Andrtoid 14 Build error
1,831件の閲覧回数
Beginner1122
I am trying to make a android 14 build for my inventron invesom-imx8mm board, The issue i am facing right now it gives alot of errors like some of the drivers like nwl-dsi is missing also i have attached the Build log.txt file and the files it creates after completing incomplete build.Also the kernel-obj doesnot contain anything. Please help in resolving this issue.
ANDROID-AUTO
1,802件の閲覧回数
Zhiming_Liu
Since you are using a third party BSP, you need to consult inventron for this issue. judging from the error, it looks like the problem is caused by code modified by inventron, or it could be due to your source code being incomplete.
Zhiming
