Android build error with -llzo2 and -luuid on 64 bits ubuntu
24,787 次查看
shaojun_wang
When build ICS on 64 bits ubuntu 11.10, if there is -llzo2 in some Android.mk, even you have already run “sudo apt-get install liblzo2-dev”, you may still meet some build error.
For example, in attached mtd-utils package, there is -llzo2 in mtd-utils/mkfs.ubifs/Android.mk, so you may meet this kind of error message:
host Executable: mkfs.ubifs (out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/mkfs.ubifs)
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6.1/../../../liblzo2.so when searching for -llzo2
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6.1/../../../liblzo2.a when searching for -llzo2
/usr/bin/ld: skipping incompatible /usr/lib/liblzo2.so when searching for -llzo2
/usr/bin/ld: skipping incompatible /usr/lib/liblzo2.a when searching for -llzo2
/usr/bin/ld: cannot find -llzo2
collect2: ld returned 1 exit status
make: *** [out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/mkfs.ubifs] Error 1
To fix the error, you should install 32 bits lzo2 and luuid to your 64 bits ubuntu. Below is the example of lzo2.
1. Down 32 bits lzo2, then unpack it to a folder. You can get the lzo2 deb package in the attachmemt.
$ sudo mkdir /usr/lib/liblzo2_i386
$ sudo dpkg -x liblzo2-dev_2.05-1_i386.deb /usr/lib/liblzo2_i386/
$ sudo dpkg -x liblzo2-2_2.05-1_i386.deb /usr/lib/liblzo2_i386/
2. Change the link of liblzo2 from default 64 bit lib to 32 bit lib.
$ cd /usr/lib/
$ sudo rm liblzo2.a
$ sudo rm liblzo2.so
$ sudo rm liblzo2.so.2
$ sudo ln -s liblzo2_i386/usr/lib/liblzo2.a liblzo2.a
$ sudo ln -s liblzo2_i386/usr/lib/liblzo2.so.2.0.0 liblzo2.so
$ sudo ln -s liblzo2_i386/usr/lib/liblzo2.so.2.0.0 liblzo2.so.2
Original Attachment has been moved to: liblzo2-2_2.05-1_i386.deb.zip
Original Attachment has been moved to: liblzo2-dev_2.05-1_i386.deb.zip
Original Attachment has been moved to: mtd-utils.tgz
Original Attachment has been moved to: uuid-dev_2.20.1-1ubuntu3_i386.deb.zip
20 回复数
10,105 次查看
saurabh206
Senior Contributor III
Use this
# Copyright 2009 The Android Open Source Project
LOCAL_PATH:= $(call my-dir)
include $(CLEAR_VARS)
LOCAL_SRC_FILES := \
    mkfs.ubifs.c \
    crc16.c \
    crc32.c \
    devtable.c \
    lpt.c \
    compr.c \
    hashtable/hashtable.c \
    hashtable/hashtable_itr.c
#LOCAL_CC := /usr/bin/gcc
#LOCAL_CXX := /usr/bin/g++
LOCAL_CFLAGS = -O2 -Wall
LOCAL_CFLAGS+= -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -m64
LOCAL_CFLAGS+= -Wmissing-prototypes -Winline
LOCAL_LDFLAGS += -L/usr/lib/x86_64-linux-gnu
LOCAL_LDLIBS:= -lz -llzo2 -lm -luuid -m64
LOCAL_C_INCLUDES += $(LOCAL_PATH)/
LOCAL_C_INCLUDES += /usr/include/
LOCAL_C_INCLUDES += $(LOCAL_PATH)/hashtable
LOCAL_MODULE_TAGS := optional
LOCAL_MODULE := mkfs.ubifs
include $(BUILD_HOST_EXECUTABLE)
10,105 次查看
shinuv
I have tried the same and its giving error. so i changed as
    mkfs.ubifs.c \
    crc16.c \
    crc32.c \
    devtable.c \
    lpt.c \
    compr.c \
LOCAL_CFLAGS+= -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -m32
LOCAL_LDFLAGS += -L/usr/lib/i386-linux-gnu
LOCAL_LDLIBS:= -lz -llzo2 -lm -luuid -m32
now following error as getting
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/libstdc++.so when searching for -lstdc++
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/libstdc++.a when searching for -lstdc++
/usr/bin/ld: cannot find -lstdc++
10,105 次查看
shinuv
gcc-multilib_4.6.3-1ubuntu5 is already installed. But i am not able to install g++-multilib_4.6.3-1ubuntu5 giving error as 'E: Internal Error, No file name for libuuid1'
10,105 次查看
saurabh206
Shinu
Just try to delete whole output directory.
10,102 次查看
shinuv
Hi Saurabh,
I deleted output directory and compiled again. Still i am getting the following errors
10,105 次查看
saurabh206
You need to add -m64  in Android.mk,
Check my previous reply.
