Accessing physical registers in A53 using linux commands
1,413 次查看
subhash_ponnusamy
Hi NXP team,
 I'm using I.MX8MMINI EVK for my project. I need to transfer data from M4 to A53 using message unit.
In A53 I need to access a physical register address (0x30AA0010) to see whether I received data or not.
How can I access this register through linux commands.
How should I transfer data from M4 to A53 through messaging unit (MU).
Subhash
1,406 次查看
joanxie
for communication between A core and M core, pls refer to the chapter 2.8 Remote Processor Messaging of linux reference manual, you also can refer to the link as below:
"https://community.nxp.com/t5/i-MX-Processors/Where-is-the-RPMsg-document-for-IMX8MM/m-p/894428"
