A65536%EF%BC%88%E9%98%B6%E6%95%B0%EF%BC%9A6%EF%BC%8C262144%20%E5%AD%97%E8%8A%82%EF%BC%8C%E7%BA%BF%E6%80%A7%EF%BC%89%3CBR%20%2F%3E%20%5B%200.066337%5D%20TCP%20%E5%B7%B2%E5%BB%BA%E7%AB%8B%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A32768%EF%BC%88%E9%98%B6%E6%95%B0%EF%BC%9A6%EF%BC%8C262144%20%E5%AD%97%E8%8A%82%EF%BC%8C%E7%BA%BF%E6%80%A7%EF%BC%89%3CBR%20%2F%3E%20%5B%200.066585%5D%20TCP%E7%BB%91%E5%AE%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A32768%EF%BC%88%E9%98%B6%E6%95%B0%EF%BC%9A8%EF%BC%8C1048576%E5%AD%97%E8%8A%82%EF%BC%8C%E7%BA%BF%E6%80%A7%EF%BC%89%3CBR%20%2F%3E%20%5B%200.067521%5D%20TCP%EF%BC%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E5%B7%B2%E9%85%8D%E7%BD%AE%EF%BC%88%E5%B7%B2%E5%BB%BA%E7%AB%8B%E8%BF%9E%E6%8E%A5%2032768%EF%BC%8C%E7%BB%91%E5%AE%9A%2032768%EF%BC%89%3CBR%20%2F%3E%20%5B%200.067635%5D%20UDP%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A2048%EF%BC%88%E9%98%B6%E6%95%B0%EF%BC%9A4%EF%BC%8C65536%20%E5%AD%97%E8%8A%82%EF%BC%8C%E7%BA%BF%E6%80%A7%EF%BC%89%3CBR%20%2F%3E%20%5B%200.067720%5D%20UDP-Lite%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A2048%EF%BC%88%E9%98%B6%E6%95%B0%EF%BC%9A4%EF%BC%8C65536%20%E5%AD%97%E8%8A%82%EF%BC%8C%E7%BA%BF%E6%80%A7%EF%BC%89%3CBR%20%2F%3E%20%5B%200.067927%5D%20NET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20PF_UNIX%2FPF_LOCAL%20%E5%8D%8F%E8%AE%AE%E6%97%8F%3CBR%20%2F%3E%5B%200.068373%5D%20RPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%91%BD%E5%90%8D%E7%9A%84%20UNIX%20%E5%A5%97%E6%8E%A5%E5%AD%97%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3E%5B%200.068379%5D%20RPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20UDP%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3E%5B%200.068381%5D%20RPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20TCP%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3E%5B%200.068384%5D%20RPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20tcp-with-tls%20%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3E%5B%200.068386%5D%20RPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20tcp%20NFSv4.1%20%E5%8F%8D%E5%90%91%E9%80%9A%E9%81%93%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3E%5B%200.069403%5D%20PCI%EF%BC%9ACLS%200%20%E5%AD%97%E8%8A%82%EF%BC%8C%E9%BB%98%E8%AE%A4%E5%80%BC%2064%3CBR%20%2F%3E%20%5B%200.070488%5D%20%E5%88%9D%E5%A7%8B%E5%8C%96%E7%B3%BB%E7%BB%9F%E5%8F%AF%E4%BF%A1%E5%AF%86%E9%92%A5%E7%8E%AF%3CBR%20%2F%3E%5B%200.070625%5D%20%E5%B7%A5%E4%BD%9C%E9%9B%86%EF%BC%9A%E6%97%B6%E9%97%B4%E6%88%B3%E4%BD%8D%E6%95%B0%3D46%20%E6%9C%80%E5%A4%A7%E9%98%B6%E6%95%B0%3D20%20%E6%A1%B6%E9%98%B6%E6%95%B0%3D0%3CBR%20%2F%3E%20%5B0.070895%5Dsquashfs%3A%E7%89%88%E6%9C%AC4.0(2009%2F01%2F31)%E8%8F%B2%E5%88%A9%E6%99%AE%C2%B7%E5%8A%B3%E6%A0%BC%3CBR%20%2F%3E%5B%200.071096%5D%20NFS%EF%BC%9A%E6%B3%A8%E5%86%8C%20id_resolver%20%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8B%3CBR%20%2F%3E%5B%200.071116%5D%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E9%94%AE%E7%B1%BB%E5%9E%8B%20id_resolver%3CBR%20%2F%3E%20%5B%200.071120%5D%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E9%94%AE%E7%B1%BB%E5%9E%8B%20id_legacy%3CBR%20%2F%3E%20%5B%200.071137%5D%20nfs4filelayout_init%EF%BC%9ANFSv4%20%E6%96%87%E4%BB%B6%E5%B8%83%E5%B1%80%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%AD%A3%E5%9C%A8%E6%B3%A8%E5%86%8C...%3CBR%20%2F%3E%20%5B%200.071142%5D%20nfs4flexfilelayout_init%EF%BC%9ANFSv4%20Flexfile%20%E5%B8%83%E5%B1%80%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%AD%A3%E5%9C%A8%E6%B3%A8%E5%86%8C...%3CBR%20%2F%3E%20%5B%200.071159%5D%20jffs2%EF%BC%9A%E7%89%88%E6%9C%AC%202.2%E3%80%82%EF%BC%88%E4%B8%8E%E9%9D%9E%EF%BC%89%20%C2%A9%202001-2006%20Red%20Hat%2C%20Inc.%3CBR%20%2F%3E%20%5B%200.071346%5D%209p%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%AE%89%E8%A3%85%20v9fs%209p2000%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%200.100048%5D%20jitterentropy%EF%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%EF%BC%8C%E4%B8%BB%E6%9C%BA%E4%B8%8D%E7%AC%A6%E5%90%88%E8%A6%81%E6%B1%82%EF%BC%9A9%3CBR%20%2F%3E%20%5B%200.100055%5D%20%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8B%E9%9D%9E%E5%AF%B9%E7%A7%B0%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%200.100059%5D%20%E9%9D%9E%E5%AF%B9%E7%A7%B0%E5%AF%86%E9%92%A5%E8%A7%A3%E6%9E%90%E5%99%A8%E2%80%9Cx509%E2%80%9D%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%200.100104%5D%20%E5%B7%B2%E5%8A%A0%E8%BD%BD%E5%9D%97%E5%B1%82%20SCSI%20%E9%80%9A%E7%94%A8%20(bsg)%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%200.4%EF%BC%88%E4%B8%BB%E7%89%88%E6%9C%AC%20246%EF%BC%89%3CBR%20%2F%3E%20%5B%200.100110%5D%20io%20%E8%B0%83%E5%BA%A6%E5%99%A8%20mq-deadline%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%200.100114%5D%20io%20%E8%B0%83%E5%BA%A6%E5%99%A8%20kyber%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%200.100139%5D%20io%20%E8%B0%83%E5%BA%A6%E5%99%A8%20bfq%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%200.115771%5D%20imx-sdma%2030bd0000.dma-controller%3A%E7%9B%B4%E6%8E%A5%E5%8A%A0%E8%BD%BD%20imx%2Fsdma%2Fsdma-imx7d.bin%20%E5%9B%BA%E4%BB%B6%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%20-2%3CBR%20%2F%3E%20%5B%200.115787%5D%20imx-sdma%2030bd0000.dma-controller%3A%E5%9B%9E%E9%80%80%E5%88%B0%20sysfs%20%E5%A4%87%E9%80%89%E6%96%B9%E6%A1%88%EF%BC%9Aimx%2Fsdma%2Fsdma-imx7d.bin%3CBR%20%2F%3E%20%5B%200.117292%5D%20mxs-dma%2033000000.dma-apbh%3A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%5B%200.118069%5D%20SoC%EF%BC%9Ai.MX8MP%20%E7%89%88%E6%9C%AC%201.1%3CBR%20%2F%3E%20%5B%200.118477%5D%20%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3E%5B%200.135536%5D%20%E4%B8%B2%E5%8F%A3%EF%BC%9A8250%2F16550%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C4%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%EF%BC%8C%E5%B7%B2%E5%90%AF%E7%94%A8%20IRQ%20%E5%85%B1%E4%BA%AB%3CBR%20%2F%3E%5B%200.138454%5D%2030880000.serial%3Attymxc2%20%E4%BD%8D%E4%BA%8E%20MMIO%200x30880000%EF%BC%88%E4%B8%AD%E6%96%AD%E5%8F%B7%20%3D%2016%EF%BC%8C%E5%9F%BA%E6%9C%AC%E6%B3%A2%E7%89%B9%E7%8E%87%20%3D%205000000%EF%BC%89%EF%BC%8C%E6%98%AF%E4%B8%80%E5%8F%B0%20IMX%20%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3E%20%5B%200.138703%5D%20%E4%B8%B2%E5%8F%A3%20serial0%EF%BC%9Atty%20%E7%AB%AF%E5%8F%A3%20ttymxc2%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%200.139315%5D%2030890000.serial%3A%E4%BD%8D%E4%BA%8E%20MMIO%200x30890000%20%E7%9A%84%20ttymxc1%EF%BC%88%E4%B8%AD%E6%96%AD%E5%8F%B7%20%3D%2017%EF%BC%8C%E5%9F%BA%E6%9C%AC%E6%B3%A2%E7%89%B9%E7%8E%87%20%3D%201500000%EF%BC%89%E6%98%AF%E4%B8%80%E5%8F%B0%20IMX%20%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3E%20%5B%200.139350%5D%20printk%3A%20%E6%97%A7%E7%89%88%E6%8E%A7%E5%88%B6%E5%8F%B0%20%5Bttymxc1%5D%20%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%5B%201.222791%5D%20%E5%BE%AA%E7%8E%AF%EF%BC%9A%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3E%5B%201.227149%5D%20of_reserved_mem_lookup()%20%E8%BF%94%E5%9B%9E%20NULL%3CBR%20%2F%3E%20%5B%201.237919%5D%20tun%EF%BC%9A%E9%80%9A%E7%94%A8%20TUN%2FTAP%20%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C1.6%3CBR%20%2F%3E%20%5B%201.244863%5D%20sky2%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%201.30%3CBR%20%2F%3E%20%5B%201.249061%5D%20usbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20r8152-cfgselector%3CBR%20%2F%3E%20%5B%201.255367%5D%20usbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20r8152%3CBR%20%2F%3E%20%5B%201.261230%5D%20VFIO%20-%20%E7%94%A8%E6%88%B7%E7%BA%A7%E5%85%83%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%EF%BC%9A0.3%3CBR%20%2F%3E%20%5B%201.271293%5D%20usbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20uas%3CBR%20%2F%3E%20%5B%201.276669%5D%20usbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb-storage%3CBR%20%2F%3E%20%5B%201.282753%5D%20usbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usbserial_generic%3CBR%20%2F%3E%20%5B%201.289312%5D%20usbserial%EF%BC%9A%E5%B7%B2%E4%B8%BA%E9%80%9A%E7%94%A8%20USB%20%E4%B8%B2%E8%A1%8C%E6%94%AF%E6%8C%81%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%201.295346%5D%20usbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20ftdi_sio%3CBR%20%2F%3E%20%5B%201.301121%5D%20usbserial%EF%BC%9A%E5%B7%B2%E4%B8%BA%20FTDI%20USB%20%E4%B8%B2%E5%8F%A3%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%20USB%20%E4%B8%B2%E5%8F%A3%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.308467%5D%20usbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb_serial_simple%3CBR%20%2F%3E%20%5B%201.315022%5D%20usbserial%EF%BC%9A%E5%B7%B2%E4%B8%BA%20Carelink%20%E6%B3%A8%E5%86%8C%20USB%20%E4%B8%B2%E5%8F%A3%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.321145%5D%20usbserial%EF%BC%9A%E5%B7%B2%E4%B8%BA%20flashloader%20%E6%B3%A8%E5%86%8C%20USB%20%E4%B8%B2%E5%8F%A3%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.327526%5D%20usbserial%EF%BC%9A%E5%B7%B2%E4%B8%BA%20funsoft%20%E6%B3%A8%E5%86%8C%20USB%20%E4%B8%B2%E5%8F%A3%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.333554%5D%20usbserial%EF%BC%9A%E5%B7%B2%E4%B8%BA%20Google%20%E6%B3%A8%E5%86%8C%20USB%20%E4%B8%B2%E5%8F%A3%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.339503%5D%20usbserial%EF%BC%9A%E5%B7%B2%E4%B8%BA%20hp4x%20%E6%B3%A8%E5%86%8C%20USB%20%E4%B8%B2%E5%8F%A3%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.345284%5D%20usbserial%EF%BC%9A%E5%B7%B2%E4%B8%BA%20kaufmann%20%E6%B3%A8%E5%86%8C%20USB%20%E4%B8%B2%E5%8F%A3%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.351402%5D%20usbserial%EF%BC%9Alibtransistor%20