Android 7.1.2 u-boot building every time
2,133 次查看
aravinthkumarja
Senior Contributor II
Hi All,
I'm trying to build the Android 7.1.2 BSP. The build was successful but every time when i give make u-boot get compiling.
I have attached compilation log on this post.
Can you please provide suggestion on this.?
Aravinth
标签 (5)
2 回复数
1,739 次查看
weidong_sun
Hello aravinthkumar,
        If you don't want to compile u-boot when comiling android source code, you can do like this:
open "device\fsl\imx6\BoardConfigCommon.mk", and change "TARGET_NO_BOOTLOADER := true"
Have a nice day!
TIC Weidong sun
1,739 次查看
aravinthkumarja
Hi Weidong,
Thanks for your response. The default value itself "TARGET_NO_BOOTLOADER := true" only. So it's not helping me.
Can you please provide any other solution.?
Also I want know why this u-boot compiling every time in Android 7.1.2.  As per my knowledge previous version of android u-boot won't compile every time.
Can you please provide reason for this.?
Aravinth