10,105 次查看
shinuv
I added -m64 then i am getting following errors
Export includes file: external/mtd-utils/mkfs.ubifs/Android.mk -- out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/export_includes
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib/liblzo2.so when searching for -llzo2
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib/liblzo2.a when searching for -llzo2
/usr/bin/ld: skipping incompatible /usr/lib/../lib/liblzo2.so when searching for -llzo2
/usr/bin/ld: skipping incompatible /usr/lib/../lib/liblzo2.a when searching for -llzo2
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../liblzo2.so when searching for -llzo2
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../liblzo2.a when searching for -llzo2
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib/libuuid.so when searching for -luuid
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib/libuuid.a when searching for -luuid
/usr/bin/ld: skipping incompatible /usr/lib/../lib/libuuid.so when searching for -luuid
/usr/bin/ld: skipping incompatible /usr/lib/../lib/libuuid.a when searching for -luuid
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../libuuid.so when searching for -luuid
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../libuuid.a when searching for -luuid
/usr/bin/ld: skipping incompatible /usr/lib/libuuid.so when searching for -luuid
/usr/bin/ld: skipping incompatible /usr/lib/libuuid.a when searching for -luuid
/usr/bin/ld: cannot find -luuid
so i added LOCAL_LDFLAGS += -L/usr/lib/i386-linux-gnu instead of LOCAL_LDFLAGS += -L/usr/lib/x86_64-linux-gnu and -m32
then the above error are gone but getting error as
10,105 次查看
shinuv
Hi all,
I am new to Android.
I am trying to compile Android source in ubuntu 12.04 and i have done the changes as said in the previous post but its giving following errors
Checking API: checkapi-current
/usr/bin/ld: skipping incompatible /usr/lib/x86_64-linux-gnu/libz.so when searching for -lz
/usr/bin/ld: skipping incompatible /usr/lib/x86_64-linux-gnu/libz.a when searching for -lz
/usr/bin/ld: skipping incompatible /usr/lib/x86_64-linux-gnu/libm.so when searching for -lm
/usr/bin/ld: skipping incompatible /usr/lib/x86_64-linux-gnu/libm.a when searching for -lm
/usr/bin/ld: skipping incompatible /usr/lib/x86_64-linux-gnu/libc.so when searching for -lc
/usr/bin/ld: skipping incompatible /usr/lib/x86_64-linux-gnu/libc.a when searching for -lc
Please help me to resolve this.
10,105 次查看
saurabh206
Shinu
Which android version you are trying to build?
What processor you are using 32 bit or 64 bit and same for ubuntu?
Saurabh
10,105 次查看
shinuv
Hi Saurabh,
Thanks for your quick reply.
android version is 4.2.2  , processor  and Ubuntu is 64 bit .
10,105 次查看
saurabh206
You can check your Android.mk has following.
Saurabh
10,105 次查看
shinuv
'/home/svg6kor/MRST/myandroid/external/mtd-utils/mkfs.ubifs/Android.mk' has the following
    mkfs.ubifs.c \
    crc16.c \
    crc32.c \
    devtable.c \
    lpt.c \
    compr.c \
In '/home/svg6kor/MRST/myandroid/external/mtd-utils/Android.mk'
added
LOCAL_LDFLAGS +=-L /usr/lib/
LOCAL_C_INCLUDES +=/usr/lib/uuid-dev/usr/include/
LOCAL_C_INCLUDES +=/usr/lib/liblzo2_i386/usr/include
10,104 次查看
junfrost
Hello Everyone,@@@@ ! !
Here is my workaround, hope it will help you.
My enviroment is Ubuntu 12.04_64bit.I tried the solution of ShaojunWang and made some changes.
  1. I installed liblzo2-2_2.05-1_i386.deb ,liblzo2-dev_2.05-1_i386.deb and uuid-dev_2.20.1-1ubuntu3_i386.deb which are provided by ShaojunWang .
  • install liblzo2
    $ cd /usr/lib/
    $ sudo rm liblzo2.a
  • install uuid-dev
    $ sudo mkdir /usr/lib/uuid-dev
    $ sudo dpkg -x uuid-dev_2.20.1-1ubuntu3_i386.deb  /usr/lib/uuid-dev/
    $ cd /usr/lib/
    $ sudo ln -s uuid-dev/usr/lib/i386-linux-gnu/libuuid.a  libuuid.a
    $ sudo ln -s uuid-dev/usr/lib/i386-linux-gnu/libuuid.so  libuuid.so
2. I modified the  external/mtd-utils/mkfs.ubifs/Android.mk.This fixed the "-llzo2 not found; uuid/uuid.h not found;".
    $ vi external/mtd-utils/mkfs.ubifs/Android.mk
    I added  the following  to  external/mtd-utils/mkfs.ubifs/Android.mk.