%E5%B7%B2%E6%B3%A8%E5%86%8C%20USB%20%E4%B8%B2%E5%8F%A3%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.357961%5D%20usbserial%EF%BC%9A%E5%B7%B2%E4%B8%BA%20moto_modem%20%E6%B3%A8%E5%86%8C%20USB%20%E4%B8%B2%E5%8F%A3%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.364256%5D%20usbserial%EF%BC%9A%E5%B7%B2%E4%B8%BA%20motorola_tetra%20%E6%B3%A8%E5%86%8C%20USB%20%E4%B8%B2%E5%8F%A3%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.370900%5D%20usbserial%EF%BC%9A%E8%AF%BA%E5%9F%BA%E4%BA%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20USB%20%E4%B8%B2%E5%8F%A3%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.376765%5D%20usbserial%EF%BC%9A%E5%B7%B2%E4%B8%BA%20novatel_gps%20%E6%B3%A8%E5%86%8C%20USB%20%E4%B8%B2%E5%8F%A3%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.383149%5D%20usbserial%EF%BC%9A%E5%B7%B2%E4%B8%BA%20siemens_mpi%20%E6%B3%A8%E5%86%8C%20USB%20%E4%B8%B2%E5%8F%A3%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.389527%5D%20usbserial%EF%BC%9A%E5%B7%B2%E4%B8%BA%20Suunto%20%E6%B3%A8%E5%86%8C%20USB%20%E4%B8%B2%E5%8F%A3%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.395476%5D%20usbserial%EF%BC%9Avivopay%20%E5%B7%B2%E6%B3%A8%E5%86%8C%20USB%20%E4%B8%B2%E5%8F%A3%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.401511%5D%20usbserial%EF%BC%9A%E5%B7%B2%E4%B8%BA%20zio%20%E6%B3%A8%E5%86%8C%20USB%20%E4%B8%B2%E5%8F%A3%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.407203%5D%20usbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb_ehset_test%3CBR%20%2F%3E%20%5B%201.413528%5D%20usbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20onboard-usb-hub%3CBR%20%2F%3E%20%5B%201.422006%5D%20snvs_rtc%2030370000.snvs%3Asnvs-rtc-lp%3A%E6%B3%A8%E5%86%8C%E4%B8%BA%20rtc0%3CBR%20%2F%3E%20%5B%201.428227%5D%20snvs_rtc%2030370000.snvs%3Asnvs-rtc-lp%3A%E5%B0%86%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%92%9F%E8%AE%BE%E7%BD%AE%E4%B8%BA%201970-01-01T00%3A00%3A00%20UTC%20(0)%3CBR%20%2F%3E%20%5B%201.437427%5D%20i2c_dev%EF%BC%9Ai2c%20%2Fdev%20%E6%9D%A1%E7%9B%AE%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%5B%201.445729%5D%20%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%202.3%3CBR%20%2F%3E%20%5B%201.450203%5D%20%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%20%E5%8D%8F%E8%AE%AE%20H4%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%201.455351%5D%20%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%20%E5%8D%8F%E8%AE%AE%20BCSP%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%201.460695%5D%20%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%20%E5%8D%8F%E8%AE%AE%20LL%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%201.465847%5D%20%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%20%E5%8D%8F%E8%AE%AE%20ATH3K%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%201.471280%5D%20%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%20%E5%8D%8F%E8%AE%AE%E4%B8%89%E7%BA%BF%20(H5)%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%201.477642%5D%20%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%20%E5%8D%8F%E8%AE%AE%EF%BC%8C%E5%8D%9A%E9%80%9A%E5%85%AC%E5%8F%B8%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%201.483333%5D%20%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%20%E5%8D%8F%E8%AE%AE%20QCA%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%201.488739%5D%20EDAC%20MC%EF%BC%9AECC%20%E6%9C%AA%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%5B%201.493561%5D%20sdhci%EF%BC%9A%E5%AE%89%E5%85%A8%E6%95%B0%E5%AD%97%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%5B%201.499762%5D%20sdhci%EF%BC%9A%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89(c)%20%E7%9A%AE%E5%9F%83%E5%B0%94%C2%B7%E5%A5%A5%E6%96%AF%E6%9B%BC%3CBR%20%2F%3E%5B%201.504580%5D%20Synopsys%20Designware%20%E5%A4%9A%E5%AA%92%E4%BD%93%E5%8D%A1%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%5B%201.511193%5D%20sdhci-pltfm%EF%BC%9ASDHCI%20%E5%B9%B3%E5%8F%B0%E5%92%8C%20OF%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8A%A9%E6%89%8B%3CBR%20%2F%3E%5B%201.519372%5D%20ledtrig-cpu%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E4%BB%A5%E6%8C%87%E7%A4%BA%20CPU%20%E6%B4%BB%E5%8A%A8%3CBR%20%2F%3E%5B%201.526326%5D%20SMCCC%EF%BC%9ASOC_ID%EF%BC%9AARCH_SOC_ID%20%E6%9C%AA%E5%AE%9E%E7%8E%B0%EF%BC%8C%E8%B7%B3%E8%BF%87....%3CBR%20%2F%3E%20%5B%201.535249%5D%20%E7%A1%AC%E4%BB%B6%E6%80%A7%E8%83%BD%E4%BA%8B%E4%BB%B6%EF%BC%9A%E5%B7%B2%E5%90%AF%E7%94%A8%20armv8_cortex_a53%20PMU%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%8F%AF%E7%94%A8%E8%AE%A1%E6%95%B0%E5%99%A8%E4%B8%BA%207%20%E4%B8%AA%3CBR%20%2F%3E%5B%201.545746%5D%20platform%20soc%400%3A%20%E4%BF%AE%E5%A4%8D%E4%BA%86%E4%B8%8E%20%2Fsoc%400%2Fbus%4030000000%2Fefuse%4030350000%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%5B%201.548948%5D%20mmc2%EF%BC%9A30b60000.mmc%20%E4%B8%8A%E7%9A%84%20SDHCI%20%E6%8E%A7%E5%88%B6%E5%99%A8%20%5B30b60000.mmc%5D%E4%BD%BF%E7%94%A8ADMA%3CBR%20%2F%3E%20%5B%201.555377%5D%20optee%EF%BC%9A%E6%8E%A2%E6%B5%8B%E7%AE%A1%E9%81%93%E6%96%B9%E6%B3%95%E3%80%82%3CBR%20%2F%3E%5B%201.565851%5D%20optee%EF%BC%9AAPI%20%E7%94%A8%E6%88%B7%20ID%20%E4%B8%8D%E5%8C%B9%E9%85%8D%3CBR%20%2F%3E%5B%201.569678%5D%20optee%EF%BC%9A%E5%9B%BA%E4%BB%B6%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%20-22%3CBR%20%2F%3E%20%5B%201.576620%5D%20NET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20PF_LLC%20%E5%8D%8F%E8%AE%AE%E6%97%8F%3CBR%20%2F%3E%5B%201.581492%5D%20u32%20%E5%88%86%E7%B1%BB%E5%99%A8%3CBR%20%2F%3E%5B%201.584247%5D%20%E8%BE%93%E5%85%A5%E8%AE%BE%E5%A4%87%E6%A3%80%E6%9F%A5%E5%BC%80%E5%90%AF%3CBR%20%2F%3E%5B%201.587910%5D%20%E5%B7%B2%E9%85%8D%E7%BD%AE%E7%9A%84%E6%93%8D%E4%BD%9C%3CBR%20%2F%3E%5B%201.591634%5D%20NET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20PF_INET6%20%E5%8D%8F%E8%AE%AE%E6%97%8F%3CBR%20%2F%3E%5B%201.598148%5D%20IPv6%20%E5%88%86%E6%AE%B5%E8%B7%AF%E7%94%B1%3CBR%20%2F%3E%5B%201.601891%5D%20%E5%9F%BA%E4%BA%8E%20IPv6%20%E7%9A%84%E5%8E%9F%E4%BD%8D%20OAM%20(IOAM)%3CBR%20%2F%3E%20%5B%201.605875%5D%20NET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20PF_PACKET%20%E5%8D%8F%E8%AE%AE%E6%97%8F%3CBR%20%2F%3E%5B%201.610955%5D%20bridge%EF%BC%9A%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%E4%B8%8D%E5%86%8D%E6%94%AF%E6%8C%81%E9%80%9A%E8%BF%87%20arp%2Fip%2Fip6tables%20%E8%BF%9B%E8%A1%8C%E8%BF%87%E6%BB%A4%E3%80%82%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%EF%BC%8C%E8%AF%B7%E6%9B%B4%E6%96%B0%E8%84%9A%E6%9C%AC%E4%BB%A5%E5%8A%A0%E8%BD%BD%20br_netfilter%E3%80%82%3CBR%20%2F%3E%20%5B%201.625927%5D%20%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20TTY%20%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%5B%201.630834%5D%20%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%5B%201.634392%5D%20mmc2%EF%BC%9A%E5%9C%B0%E5%9D%80%200001%20%E5%A4%84%E6%96%B0%E5%A2%9E%20HS400%20%E5%A2%9E%E5%BC%BA%E5%9E%8B%E9%A2%91%E9%97%AA%20MMC%20%E5%8D%A1%3CBR%20%2F%3E%5B%201.636001%5D%20%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20%E7%89%88%E6%9C%AC%201.11%3CBR%20%2F%3E%20%5B1.642888%5Dmmcblk2%EF%BC%9Ammc2%EF%BC%9A0001%20064G90%2058.2%20GiB%3CBR%20%2F%3E%20%5B%201.646098%5D%20%E8%93%9D%E7%89%99%EF%BC%9ABNEP%EF%BC%88%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BB%BF%E7%9C%9F%EF%BC%89%E7%89%88%E6%9C%AC%201.3%3CBR%20%2F%3E%20%5B%201.653585%5D%20mmcblk2%EF%BC%9Ap1%20p2%20p3%3CBR%20%2F%3E%20%5B%201.655851%5D%20%E8%93%9D%E7%89%99%EF%BC%9ABNEP%20%E8%BF%87%E6%BB%A4%E5%99%A8%EF%BC%9A%E5%8D%8F%E8%AE%AE%E7%BB%84%E6%92%AD%3CBR%20%2F%3E%5B%201.661320%5D%20mmcblk2boot0%3A%20mmc2%3A0001%20064G90%208.00%20MiB%3CBR%20%2F%3E%20%5B%201.664139%5D%20%E8%93%9D%E7%89%99%EF%BC%9ABNEP%20%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%5B%201.670589%5D%20mmcblk2boot1%3A%20mmc2%3A0001%20064G90%208.00%20MiB%3CBR%20%2F%3E%20%5B%201.674997%5D%208021q%EF%BC%9A802.1Q%20VLAN%20%E6%94%AF%E6%8C%81%20v1.8%3CBR%20%2F%3E%20%5B%201.680430%5D%20mmcblk2rpmb%3A%20mmc2%3A0001%20064G90%2016.0%20MiB%EF%BC%8Cchardev%20(238%3A0)%3CBR%20%2F%3E%20%5B%201.683109%5D%20lib80211%EF%BC%9AIEEE802.11%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E9%80%9A%E7%94%A8%E4%BE%8B%E7%A8%8B%3CBR%20%2F%3E%5B%201.695071%5D%209pnet%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%AE%89%E8%A3%85%209P2000%20%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.699490%5D%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8B%20dns_resolver%3CBR%20%2F%3E%20%5B%201.704490%5D%20NET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20PF_VSOCK%20%E5%8D%8F%E8%AE%AE%E6%97%8F%3CBR%20%2F%3E%5B%201.719723%5D%20%E5%B7%B2%E6%B3%A8%E5%86%8C%20taskstats%20%E7%89%88%E6%9C%AC%201%3CBR%20%2F%3E%20%5B%201.723967%5D%20%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%E7%BC%96%E8%AF%91%E5%86%85%E7%BD%AE%E7%9A%84%20X.509%20%E8%AF%81%E4%B9%A6%3CBR%20%2F%3E%5B%201.751680%5D%20gpio%20gpiochip0%EF%BC%9AGPIO%20%E5%9F%BA%E5%9D%80%E7%9A%84%E9%9D%99%E6%80%81%E5%88%86%E9%85%8D%E5%B7%B2%E5%BC%83%E7%94%A8%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E5%8A%A8%E6%80%81%E5%88%86%E9%85%8D%E3%80%82%3CBR%20%2F%3E%5B%201.762305%5D%20gpio%20gpiochip1%EF%BC%9AGPIO%20%E5%9F%BA%E5%9D%80%E7%9A%84%E9%9D%99%E6%80%81%E5%88%86%E9%85%8D%E5%B7%B2%E5%BC%83%E7%94%A8%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E5%8A%A8%E6%80%81%E5%88%86%E9%85%8D%E3%80%82%3CBR%20%2F%3E%5B%201.772790%5D%20gpio%20gpiochip2%EF%BC%9AGPIO%20%E5%9F%BA%E5%9D%80%E7%9A%84%E9%9D%99%E6%80%81%E5%88%86%E9%85%8D%E5%B7%B2%E5%BC%83%E7%94%A8%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E5%8A%A8%E6%80%81%E5%88%86%E9%85%8D%E3%80%82%3CBR%20