Adding SPL to U-Boot config causes build error OOM 137
716 次查看
Gurban
I am creating Linux image for Colibri iMX8QXP SoM module and I wanted to include Falcon Mode for U-Boot. I used Fast Boot for i.MX 8QXP Using U-Boot Falcon Mode  as a reference.
Build configuration I'm using:
Build Configuration:
BB_VERSION           = "2.8.1"
BUILD_SYS            = "x86_64-linux"
NATIVELSBSTRING      = "universal"
TARGET_SYS           = "aarch64-tdx-linux"
MACHINE              = "colibri-imx8x"
DISTRO               = "tdx-xwayland"
DISTRO_VERSION       = "7.6.0-devel-20260423064324+build.0"
TUNE_FEATURES        = "aarch64 armv8a crypto"
TARGET_FPU           = ""
meta                 = "scarthgap:41597b5260fb5ca811d0fb4ae7e65246d61734eb"
meta-yocto-bsp
meta-poky            = "scarthgap:c7c38663a1cafb1fa8593c0b246811e51d3bbe20"
meta-freescale       = "scarthgap:902dde8c5bd29bb507ac8d37772565a6c9ab77cd"
meta-freescale-3rdparty = "scarthgap:70c83e96c7f75e73245cb77f1b0cada9ed4bbc6d"
meta-oe
meta-python
meta-multimedia
meta-networking
meta-filesystems     = "scarthgap:06f846a325fde423bb0a6d49d771d8c1e144d7eb"
meta-toradex-bsp-common = "scarthgap-7.x.y:159b1b42c4c527a39ac0b41faad408d74299e2d6"
meta-toradex-nxp     = "scarthgap-7.x.y:1c108e5846f71a543e97327274afb53d136c16ae"
meta-toradex-distro  = "scarthgap-7.x.y:c55b5b491427ac1f129dcd905bb9956feecd31a4"
meta-qt6             = "6.7.3:9e6928ef66bced84ec3eecfdac00a3540b0a6479"
meta-splash
workspace
meta-imx-fastboot    = "lf-6.6.52-2.2.0:5b3363688aac96e5e1e73ad73bcf9f074cfb1160"
After adding meta-imx-fastboot layer my build failed because it couldn't find SPL related bin file, so I added SPL support using menuconfig for virtual/bootloader.
It caused my build to crash with error 137 and without any additional information in logs. I have 64Gb RAM on my machine and for the experiment I added 256Gb more of swap space, that didn't help.
Information in the internet didn't help much either, all I've found was reducing parallel make variable and adding 8Gb swap, which didn't resolve my problem.
What can be a solution to this?
210 次查看
elena_popa
Hi @Gurban
Please use as reference our i.MX 8QXP MEK configuration file, which enables SPL by default. Since you are using the Toradex BSP, I recommend reaching out to Toradex for guidance on enabling SPL in their software.
Alternatively, you may also choose to keep U‑Boot proper and focus on optimizing it along with the Linux kernel. I suggest reviewing the article i.MX 6ULZ: How to boot Linux in under 2s, which provides some recommendations for reducing both U‑Boot and Linux kernel boot times.
Elena
6 回复数
698 次查看
elena_popa
Hi @Gurban
Please use this layer instead: https://github.com/nxp-imx-support/meta-imx-fastboot/tree/lf-6.6.52-2.2.0
i.MX 8QXP is supported on lf-6.6.36-2.1.0 and lf-6.6.52-2.2.0 branches.
As a general rule for i.MX 8QXP, to generate the SPL binary, the following variables must be set:
UBOOT_MAKE_TARGET:mx8qxp-generic-bsp = ""
SPL_BINARY:mx8qxp-generic-bsp = "spl/u-boot-spl.bin"
IMXBOOT_TARGETS_SD:mx8qxp-generic-bsp = "flash_spl"
These are already defined in the conf/layer.confhttps://github.com/nxp-imx-support/meta-imx-fastboot/blob/lf-6.6.52-2.2.0/conf/layer.conf#L21C1-L25C...
Could you share the error log as well?
Please, let me know if you have further questions.
Elena
684 次查看
Gurban
Hello @elena_popa,
I'm already using this branch you've mentioned, it matches the version in my build configuration in the last row.
