Adding a new user on Linux.
ricardo_ioct
Ladies and Gentlemens,
I'm facing a little problem while using the adduser command on linux. When I tried to add a new user, the console bricks at the password point, not accepting any character neither CTRL+C. The only command supported is finger+reset button. ^^
This is my configuration:
- i.MX53 Novpeck board(pretty much the same as QSB);
- LINUX BSP 11.09;
- Standard USB-to-serial converter;
And this is the adduser output:
root@freescale ~$ adduser horus
adduser: horus: login already in use
root@freescale ~$ passwd horus
Changing password for horus
Enter the new password (minimum of 5, maximum of 8 characters)
Please use a combination of upper and lower case letters and numbers.
Enter new password:
(Deadlock)
Funny fact: When I reboot the board, the new user actually has been created. I tried to login with it, but, again, whenever I need to type a password, the console stops to work.
I hope somebody could help me, or just say that I'm not the only one that are not capable to create a new user on Linux(so shame...).
Labels (2)
Tags (2)
AlanZhang
Contributor V
Following is my test snapshot based on i.MX53 QSD running ltib 110901, pls check! I did not encounter your deadlock. No problem.
arm-none-linux-gnueabi-gcc (4.4.4_09.06.2010) 4.4.4
root filesystem built on Thu, 20 Sep 2012 14:08:28 +0800
Freescale Semiconductor, Inc.
freescale login: root
login[2192]: root login on 'ttymxc0'
New password:
Bad password: too weak
Retype password:
Password for horus changed by root
root@freescale ~$ su horus
horus@freescale ~$
Re-login log message:
Booted NFS, not relocating: /tmp /var
mount: mounting usbfs on /proc/bus/usb failed: No such file or directory
starting pid 2187, tty '': '/sbin/getty -L ttymxc0 115200 vt100'
freescale login: horus
Password:
horus@freescale ~$
Alan Zhang
AlanZhang
Contributor V
New password:
Retype password:
horus@freescale ~$
Password:
horus@freescale ~$
Alan Zhang
ricardo_ioct
Hello Alan Zhang,
Sorry by take a long time to reply, but I figure out what was happening. As I can notice, you was using ttymxc0 to do the login, and I know that is the default. But, on my application, I had to change the login to ttymxc1. Even after I change it on uBoot env, and on LTIB's inittab line argument too, when I try to do passwd or adduser, the application expects the password input on ttymxc0, thus causing the deadlock. I could confirm it putting back the login on ttymxc0. Apparently, I'll need to recompile u-Boot, using ttymxc1 as primary login serial.
Thank you for the reply.
Ricardo.