%2F%3E%5B%201.783311%5D%20gpio%20gpiochip3%EF%BC%9AGPIO%20%E5%9F%BA%E5%9D%80%E7%9A%84%E9%9D%99%E6%80%81%E5%88%86%E9%85%8D%E5%B7%B2%E5%BC%83%E7%94%A8%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E5%8A%A8%E6%80%81%E5%88%86%E9%85%8D%E3%80%82%3CBR%20%2F%3E%5B%201.793861%5D%20gpio%20gpiochip4%EF%BC%9AGPIO%20%E5%9F%BA%E5%9D%80%E7%9A%84%E9%9D%99%E6%80%81%E5%88%86%E9%85%8D%E5%B7%B2%E5%BC%83%E7%94%A8%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E5%8A%A8%E6%80%81%E5%88%86%E9%85%8D%E3%80%82%3CBR%20%2F%3E%5B%201.806692%5D%20i2c%20i2c-0%EF%BC%9AIMX%20I2C%20%E9%80%82%E9%85%8D%E5%99%A8%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%201.813480%5D%20rtc-rx8111%202-0032%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E4%B8%BA%20rtc1%3CBR%20%2F%3E%20%5B%201.820041%5D%20ina238%202-0043%3A%20%E5%8A%9F%E7%8E%87%E7%9B%91%E6%B5%8B%20ina237%20(Rshunt%20%3D%2050000%20uOhm%2C%20gain%20%3D%204)%3CBR%20%2F%3E%20%5B%201.821839%5D%20nxp-pca9450%200-0025%3A%20pca9450bc%20%E5%B7%B2%E6%8E%A2%E6%B5%8B%E3%80%82%3CBR%20%2F%3E%5B%201.827481%5D%20i2c%20i2c-2%EF%BC%9AIMX%20I2C%20%E9%80%82%E9%85%8D%E5%99%A8%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%201.869694%5D%20usb251xb%203-002c%3A%20%E9%9B%86%E7%BA%BF%E5%99%A8%E9%85%8D%E7%BD%AE%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3E%5B%201.875553%5D%20usb251xb%203-002c%EF%BC%9A%E9%9B%86%E7%BA%BF%E5%99%A8%E6%8E%A2%E6%B5%8B%E6%88%90%E5%8A%9F%3CBR%20%2F%3E%5B%201.880583%5D%20i2c%20i2c-3%EF%BC%9AIMX%20I2C%20%E9%80%82%E9%85%8D%E5%99%A8%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%201.885922%5D%20imx8mq-usb-phy%20381f0040.usb-phy%3A%E6%9C%AA%E6%89%BE%E5%88%B0%E7%94%B5%E6%BA%90%E6%80%BB%E7%BA%BF%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3E%5B%201.894643%5D%20imx8mq-usb-phy%20382f0040.usb-phy%3A%E6%9C%AA%E6%89%BE%E5%88%B0%E7%94%B5%E6%BA%90%E6%80%BB%E7%BA%BF%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3E%5B%201.912708%5D%2030a60000.serial%3Attymxc3%20%E4%BD%8D%E4%BA%8E%20MMIO%200x30a60000%EF%BC%88%E4%B8%AD%E6%96%AD%E5%8F%B7%20%3D%20199%EF%BC%8C%E5%9F%BA%E6%9C%AC%E6%B3%A2%E7%89%B9%E7%8E%87%20%3D%201500000%EF%BC%89%EF%BC%8C%E6%98%AF%E4%B8%80%E5%8F%B0%20IMX%20%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3E%20%5B%201.922917%5D%20imx-dwmac%2030bf0000.ethernet%3A%E6%9C%AA%E6%89%BE%E5%88%B0%20IRQ%20eth_lpi%3CBR%20%2F%3E%20%5B%201.929740%5D%20imx-dwmac%2030bf0000.ethernet%3A%E7%94%A8%E6%88%B7%20ID%EF%BC%9A0x10%EF%BC%8CSynopsys%20ID%EF%BC%9A0x51%3CBR%20%2F%3E%20%5B%201.936555%5D%20imx-dwmac%2030bf0000.ethernet%3ADWMAC4%2F5%3CBR%20%2F%3E%20%5B%201.941361%5D%20imx-dwmac%2030bf0000.ethernet%3ADMA%20%E7%A1%AC%E4%BB%B6%E5%8A%9F%E8%83%BD%E5%AF%84%E5%AD%98%E5%99%A8%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%201.948509%5D%20imx-dwmac%2030bf0000.ethernet%3A%E6%94%AF%E6%8C%81%20RX%20%E6%A0%A1%E9%AA%8C%E5%92%8C%E5%8D%B8%E8%BD%BD%E5%BC%95%E6%93%8E%3CBR%20%2F%3E%5B%201.955650%5D%20imx-dwmac%2030bf0000.ethernet%3A%E6%94%AF%E6%8C%81%E6%8F%92%E5%85%A5%20TX%20%E6%A0%A1%E9%AA%8C%E5%92%8C%3CBR%20%2F%3E%5B%201.962359%5D%20imx-dwmac%2030bf0000.ethernet%3A%E6%94%AF%E6%8C%81%E5%B1%80%E5%9F%9F%E7%BD%91%E5%94%A4%E9%86%92%3CBR%20%2F%3E%5B%201.968520%5D%20imx-dwmac%2030bf0000.ethernet%3A%E9%80%9A%E8%BF%87%E7%A1%AC%E4%BB%B6%E7%9C%8B%E9%97%A8%E7%8B%97%E5%AE%9A%E6%97%B6%E5%99%A8%E5%90%AF%E7%94%A8%E6%8E%A5%E6%94%B6%E7%BC%93%E8%A7%A3%3CBR%20%2F%3E%5B%201.976199%5D%20imx-dwmac%2030bf0000.ethernet%3A%E8%AE%BE%E5%A4%87%20MAC%20%E5%9C%B0%E5%9D%80%202a%3Ac5%3A99%3A84%3A66%3Abb%3CBR%20%2F%3E%20%5B%201.983350%5D%20imx-dwmac%2030bf0000.ethernet%3A%E5%B7%B2%E5%90%AF%E7%94%A8%20L3L4%20%E6%B5%81%20TC%EF%BC%88%E6%9D%A1%E7%9B%AE%3D8%EF%BC%89%3CBR%20%2F%3E%20%5B%201.990152%5D%20imx-dwmac%2030bf0000.ethernet%3A%E5%B7%B2%E5%90%AF%E7%94%A8%20RFS%20%E6%B5%81%20TC%EF%BC%88%E6%9D%A1%E7%9B%AE%E6%95%B0%3D10%EF%BC%89%3CBR%20%2F%3E%20%5B%201.996965%5D%20imx-dwmac%2030bf0000.ethernet%3A%E5%90%AF%E7%94%A8%E7%A1%AC%E4%BB%B6TC%EF%BC%88%E6%9D%A1%E7%9B%AE%E6%95%B0%3D256%EF%BC%8C%E6%9C%80%E5%A4%A7%E5%85%B3%E9%97%AD%E6%AC%A1%E6%95%B0%3D256%EF%BC%89%3CBR%20%2F%3E%20%5B%202.004554%5D%20imx-dwmac%2030bf0000.ethernet%3A%E4%BD%BF%E7%94%A8%2034%2F40%20%E4%BD%8D%20DMA%20%E4%B8%BB%E6%9C%BA%2F%E8%AE%BE%E5%A4%87%E5%AE%BD%E5%BA%A6%3CBR%20%2F%3E%5B%202.158192%5D%20realtek-mdio%20stmmac-1%3A00%3A%20%E5%8F%91%E7%8E%B0%E4%B8%80%E4%B8%AA%20RTL8363NB%20%E5%BC%80%E5%85%B3%3CBR%20%2F%3E%5B%202.164168%5D%20realtek-mdio%20stmmac-1%3A00%3A%20%E6%97%A0%E6%B3%95%E6%B3%A8%E5%86%8C%E5%BC%80%E5%85%B3%20ret%20%3D%20-517%3CBR%20%2F%3E%20%5B%202.175037%5D%20xhci-hcd%20xhci-hcd.1.auto%3AxHCI%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3CBR%20%2F%3E%5B%202.180572%5D%20xhci-hcd%20xhci-hcd.1.auto%3A%E6%96%B0USB%E6%80%BB%E7%BA%BF%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B71%3CBR%20%2F%3E%20%5B%202.188568%5D%20xhci-hcd%20xhci-hcd.1.auto%3Ahcc%20%E5%8F%82%E6%95%B0%200x0220fe6d%20hci%20%E7%89%88%E6%9C%AC%200x110%20%E6%80%AA%E5%BC%82%E4%B9%8B%E5%A4%84%200x000000a001000010%3CBR%20%2F%3E%20%5B%202.198006%5D%20xhci-hcd%20xhci-hcd.1.auto%3A%E4%B8%AD%E6%96%AD%20203%EF%BC%8CIO%20%E5%86%85%E5%AD%98%200x38200000%3CBR%20%2F%3E%20%5B%202.204153%5D%20xhci-hcd%20xhci-hcd.1.auto%3AxHCI%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3CBR%20%2F%3E%5B%202.209668%5D%20xhci-hcd%20xhci-hcd.1.auto%3A%E6%96%B0USB%E6%80%BB%E7%BA%BF%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%8C%E5%88%86%E9%85%8D%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B72%3CBR%20%2F%3E%20%5B%202.217339%5D%20xhci-hcd%20xhci-hcd.1.auto%3A%E4%B8%BB%E6%9C%BA%E6%94%AF%E6%8C%81%20USB%203.0%20%E8%B6%85%E9%AB%98%E9%80%9F%3CBR%20%2F%3E%5B%202.226380%5D%20hub%201-0%3A1.0%3A%E5%8F%91%E7%8E%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3E%5B%202.230477%5D%20hub%201-0%3A1.0%3A%20%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3CBR%20%2F%3E%5B%202.236611%5D%20usb%20usb2%EF%BC%9A%E6%88%91%E4%BB%AC%E4%B8%8D%E7%9F%A5%E9%81%93%E6%AD%A4%E4%B8%BB%E6%9C%BA%E7%9A%84%20LPM%20%E7%AE%97%E6%B3%95%EF%BC%8C%E5%B7%B2%E7%A6%81%E7%94%A8%20LPM%E3%80%82%3CBR%20%2F%3E%20%5B%202.246489%5D%20hub%202-0%3A1.0%3A%E5%8F%91%E7%8E%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3E%5B%202.250581%5D%20hub%202-0%3A1.0%3A%20%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3CBR%20%2F%3E%5B%202.256296%5D%20imx-cpufreq-dt%20imx-cpufreq-dt%3A%20CPU%20%E9%80%9F%E5%BA%A6%E7%AD%89%E7%BA%A7%205%20%E5%B8%82%E5%9C%BA%E6%AE%B5%200%20%E6%94%AF%E6%8C%81%E7%A1%AC%E4%BB%B6%200x20%200x1%3CBR%20%2F%3E%20%5B%202.268964%5D%20sdhci-esdhc-imx%2030b40000.mmc%3A%E5%88%86%E9%85%8D%E7%9A%84%20mmc-pwrseq%3CBR%20%2F%3E%20%5B%202.269069%5D%20sdhci-esdhc-imx%2030b50000.mmc%3A%E5%B7%B2%E8%8E%B7%E5%8F%96%20CD%20GPIO%3CBR%20%2F%3E%20%5B%202.313534%5D%20mmc1%EF%BC%9A30b50000.mmc%20%E4%B8%8A%E7%9A%84%20SDHCI%20%E6%8E%A7%E5%88%B6%E5%99%A8%20%5B30b50000.mmc%5D%E4%BD%BF%E7%94%A8ADMA%3CBR%20%2F%3E%20%5B%202.413613%5D%20mmc0%EF%BC%9A30b40000.mmc%20%E4%B8%8A%E7%9A%84%20SDHCI%20%E6%8E%A7%E5%88%B6%E5%99%A8%20%5B30b40000.mmc%5D%E4%BD%BF%E7%94%A8ADMA%3CBR%20%2F%3E%20%5B%202.414283%5D%20realtek-mdio%20stmmac-1%3A00%3A%20%E5%8F%91%E7%8E%B0%E4%B8%80%E4%B8%AA%20RTL8363NB%20%E5%BC%80%E5%85%B3%3CBR%20%2F%3E%5B%202.492421%5D%20usb%201-1%EF%BC%9A%E4%BD%BF%E7%94%A8%20xhci-hcd%20%E7%9A%84%E6%96%B0%E5%9E%8B%E9%AB%98%E9%80%9F%20USB%20%E8%AE%BE%E5%A4%87%EF%BC%8C%E7%BC%96%E5%8F%B7%202%3CBR%20%2F%3E%20%5B%202.540131%5D%20mmc0%EF%BC%9A%E5%9C%B0%E5%9D%80%200001%20%E5%A4%84%E6%96%B0%E5%A2%9E%E8%B6%85%E9%AB%98%E9%80%9F%20SDR104%20SDIO%20%E5%8D%A1%3CBR%20%2F%3E%5B%202.600919%5D%20realtek-mdio%20stmmac-1%3A00%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%85%8D%E7%BD%AE%E5%9B%BA%E5%AE%9A%2FRGMII%20%E9%93%BE%E8%B7%AF%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%202.610450%5D%20realtek-mdio%20stmmac-1%3A00%3A%20%E9%93%BE%E8%B7%AF%E5%B7%B2%E8%BF%9E%E6%8E%A5%20-%201Gbps%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%20-%20%E6%B5%81%E6%8E%A7%E5%88%B6%E5%B7%B2%E5%85%B3%E9%97%AD%3CBR%20%2F%3E%5B%202.644563%5D%20realtek-mdio%20stmmac-1%3A00%20eth1%EF%BC%88%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%89%EF%BC%9APHY%20%5Bdsa-0.0%3A01%5D%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5B%E9%80%9A%E7%94%A8%20PHY%5D%20(irq%3DPOLL)%3CBR%20%2F%3E%20%5B%202.684441%5D%20realtek-mdio%20stmmac-1%3A00%20eth2%EF%BC%88%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%89%EF%BC%9APHY%20%5Bdsa-0.0%3A03%5D%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5B%E9%80%9A%E7%94%A8%20PHY%5D%20(irq%3DPOLL)%3CBR%20%2F%3E%20%5B%202.699335%5D%20DSA%EF%BC%9A%E6%A0%91%200%20%E8%AE%BE%E7%BD%AE%3CBR%20%2F%3E%5B%202.704695%5D%20%E8%BE%93%E5%85%A5%EF%BC%9Agpio-keys%20%E4%BD%9C%E4%B8%BA%20%2Fdevices%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3CBR%20%2F%3E%20%5B%202.704785%5D%20hub%201-1%3A1.0%3A%E5%8F%91%E7%8E%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3E%5B%202.712031%5D%20%E8%BE%93%E5%85%A5%EF%BC%9Acpu_inputs%20%E4%BD%9C%E4%B8%BA%20%2Fdevices%2Fplatform%2Fcpu_inputs%2Finput%2Finput1%3CBR%20%2F%3E%20%5B%202.715286%5D%20hub%201-1%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%204%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3CBR%20%2F%3E%5B%202.722488%5D%20cfg80211%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%E7%9B%91%E7%AE%A1%E6%95%B0%E6%8D%AE%E5%BA%93%E7%9A%84%E7%BC%96%E8%AF%91%E5%86%85%20X.509%20%E8%AF%81%E4%B9%A6%3CBR%20%2F%3E%5B%202.734966%5D%20%E5%B7%B2%E5%8A%A0%E8%BD%BD%20X.509%20%E8%AF%81%E4%B9%A6%E2%80%9Csforshee%3A%2000b28ddf47aef9cea7%E2%80%9D%3CBR%20%2F%3E%20%5B%202.741369%5D%20%E5%B7%B2%E5%8A%A0%E8%BD%BD%20X.509%20%E8%AF%81%E4%B9%A6%E2%80%9Cwens%3A%2061c038651aabdcf94bd0ac7ff06c7248db18c600%E2%80%9D%3CBR%20%2F%3E%20%5B%202.748657%5D%20clk%EF%BC%9A%E7%A6%81%E7%94%A8%E6%9C%AA%E4%BD%BF%E7%94%A8%E7%9A%84%E6%97%B6%E9%92%9F%3CBR%20%2F%3E%5B%202.752652%5D%20%E5%B9%B3%E5%8F%B0%E7%9B%91%E7%AE%A1.0%EF%BC%9A%E7%9B%B4%E6%8E%A5%E5%8A%A0%E8%BD%BD%20regulatory.db%20%E7%9A%84%E5%9B%BA%E4%BB%B6%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%E4%B8%BA%20-2%3CBR%20%2F%3E%20%5B%202.761287%5D%20%E5%B9%B3%E5%8F%B0%E7%9B%91%E7%AE%A1.0%EF%BC%9A%E5%9B%9E%E9%80%80%E5%88%B0%20sysfs%20%E5%A4%87%E7%94%A8%E6%96%B9%E6%A1%88%EF%BC%8C%E7%94%A8%E4%BA%8E%EF%BC%9Aregulatory.db%3CBR%20%2F%3E%5B%202.865310%5D%20hub%201-1%3A1.0%3A%E5%8F%91%E7%8E%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3E%5B%202.869427%5D%20hub%201-1%3A1.