Arm compiler
Arm compiler
2,282 次查看
christophe
Hi all,
I'm trying to compil under arm target, as ltib does.
I don't see where i must act: just add an option, take another gcc, ...?
2,065 次查看
StevieRG
The attached might be useful for small projects, these are a makefile and makerules for simple building for the iMX. There are lots of ways to do this, and this might not be the best, but maybe it could be a useful basis to start with.
2,065 次查看
Yuri
You can use LTIB environment under LTIB shell
> ./ltib -m sheel
LTIB> gcc .....
here gcc relates to ARM cross compiler.
Also please look at AN3870
AN3870 :    Developing an Application for the i.MX Devices on Linux Platform
http://cache.freescale.com/files/dsp/doc/app_note/AN3870.pdf