I've checked variables too:
bitbake -e core-image-minimal | grep "^SPL_BINARY"
SPL_BINARY="spl/u-boot-spl.bin"
SPL_BINARY:mx8qxp-generic-bsp="spl/u-boot-spl.bin"
Error log if I try to build core-image-minimal without modifying virtual/bootloader and adding SPL support:
WARNING: /home/yocto/bitbake-builds/poky-master/layers/meta-toradex-nxp/recipes-bsp/u-boot/u-boot-toradex_2024.04.bb:do_compile is tainted from a forced run | ETA: 0:00:00
Sstate summary: Wanted 930 Local 905 Mirrors 0 Missed 25 Current 2440 (97% match, 99% complete)################################################################################## | ETA: 0:00:00
Initialising tasks: 100% |#########################################################################################################################################################################| Time: 0:00:02
NOTE: Executing Tasks
ERROR: u-boot-toradex-2024.04-r0 do_install: ExecutionError('/home/yocto/bitbake-builds/poky-master/build/tmp/work/colibri_imx8x-tdx-linux/u-boot-toradex/2024.04/temp/run.do_install.43334', 1, None, None)
ERROR: Logfile of failure stored in: /home/yocto/bitbake-builds/poky-master/build/tmp/work/colibri_imx8x-tdx-linux/u-boot-toradex/2024.04/temp/log.do_install.43334
Log data follows:
| DEBUG: Executing python function extend_recipe_sysroot
| NOTE: Direct dependencies are ['/home/yocto/bitbake-builds/poky-master/layers/openembedded-core/meta/recipes-core/glibc/glibc_2.39.bb:do_populate_sysroot', '/home/yocto/bitbake-builds/poky-master/layers/openembedded-core/meta/recipes-devtools/gcc/gcc-cross_13.4.bb:do_populate_sysroot', '/home/yocto/bitbake-builds/poky-master/layers/openembedded-core/meta/recipes-devtools/gcc/gcc-runtime_13.4.bb:do_populate_sysroot', '/home/yocto/bitbake-builds/poky-master/layers/openembedded-core/meta/recipes-devtools/quilt/quilt-native_0.67.bb:do_populate_sysroot', '/home/yocto/bitbake-builds/poky-master/layers/openembedded-core/meta/recipes-kernel/kern-tools/kern-tools-native_git.bb:do_populate_sysroot', 'virtual:native:/home/yocto/bitbake-builds/poky-master/layers/openembedded-core/meta/recipes-connectivity/openssl/openssl_3.5.5.bb:do_populate_sysroot', 'virtual:native:/home/yocto/bitbake-builds/poky-master/layers/openembedded-core/meta/recipes-devtools/bison/bison_3.8.2.bb:do_populate_sysroot', 'virtual:native:/home/yocto/bitbake-builds/poky-master/layers/openembedded-core/meta/recipes-devtools/flex/flex_2.6.4.bb:do_populate_sysroot', 'virtual:native:/home/yocto/bitbake-builds/poky-master/layers/openembedded-core/meta/recipes-devtools/patch/patch_2.7.6.bb:do_populate_sysroot', 'virtual:native:/home/yocto/bitbake-builds/poky-master/layers/openembedded-core/meta/recipes-devtools/pseudo/pseudo_git.bb:do_populate_sysroot', 'virtual:native:/home/yocto/bitbake-builds/poky-master/layers/openembedded-core/meta/recipes-devtools/python/python3-setuptools_69.1.1.bb:do_populate_sysroot', 'virtual:native:/home/yocto/bitbake-builds/poky-master/layers/openembedded-core/meta/recipes-devtools/python/python3_3.12.12.bb:do_populate_sysroot', 'virtual:native:/home/yocto/bitbake-builds/poky-master/layers/openembedded-core/meta/recipes-devtools/swig/swig_4.2.1.bb:do_populate_sysroot', 'virtual:native:/home/yocto/bitbake-builds/poky-master/layers/openembedded-core/meta/recipes-extended/bc/bc_1.07.1.bb:do_populate_sysroot', 'virtual:native:/home/yocto/bitbake-builds/poky-master/layers/openembedded-core/meta/recipes-kernel/dtc/dtc_1.7.0.bb:do_populate_sysroot']
| NOTE: Installed into sysroot: []
| NOTE: Skipping as already exists in sysroot: ['gettext-minimal-native', 'glibc', 'binutils-cross-aarch64', 'cmake-native', 'gcc-cross-aarch64', 'gcc-runtime', 'libgcc', 'libtool-native', 'm4-native', 'quilt-native', 'texinfo-dummy-native', 'kern-tools-native', 'linux-libc-headers', 'openssl-native', 'expat-native', 'ncurses-native', 'readline-native', 'util-linux-libuuid-native', 'zlib-native', 'bison-native', 'flex-native', 'git-native', 'gnu-config-native', 'libedit-native', 'make-native', 'patch-native', 'perl-native', 'pseudo-native', 'python3-build-native', 'python3-flit-core-native', 'python3-installer-native', 'python3-packaging-native', 'python3-pyproject-hooks-native', 'python3-setuptools-native', 'python3-wheel-native', 'python3-native', 'swig-native', 'bc-native', 'bzip2-native', 'libnsl2-native', 'libtirpc-native', 'unzip-native', 'xz-native', 'zstd-native', 'dtc-native', 'attr-native', 'ca-certificates-native', 'curl-native', 'gdbm-native', 'gmp-native', 'libffi-native', 'libmpc-native', 'libpcre2-native', 'mpfr-native', 'sqlite3-native']
| DEBUG: Python function extend_recipe_sysroot finished
| DEBUG: Executing shell function do_install
| install: cannot stat '/home/yocto/bitbake-builds/poky-master/build/tmp/work/colibri_imx8x-tdx-linux/u-boot-toradex/2024.04/build/colibri-imx8x_defconfig/spl/u-boot-spl.bin': No such file or directory
| WARNING: exit code 1 from a shell command.