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%204%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3CBR%20%2F%3E%5B%203.269517%5D%20EXT4-fs%20(mmcblk2p3)%3A%20%E6%81%A2%E5%A4%8D%E5%AE%8C%E6%88%90%3CBR%20%2F%3E%5B%203.275227%5D%20EXT4-fs%20(mmcblk2p3)%3A%20%E5%B7%B2%E6%8C%82%E8%BD%BD%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20057d8de8-a7e7-4440-9fea-c9670c0c5df9%20%E8%AF%BB%2F%E5%86%99%EF%BC%8C%E6%95%B0%E6%8D%AE%E6%A8%A1%E5%BC%8F%E4%B8%BA%E6%9C%89%E5%BA%8F%E6%A8%A1%E5%BC%8F%E3%80%82%E9%85%8D%E9%A2%9D%E6%A8%A1%E5%BC%8F%EF%BC%9A%E6%97%A0%E3%80%82%3CBR%20%2F%3E%5B%203.287379%5D%20VFS%EF%BC%9A%E5%B7%B2%E5%B0%86%E6%A0%B9%EF%BC%88ext4%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%89%E6%8C%82%E8%BD%BD%E5%88%B0%E8%AE%BE%E5%A4%87%20179%3A3%E3%80%82%3CBR%20%2F%3E%5B%203.294319%5D%20devtmpfs%EF%BC%9A%E5%B7%B2%E6%8C%82%E8%BD%BD%3CBR%20%2F%3E%5B%203.298268%5D%20%E9%87%8A%E6%94%BE%E6%9C%AA%E4%BD%BF%E7%94%A8%E7%9A%84%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%EF%BC%9A3520K%3CBR%20%2F%3E%20%5B%203.302934%5D%20%E4%BB%A5%20init%20%E8%BF%9B%E7%A8%8B%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%20%2Fsbin%2Finit%3CBR%20%2F%3E%20%5B%203.423469%5D%20systemd%5B1%5D%3A%20%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%97%B4%E6%97%A9%E4%BA%8E%E7%89%88%E6%9C%AC%E6%97%B6%E9%97%B4%EF%BC%8C%E6%AD%A3%E5%9C%A8%E6%8E%A8%E8%BF%9B%E6%97%B6%E9%92%9F%E3%80%82%3CBR%20%2F%3E%5B%203.450897%5D%20systemd%5B1%5D%3A%20systemd%20252.39-1~deb12u2%20%E4%BB%A5%E7%B3%BB%E7%BB%9F%E6%A8%A1%E5%BC%8F%E8%BF%90%E8%A1%8C%20(%2BPAM%20%2BAUDIT%20%2BSELINUX%20%2BAPPARMOR%20%2BIMA%20%2BSMACK%20%2BSECCOMP%20%2BGCRYPT%20-GNUTLS%20%2BOPENSSL%20%2BACL%20%2BBLKID%20%2BCURL%20%2BELFUTILS%20%2BFIDO2%20%2BIDN2%20-IDN%20%2BIPTC%20%2BKMOD%20%2BLIBCRYPTSETUP%20%2BLIBFDISK%20%2BPCRE2%20-PWQUALITY%20%2BP11KIT%20%2BQRENCODE%20%2BTPM2%20%2BBZIP2%20%2BLZ4%20%2BXZ%20%2BZLIB%20%2BZSTD%20-BPF_FRAMEWORK%20-XKBCOMMON%20%2BUTMP%20%2BSYSVINIT%20default-hierarchy%3Dunified)%3CBR%20%2F%3E%20%5B%203.483986%5D%20systemd%5B1%5D%3A%20%E6%A3%80%E6%B5%8B%E5%88%B0%E6%9E%B6%E6%9E%84%20arm64%E3%80%82%3C%2FGIOMETTI%3E%3C%2FP%3E%3CP%3E%E6%AC%A2%E8%BF%8E%E4%BD%BF%E7%94%A8%20Debian%20GNU%2FLinux%2012%EF%BC%88%E4%B9%A6%E8%99%AB%EF%BC%89%EF%BC%81%3C%2FP%3E%3CP%3E%5B%203.506158%5D%20systemd%5B1%5D%3A%20%E4%B8%BB%E6%9C%BA%E5%90%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%20%3CLOCALHOST%3E%E3%80%82%3CBR%20%2F%3E%20%5B%203.512764%5D%20systemd%5B1%5D%3A%20%E4%BB%8E%E9%9A%8F%E6%9C%BA%E7%94%9F%E6%88%90%E5%99%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E6%9C%BA%E5%99%A8%20ID%E3%80%82%3CBR%20%2F%3E%5B%203.558947%5D%20systemd%5B1%5D%3A%20%E8%B0%83%E7%94%A8%20memfd_create()%20%E6%97%B6%E6%9C%AA%E8%AE%BE%E7%BD%AE%20MFD_EXEC%20%E6%88%96%20MFD_NOEXEC_SEAL%20%E5%8F%82%E6%95%B0%3CBR%20%2F%3E%5B%203.931119%5D%20systemd%5B1%5D%3A%20%E5%B7%B2%E5%B0%86%E9%BB%98%E8%AE%A4%E7%9B%AE%E6%A0%87%20graphic.target%20%E7%9A%84%E5%90%AF%E5%8A%A8%E4%BD%9C%E4%B8%9A%E5%8A%A0%E5%85%A5%E9%98%9F%E5%88%97%E3%80%82%3CBR%20%2F%3E%5B%203.968011%5D%20systemd%5B1%5D%3A%20%E5%88%9B%E5%BB%BA%E5%88%87%E7%89%87%20system-getty.slice%20-%20%E5%88%87%E7%89%87%20%2Fsystem%2Fgetty%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%88%9B%E5%BB%BA%E5%88%87%E7%89%87%20system-getty.slice%20-%20%E5%88%87%E7%89%87%20%2Fsystem%2Fgetty%E3%80%82%3CBR%20%2F%3E%5B%203.993796%5D%20systemd%5B1%5D%3A%20%E5%88%9B%E5%BB%BA%E5%88%87%E7%89%87%20system-modprobe.slice%20-%20%E5%88%87%E7%89%87%20%2Fsystem%2Fmodprobe%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%88%9B%E5%BB%BA%E5%88%87%E7%89%87%20system-modpr%E2%80%A6lice%20-%20%E5%88%87%E7%89%87%20%2Fsystem%2Fmodprobe%E3%80%82%3CBR%20%2F%3E%5B%204.022309%5D%20systemd%5B1%5D%3A%20%E5%88%9B%E5%BB%BA%E5%88%87%E7%89%87%20system-serial%5Cx2dgetty.slice%20-%20%E5%88%87%E7%89%87%20%2Fsystem%2Fserial-getty%E3%80%82%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%88%9B%E5%BB%BA%E5%88%87%E7%89%87%20system-seria%E2%80%A6%20-%20%E5%88%87%E7%89%87%20%2Fsystem%2Fserial-getty%E3%80%82%3CBR%20%2F%3E%20%5B%204.049678%5D%20systemd%5B1%5D%3A%20%E5%88%9B%E5%BB%BA%E5%88%87%E7%89%87%20system-systemd%5Cx2dfsck.slice%20-%20%E5%88%87%E7%89%87%20%2Fsystem%2Fsystemd-fsck%E3%80%82%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%88%9B%E5%BB%BA%E5%88%87%E7%89%87%20system-syste%E2%80%A6%20-%20%E5%88%87%E7%89%87%20%2Fsystem%2Fsystemd-fsck%E3%80%82%3CBR%20%2F%3E%20%5B%204.077353%5D%20systemd%5B1%5D%3A%20%E5%88%9B%E5%BB%BA%E5%88%87%E7%89%87%20user.slice%20-%20%E7%94%A8%E6%88%B7%E5%92%8C%E4%BC%9A%E8%AF%9D%E5%88%87%E7%89%87%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%88%9B%E5%BB%BA%E5%88%87%E7%89%87%20user.slice%20-%20%E7%94%A8%E6%88%B7%E5%92%8C%E4%BC%9A%E8%AF%9D%E5%88%87%E7%89%87%E3%80%82%3CBR%20%2F%3E%5B%204.100497%5D%20systemd%5B1%5D%3A%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20systemd-ask-password-console.path%20-%20%E5%B0%86%E5%AF%86%E7%A0%81%E8%AF%B7%E6%B1%82%E5%88%86%E5%8F%91%E5%88%B0%E6%8E%A7%E5%88%B6%E5%8F%B0%E7%9B%AE%E5%BD%95%E7%9B%91%E8%A7%86%E5%99%A8%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20systemd-ask-passwo%E2%80%A6quests%20%E5%88%B0%E6%8E%A7%E5%88%B6%E5%8F%B0%E7%9B%AE%E5%BD%95%E7%9B%91%E8%A7%86%E3%80%82%3CBR%20%2F%3E%5B%204.128453%5D%20systemd%5B1%5D%3A%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20systemd-ask-password-wall.path%20-%20%E5%B0%86%E5%AF%86%E7%A0%81%E8%AF%B7%E6%B1%82%E8%BD%AC%E5%8F%91%E5%88%B0%20Wall%20%E7%9B%AE%E5%BD%95%E7%9B%91%E8%A7%86%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20systemd-ask-passwo%E2%80%A6%20%E8%AF%B7%E6%B1%82%20Wall%20%E7%9B%AE%E5%BD%95%E7%9B%91%E8%A7%86%E3%80%82%3CBR%20%2F%3E%5B%204.156396%5D%20systemd%5B1%5D%3A%20proc-sys-fs-binfmt_misc.automount%20-%20%E7%94%B1%E4%BA%8E%E6%9D%A1%E4%BB%B6%E6%A3%80%E6%9F%A5%E6%9C%AA%E6%BB%A1%E8%B6%B3%20(ConditionPathExists%3D%2Fproc%2Fsys%2Ffs%2Fbinfmt_misc)%EF%BC%8C%E4%BB%BB%E6%84%8F%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%96%87%E4%BB%B6%E6%A0%BC%E5%BC%8F%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E8%87%AA%E5%8A%A8%E6%8C%82%E8%BD%BD%E7%82%B9%E8%A2%AB%E8%B7%B3%E8%BF%87%E3%80%82%3CBR%20%2F%3E%5B%204.175866%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E7%AD%89%E5%BE%85%E8%AE%BE%E5%A4%87%20dev-mmcblk2p1.device%20-%20%2Fdev%2Fmmcblk2p1...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E6%9F%A5%E6%89%BE%E8%AE%BE%E5%A4%87%20dev-mmcblk2p1.device%20-%20%2Fdev%2Fmmcblk2p1...%3CBR%20%2F%3E%20%5B%204.200472%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E7%AD%89%E5%BE%85%E8%AE%BE%E5%A4%87%20dev-ttymxc1.device%20-%20%2Fdev%2Fttymxc1...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E6%9F%A5%E6%89%BE%E8%AE%BE%E5%A4%87%20dev-ttymxc1.device%20-%20%2Fdev%2Fttymxc1...%3CBR%20%2F%3E%20%5B%204.224224%5D%20systemd%5B1%5D%3A%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20cryptsetup.target%20-%20%E6%9C%AC%E5%9C%B0%E5%8A%A0%E5%AF%86%E5%8D%B7%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20cryptsetup.%E2%80%A6get-%20%E6%9C%AC%E5%9C%B0%E5%8A%A0%E5%AF%86%E5%8D%B7%E3%80%82%3CBR%20%2F%3E%5B%204.248610%5D%20systemd%5B1%5D%3A%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20integritysetup.target%20-%20%E6%9C%AC%E5%9C%B0%E5%AE%8C%E6%95%B4%E6%80%A7%E4%BF%9D%E6%8A%A4%E5%8D%B7%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%E5%AE%8C%E6%95%B4%E6%80%A7%E2%80%A6%E6%9C%AC%E5%9C%B0%E5%AE%8C%E6%95%B4%E6%80%A7%E4%BF%9D%E6%8A%A4%E5%8D%B7%E3%80%82%3CBR%20%2F%3E%5B%204.276289%5D%20systemd%5B1%5D%3A%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20paths.target%20-%20%E8%B7%AF%E5%BE%84%E5%8D%95%E5%85%83%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%E8%B7%AF%E5%BE%84%E3%80%82target%20-%20%E8%B7%AF%E5%BE%84%E5%8D%95%E5%85%83%E3%80%82%3CBR%20%2F%3E%5B%204.296264%5D%20systemd%5B1%5D%3A%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20remote-fs.target%20-%20%E8%BF%9C%E7%A8%8B%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20remote-fs.target%20-%20%E8%BF%9C%E7%A8%8B%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%5B%204.320247%5D%20systemd%5B1%5D%3A%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20slices.target%20-%20%E5%88%87%E7%89%87%E5%8D%95%E5%85%83%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%E5%88%87%E7%89%87%E6%95%B0%E3%80%82target%20-%20%E5%88%87%E7%89%87%E5%8D%95%E4%BD%8D%E3%80%82%3CBR%20%2F%3E%5B%204.340224%5D%20systemd%5B1%5D%3A%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20swap.target%20-%20%E4%BA%A4%E6%8D%A2%E5%88%86%E5%8C%BA%E3%80%82%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20swap.target%20-%20%E4%BA%A4%E6%8D%A2%E3%80%82%3CBR%20%2F%3E%20%5B%204.360269%5D%20systemd%5B1%5D%3A%