Amphion Malone decoder detiling
crg7475
Hi, the gstv4l2 based decoder outputs frames in a tiled format. However, I need the frames in a detiled form.
Is there a way to detile the frames so that for example some other image processing tools can use them?
joanxie
what board are you talking about?
crg7475
Any board with an i.MX8 QuadMax. But now I discovered that the DPU on the QuadMax can do this detiling.