ERROR: Task (/home/yocto/bitbake-builds/poky-master/layers/meta-toradex-nxp/recipes-bsp/u-boot/u-boot-toradex_2024.04.bb:do_install) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3704 tasks of which 3699 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
NOTE: Writing buildhistory took: 2 seconds
Summary: 1 task failed:
log: /home/yocto/bitbake-builds/poky-master/build/tmp/work/colibri_imx8x-tdx-linux/u-boot-toradex/2024.04/temp/log.do_install.43334
Summary: There were 2 WARNING messages.
Summary: There was 1 ERROR message, returning a non-zero exit code.
After enabling SPL support in virtual/bootloader the build is stuck in do_compile part and finishes with error 137
Sstate summary: Wanted 929 Local 904 Mirrors 0 Missed 25 Current 2441 (97% match, 99% complete)################################################################################## | ETA: 0:00:00
Initialising tasks: 100% |#########################################################################################################################################################################| Time: 0:00:01
ERROR: Task (/home/yocto/bitbake-builds/poky-master/layers/meta-toradex-nxp/recipes-bsp/u-boot/u-boot-toradex_2024.04.bb:do_compile) failed with exit code '137'
NOTE: Tasks Summary: Attempted 2992 tasks of which 2991 didn't need to be rerun and 1 failed.
Tell me if I need to provide more information.
Thank you in advance,
Arkadij
657 次查看
elena_popa
Hi @Gurban
For the 137 code error, could you please attach the U-Boot compile log file? You should find it in tmp/work/colibri_imx8x-tdx-linux/u-boot-toradex/2024.04/temp/log.do_compile
597 次查看
Gurban
Hello @elena_popa ,
Attached the last log file
504 次查看
Gurban
I've checked again and turns out log.do_compile file is exceeding 50Gb, but its all are repeating lines:
Maximum size in memory allocated to the SPL BSS (SPL_BSS_MAX_SIZE) [] (NEW)
Error in reading or end of file.
211 次查看
elena_popa
Hi @Gurban
Elena
%3CLINGO-SUB%20id%3D%22lingo-sub-2355056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20U-Boot%20%E9%85%8D%E7%BD%AE%E4%B8%AD%E6%B7%BB%E5%8A%A0%20SPL%20%E4%BC%9A%E5%AF%BC%E8%87%B4%E7%BC%96%E8%AF%91%E9%94%99%E8%AF%AF%20OOM%20137%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%B8%BA%20Colibri%20imx8QXP%20SoM%20%E6%A8%A1%E5%9D%97%E5%88%9B%E5%BB%BA%20Linux%20%E9%95%9C%E5%83%8F%EF%BC%8C%E6%88%91%E6%83%B3%E4%B8%BA%20U-Boot%20%E5%8A%A0%E5%85%A5%E7%8C%8E%E9%B9%B0%E6%A8%A1%E5%BC%8F%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FFast-Boot-for-i-MX-8QXP-Using-U-Boot-Falcon-Mode%2Fm-p%2F1958752%23U1958752%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-tkb-thread%20lia-fa-icon%20lia-fa-tkb%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3Ei.MX%208QXP%20%E7%9A%84%E5%BF%AB%E9%80%9F%E5%90%AF%E5%8A%A8%E4%BD%BF%E7%94%A8%20U-Boot%20Falcon%3C%2FA%3E%20%E6%A8%A1%E5%BC%8F%E4%BD%9C%E4%B8%BA%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E7%89%88%E6%9C%AC%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EBuild%20Configuration%3A%0ABB_VERSION%20%20%20%20%20%20%20%20%20%20%20%3D%20%222.8.1%22%0ABUILD_SYS%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22x86_64-linux%22%0ANATIVELSBSTRING%20%20%20%20%20%20%3D%20%22universal%22%0ATARGET_SYS%20%20%20%20%20%20%20%20%20%20%20%3D%20%22aarch64-tdx-linux%22%0AMACHINE%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22colibri-imx8x%22%0ADISTRO%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22tdx-xwayland%22%0ADISTRO_VERSION%20%20%20%20%20%20%20%3D%20%227.6.0-devel-20260423064324%2Bbuild.0%22%0ATUNE_FEATURES%20%20%20%20%20%20%20%20%3D%20%22aarch64%20armv8a%20crypto%22%0ATARGET_FPU%20%20%20%20%20%20%20%20%20%20%20%3D%20%22%22%0Ameta%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22scarthgap%3A41597b5260fb5ca811d0fb4ae7e65246d61734eb%22%0Ameta-yocto-bsp%20%20%20%20%20%20%20%0Ameta-poky%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22scarthgap%3Ac7c38663a1cafb1fa8593c0b246811e51d3bbe20%22%0Ameta-freescale%20%20%20%20%20%20%20%3D%20%22scarthgap%3A902dde8c5bd29bb507ac8d37772565a6c9ab77cd%22%0Ameta-freescale-3rdparty%20%3D%20%22scarthgap%3A70c83e96c7f75e73245cb77f1b0cada9ed4bbc6d%22%0Ameta-oe%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Ameta-python%20%20%20%20%20%20%20%20%20%20%0Ameta-multimedia%20%20%20%20%20%20%0Ameta-networking%20%20%20%20%20%20%0Ameta-filesystems%20%20%20%20%20%3D%20%22scarthgap%3A06f846a325fde423bb0a6d49d771d8c1e144d7eb%22%0Ameta-toradex-bsp-common%20%3D%20%22scarthgap-7.x.y%3A159b1b42c4c527a39ac0b41faad408d74299e2d6%22%0Ameta-toradex-nxp%20%20%20%20%20%3D%20%22scarthgap-7.x.y%3A1c108e5846f71a543e97327274afb53d136c16ae%22%0Ameta-toradex-distro%20%20%3D%20%22scarthgap-7.x.y%3Ac55b5b491427ac1f129dcd905bb9956feecd31a4%22%0Ameta-qt6%20%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%226.7.3%3A9e6928ef66bced84ec3eecfdac00a3540b0a6479%22%0Ameta-splash%20%20%20%20%20%20%20%20%20%20%0Aworkspace%20%20%20%20%20%20%20%20%20%20%20%20%0Ameta-imx-fastboot%20%20%20%20%3D%20%22lf-6.6.52-2.2.0%3A5b3363688aac96e5e1e73ad73bcf9f074cfb1160%22%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E6%B7%BB%E5%8A%A0%E4%BA%86%20meta-imx-fastboot%20%E5%B1%82%E5%90%8E%EF%BC%8C%E6%88%91%E7%9A%84%E7%BC%96%E8%AF%91%E5%A4%B1%E8%B4%A5%E4%BA%86%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E6%89%BE%E4%B8%8D%E5%88%B0%E4%B8%8E%20SPL%20%E7%9B%B8%E5%85%B3%E7%9A%84%E5%9E%83%E5%9C%BE%E7%AE%B1%E6%96%87%E4%BB%B6%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%2F%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E7%9A%84%20menuconfig%20%E6%B7%BB%E5%8A%A0%E4%BA%86%20SPL%20%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E%E5%AE%83%E5%AF%BC%E8%87%B4%E6%88%91%E7%9A%84%E7%89%88%E6%9C%AC%E5%B4%A9%E6%BA%83%EF%BC%8C%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%20137%EF%BC%8C%E6%97%A5%E5%BF%97%E4%B8%AD%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E4%BF%A1%E6%81%AF%E3%80%82%E6%88%91%E7%9A%84%E6%9C%BA%E5%99%A8%E6%9C%89%2064GB%20%E5%86%85%E5%AD%98%EF%BC%8C%E4%B8%BA%E4%BA%86%E8%BF%9B%E8%A1%8C%E5%AE%9E%E9%AA%8C%EF%BC%8C%E6%88%91%E5%A2%9E%E5%8A%A0%E4%BA%86%20256GB%20%E7%9A%84%E4%BA%A4%E6%8D%A2%E7%A9%BA%E9%97%B4%EF%BC%8C%E4%BD%86%E5%B9%B6%E6%B2%A1%E6%9C%89%E4%BB%80%E4%B9%88%E7%94%A8%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BA%92%E8%81%94%E7%BD%91%E4%B8%8A%E7%9A%84%E4%BF%A1%E6%81%AF%E4%B9%9F%E5%B8%AE%E4%B8%8D%E4%B8%8A%E4%BB%80%E4%B9%88%E5%BF%99%EF%BC%8C%E6%88%91%E5%8F%AA%E6%89%BE%E5%88%B0%E4%BA%86%E5%87%8F%E5%B0%91%E5%B9%B6%E8%A1%8C%20make%20%E5%8F%98%E9%87%8F%E5%92%8C%E5%A2%9E%E5%8A%A0%208GB%20swap%20%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%8C%E4%BD%86%E8%BF%99%E5%B9%B6%E6%B2%A1%E6%9C%89%E8%A7%A3%E5%86%B3%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9C%89%E4%BB%80%E4%B9%88%E5%8A%9E%E6%B3%95%E5%8F%AF%E4%BB%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2355056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Adding%20SPL%20to%20U-Boot%20config%20causes%20build%20error%20OOM%20137%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203745%22%20target%3D%22_blank%22%3E%40elena_popa%3C%2FA%3E%2C%3CBR%20%2F%3E%E9%99%84%E4%B8%8A%E6%9C%80%E5%90%8E%E4%B8%80%E4%B8%AA%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355208%