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20veritysetup.target%20-%20%E6%9C%AC%E5%9C%B0%20Verity%20%E4%BF%9D%E6%8A%A4%E5%8D%B7%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20veritysetup%E2%80%A6%20-%20%E6%9C%AC%E5%9C%B0%20Verity%20%E4%BF%9D%E6%8A%A4%E5%8D%B7%E3%80%82%3CBR%20%2F%3E%5B%204.384758%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E7%9B%91%E5%90%AC%20systemd-fsckd.socket%20-%20fsck%20%E4%B8%8E%20fsckd%20%E9%80%9A%E4%BF%A1%E5%A5%97%E6%8E%A5%E5%AD%97%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E6%AD%A3%E5%9C%A8%E7%9B%91%E5%90%AC%20systemd-fsckd%E2%80%A6sck%20%E5%88%B0%20fsckd%20%E9%80%9A%E4%BF%A1%E5%A5%97%E6%8E%A5%E5%AD%97%E3%80%82%3CBR%20%2F%3E%5B%204.412536%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E7%9B%91%E5%90%AC%20systemd-initctl.socket%20-%20initctl%20%E5%85%BC%E5%AE%B9%E5%91%BD%E5%90%8D%E7%AE%A1%E9%81%93%E3%80%82%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E6%AD%A3%E5%9C%A8%E7%9B%91%E5%90%AC%20systemd-initc%E2%80%A6%20initctl%20%E5%85%BC%E5%AE%B9%E6%80%A7%E5%91%BD%E5%90%8D%E7%AE%A1%E9%81%93%E3%80%82%3CBR%20%2F%3E%20%5B%204.441749%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E7%9B%91%E5%90%AC%20systemd-journald-audit.socket%20-%20%E6%97%A5%E5%BF%97%E5%AE%A1%E8%AE%A1%E5%A5%97%E6%8E%A5%E5%AD%97%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E6%AD%A3%E5%9C%A8%E7%9B%91%E5%90%AC%20systemd-journ%E2%80%A6%E5%A5%97%E6%8E%A5%E5%AD%97%20-%20%E6%97%A5%E5%BF%97%E5%AE%A1%E8%AE%A1%E5%A5%97%E6%8E%A5%E5%AD%97%E3%80%82%3CBR%20%2F%3E%5B%204.468740%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E7%9B%91%E5%90%AC%20systemd-journald-dev-log.socket%20-%20%E6%97%A5%E5%BF%97%E5%A5%97%E6%8E%A5%E5%AD%97%20(%2Fdev%2Flog)%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E6%AD%A3%E5%9C%A8%E7%9B%91%E5%90%AC%20systemd-journ%E2%80%A6t%20-%20%E6%97%A5%E5%BF%97%E5%A5%97%E6%8E%A5%E5%AD%97%20(%2Fdev%2Flog)%E3%80%82%3CBR%20%2F%3E%5B%204.496878%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E7%9B%91%E5%90%AC%20systemd-journald.socket%20-%20%E6%97%A5%E5%BF%97%E5%A5%97%E6%8E%A5%E5%AD%97%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E6%AD%A3%E5%9C%A8%E7%9B%91%E5%90%AC%20systemd-journald.socket%20-%20%E6%97%A5%E5%BF%97%E5%A5%97%E6%8E%A5%E5%AD%97%E3%80%82%3CBR%20%2F%3E%5B%204.520946%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E7%9B%91%E5%90%AC%20systemd-networkd.socket%20-%20%E7%BD%91%E7%BB%9C%E6%9C%8D%E5%8A%A1%20Netlink%20%E5%A5%97%E6%8E%A5%E5%AD%97%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E6%AD%A3%E5%9C%A8%E7%9B%91%E5%90%AC%20systemd-netwo%E2%80%A6%20-%20%E7%BD%91%E7%BB%9C%E6%9C%8D%E5%8A%A1%20Netlink%20%E5%A5%97%E6%8E%A5%E5%AD%97%E3%80%82%3CBR%20%2F%3E%5B%204.557127%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E7%9B%91%E5%90%AC%20systemd-udevd-control.socket%20-%20udev%20%E6%8E%A7%E5%88%B6%E5%A5%97%E6%8E%A5%E5%AD%97%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E6%AD%A3%E5%9C%A8%E7%9B%91%E5%90%AC%20systemd-udevd%E2%80%A6%E5%A5%97%E6%8E%A5%E5%AD%97-%20udev%20%E6%8E%A7%E5%88%B6%E5%A5%97%E6%8E%A5%E5%AD%97%E3%80%82%3CBR%20%2F%3E%5B4.584722%5D%20systemd%5B1%5D%EF%BC%9A%E7%9B%91%E5%90%AC%20systemd-udevd-kernel.socket%20-%20udev%20%E5%86%85%E6%A0%B8%E5%A5%97%E6%8E%A5%E5%AD%97%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E6%AD%A3%E5%9C%A8%E7%9B%91%E5%90%AC%20systemd-udevd%E2%80%A6l.socket-%20udev%20%E5%86%85%E6%A0%B8%E5%A5%97%E6%8E%A5%E5%AD%97%E3%80%82%3CBR%20%2F%3E%5B%204.624665%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E6%8C%82%E8%BD%BD%20dev-hugepages.mount%20-%20%E5%A4%A7%E9%A1%B5%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E6%8C%82%E8%BD%BD%20dev-hugepages.mount%20-%20%E5%A4%A7%E9%A1%B5%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%3CBR%20%2F%3E%20%5B%204.651859%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E6%8C%82%E8%BD%BD%20dev-mqueue.mount%20-%20POSIX%20%E6%B6%88%E6%81%AF%E9%98%9F%E5%88%97%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%3CBR%20%2F%3E%E6%8C%82%E8%BD%BD%20dev-mqueue.mount%E2%96%92%E2%96%92POSIX%E6%B6%88%E6%81%AF%E9%98%9F%E5%88%97%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%3CBR%20%2F%3E%20%5B%204.680049%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E6%8C%82%E8%BD%BD%20sys-kernel-debug.mount%20-%20%E5%86%85%E6%A0%B8%E8%B0%83%E8%AF%95%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E6%8C%82%E8%BD%BD%20sys-kernel-debug.%E2%80%A6%20-%20%E5%86%85%E6%A0%B8%E8%B0%83%E8%AF%95%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%3CBR%20%2F%3E%20%5B%204.709270%5D%20systemd%5B1%5D%3A%20sys-kernel-tracing.mount%20-%20%E7%94%B1%E4%BA%8E%E6%9C%AA%E6%BB%A1%E8%B6%B3%E6%9D%A1%E4%BB%B6%E6%A3%80%E6%9F%A5%20(ConditionPathExists%3D%2Fsys%2Fkernel%2Ftracing)%EF%BC%8C%E5%86%85%E6%A0%B8%E8%B7%9F%E8%B8%AA%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E8%A2%AB%E8%B7%B3%E8%BF%87%E3%80%82%3CBR%20%2F%3E%5B%204.724518%5D%20systemd%5B1%5D%3A%20kmod-static-nodes.service%20-%20%E5%88%9B%E5%BB%BA%E9%9D%99%E6%80%81%E8%AE%BE%E5%A4%87%E8%8A%82%E7%82%B9%E5%88%97%E8%A1%A8%E7%94%B1%E4%BA%8E%E6%9C%AA%E6%BB%A1%E8%B6%B3%E6%9D%A1%E4%BB%B6%E6%A3%80%E6%9F%A5%20(ConditionFileNotEmpty%3D%2Flib%2Fmodules%2F6.6.52-rt43-gd377c9049508-dirty%2Fmodules.devname)%20%E8%80%8C%E8%A2%AB%E8%B7%B3%E8%BF%87%E3%80%82%3CBR%20%2F%3E%5B%204.757545%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20modprobe%40configfs.service%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20configfs...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20modprobe%40configfs%E2%80%A6m%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20configfs%E2%80%A6%3CBR%20%2F%3E%20%5B%204.788352%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20modprobe%40dm_mod.service%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20dm_mod...%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%20modprobe%40dm_mod.s%E2%80%A6%5B0m-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20dm_mod...%3CBR%20%2F%3E%20%5B%204.816731%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20modprobe%40drm.service%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20drm...%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%20modprobe%40drm.service%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20drm...%3CBR%20%2F%3E%20%5B%204.848481%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20modprobe%40efi_pstore.service%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20efi_pstore...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20modprobe%40efi_psto%E2%80%A6-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20efi_pstore%E2%80%A6%3CBR%20%2F%3E%20%5B%204.876748%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20modprobe%40fuse.service%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20fuse...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20modprobe%40fuse.ser%E2%80%A6e%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20fuse%E2%80%A6%3CBR%20%2F%3E%20%5B%204.904963%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20modprobe%40loop.service%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20loop...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20modprobe%40loop.ser%E2%80%A6e%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20loop%E2%80%A6%3CBR%20%2F%3E%20%5B%204.928580%5D%20systemd%5B1%5D%3A%20systemd-fsck-root.service%20-%20%E7%94%B1%E4%BA%8E%E6%9D%A1%E4%BB%B6%E6%A3%80%E6%9F%A5%E6%9C%AA%E6%BB%A1%E8%B6%B3%20(ConditionPathIsReadWrite%3D!%2F)%EF%BC%8C%E5%B7%B2%E8%B7%B3%E8%BF%87%E5%AF%B9%E6%A0%B9%E8%AE%BE%E5%A4%87%E7%9A%84%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E6%A3%80%E6%9F%A5%E3%80%82%3CBR%20%2F%3E%20%5B%204.968886%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-journald.service%20-%20%E6%97%A5%E5%BF%97%E6%9C%8D%E5%8A%A1...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-journald.service%20-%20%E6%97%A5%E5%BF%97%E6%9C%8D%E5%8A%A1...%3CBR%20%2F%3E%20%5B%205.004486%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-modules-load.service%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-modules-l%E2%80%A6rvice%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97...%3CBR%20%2F%3E%20%5B%205.031531%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-network-generator.service%20-%20%E4%BB%8E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%94%9F%E6%88%90%E7%BD%91%E7%BB%9C%E5%8D%95%E5%85%83...%3CBR%20%2F%3E%E4%BB%8E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%E5%90%AF%E5%8A%A8%20systemd-network-g%E2%80%A6%20%E5%8D%95%E5%85%83%E2%80%A6%3CBR%20%2F%3E%20%5B%205.084818%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-remount-fs.service%20-%20%E9%87%8D%E6%96%B0%E6%8C%82%E8%BD%BD%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%92%8C%E5%86%85%E6%A0%B8%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-remount-f%E2%80%A6nt%20%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%92%8C%E5%86%85%E6%A0%B8%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%3CBR%20%2F%3E%20%5B%205.115743%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-udev-trigger.service%20-%20%E5%86%B7%E6%8F%92%E6%8B%94%E6%89%80%E6%9C%89%20udev%20%E8%AE%BE%E5%A4%87...