BSDL FILE MX6S
BSDL FILE MX6S
8,306件の閲覧回数
tommaso_astolfi
Where Can I Get bsdl File Of MCIMX6S1AVM08AC For Boundary SCAN
ラベル(3)
6 返答(返信)
8,114件の閲覧回数
gusarambula
Hello Tommaso Astolfi,
The BSDL file for the i.MX6S can be found on the Tools and Software section of the i.MX6Solo webpage under Design Tools & Files and then Models.
Here is the direct link for the BSDL file, please note that you may need to login to download this file:
https://www.nxp.com/webapp/Download?colCode=IMX6_DL_S_BSDL&appType=license
I hope this helps!
8,114件の閲覧回数
tommaso_astolfi
Solved
cancel request
Tommaso Astolfi
I&D Manufacturing Department
Direct Phone: +39 075 89800346, +39 075 89800270
Fax: +39 075 8987215
email: [email protected]
www.eles.com
ELES Semiconductor Equipment SpA
Sede legale - Fraz. Pian di Porto – Z.I. Bodoglie, 148/1/Z - 06059 Todi
(PG) Italy
P. Iva - IT 01844830545
CF e Registro Imprese di Perugia n. 01844830545 – REA n. 163060
Capitale Sociale euro 4.000.000 i.v.
Il giorno mer 18 mar 2020 alle ore 09:58 Tommaso Astolfi <
[email protected]> ha scritto:
hi
I used the files you reported, but despite having the silkscreen of the
component the same as the one reread by the BSDL model, when I run the
infrastructure test I get a pn error on a bit.
I attach an error screen
the diagnostic answers the wrong component.
I think the file is not the right one. Do you have any suggestions?
Yours sincerely
Tommaso Astolfi
www.eles.com
(PG) Italy
Il giorno mar 10 mar 2020 alle ore 17:37 gusarambula <
>> NXP Community
>> <https://community.freescale.com/resources/statics/1000/35400-NXP-Community-Email-banner-600x75.jpg>
>> Re: BSDL FILE MX6S
>> reply from gusarambula
>> <https://community.nxp.com/people/gusarambula?et=watches.email.thread>
>> in i.MX Processors - View the full discussion
>> <https://community.nxp.com/message/1281254?commentID=1281254&et=watches.email.thread#comment-1281254>
8,114件の閲覧回数
gusarambula
I'm glad you solved this problem! If it's feasible, sharing the solution may help other Community Users.
8,112件の閲覧回数
tommaso_astolfi
Good morning
I don't know if it is relevant globally, but what I found is that my test
consists of two jtag chains with a device for each chain, each interfaced
with a different tap.
In the automatic configuration generated by the sw, I had tap1 on u11 a pld
altera 5agxma5g4f35c5n, tap 2 on U1 a mcimx6s1avm08ac and the infra test is
performed without fail.
To align the screen printing of the card with the taps, I have inverted the
assignment of the two taps, tap1 on U1 and tap2 on u11 at sw level,
inexplicably the error of re-reading the id code of the mcimx6 returns
persistently. I attach the two screens.
By returning the tap configuration to the original configuration, the error
disappears.
I solved it at the moment and sent a report to the sw manufacturer.
Tommaso Astolfi
www.eles.com
(PG) Italy
Il giorno mer 18 mar 2020 alle ore 23:23 gusarambula <
NXP Community
Re: BSDL FILE MX6S
<https://community.nxp.com/people/gusarambula?et=watches.email.thread> in *i.MX
Processors* - View the full discussion
<https://community.nxp.com/message/1285428?commentID=1285428&et=watches.email.thread#comment-1285428>
8,112件の閲覧回数
gusarambula
Thank you for taking the time to explain your setup!
8,112件の閲覧回数
tommaso_astolfi
hi
Yours sincerely
Tommaso Astolfi
www.eles.com
(PG) Italy
NXP Community
Re: BSDL FILE MX6S
