Android 9 build error with clean AOSP build
已解决
跳至解决方案
6,100 次查看
vinothkumars
Senior Contributor IV
Dear NXP,
I am working on IMX8QM with Android 9. I got build error after with clean Android 9 build.
Build Steps,
     source build/envsetup.sh
     lunch mek_8q_car-userdebug
     make clean
     make -j6
OpenJDK 64-Bit Server VM warning: INFO: os::commit_memory(0x00000000d4400000, 132120576, 0) failed; error='Not enough space' (errno=12)
# There is insufficient memory for the Java Runtime Environment to continue.
# Native memory allocation (mmap) failed to map 132120576 bytes for committing reserved memory.
Thanks & Regards,
VinothS,
Vinothkumar Sekar
1 解答
5,421 次查看
vinothkumars
Build was done. once reboot the system
Thanks & Regards,
VinothS,
Vinothkumar Sekar
在原帖中查看解决方案
3 回复数
5,422 次查看
vinothkumars
Thanks & Regards,
VinothS,
Vinothkumar Sekar
5,421 次查看
gusarambula
Hello VinothS,
The AOSP is supported by Google so I would suggest that you consult the Google Developer Forums.
It seems, however, that you need more RAM (or SWAP) memory for building Android. Please review the requirements from the Android Source repository:
https://source.android.com/setup/build/requirements
I hope this helps.
5,420 次查看
vinothkumars
Thank you Gusarambula,
Thanks & Regards,
VinothS,
Vinothkumar Sekar