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-udev-trig%E2%80%A6%5B0m%20-%20%E5%86%B7%E6%8F%92%E6%8B%94%E6%89%80%E6%9C%89%20udev%20%E8%AE%BE%E5%A4%87%E2%80%A6%5D%3CBR%20%2F%3E%20%5B%205.136505%5D%20EXT4-fs%20(mmcblk2p3)%3A%20%E9%87%8D%E6%96%B0%E6%8C%82%E8%BD%BD%20057d8de8-a7e7-4440-9fea-c9670c0c5df9%20r%2Fw%E3%80%82%E9%85%8D%E9%A2%9D%E6%A8%A1%E5%BC%8F%EF%BC%9A%E6%97%A0%E3%80%82%3CBR%20%2F%3E%5B%205.153130%5D%20systemd%5B1%5D%3A%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20systemd-journald.service%20-%20%E6%97%A5%E5%BF%97%E6%9C%8D%E5%8A%A1%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20systemd-journald.service%20-%20%E6%97%A5%E5%BF%97%E6%9C%8D%E5%8A%A1%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E6%8C%82%E8%BD%BD%20dev-hugepages.mount%20-%20%E5%A4%A7%E9%A1%B5%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E6%8C%82%E8%BD%BD%20dev-mqueue.mount%E2%96%92%E2%96%92-POSIX%20%E6%B6%88%E6%81%AF%E9%98%9F%E5%88%97%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E6%8C%82%E8%BD%BD%20sys-kernel-debug.m%E2%80%A6nt%20-%20%E5%86%85%E6%A0%B8%E8%B0%83%E8%AF%95%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20modprobe%40configfs%20%E5%B7%B2%E5%AE%8C%E6%88%90%E2%80%A6%5B0m%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20configfs%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20modprobe%40dm_mod.s%E2%80%A6e%20%E5%B7%B2%E5%AE%8C%E6%88%90-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20dm_mod%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20modprobe%40drm.service%20%E5%B7%B2%E5%AE%8C%E6%88%90%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20drm%E3%80%82%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20modprobe%40efi_psto%E2%80%A6m%20%E5%B7%B2%E5%AE%8C%E6%88%90%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20efi_pstore%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20modprobe%40fuse.service%20%E5%B7%B2%E5%AE%8C%E6%88%90%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20%E7%86%94%E4%B8%9D%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20modprobe%40loop.service%20%E5%B7%B2%E5%AE%8C%E6%88%90%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%E5%BE%AA%E7%8E%AF%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20systemd-modules-l%E2%80%A6%E6%9C%8D%E5%8A%A1%E5%B7%B2%E5%AE%8C%E6%88%90%20-%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%AE%8C%E6%88%90%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%E4%B8%AD%E7%9A%84%20systemd-network-g%E2%80%A6rk%20%E5%8D%95%E5%85%83%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E5%AE%8C%E6%88%90%20systemd-remount-f%E2%80%A6%E6%8C%82%E8%BD%BD%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%92%8C%E5%86%85%E6%A0%B8%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%E7%BD%91%E7%BB%9C%E9%A2%84%E2%80%A6%E8%8E%B7%E5%8F%96%20-%20%E7%BD%91%E7%BB%9C%E5%87%86%E5%A4%87%E3%80%82%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E6%8C%82%E8%BD%BD%20sys-kernel-config%E2%80%A6%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E2%80%A6%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-journal-f%E2%80%A6h%20%E5%B0%86%E6%97%A5%E5%BF%97%E5%86%99%E5%85%A5%E6%8C%81%E4%B9%85%E5%AD%98%E5%82%A8%E2%80%A6%3CBR%20%2F%3E%20%5B%205.501074%5D%20systemd-journald%5B137%5D%3A%20%E6%94%B6%E5%88%B0%E5%AE%A2%E6%88%B7%E7%AB%AF%E8%AF%B7%E6%B1%82%E4%BB%A5%E5%88%B7%E6%96%B0%E8%BF%90%E8%A1%8C%E6%97%B6%E6%97%A5%E5%BF%97%E3%80%82%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-random-se%E2%80%A6ice%20-%20%E5%8A%A0%E8%BD%BD%2F%E4%BF%9D%E5%AD%98%E9%9A%8F%E6%9C%BA%E7%A7%8D%E5%AD%90...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-sysctl.se%E2%80%A6ce-%20%E5%BA%94%E7%94%A8%E6%A0%B8%E5%8F%98%E9%87%8F...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-sysusers.%E2%80%A6%E6%9C%8D%E5%8A%A1%20-%20%E5%88%9B%E5%BB%BA%E7%B3%BB%E7%BB%9F%E7%94%A8%E6%88%B7...%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20systemd-udev-trig%E2%80%A6e%20%E5%AE%8C%E6%88%90%20-%20%E5%86%B7%E6%8F%92%E6%8B%94%E6%89%80%E6%9C%89%20udev%20%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E6%8C%82%E8%BD%BD%20sys-kernel-config...%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%AE%8C%E6%88%90%20systemd-journal-f%E2%80%A6ush%20%E6%97%A5%E5%BF%97%E5%88%B0%E6%8C%81%E4%B9%85%E5%AD%98%E5%82%A8%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20systemd-sysctl.service%20%E5%B7%B2%E5%AE%8C%E6%88%90%20-%20%E5%BA%94%E7%94%A8%E5%86%85%E6%A0%B8%E5%8F%98%E9%87%8F%E3%80%82%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%20ifupdown-pre.serv%E2%80%A6%E5%90%8C%E6%AD%A5ifupdown%20%E5%90%AF%E5%8A%A8...%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20systemd-sysusers.service%20%E5%B7%B2%E5%AE%8C%E6%88%90%20-%20%E5%88%9B%E5%BB%BA%E7%B3%BB%E7%BB%9F%E7%94%A8%E6%88%B7%E3%80%82%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20%2Fdev%20%E4%B8%AD%E7%9A%84%20systemd-tmpfiles-%E2%80%A6ate%20%E9%9D%99%E6%80%81%E8%AE%BE%E5%A4%87%E8%8A%82%E7%82%B9...%3CBR%20%2F%3E%20%5B%20OK%20%5D%20%E5%B7%B2%E5%AE%8C%E6%88%90%20systemd-tmpfiles-%E2%80%A6%E5%9C%A8%20%2Fdev%20%E4%B8%AD%E5%88%9B%E5%BB%BA%E9%9D%99%E6%80%81%E8%AE%BE%E5%A4%87%E8%8A%82%E7%82%B9%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E6%9C%AC%E5%9C%B0%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%87%86%E5%A4%87%E7%9B%AE%E6%A0%87%20local-fs-pr%E2%80%A6%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20local-fs.target%20-%20%E6%9C%AC%E5%9C%B0%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-tmpfiles-%E2%80%A6te%20%E7%B3%BB%E7%BB%9F%E6%96%87%E4%BB%B6%E5%92%8C%E7%9B%AE%E5%BD%95...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-udevd.ser%E2%80%A6ger%20%E4%BB%A5%E5%A4%84%E7%90%86%E8%AE%BE%E5%A4%87%E4%BA%8B%E4%BB%B6%E5%92%8C%E6%96%87%E4%BB%B6%E2%80%A6%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20systemd-tmpfiles-%E2%80%A6eate%20%E7%B3%BB%E7%BB%9F%E6%96%87%E4%BB%B6%E5%92%8C%E7%9B%AE%E5%BD%95%E5%B7%B2%E5%AE%8C%E6%88%90%E3%80%82%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-timesyncd%E2%80%A6%20-%20%E7%BD%91%E7%BB%9C%E6%97%B6%E9%97%B4%E5%90%8C%E6%AD%A5%E2%80%A6%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-update-ut%E2%80%A6rd%20%E7%B3%BB%E7%BB%9F%E5%90%AF%E5%8A%A8%2F%E5%85%B3%E9%97%AD%EF%BC%88UTMP%20%E6%A8%A1%E5%BC%8F%EF%BC%89...%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20systemd-update-ut%E2%80%A6cord%20%E7%B3%BB%E7%BB%9F%E5%90%AF%E5%8A%A8%2F%E5%85%B3%E9%97%AD%EF%BC%88UTMP%EF%BC%89%E5%AE%8C%E6%88%90%E3%80%82%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20systemd-udevd.serv%E2%80%A6%E8%AE%BE%E5%A4%87%E4%BA%8B%E4%BB%B6%E5%92%8C%E6%96%87%E4%BB%B6%E7%AE%A1%E7%90%86%E5%99%A8%E3%80%82%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-networkd.%E2%80%A6ice%20-%20%E7%BD%91%E7%BB%9C%E9%85%8D%E7%BD%AE...%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E6%89%BE%E5%88%B0%E8%AE%BE%E5%A4%87%20dev-ttymxc1.device%20-%20%2Fdev%2Fttymxc1%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20systemd-timesyncd.%E2%80%A60m%20-%20%E7%BD%91%E7%BB%9C%E6%97%B6%E9%97%B4%E5%90%8C%E6%AD%A5%E3%80%82%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20sysinit.target%20-%20%E7%B3%BB%E7%BB%9F%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20systemd-tmpfiles-c%E2%80%A6%20%E6%B8%85%E7%90%86%E4%B8%B4%E6%97%B6%E7%9B%AE%E5%BD%95%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%E6%97%B6%E9%97%B4%E8%AE%BE%E7%BD%AE%E3%80%82%E7%9B%AE%E6%A0%87%20-%20%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%97%B4%E8%AE%BE%E7%BD%AE%E3%80%82%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20apt-daily.timer%20-%20%E6%AF%8F%E6%97%A5%20apt%20%E4%B8%8B%E8%BD%BD%E6%B4%BB%E5%8A%A8%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20apt-daily-upgrade...%E5%90%88%E9%80%82%E7%9A%84%E5%8D%87%E7%BA%A7%E5%92%8C%E6%B8%85%E6%B4%81%E6%B4%BB%E5%8A%A8%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20dpkg-db-backup.tim%E2%80%A6%E6%AF%8F%E6%97%A5%20dpkg%20%E6%95%B0%E6%8D%AE%E5%BA%93%E5%A4%87%E4%BB%BD%E5%AE%9A%E6%97%B6%E5%99%A8%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20e2scrub_all.timer%E2%96%92%E2%96%92etadata%E6%A3%80%E6%9F%A5%E6%89%80%E6%9C%89%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%90%AF%E5%8A%A8%20fstrim.timer%20-%20%E6%AF%8F%E5%91%A8%E4%B8%A2%E5%BC%83%E4%B8%80%E6%AC%A1%E6%9C%AA%E4%BD%BF%E7%94%A8%E7%9A%84%E5%9D%97%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20logrotate.timer%20-%20%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E6%AF%8F%E6%97%A5%E8%BD%AE%E6%8D%A2%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20man-db.timer%20-%20%E6%AF%8F%E6%97%A5%20man-db%20%E5%86%8D%E7%94%9F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20sysstat-collect.ti%E2%80%A6%E6%AF%8F%2010%20%E5%88%86%E9%92%9F%E4%BD%BF%E7%94%A8%E4%B8%80%E6%AC%A1%E4%BC%9A%E8%AE%A1%E5%B7%A5%E5%85%B7%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%E5%90%AF%E5%8A%A8%E4%BA%86sysstat-summary.ti%E2%80%A6%E7%9A%84%E6%98%A8%E5%A4%A9%E7%9A%84%E6%B5%81%E7%A8%8B%E4%BC%9A%E8%AE%A1%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%E8%AE%A1%E6%97%B6%E5%99%A8%E3%80%82target%20-%20%E8%AE%A1%E6%97%B6%E5%99%A8%E5%8D%95%E4%BD%8D%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E6%AD%A3%E5%9C%A8%E7%9B%91%E5%90%AC%20dbus.socket%E2%96%92%E2%96%92-D-Bus%E7%B3%BB%E7%BB%9F%E6%B6%88%E6%81%AF%E6%80%BB%E7%BA%BF%E6%8F%92%E5%BA%A7%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%5B6.421751%5D%20cfg80211%EF%BC%9A%E5%8A%A0%E8%BD%BD%20regulatory.db%20%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3Et%20sockets.target%20-%20Socket%20%E5%8D%95%E5%85%83%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20basic.target%20-%20%E5%9F%BA%E6%9C%AC%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20cron.service%20-%E2%80%A6%E5%90%8E%E5%8F%B0%E7%A8%8B%E5%BA%8F%E5%A4%84%E7%90%86%E5%AE%88%E6%8A%A4%E8%BF%9B%E7%A8%8B%E3%80%82%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20dbus.service%20-%20D-Bus%20%E7%B3%BB%E7%BB%9F%E6%B6%88%E6%81%AF%E6%80%BB%E7%BA%BF...