10,104 次查看
anthonyharivel
Well I've got a work around....
When it fails:
> rm -rf out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/
> make BUILD_HOST_64bit=1
then it build the stupid mkfs.ubifs stuff in 64bit
then it fails again but further and then you can re-run normal "make" and it will build.
I know it's painfull solution but it breaks nothing.
Anthony
10,104 次查看
jian
my virtual is ubuntu 12.04 x86_64, when I build the android 4.2.2 for sabresd_6dq I meet the error:
make: *** No rule to make target `out/target/product/sabresd_6dq/obj/STATIC_LIBRARIES/libubi_intermediates/export_includes', needed by `out/target/product/sabresd_6dq/obj/EXECUTABLES/recovery_intermediates/import_includes'.  Stop.
please help me!
     Thanks!
10,104 次查看
LeonardoSandova
Specialist I
I got the same error and decided to run a Ubuntu 10.04 virtually. I decided to do this due to the following text:
" Building on Ubuntu 12.04 is currently only experimentally supported and is not guaranteed to work on branches other than master."
located on this page: Initializing a Build Environment | Android Developers
Anyway, on 10.4 besides the  packages mentioned on the later page, one needs to install these:
   65  sudo apt-get install sun-java6-jdk
   99  sudo apt-get install uuid uuid-dev
  103  sudo apt-get install zlib1g-dev liblz-dev
  106  sudo apt-get install liblzo2-2 liblzo2-dev
I had some trouble finding the first one (sun-java6-jdk) and the trick was to add another repo:
sudo add-apt-repository ppa:ferramroberto/java && sudo apt-get update
Leo
10,103 次查看
app025
Dear all,
both solutions break capability to compile 64 bit applications on Ubuntu 12.04 64bits.
Assuming you already installed liblzo2 and uuid running something like
$ sudo apt-get install liblzo2-dev uuid-dev
you can force 64bits compilation (using -m64 flag) applying the attached patch within android build system in the external/mtd-utils folder.
My Two Cents
Gigi
10,102 次查看
dureshasanka
Hello Pierluigi Passaro,
I had the same problem and I applied the patch that you attached. Thank you very much for the patch file. Now the problem is solved.
But now I am getting some another problem. Could you please help me to solve this issue. I am new to these stuff.
I am using Ubuntu 10.10 64-bit to compile Android Jelly Bean. The error is,
install -D kernel_imx/arch/arm/boot/uImage  out/target/product/sabresd_6dq/uImage
install -D kernel_imx/arch/arm/boot/zImage  out/target/product/sabresd_6dq/kernel
/usr/bin/ld: i386 architecture of input file `out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/mkfs.ubifs.o' is incompatible with i386:x86-64 output
/usr/bin/ld: i386 architecture of input file `out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/crc16.o' is incompatible with i386:x86-64 output
/usr/bin/ld: i386 architecture of input file `out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/crc32.o' is incompatible with i386:x86-64 output
/usr/bin/ld: i386 architecture of input file `out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/devtable.o' is incompatible with i386:x86-64 output
/usr/bin/ld: i386 architecture of input file `out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/lpt.o' is incompatible with i386:x86-64 output
/usr/bin/ld: i386 architecture of input file `out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/compr.o' is incompatible with i386:x86-64 output
/usr/bin/ld: i386 architecture of input file `out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/hashtable/hashtable.o' is incompatible with i386:x86-64 output
/usr/bin/ld: i386 architecture of input file `out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/hashtable/hashtable_itr.o' is incompatible with i386:x86-64 output
out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/mkfs.ubifs.o: In function `calc_min_log_lebs':
/home/duresh/Documents/A03-Android/AndroidImagebuld/myandroid/external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:314: undefined reference to `__udivdi3'
/home/duresh/Documents/A03-Android/AndroidImagebuld/myandroid/external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:320: undefined reference to `__udivdi3'
out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/mkfs.ubifs.o: In function `lookup_inum_mapping':
/home/duresh/Documents/A03-Android/AndroidImagebuld/myandroid/external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:1161: undefined reference to `__umoddi3'
The complete output is attached here and also Android.mk file which applied the patch also attached.
Please kindly help me with this matter.
Thanks in advance,
Duresh
10,101 次查看
rickchu
modify /external/mtd-utils/mkfs.ubifs/Android.mk
add "-lc" and "-lgcc" as below to fix undefined reference error.
LOCAL_LDLIBS:= -lz -llzo2 -lm -lc -lgcc -luuid -m64
tested with android_jb4.2.2_1.1.0-ga
Rick
10,104 次查看
simon_cai
dear shaojun
run sudo apt-get install liblzo2-dev:i386    ======>it will be OK.
THX
SIMON
