Android build error
Android build error
2,901件の閲覧回数
sachusanal
Dear all.
I download and compile the source follow by URL i.MX 6 Series Software and Development Tool R|Freescale. select android  5.0
$ source build/envsetup.sh
$ lunch sabresd_6dq-user
$ make 2> &1 | tee build_sabresd_6dq_android.log
This command I get below errors.
make: *** No rule to make target `kernel_imx/arch/arm/configs/imx_v7_android_defconfig', needed by `out/target/product/sabresd_6dq/.config'. Stop.
how to fix this issue?
Please help me to solve this issue.
Regrds
Sachu
タグ(1)
3 返答(返信)
2,281件の閲覧回数
weidong_sun
Hello Sachu,
    I tesed the question you encountered. you should forget to set the value of ARCH & CROSS_COMPILE, please check user's guide of android5.0 BSP and re-configure these 2 parameters.
Weidong
2,281件の閲覧回数
sachusanal
Thanks for your reply
let me know i am using android 5.0  for custom build build.my linux pc have 8GB RAM space.
ubuntu 12.04 is installed.
could u please tell me this RAM space is enough for the custom build
2,281件の閲覧回数
balamuruga
Though the thread is very old, just to update.
The error log seems that, the file 'kernel_imx/arch/arm/configs/imx_v7_android_defconfig' is not present in your android source tree.
Possibly issue could be either of below,
1. the imx6 kernel code at kernel_imx folder is not present.
2. the kernel code is not checked out to the release version.
First go to your android code and check 'ls -l kernel_imx/arch/arm/configs/imx_v7_android_defconfig'
And check whether the file is present.
If you find the file, there should not be a problem.
