BT integration guide
Ashil
I wanted to have links for the integration guide or user manual for BT integration on IMX8QXP and IMX8MPlus
joanxie
what BT module do you need to use?
Ashil
IW612
Ashil
We are using IW612 module
joanxie
for imx8mp, you can use iw612 via SDIO directly, for imx8qxp, it seems the HW doesn't support it currently, you need to change it by HW to rework it, for SW, don't need change anything, if you need further information about imx8qxp with IW612, I suggest that you create a new case in WIFI team to get further support
