Android Text message
deepanrajanbara
I have compiled Android 5.0 lollipop for imx6 and we are using a 3rd party ril library for connecting to gprs.It seemed to work fine But when we try to delete sms which in the sim card it crashes and comes out.when we give logcat we get the following log
Writing exception to parcel
E/DatabaseUtils( 1009): java.lang.SecurityException: Updating message on Icc: uid 1001 does not have android.permission.RECEIVE_SMS.
E/DatabaseUtils( 1009): at android.app.ContextImpl.enforce(ContextImpl.java:1893)
E/DatabaseUtils( 1009): at android.app.ContextImpl.enforceCallingPermission(ContextImpl.java:1913)
E/DatabaseUtils( 1009): at android.content.ContextWrapper.enforceCallingPermission(ContextWrapper.java:587)
E/DatabaseUtils( 1009): at com.android.internal.telephony.IccSmsInterfaceManager.enforceReceiveAndSend(IccSmsInterfaceManager.java:176)
E/DatabaseUtils( 1009): at com.android.internal.telephony.IccSmsInterfaceManager.updateMessageOnIccEf(IccSmsInterfaceManager.java:199)
E/DatabaseUtils( 1009): at com.android.internal.telephony.UiccSmsController.updateMessageOnIccEfForSubscriber(UiccSmsController.java:64)
E/DatabaseUtils( 1009): at com.android.internal.telephony.UiccSmsController.updateMessageOnIccEf(UiccSmsController.java:55)
E/DatabaseUtils( 1009): at android.telephony.SmsManager.deleteMessageFromIcc(SmsManager.java:575)
E/DatabaseUtils( 1009): at com.android.providers.telephony.SmsProvider.deleteMessageFromIcc(SmsProvider.java:623)
E/DatabaseUtils( 1009): at com.android.providers.telephony.SmsProvider.delete(SmsProvider.java:602)
E/DatabaseUtils( 1009): at android.content.ContentProvider$Transport.delete(ContentProvider.java:309)
E/DatabaseUtils( 1009): at android.content.ContentProviderNative.onTransact(ContentProviderNative.java:206)
E/DatabaseUtils( 1009): at android.os.Binder.execTransact(Binder.java:446)
D/AndroidRuntime( 1702): Shutting down VM
E/AndroidRuntime( 1702): FATAL EXCEPTION: main
E/AndroidRuntime( 1702): Process: com.android.mms, PID: 1702
E/AndroidRuntime( 1702): java.lang.SecurityException: Updating message on Icc: uid 1001 does not have android.permission.RECEIVE_SMS.
E/AndroidRuntime( 1702): at android.os.Parcel.readException(Parcel.java:1540)
E/AndroidRuntime( 1702): at android.database.DatabaseUtils.readExceptionFromParcel(DatabaseUtils.java:185)
E/AndroidRuntime( 1702): at android.database.DatabaseUtils.readExceptionFromParcel(DatabaseUtils.java:137)
E/AndroidRuntime( 1702): at android.content.ContentProviderProxy.delete(ContentProviderNative.java:543)
E/AndroidRuntime( 1702): at android.content.ContentResolver.delete(ContentResolver.java:1299)
E/AndroidRuntime( 1702): at android.database.sqlite.SqliteWrapper.delete(SqliteWrapper.java:90)
E/AndroidRuntime( 1702): at com.android.mms.ui.ManageSimMessages.deleteFromSim(ManageSimMessages.java:289)
E/AndroidRuntime( 1702): at com.android.mms.ui.ManageSimMessages.deleteAllFromSim(ManageSimMessages.java:300)
E/AndroidRuntime( 1702): at com.android.mms.ui.ManageSimMessages.access$600(ManageSimMessages.java:59)
E/AndroidRuntime( 1702): at com.android.mms.ui.ManageSimMessages$4.onClick(ManageSimMessages.java:326)
E/AndroidRuntime( 1702): at com.android.internal.app.AlertController$ButtonHandler.handleMessage(AlertController.java:160)
E/AndroidRuntime( 1702): at android.os.Handler.dispatchMessage(Handler.java:102)
E/AndroidRuntime( 1702): at android.os.Looper.loop(Looper.java:135)
E/AndroidRuntime( 1702): at android.app.ActivityThread.main(ActivityThread.java:5221)
E/AndroidRuntime( 1702): at java.lang.reflect.Method.invoke(Native Method)
E/AndroidRuntime( 1702): at java.lang.reflect.Method.invoke(Method.java:372)
E/AndroidRuntime( 1702): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:899)
E/AndroidRuntime( 1702): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:694)
Thank you,
Deepanraj.A
b36401
There is nothing special regarding to SMS in our Android BSP.
Please refer common recomendations regarding to SMS deletion:
http://stackoverflow.com/questions/29361749/how-to-delete-sms-programatically-in-android
Victor
deepanrajanbara
But it seemed to be some permission related issue
So any permission need to be given in Android source code
Any idea ?
Thank you,
Deepanraj.A