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Adding%20SPL%20to%20U-Boot%20config%20causes%20build%20error%20OOM%20137%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355208%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261986%22%20target%3D%22_blank%22%3E%EF%BC%8C%40%E5%8F%A4%E5%B0%94%E7%8F%AD%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%20137%20%E4%BB%A3%E7%A0%81%E9%94%99%E8%AF%AF%EF%BC%8C%E8%83%BD%E5%90%A6%E9%99%84%E4%B8%8A%20U-Boot%20%E7%BC%96%E8%AF%91%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%EF%BC%9F%E4%BD%A0%E5%BA%94%E8%AF%A5%E5%9C%A8%20tmp%2Fwork%2Fcolibri_imx8x-tdx-linux%2Fu-boot-tradex%2F2024.04%2Ftemp%2Flog.do_compile%20%E4%B8%AD%E6%89%BE%E5%88%B0%E5%AE%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Adding%20SPL%20to%20U-Boot%20config%20causes%20build%20error%20OOM%20137%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203745%22%20target%3D%22_blank%22%3E%40elena_popa%3C%2FA%3E%EF%BC%8C%3CBR%20%2F%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%9C%A8%E4%BD%BF%E7%94%A8%E4%BD%A0%E6%8F%90%E5%88%B0%E7%9A%84%E8%BF%99%E4%B8%AA%E5%88%86%E6%94%AF%E4%BA%86%EF%BC%8C%E5%AE%83%E4%B8%8E%E6%88%91%E6%9C%80%E5%90%8E%E4%B8%80%E8%A1%8C%E6%9E%84%E5%BB%BA%E9%85%8D%E7%BD%AE%E4%B8%AD%E7%9A%84%E7%89%88%E6%9C%AC%E7%9B%B8%E5%8C%B9%E9%85%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%9F%E6%A3%80%E6%9F%A5%E8%BF%87%E5%8F%98%E9%87%8F%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ebitbake%20-e%20core-image-minimal%20%7C%20grep%20%22%5ESPL_BINARY%22%0ASPL_BINARY%3D%22spl%2Fu-boot-spl.bin%22%0ASPL_BINARY%3Amx8qxp-generic-bsp%3D%22spl%2Fu-boot-spl.bin%22%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%E4%B8%8D%E4%BF%AE%E6%94%B9%E8%99%9A%E6%8B%9F%2F%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%92%8C%E6%B7%BB%E5%8A%A0%20SPL%20%E6%94%AF%E6%8C%81%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E6%9E%84%E5%BB%BA%20core-image-minimal%EF%BC%8C%E5%88%99%E4%BC%9A%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%E6%97%A5%E5%BF%97%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EWARNING%3A%20%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fmeta-toradex-nxp%2Frecipes-bsp%2Fu-boot%2Fu-boot-toradex_2024.04.bb%3Ado_compile%20is%20tainted%20from%20a%20forced%20run%20%7C%20ETA%3A%200%3A00%3A00%0ASstate%20summary%3A%20Wanted%20930%20Local%20905%20Mirrors%200%20Missed%2025%20Current%202440%20(97%25%20match%2C%2099%25%20complete)%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%7C%20ETA%3A%200%3A00%3A00%0AInitialising%20tasks%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A02%0ANOTE%3A%20Executing%20Tasks%0AERROR%3A%20u-boot-toradex-2024.04-r0%20do_install%3A%20ExecutionError('%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Fbuild%2Ftmp%2Fwork%2Fcolibri_imx8x-tdx-linux%2Fu-boot-toradex%2F2024.04%2Ftemp%2Frun.do_install.43334'%2C%201%2C%20None%2C%20None)%0AERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Fbuild%2Ftmp%2Fwork%2Fcolibri_imx8x-tdx-linux%2Fu-boot-toradex%2F2024.04%2Ftemp%2Flog.do_install.43334%0ALog%20data%20follows%3A%0A%7C%20DEBUG%3A%20Executing%20python%20function%20extend_recipe_sysroot%0A%7C%20NOTE%3A%20Direct%20dependencies%20are%20%5B'%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fopenembedded-core%2Fmeta%2Frecipes-core%2Fglibc%2Fglibc_2.39.bb%3Ado_populate_sysroot'%2C%20'%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fopenembedded-core%2Fmeta%2Frecipes-devtools%2Fgcc%2Fgcc-cross_13.4.bb%3Ado_populate_sysroot'%2C%20'%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fopenembedded-core%2Fmeta%2Frecipes-devtools%2Fgcc%2Fgcc-runtime_13.4.bb%