Android charging battery drivers
4,560件の閲覧回数
electronic15
Hi everyone,
We are starting a new design based on the i.MX8 Mini processor which will be a portable device powered by a Li-On 3.7v battery pack. This device will run Android 9 OS. The battery will be charged through a USB 2.0 Type-C interface and we need to solve the USB PD, charging battery, and fuel gauge battery.
Is there any IC(s) to solves those issues compatible with the OS or whose drivers are available? (we would like to avoid developing the drivers)
Thanks!
3 返答(返信)
4,494件の閲覧回数
weidong_sun
Hello Gonzalo,
    Our i.MX8MM-EVK doesn't support Charger IC, BUT On our I.MX6DL-SabreSD board, charger IC MAX8903C is supported, so you can refer to it's schematic and charger driver in android.
Attachment is it's schematic.
    Or your can also select  charger ICs from other providers, basically, they also provide you corresponding drivers.
Hope the information is helpf to you!
Have a great day!
B.R,
Weidong
4,494件の閲覧回数
electronic15
Thank you Wigros, it helps me a lot. I already saw a few options from MAXIM so I'm going to inquire into it a bit more.
Regards.
4,494件の閲覧回数
weidong_sun
you are welcome!
Have a great day!
B.R,
Weidong