%3CBR%20%2F%3E%20%5B%206.524255%5D%20imx-sdma%2030bd0000.dma-controller%3A%E7%9B%B4%E6%8E%A5%E5%8A%A0%E8%BD%BD%20imx%2Fsdma%2Fsdma-imx7d.bin%20%E5%9B%BA%E4%BB%B6%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%20-2%3C%2FLOCALHOST%3E%3C%2FP%3E%3CP%3E%5B%206.537384%5D%20imx-sdma%2030bd0000.dma-controller%3A%E5%9B%9E%E9%80%80%E5%88%B0%20sysfs%20%E5%A4%87%E9%80%89%E6%96%B9%E6%A1%88%EF%BC%9Aimx%2Fsdma%2Fsdma-imx7d.bin%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20firmwared.service%20-%20Linux%20%E5%9B%BA%E4%BB%B6%E5%8A%A0%E8%BD%BD%E5%AE%88%E6%8A%A4%E8%BF%9B%E7%A8%8B%E3%80%82%3CBR%20%2F%3E%5B%206.563260%5D%20imx-sdma%2030bd0000.dma-controller%3A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%A4%96%E9%83%A8%E5%9B%BA%E4%BB%B6%EF%BC%8C%E4%BD%BF%E7%94%A8ROM%E5%9B%BA%E4%BB%B6%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20kexec-load.service%E2%80%A6B%3A%E4%BD%BF%E7%94%A8%20kexec%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F...%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%20lm-sensors.service%E2%80%A6%E7%A1%AC%E4%BB%B6%E7%9B%91%E6%8E%A7%E4%BC%A0%E6%84%9F%E5%99%A8...%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%20platcfg.service%E2%96%92%E2%96%92r%E5%90%84%E7%A7%8D%20NXP%20i.MX%2FLS%20%E5%B9%B3%E5%8F%B0%E2%80%A6%E2%80%A6%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20seatd.service%20-%20%E5%BA%A7%E4%BD%8D%E7%AE%A1%E7%90%86%E5%AE%88%E6%8A%A4%E8%BF%9B%E7%A8%8B%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E5%B7%B2%E4%BD%BF%E7%94%A8%20ipsec.conf%20%E5%90%AF%E5%8A%A8%20strongswan-starter%E2%80%A6Ev1%2FIKEv2%20%E5%AE%88%E6%8A%A4%E8%BF%9B%E7%A8%8B%E3%80%82%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20sysstat.service%20-%20%E9%87%8D%E7%BD%AE%E7%B3%BB%E7%BB%9F%E6%B4%BB%E5%8A%A8%E6%97%A5%E5%BF%97...%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%20systemd-logind.se%E2%80%A6ice%E7%94%A8%E6%88%B7%E7%99%BB%E5%BD%95%E7%AE%A1%E7%90%86...%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20systemd-networkd.service%20-%20%E7%BD%91%E7%BB%9C%E9%85%8D%E7%BD%AE%E3%80%82%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20ifupdown-pre.serv%20%E5%B7%B2%E5%AE%8C%E6%88%90%E2%80%A6%E5%90%8C%E6%AD%A5%E5%90%AF%E5%8A%A8%20ifupdown%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20e2scrub_reap.serv%E2%80%A6ine%20%E5%B7%B2%E5%AE%8C%E6%88%90ext4%20%E5%85%83%E6%95%B0%E6%8D%AE%E6%A3%80%E6%9F%A5%E5%BF%AB%E7%85%A7%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20sysstat.service%20%E5%B7%B2%E5%AE%8C%E6%88%90%20-%20%E9%87%8D%E7%BD%AE%E7%B3%BB%E7%BB%9F%E6%B4%BB%E5%8A%A8%E6%97%A5%E5%BF%97%E3%80%82%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20lm-sensors.service%E2%80%A6alize%20%E5%B7%B2%E5%AE%8C%E6%88%90%E7%A1%AC%E4%BB%B6%E7%9B%91%E6%8E%A7%E4%BC%A0%E6%84%9F%E5%99%A8%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20kexec-load.service%E2%80%A6LSB%EF%BC%9A%E4%BD%BF%E7%94%A8%20kexec%20%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E6%89%BE%E5%88%B0%E8%AE%BE%E5%A4%87%20dev-mmcblk2p1.device%20-%20%2Fdev%2Fmmcblk2p1%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20usb-gadget.%E2%80%A6m-%20%E7%A1%AC%E4%BB%B6%E6%BF%80%E6%B4%BB%E7%9A%84USB%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20networking.service%20-%20%E5%90%AF%E5%8A%A8%E7%BD%91%E7%BB%9C%E6%8E%A5%E5%8F%A3...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-fsck%40dev-%E2%80%A6%20%E5%AF%B9%20%2Fdev%2Fmmcblk2p1%20%E8%BF%9B%E8%A1%8C%E7%B3%BB%E7%BB%9F%E6%A3%80%E6%9F%A5%E2%80%A6%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20systemd-fsckd.serv%E2%80%A6tem%E6%A3%80%E6%9F%A5%E5%AE%88%E6%8A%A4%E8%BF%9B%E7%A8%8B%E4%BB%A5%E6%8A%A5%E5%91%8A%E7%8A%B6%E6%80%81%E3%80%82%3CBR%20%2F%3E%5B%20OK%20%5D%20%E5%AE%8C%E6%88%90%E5%AF%B9%20%2Fdev%2Fmmcblk2p1%20%E7%9A%84%20systemd-fsck%40dev-%E2%80%A6le%20%E7%B3%BB%E7%BB%9F%E6%A3%80%E6%9F%A5%E3%80%82%3CBR%20%2F%3E%5B%207.297245%5D%20imx-dwmac%2030bf0000.ethernet%20eth0%3A%20%E6%B3%A8%E5%86%8C%20MEM_TYPE_PAGE_POOL%20RxQ-0%3CBR%20%2F%3E%20%5B%207.305583%5D%20imx-dwmac%2030bf0000.ethernet%20eth0%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%8A%9F%E8%83%BD%E5%AE%89%E5%85%A8%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%5B%207.312850%5D%20imx-dwmac%2030bf0000.ethernet%20eth0%EF%BC%9A%E6%94%AF%E6%8C%81%20IEEE%201588-2008%20%E9%AB%98%E7%BA%A7%E6%97%B6%E9%97%B4%E6%88%B3%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E6%8C%82%E8%BD%BD%20%E5%90%AF%E5%8A%A8.mount%20-%20%2F%E5%90%AF%E5%8A%A8...%3CBR%20%2F%3E%20%5B%207.324878%5D%20imx-dwmac%2030bf0000.ethernet%20eth0%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20PTP%20%E6%97%B6%E9%92%9F%3CBR%20%2F%3E%5B%207.336555%5D%20imx-dwmac%2030bf0000.ethernet%20eth0%3A%20FPE%20%E5%B7%A5%E4%BD%9C%E9%98%9F%E5%88%97%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%5B%207.343570%5D%20imx-dwmac%2030bf0000.ethernet%20eth0%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%85%8D%E7%BD%AE%E5%9B%BA%E5%AE%9A%2FRGMII%20ID%20%E9%93%BE%E8%B7%AF%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%207.353100%5D%20imx-dwmac%2030bf0000.ethernet%20eth0%EF%BC%9A%E9%93%BE%E8%B7%AF%E5%B7%B2%E8%BF%9E%E6%8E%A5%20-%201Gbps%2F%E5%85%A8%E5%8F%8C%E5%B7%A5%20-%20%E6%B5%81%E6%8E%A7%E5%B7%B2%E5%85%B3%E9%97%AD%3CBR%20%2F%3E%5B%207.353244%5D%20EXT4-fs%20(mmcblk2p1)%3A%20%E5%B7%B2%E6%8C%82%E8%BD%BD%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%2045d36d6d-da2c-4fa0-ae4f-46086176bf89%20%E8%AF%BB%2F%E5%86%99%EF%BC%8C%E6%95%B0%E6%8D%AE%E6%A8%A1%E5%BC%8F%E4%B8%BA%E6%9C%89%E5%BA%8F%E6%A8%A1%E5%BC%8F%E3%80%82%E9%85%8D%E9%A2%9D%E6%A8%A1%E5%BC%8F%EF%BC%9A%E6%97%A0%E3%80%82%3CBR%20%2F%3E%5B%207.354853%5D%208021q%EF%BC%9A%E5%B0%86%20VLAN%200%20%E6%B7%BB%E5%8A%A0%E5%88%B0%E8%AE%BE%E5%A4%87%20eth0%20%E7%9A%84%E7%A1%AC%E4%BB%B6%E8%BF%87%E6%BB%A4%E5%99%A8%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E6%8C%82%E8%BD%BD%20boot.mount%20-%20%2Fboot%E3%80%82%3CBR%20%2F%3E%5B%207.484902%5D%20realtek-mdio%20stmmac-1%3A00%20eth1%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%85%8D%E7%BD%AE%20phy%2Fgmii%20%E9%93%BE%E8%B7%AF%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%207.499221%5D%208021q%EF%BC%9A%E5%9C%A8%E8%AE%BE%E5%A4%87%20eth1%20%E4%B8%8A%E5%B0%86%20VLAN%200%20%E6%B7%BB%E5%8A%A0%E5%88%B0%E7%A1%AC%E4%BB%B6%E8%BF%87%E6%BB%A4%E5%99%A8%3CBR%20%2F%3E%5B%207.722835%5D%20realtek-mdio%20stmmac-1%3A00%20eth2%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%85%8D%E7%BD%AE%20phy%2Fgmii%20%E9%93%BE%E8%B7%AF%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%207.758421%5D%208021q%EF%BC%9A%E5%9C%A8%20eth2%20%E8%AE%BE%E5%A4%87%E4%B8%8A%E5%B0%86%20VLAN%200%20%E6%B7%BB%E5%8A%A0%E5%88%B0%E7%A1%AC%E4%BB%B6%E8%BF%87%E6%BB%A4%E5%99%A8%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E7%BD%91%E7%BB%9C%E6%9C%8D%E5%8A%A1%E5%B7%B2%E5%AE%8C%E6%88%90%20-%20%E5%90%AF%E5%8A%A8%E7%BD%91%E7%BB%9C%E6%8E%A5%E5%8F%A3%E3%80%82%3CBR%20%2F%3E%5B%207.988116%5D%20random%3A%20crng%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%AE%8C%E6%88%90%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20systemd-random-se%E2%80%A6%E6%9C%8D%E5%8A%A1%E5%B7%B2%E5%AE%8C%E6%88%90%20-%20%E5%8A%A0%E8%BD%BD%2F%E4%BF%9D%E5%AD%98%E9%9A%8F%E6%9C%BA%E7%A7%8D%E5%AD%90%E3%80%82%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20dbus.service%20-%20D-Bus%20%E7%B3%BB%E7%BB%9F%E6%B6%88%E6%81%AF%E6%80%BB%E7%BA%BF%E3%80%82%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20wpa_supplicant.service%20-%20WPA%20%E8%AF%B7%E6%B1%82%E7%A8%8B%E5%BA%8F...%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20systemd-logind.service%20-%20%E7%94%A8%E6%88%B7%E7%99%BB%E5%BD%95%E7%AE%A1%E7%90%86%E3%80%82%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20wpa_supplicant.service%20-%20WPA%20%E8%AF%B7%E6%B1%82%E7%A8%8B%E5%BA%8F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%E7%BD%91%E7%BB%9C%E3%80%82target%20-%20%E7%BD%91%E7%BB%9C%E3%80%82%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20mosquitto.service%20-%20Mosquitto%20MQTT%20%E4%BB%A3%E7%90%86...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20ssh.service%20-%20OpenBSD%20%E5%AE%89%E5%85%A8%E5%A4%96%E5%A3%B3%E6%9C%8D%E5%8A%A1%E5%99%A8...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-hostnamed.service%20-%20%E4%B8%BB%E6%9C%BA%E5%90%8D%E6%9C%8D%E5%8A%A1...