3Ado_populate_sysroot'%2C%20'%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fopenembedded-core%2Fmeta%2Frecipes-devtools%2Fquilt%2Fquilt-native_0.67.bb%3Ado_populate_sysroot'%2C%20'%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fopenembedded-core%2Fmeta%2Frecipes-kernel%2Fkern-tools%2Fkern-tools-native_git.bb%3Ado_populate_sysroot'%2C%20'virtual%3Anative%3A%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fopenembedded-core%2Fmeta%2Frecipes-connectivity%2Fopenssl%2Fopenssl_3.5.5.bb%3Ado_populate_sysroot'%2C%20'virtual%3Anative%3A%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fopenembedded-core%2Fmeta%2Frecipes-devtools%2Fbison%2Fbison_3.8.2.bb%3Ado_populate_sysroot'%2C%20'virtual%3Anative%3A%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fopenembedded-core%2Fmeta%2Frecipes-devtools%2Fflex%2Fflex_2.6.4.bb%3Ado_populate_sysroot'%2C%20'virtual%3Anative%3A%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fopenembedded-core%2Fmeta%2Frecipes-devtools%2Fpatch%2Fpatch_2.7.6.bb%3Ado_populate_sysroot'%2C%20'virtual%3Anative%3A%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fopenembedded-core%2Fmeta%2Frecipes-devtools%2Fpseudo%2Fpseudo_git.bb%3Ado_populate_sysroot'%2C%20'virtual%3Anative%3A%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fopenembedded-core%2Fmeta%2Frecipes-devtools%2Fpython%2Fpython3-setuptools_69.1.1.bb%3Ado_populate_sysroot'%2C%20'virtual%3Anative%3A%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fopenembedded-core%2Fmeta%2Frecipes-devtools%2Fpython%2Fpython3_3.12.12.bb%3Ado_populate_sysroot'%2C%20'virtual%3Anative%3A%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fopenembedded-core%2Fmeta%2Frecipes-devtools%2Fswig%2Fswig_4.2.1.bb%3Ado_populate_sysroot'%2C%20'virtual%3Anative%3A%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fopenembedded-core%2Fmeta%2Frecipes-extended%2Fbc%2Fbc_1.07.1.bb%3Ado_populate_sysroot'%2C%20'virtual%3Anative%3A%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fopenembedded-core%2Fmeta%2Frecipes-kernel%2Fdtc%2Fdtc_1.7.0.bb%3Ado_populate_sysroot'%5D%0A%7C%20NOTE%3A%20Installed%20into%20sysroot%3A%20%5B%5D%0A%7C%20NOTE%3A%20Skipping%20as%20already%20exists%20in%20sysroot%3A%20%5B'gettext-minimal-native'%2C%20'glibc'%2C%20'binutils-cross-aarch64'%2C%20'cmake-native'%2C%20'gcc-cross-aarch64'%2C%20'gcc-runtime'%2C%20'libgcc'%2C%20'libtool-native'%2C%20'm4-native'%2C%20'quilt-native'%2C%20'texinfo-dummy-native'%2C%20'kern-tools-native'%2C%20'linux-libc-headers'%2C%20'openssl-native'%2C%20'expat-native'%2C%20'ncurses-native'%2C%20'readline-native'%2C%20'util-linux-libuuid-native'%2C%20'zlib-native'%2C%20'bison-native'%2C%20'flex-native'%2C%20'git-native'%2C%20'gnu-config-native'%2C%20'libedit-native'%2C%20'make-native'%2C%20'patch-native'%2C%20'perl-native'%2C%20'pseudo-native'%2C%20'python3-build-native'%2C%20'python3-flit-core-native'%2C%20'python3-installer-native'%2C%20'python3-packaging-native'%2C%20'python3-pyproject-hooks-native'%2C%20'python3-setuptools-native'%2C%20'python3-wheel-native'%2C%20'python3-native'%2C%20'swig-native'%2C%20'bc-native'%2C%20'bzip2-native'%2C%20'libnsl2-native'%2C%20'libtirpc-native'%2C%20'unzip-native'%2C%20'xz-native'%2C%20'zstd-native'%2C%20'dtc-native'%2C%20'attr-native'%2C%20'ca-certificates-native'%2C%20'curl-native'%2C%20'gdbm-native'%2C%20'gmp-native'%2C%20'libffi-native'%2C%20'libmpc-native'%2C%20'libpcre2-native'%2C%20'mpfr-native'%2C%20'sqlite3-native'%5D%0A%7C%20DEBUG%3A%20Python%20function%20extend_recipe_sysroot%20finished%0A%7C%20DEBUG%3A%20Executing%20shell%20function%20do_install%0A%7C%20install%3A%20cannot%20stat%20'%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Fbuild%2Ftmp%2Fwork%2Fcolibri_imx8x-tdx-linux%2Fu-boot-toradex%2F2024.04%2Fbuild%2Fcolibri-imx8x_defconfig%2Fspl%2Fu-boot-spl.bin'%3A%20No%20such%20file%20or%20directory%0A%7C%20WARNING%3A%20exit%20code%201%20from%20a%20shell%20command.