BSDL FILE MX6S
BSDL FILE MX6S
tommaso_astolfi
Where Can I Get bsdl File Of MCIMX6S1AVM08AC For Boundary SCAN
Labels (3)
gusarambula
Hello Tommaso Astolfi,
The BSDL file for the i.MX6S can be found on the Tools and Software section of the i.MX6Solo webpage under Design Tools & Files and then Models.
Here is the direct link for the BSDL file, please note that you may need to login to download this file:
https://www.nxp.com/webapp/Download?colCode=IMX6_DL_S_BSDL&appType=license
I hope this helps!
tommaso_astolfi
Solved
cancel request
Tommaso Astolfi
I&D Manufacturing Department
Direct Phone: +39 075 89800346, +39 075 89800270
Fax: +39 075 8987215
email: [email protected]
www.eles.com
ELES Semiconductor Equipment SpA
Sede legale - Fraz. Pian di Porto – Z.I. Bodoglie, 148/1/Z - 06059 Todi
(PG) Italy
P. Iva - IT 01844830545
CF e Registro Imprese di Perugia n. 01844830545 – REA n. 163060
Capitale Sociale euro 4.000.000 i.v.
Il giorno mer 18 mar 2020 alle ore 09:58 Tommaso Astolfi <
[email protected]> ha scritto:
hi
I used the files you reported, but despite having the silkscreen of the
component the same as the one reread by the BSDL model, when I run the
infrastructure test I get a pn error on a bit.
I attach an error screen
the diagnostic answers the wrong component.
I think the file is not the right one. Do you have any suggestions?
Yours sincerely
Tommaso Astolfi
www.eles.com
(PG) Italy
Il giorno mar 10 mar 2020 alle ore 17:37 gusarambula <
>> NXP Community
>> <https://community.freescale.com/resources/statics/1000/35400-NXP-Community-Email-banner-600x75.jpg>
>> Re: BSDL FILE MX6S
>> reply from gusarambula
>> <https://community.nxp.com/people/gusarambula?et=watches.email.thread>
>> in i.MX Processors - View the full discussion
>> <https://community.nxp.com/message/1281254?commentID=1281254&et=watches.email.thread#comment-1281254>
gusarambula
I'm glad you solved this problem! If it's feasible, sharing the solution may help other Community Users.
tommaso_astolfi
Good morning
I don't know if it is relevant globally, but what I found is that my test
consists of two jtag chains with a device for each chain, each interfaced
with a different tap.
In the automatic configuration generated by the sw, I had tap1 on u11 a pld
altera 5agxma5g4f35c5n, tap 2 on U1 a mcimx6s1avm08ac and the infra test is
performed without fail.
To align the screen printing of the card with the taps, I have inverted the
assignment of the two taps, tap1 on U1 and tap2 on u11 at sw level,
inexplicably the error of re-reading the id code of the mcimx6 returns
persistently. I attach the two screens.
By returning the tap configuration to the original configuration, the error
disappears.
I solved it at the moment and sent a report to the sw manufacturer.
Tommaso Astolfi
www.eles.com
(PG) Italy
Il giorno mer 18 mar 2020 alle ore 23:23 gusarambula <
NXP Community
Re: BSDL FILE MX6S
<https://community.nxp.com/people/gusarambula?et=watches.email.thread> in *i.MX
Processors* - View the full discussion
<https://community.nxp.com/message/1285428?commentID=1285428&et=watches.email.thread#comment-1285428>
gusarambula
Thank you for taking the time to explain your setup!
tommaso_astolfi
hi
Yours sincerely
Tommaso Astolfi
www.eles.com
(PG) Italy
NXP Community
Re: BSDL FILE MX6S
