Android-Nougat-imx6q 9axis sensor integartion
1,691件の閲覧回数
ravikiranjj
Hi All,
I am working on the SABRESD based board - Nougat porting.
We are using the 9axis sensor MPU-9150 from invensense.
Currently we are able to get the raw values of sensors from sysfs entries.
But Invensense HAL is failing to register and get the sensors values.
Is anybody knows how to integrate  the invensense Sensor  HAL in Android  ?
Ravikiran J J
ラベル(4)
2 返答(返信)
1,635件の閲覧回数
weidong_sun
Hello RAVIKIRAN,
       Unfortunately, we don't have corresponding solutions.
       Generally speaking, Invensense  should provide linux driver & documents on how to port it to android, if you have got these resouces from manufacture, and encountered some problems, the better way is to ask for help from Invensense. Because we don't have corresponding solutions.
TIC    weidong sun
1,634件の閲覧回数
ravikiranjj
Hello Wigros,
Thank you for your reply.
I will check with invensense team.
Ravikiran  J J