%0AERROR%3A%20Task%20(%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fmeta-toradex-nxp%2Frecipes-bsp%2Fu-boot%2Fu-boot-toradex_2024.04.bb%3Ado_install)%20failed%20with%20exit%20code%20'1'%0ANOTE%3A%20Tasks%20Summary%3A%20Attempted%203704%20tasks%20of%20which%203699%20didn't%20need%20to%20be%20rerun%20and%201%20failed.%0ANOTE%3A%20Writing%20buildhistory%0ANOTE%3A%20Writing%20buildhistory%20took%3A%202%20seconds%0A%0ASummary%3A%201%20task%20failed%3A%0A%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fmeta-toradex-nxp%2Frecipes-bsp%2Fu-boot%2Fu-boot-toradex_2024.04.bb%3Ado_install%0Alog%3A%20%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Fbuild%2Ftmp%2Fwork%2Fcolibri_imx8x-tdx-linux%2Fu-boot-toradex%2F2024.04%2Ftemp%2Flog.do_install.43334%0ASummary%3A%20There%20were%202%20WARNING%20messages.%0ASummary%3A%20There%20was%201%20ERROR%20message%2C%20returning%20a%20non-zero%20exit%20code.%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%E5%9C%A8%E8%99%9A%E6%8B%9F%2F%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%B8%AD%E5%90%AF%E7%94%A8%20SPL%20%E6%94%AF%E6%8C%81%E5%90%8E%EF%BC%8C%E7%89%88%E6%9C%AC%E5%81%9C%E7%95%99%E5%9C%A8%20do_compile%20%E9%83%A8%E5%88%86%E5%B9%B6%E4%BB%A5%E9%94%99%E8%AF%AF%20137%20%E7%BB%93%E6%9D%9F%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EWARNING%3A%20%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fmeta-toradex-nxp%2Frecipes-bsp%2Fu-boot%2Fu-boot-toradex_2024.04.bb%3Ado_compile%20is%20tainted%20from%20a%20forced%20run%20%7C%20ETA%3A%200%3A00%3A00%0ASstate%20summary%3A%20Wanted%20929%20Local%20904%20Mirrors%200%20Missed%2025%20Current%202441%20(97%25%20match%2C%2099%25%20complete)%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%7C%20ETA%3A%200%3A00%3A00%0AInitialising%20tasks%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A01%0ANOTE%3A%20Executing%20Tasks%0AERROR%3A%20Task%20(%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fmeta-toradex-nxp%2Frecipes-bsp%2Fu-boot%2Fu-boot-toradex_2024.04.bb%3Ado_compile)%20failed%20with%20exit%20code%20'137'%0ANOTE%3A%20Tasks%20Summary%3A%20Attempted%202992%20tasks%20of%20which%202991%20didn't%20need%20to%20be%20rerun%20and%201%20failed.%0ANOTE%3A%20Writing%20buildhistory%0ANOTE%3A%20Writing%20buildhistory%20took%3A%202%20seconds%0A%0ASummary%3A%201%20task%20failed%3A%0A%2Fhome%2Fyocto%2Fbitbake-builds%2Fpoky-master%2Flayers%2Fmeta-toradex-nxp%2Frecipes-bsp%2Fu-boot%2Fu-boot-toradex_2024.04.bb%3Ado_compile%0ASummary%3A%20There%20were%202%20WARNING%20messages.%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%88%91%E9%9C%80%E8%A6%81%E6%8F%90%E4%BE%9B%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%AD%A4%E5%85%88%E8%A1%A8%E7%A4%BA%E6%84%9F%E8%B0%A2%E3%80%81%3C%2FP%3E%3CP%3E%E9%98%BF%E5%B0%94%E5%8D%A1%E5%AD%A3%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Adding%20SPL%20to%20U-Boot%20config%20causes%20build%20error%20OOM%20137%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261986%22%20target%3D%22_blank%22%3E%EF%BC%8C%40%E5%8F%A4%E5%B0%94%E7%8F%AD%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E6%94%B9%E7%94%A8%E8%BF%99%E4%B8%AA%E5%B1%82%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-fastboot%2Ftree%2Flf-6.6.52-2.2.0%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-fastboot%2Ftree%2Flf-6.6.52-