Audio over HDMI Creates a Kernel Panic When Audio Stops
maxkrummenacher
On an i.MX 8QM system the kernel panics after audio was played over HDMI.
The kernel version is based on lf-6.12.20-2.0.0. It looks like the issue is still present in lf-6.12.49-2.2.0.
Looks like commit c91c717f7113 ("LF-13883: drm: bridge: mhdp: Add info frame remove function") introduced a regression as it does not use the register access helper cdns_mhdp_bus_write() and thus for i.MX 8QM does not write registers in they way they should be written.
The attached patch fixed the issue for me.
Max
Zhiming_Liu
Hi @maxkrummenacher
The Q2 BSP is expected to resolve this issue.
Zhiming
Zhiming_Liu
Hi @maxkrummenacher
Reported it, wait for internal reply.
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2264780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAudio%20over%20HDMI%20Creates%20a%20Kernel%20Panic%20When%20Audio%20Stops%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%3CP%3EOn%20an%20i.MX%208QM%20system%20the%20kernel%20panics%20after%20audio%20was%20played%20over%20HDMI.%3C%2FP%3E%3CP%3EThe%20kernel%20version%20is%20based%20on%26nbsp%3Blf-6.12.20-2.0.0.%20It%20looks%20like%20the%20issue%20is%20still%20present%20in%26nbsp%3Blf-6.12.49-2.2.0.%3C%2FP%3E%3CP%3ELooks%20like%20commit%26nbsp%3Bc91c717f7113%20(%22LF-13883%3A%20drm%3A%20bridge%3A%20mhdp%3A%20Add%20info%20frame%20remove%20function%22)%20introduced%20a%20regression%20as%20it%20does%20not%20use%20the%20register%20access%20helper%26nbsp%3Bcdns_mhdp_bus_write()%20and%20thus%20for%20i.MX%208QM%20does%20not%20write%20registers%20in%20they%20way%20they%20should%20be%20written.%3C%2FP%3E%3CP%3EThe%20attached%20patch%20fixed%20the%20issue%20for%20me.%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3CP%3EMax%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2265819%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Audio%20over%20HDMI%20Creates%20a%20Kernel%20Panic%20When%20Audio%20Stops%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265819%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F18368%22%20target%3D%22_blank%22%3E%40maxkrummenacher%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EReported%20it%2C%20wait%20for%20internal%20reply.%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2327419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Audio%20over%20HDMI%20Creates%20a%20Kernel%20Panic%20When%20Audio%20Stops%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2327419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F18368%22%20target%3D%22_blank%22%3E%40maxkrummenacher%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20Q2%20BSP%20is%20expected%20to%20resolve%20this%20issue.%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E
