Android 15. gpioinfo : Permission denied
761件の閲覧回数
Axent
Hello.
I just built Android 15 for Compulab board and started the system.
https://github.com/compulab-yokneam/imx8-android
userdebug configuration was used.
But when I try to run some command from shell (minicom), I get: Permission denied.
For example when I try to check gpio map through gpioinfo, I get this.
How can I change permissions.?
Thanks.
3 返答(返信)
734件の閲覧回数
Axent
Could anyone help me??
724件の閲覧回数
danielchen
Hi Axent:
Do you have the root privilege to access the gpioinfo?   you can use "su" to elevate the privileges.
699件の閲覧回数
Axent
Yes.
Thanks. The 'su' is working.'
タグ(1)