2.2.0%3C%2FA%3E%3C%2FP%3E%0A%3CP%3Elf-6.6.36-2.1.0%20%E6%94%AF%E6%8C%81%20i.MX%208QXP%E5%92%8C%20lf-6.6.52-2.2.0%20%E5%88%86%E6%94%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%9C%E4%B8%BA%20i.MX%208QXP%20%E7%9A%84%E4%B8%80%E8%88%AC%E8%A7%84%E5%88%99%EF%BC%8C%E8%A6%81%E7%94%9F%E6%88%90%20SPL%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%8C%E5%BF%85%E9%A1%BB%E8%AE%BE%E7%BD%AE%E4%BB%A5%E4%B8%8B%E5%8F%98%E9%87%8F%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Euboot_make_target%3Amx8qxp-generic-bsp%20%3D%20%22%20%22%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%20spl_binary%3A%20mx8qxp-generic-bsp%20%3D%20%22%20spl%2Fu-boot-spl.bin%20%22%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%20imxboot_targets_sd%3A%20mx8qxp-generic-%20bsp%20%3D%20%22%20flash_spl%20%22%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E4%BA%9B%E5%B7%B2%E7%BB%8F%E5%9C%A8%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Econf%2F%E5%B1%82.conf%3C%2FFONT%3E%20%E4%B8%AD%E5%AE%9A%E4%B9%89%E4%BA%86%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-fastboot%2Fblob%2Flf-6.6.52-2.2.0%2Fconf%2Flayer.conf%23L21C1-L22C53%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-fastboot%2Fblob%2Flf-6.6.52-2.2.0%2Fconf%2Flayer.conf%23L21C1-L25C66%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E5%90%8C%E6%97%B6%E6%8F%90%E4%BE%9B%E9%94%99%E8%AF%AF%E6%97%A5%E5%BF%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E5%9F%83%E7%90%B3%E5%A8%9C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2359437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Adding%20SPL%20to%20U-Boot%20config%20causes%20build%20error%20OOM%20137%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2359437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261986%22%20target%3D%22_blank%22%3E%EF%BC%8C%40%E5%8F%A4%E5%B0%94%E7%8F%AD%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E4%BD%BF%E7%94%A8%E6%88%91%E4%BB%AC%E7%9A%84%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fuboot-imx%2Fblob%2Flf-6.6.52-2.2.0%2Fconfigs%2Fimx8qxp_mek_defconfig%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%208QXP%20MEK%20%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E4%BD%9C%E4%B8%BA%E5%8F%82%E8%80%83%EF%BC%8C%E8%AF%A5%E6%96%87%E4%BB%B6%E9%BB%98%E8%AE%A4%3C%2FA%3E%E5%90%AF%E7%94%A8%20SPL%E3%80%82%E6%97%A2%E7%84%B6%E4%BD%A0%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AFToradex%20BSP%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E8%81%94%E7%B3%BBToradex%EF%BC%8C%E8%8E%B7%E5%8F%96%E6%9C%89%E5%85%B3%E5%9C%A8%E4%BB%96%E4%BB%AC%E7%9A%84%E8%BD%AF%E4%BB%B6%E4%B8%AD%E5%90%AF%E7%94%A8%20SPL%20%E7%9A%84%E6%8C%87%E5%AF%BC%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%96%E8%80%85%EF%BC%8C%E4%BD%A0%E4%B9%9F%E5%8F%AF%E4%BB%A5%E9%80%89%E6%8B%A9%E4%BF%9D%E7%95%99%20U-Boot%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%85%B6%E4%B8%8E%20Linux%20%E5%86%85%E6%A0%B8%E4%B8%80%E8%B5%B7%E9%87%8D%E7%82%B9%E4%BC%98%E5%8C%96%E3%80%82%E6%88%91%E5%BB%BA%E8%AE%AE%E9%98%85%E8%AF%BB%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-6ULZ-How-to-boot-Linux-in-under-2s%2Fta-p%2F2196625%22%20target%3D%22_self%22%3E%E4%B8%80%E7%AF%87%E6%96%87%E7%AB%A0%20i.MX%206ULZ%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%202%20%E7%A7%92%E5%86%85%E5%90%AF%E5%8A%A8%20Linux%3C%2FA%3E%EF%BC%8C%E5%AE%83%E4%B8%BA%E7%BC%A9%E7%9F%AD%20U%E2%80%91Boot%20%E5%92%8C%20Linux%20%E5%86%85%E6%A0%B8%E5%90%AF%E5%8A%A8%E6%97%B6%E9%97%B4%E6%8F%90%E4%BE%9B%E4%BA%86%E4%B8%80%E4%BA%9B%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%9F%83%E7%90%B3%E5%A8%9C%3C%2FP%3E%3C%2FLINGO-BODY%3E