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-user-sess%E2%80%A6vice%20-%20%E5%85%81%E8%AE%B8%E7%94%A8%E6%88%B7%E4%BC%9A%E8%AF%9D%E2%80%A6%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20systemd-user-sess%E2%80%A6%E6%9C%8D%E5%8A%A1%E5%B7%B2%E5%AE%8C%E6%88%90%20-%20%E5%85%81%E8%AE%B8%E7%94%A8%E6%88%B7%E4%BC%9A%E8%AF%9D%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20getty%40tty1.service%20-%20Getty%20on%20tty1%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20serial-getty%40ttymx%E2%80%A6ice%20-%20ttymxc1%20%E4%B8%8A%E7%9A%84%20Serial%20Getty%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20getty.target%20-%20%E7%99%BB%E5%BD%95%E6%8F%90%E7%A4%BA%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20systemd-hostnamed.service%20-%20%E4%B8%BB%E6%9C%BA%E5%90%8D%E6%9C%8D%E5%8A%A1%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20ssh.service%20-%20OpenBSD%20%E5%AE%89%E5%85%A8%E5%A4%96%E5%A3%B3%E6%9C%8D%E5%8A%A1%E5%99%A8%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%20mosquitto.service%20-%20Mosquitto%20MQTT%20%E4%BB%A3%E7%90%86%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20multi-user.target%20-%20%E5%A4%9A%E7%94%A8%E6%88%B7%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E8%BE%BE%E5%88%B0%E7%9B%AE%E6%A0%87%20graphic.target%20-%20%E5%9B%BE%E5%BD%A2%E7%95%8C%E9%9D%A2%E3%80%82%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20systemd-update-ut%E2%80%A6%20%E4%BB%A5%20UTMP%20%E6%A0%BC%E5%BC%8F%E8%AE%B0%E5%BD%95%E8%BF%90%E8%A1%8C%E7%BA%A7%E5%88%AB%E6%9B%B4%E6%94%B9%E2%80%A6%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20platcfg.service%E2%96%92%E2%96%92for%20%E5%B7%B2%E5%AE%8C%E6%88%90%E5%90%84%E7%A7%8D%20NXP%20i.MX%2FLS%20%E5%B9%B3%E5%8F%B0%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20systemd-update-ut%E2%80%A6%20%E5%B7%B2%E5%AE%8C%E6%88%90%20-%20%E4%BB%A5%20UTMP%20%E6%A0%BC%E5%BC%8F%E8%AE%B0%E5%BD%95%E8%BF%90%E8%A1%8C%E7%BA%A7%E5%88%AB%E6%9B%B4%E6%94%B9%E3%80%82%3C%2FP%3E%3CP%3EDebian%20GNU%2FLinux%2012%20imx8mpevk%20ttymxc1%3C%2FP%3E%3CP%3ENXP%20Linux%20SDK%202506%20Debian%20%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%88%E9%92%88%E5%AF%B9%20NXP%20%E7%89%B9%E5%AE%9A%E7%A1%AC%E4%BB%B6%E5%8A%A0%E9%80%9F%E8%BF%9B%E8%A1%8C%E4%BA%86%E4%BC%98%E5%8C%96%EF%BC%89%3CBR%20%2F%3E%20imx8mpevk%20%E7%99%BB%E5%BD%95%EF%BC%9Aroot%3CBR%20%2F%3E%E5%AF%86%E7%A0%81%EF%BC%9A%3CBR%20%2F%3E%20Linux%20imx8mpevk%206.6.52-rt43-gd377c9049508-dirty%231%20SMP%20PREEMPT%202026%E5%B9%B47%E6%9C%882%E6%97%A5%E6%98%9F%E6%9C%9F%E5%9B%9B%2011%3A19%3A58%20CST%20aarch64%3C%2FP%3E%3CP%3EDebian%20GNU%2FLinux%20%E7%B3%BB%E7%BB%9F%E9%99%84%E5%B8%A6%E7%9A%84%E7%A8%8B%E5%BA%8F%E5%9D%87%E4%B8%BA%E8%87%AA%E7%94%B1%E8%BD%AF%E4%BB%B6%EF%BC%9B%3CBR%20%2F%3E%E6%AF%8F%E4%B8%AA%E9%A1%B9%E7%9B%AE%E7%9A%84%E5%85%B7%E4%BD%93%E5%88%86%E9%85%8D%E6%9D%A1%E6%AC%BE%E5%9D%87%E5%9C%A8%E4%BB%A5%E4%B8%8B%E6%96%87%E4%BB%B6%E4%B8%AD%E6%8F%8F%E8%BF%B0%EF%BC%9A%3CBR%20%2F%3E%20%2Fusr%2Fshare%2Fdoc%2F*%2Fcopyright%20%E4%B8%AD%E7%9A%84%E5%8D%95%E4%B8%AA%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3EDebian%20GNU%2FLinux%20%E7%BB%9D%E5%AF%B9%E4%B8%8D%E6%8F%90%E4%BE%9B%E4%BB%BB%E4%BD%95%E5%BD%A2%E5%BC%8F%E7%9A%84%E6%8B%85%E4%BF%9D%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%E9%80%82%E7%94%A8%E6%B3%95%E5%BE%8B%E5%85%81%E8%AE%B8%E7%9A%84%E8%8C%83%E5%9B%B4%E5%86%85%E3%80%82%3CBR%20%2F%3Eroot%40imx8mpevk%3A~%23%3CBR%20%2F%3E%20root%40imx8mpevk%3A~%23%20modprobe%20moal%20mod_para%3Dnxp%2Fwifi_mod_para.conf%3CBR%20%2F%3E%5B%2027.658951%5D%20mlan%EF%BC%9A%E5%8A%A0%E8%BD%BD%E5%A4%96%E9%83%A8%E6%A8%A1%E5%9D%97%E4%BC%9A%E6%B1%A1%E6%9F%93%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3E%5B%2027.688908%5D%20wlan%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20MWLAN%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%5B%2027.693279%5D%20wlan%EF%BC%9A%E5%90%91%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%B3%A8%E5%86%8C...%3CBR%20%2F%3E%20%5B%2027.697621%5D%20vendor%3D0x02DF%20device%3D0x9149%20class%3D0%20function%3D1%3CBR%20%2F%3E%20%5B%2027.703270%5D%20%E9%99%84%E5%8A%A0%20moal%20%E5%8F%A5%E6%9F%84%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%8D%A1%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%EF%BC%9A0x105%3CBR%20%2F%3E%20%5B%2027.709133%5D%20rps%20%E4%BB%8E%E6%A8%A1%E5%9D%97%E5%8F%82%E6%95%B0%E8%AE%BE%E7%BD%AE%E4%B8%BA%200%3CBR%20%2F%3E%20%5B%2027.713466%5D%20SD8987%EF%BC%9A%E4%BB%8E%E7%94%A8%E6%88%B7%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E8%8E%B7%E5%8F%96%E5%88%9D%E5%A7%8B%E5%8C%96%E6%A8%A1%E5%9D%97%E5%8F%82%E6%95%B0%3CBR%20%2F%3E%5B%2027.718305%5D%20%E5%8D%A1%E7%B1%BB%E5%9E%8B%EF%BC%9ASD8987%EF%BC%8C%E9%85%8D%E7%BD%AE%E5%9D%97%EF%BC%9A0%3CBR%20%2F%3E%20%5B27.722765%5Dcfg80211_wext%3D0xf%3CBR%20%2F%3E%20%5B%2027.725757%5D%20max_vir_bss%3D1%3CBR%20%2F%3E%20%5B%2027.728391%5D%20cal_data_cfg%3Dnone%3CBR%20%2F%3E%20%5B%2027.731362%5D%20ps_mode%20%3D%201%3CBR%20%2F%3E%20%5B%2027.733821%5D%20auto_ds%20%3D%201%3CBR%20%2F%3E%20%5B%2027.736295%5D%20host_mlme%3D%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%5B%2027.739186%5D%20fw_name%3Dnxp%2Fsdiouart8987_combo_v0.bin%3CBR%20%2F%3E%5B27.743918%5DSDIO%EF%BC%9Amax_segs%20%3D%20128%20max_seg_size%20%3D%2065535%3CBR%20%2F%3E%20%5B%2027.748647%5D%20rx_work%3D1%20cpu_num%3D4%3CBR%20%2F%3E%20%5B27.751795%5D%E5%90%AF%E7%94%A8moal_recv_amsdu_packet%3CBR%20%2F%3E%20%5B%2027.755832%5D%20%E9%99%84%E5%8A%A0%20mlan%20%E9%80%82%E9%85%8D%E5%99%A8%E6%93%8D%E4%BD%9C%E3%80%82card_type%20%E4%B8%BA%200x105%E3%80%82%3CBR%20%2F%3E%5B%2027.762044%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20TX%20SG%20%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%2027.765551%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20RX%20SG%20%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%2027.776176%5D%20%E8%AF%B7%E6%B1%82%E5%9B%BA%E4%BB%B6%EF%BC%9Anxp%2Fsdiouart8987_combo_v0.bin%3CBR%20%2F%3E%20%5B%2028.073628%5D%20WLAN%EF%BC%9A%E5%9B%BA%E4%BB%B6%E4%B8%8B%E8%BD%BD%E5%AE%8C%E6%88%90%EF%BC%8C%E5%9B%BA%E4%BB%B6%E9%95%BF%E5%BA%A6%3D626584%EF%BC%8C%E5%B7%B2%E4%B8%8B%E8%BD%BD%20617556%3CBR%20%2F%3E%20%5B%2028.944747%5D%20WLAN%20%E5%9B%BA%E4%BB%B6%E5%B7%B2%E6%BF%80%E6%B4%BB%3CBR%20%2F%3E%5B%2028.947734%5D%20on_time%20%E4%B8%BA%2028943658375%3CBR%20%2F%3E%20%5B%2029.003401%5D%20VDLL%20%E6%98%A0%E5%83%8F%EF%BC%9A%E9%95%BF%E5%BA%A6%3D9028%3CBR%20%2F%3E%20%5B%2029.006743%5D%20%E5%9B%BA%E4%BB%B6%E5%9B%BD%E5%AE%B6%E4%BB%A3%E7%A0%81%20WW%20%E4%B8%8E%E7%BE%8E%E5%9B%BD%E4%B8%8D%E5%8C%B9%E9%85%8D%3CBR%20%2F%3E%5B%2029.012026%5D%20fw_cap_info%3D0x181d6f03%EF%BC%8Cdev_cap_mask%3D0xffffffff%3CBR%20%2F%3E%20%5B%2029.017672%5D%20max_p2p_conn%20%3D%208%2C%20max_sta_conn%20%3D%208%3CBR%20%2F%3E%20%5B%2029.022438%5D%20SDIO%20%E6%8E%A5%E6%94%B6%E8%81%9A%E5%90%88%EF%BC%9A1%20%E5%9D%97%E5%A4%A7%E5%B0%8F%3D512%3CBR%20%2F%3E%20%5B%2029.026600%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20RX%20SG%20%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%2029.030117%5D%20mpa_rx_buf_size%3D65280%3CBR%20%2F%3E%20%5B%2029.054744%5D%20%E6%B3%A8%E5%86%8C%20NXP%20802.11%20%E9%80%82%E9%85%8D%E5%99%A8%20mlan0%3CBR%20%2F%3E%20%5B%2029.061163%5D%20%E6%B3%A8%E5%86%8C%20NXP%20802.11%20%E9%80%82%E9%85%8D%E5%99%A8%20uap0%3CBR%20%2F%3E%20%5B%2029.069437%5D%20%E6%B3%A8%E5%86%8C%20NXP%20802.11%20%E9%80%82%E9%85%8D%E5%99%A8%20wfd0%3CBR%20%2F%3E%20%5B%2029.073887%5D%20wlan%3A%20%E7%89%88%E6%9C%AC%20%3D%20SD8987----16.92.21.p142.3-MM6X16505.p4-GPL-(FP92)%3CBR%20%2F%3E%5B%2029.083234%5D%20wlan%EF%BC%9A%E5%B7%B2%E5%AE%8C%E6%88%90%E5%90%91%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%2029.088229%5D%20wlan%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%88%90%E5%8A%9F%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3Eroot%40imx8mpevk%3A~%23%20%5B%2029.430504%5D%20wlan%3A%20mlan0%20%E5%BC%80%E5%A7%8B%E6%89%AB%E6%8F%8F%3CBR%20%2F%3E%5B%2033.741685%5D%20wlan%EF%BC%9A%E6%89%AB%E6%8F%8F%E5%AE%8C%E6%88%90%EF%BC%9A%E5%B7%B2%E6%89%AB%E6%8F%8F%E6%8E%A5%E5%85%A5%E7%82%B9%E6%95%B0%E9%87%8F%3D6%3C%2FP%3E%3CP%3Eroot%40imx8mpevk%3A~%23%3CBR%20%2F%3E%20root%40imx8mpevk%3A~%23%20mod%5B%2038.754412%5D%20wlan%3A%20mlan0%20%E5%BC%80%E5%A7%8B%E6%89%AB%E6%8F%8F%3CBR%20%2F%3E%E6%8E%A2%E9%92%88%20btnxpuart%3CBR%20%2F%3E%20%5B%2043.549431%5D%20btnxpuart%20serial0-0%3A%20ipg%20%E6%97%B6%E9%92%9F%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E9%80%9F%E7%8E%87%3D80000000%3CBR%20%2F%3E%20%5B%2043.555634%5D%20btnxpuart%20serial0-0%EF%BC%9A%E6%AF%8F%E4%B8%AA%E6%97%B6%E9%92%9F%E5%91%A8%E6%9C%9F%E5%90%AF%E7%94%A8%EF%BC%8C%E9%80%9F%E7%8E%87%3D80000000%3CBR%20%2F%3E%20root%40imx8mpevk%3A~%23%20%5B%2043.743746%5D%20wlan%3A%20%E6%89%AB%E6%8F%8F%E5%AE%8C%E6%88%90%EF%BC%9A%E6%89%AB%E6%8F%8F%E7%9A%84%E6%8E%A5%E5%85%A5%E7%82%B9%E6%95%B0%E9%87%8F%3D14%3CBR%20%2F%3E%20%5B%2044.580103%5D%20Bluetooth%3A%20hci0%3A%20FW%20%E5%B7%B2%E5%9C%A8%E8%BF%90%E8%A1%8C%E3%80%82%3CBR%20%2F%3E%5B%2046.628430%5D%20Bluetooth%3A%20hci0%3A%20%E6%93%8D%E4%BD%9C%E7%A0%81%200x0c03%20%E5%A4%B1%E8%B4%A5%3A%20-110%3CBR%20%2F%3E%20%5B%2048.756247%5D%20wlan%3A%20mlan0%20%E5%BC%80%E5%A7%8B%E6%89%AB%E6%8F%8F%3CBR%20%2F%3E%5B%2053.744943%5D%20wlan%EF%BC%9A%E6%89%AB%E6%8F%8F%E5%AE%8C%E6%88%90%EF%BC%9A%E5%B7%B2%E6%89%AB%E6%8F%8F%E6%8E%A5%E5%85%A5%E7%82%B9%E6%95%B0%E9%87%8F%3D16%3CBR%20%2F%3E%20%5B%2053.753462%5D%20wlan%EF%BC%9A%E8%AE%A1%E5%88%92%E6%89%AB%E6%8F%8F%E5%BC%80%E5%A7%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Bluetooth%20on%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259019%22%20target%3D%22_blank%22%3E%40wanggg%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%A0%E7%9B%AE%E5%89%8D%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E6%AC%BE8MP%E4%B8%BB%E6%9D%BF%EF%BC%9F%E8%83%BD%E5%90%A6%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E7%A1%AC%E4%BB%B6%E8%BF%9E%E6%8E%A5%E6%96%B9%E5%BC%8F%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%82%96%E6%81%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2391403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Bluetooth%20on%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2391403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F186613%22%20target%3D%22_blank%22%3E%40shaun_wu%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%89%BE%E5%88%B0%E4%BA%86%E7%A1%AC%E4%BB%B6%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E3%80%82%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Bluetooth%20on%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259019%22%20target%3D%22_blank%22%3E%40wanggg%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%AF%B7%E9%97%AE%E8%BF%99%E9%87%8C%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%E6%88%91%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
