Android for i.MX51-BBG
16,745件の閲覧回数
RashmiRamanna
Hi all,
I am porting android to i.MX51 BBG platform.
I followed i.MX_Android_R10.4_User_Guide and built the android.
But Android Gui is not starting on dvi monitor.
I am sure I am giving correct bootargs.
The log is as below
from_bootup.cap
Later I built the Android by using below command
make PRODUCT-imx51_BBG-eng
I am able to get Android GUI but all applications failing.
The log file is attached as eng.cap
Please can anyone tell me how can I fix it.
eng.cap
Original Attachment has been moved to: 166-from_bootup.cap
タグ(2)
29 返答(返信)
3,411件の閲覧回数
nit123
Have you tried both the below bootargs?
console=ttymxc0 init=/init androidboot.console=ttymxc0 di1_primary pmem=32M,64M fbmem=5M gpu_memory=32M calibration
console=ttymxc0 init=/init androidboot.console=ttymxc0 di1_primary video=mxcdi1fb:RGB565,bpp=32 pmem=32M,64M fbmem=10M gpu_memory=32M calibration
3,411件の閲覧回数
RashmiRamanna
I am using gingerbread. Booting through MMC. Yes I am getting android boot logo.
After that all android applications are failing......
3,411件の閲覧回数
nit123
Tell me some of the below questions.
(1)You are doing it for froyo or gingerbread?
(2)you are booting through mmc or NFS?
(3)Are you getting properly android boot logo animation while booting the board.
3,411件の閲覧回数
RashmiRamanna
Hi Nitin,
I changed line in init.rc as below
mount rootfs rootfs / rw remount
 I changed permissions for /data .
Now too all applications failing.
Please help me out.
3,410件の閲覧回数
RashmiRamanna
Thank you Nitin.
My init.rc is attached.
Please tell me where is the problem.
3,410件の閲覧回数
nit123
i think some permission issue or some mounting partition issue is there as per your eng.cap log.
3,410件の閲覧回数
nit123
i just checked from_bootup.cap,in that it is keep on rebooting android zygote process and coming the below message again and again.
"AndroidRuntime START com.android.internal.os.ZygoteInit"
3,410件の閲覧回数
RashmiRamanna
Thanks Nitin.
whats wrong in eng.cap?
3,410件の閲覧回数
nit123
I think some permission issue is there thats why it is rebooting with below message.
Try to give rw permission in init.rc as below and check.
on post-fs
    # once everything is setup, no need to modify /
or somewhere else permission is missing.
share your init.rc file once.
