Access u-boot varibale from linux user space
2,543 次查看
kartheek
Processor: IMX8M PLUS
Yocto : 5.15-kirkstone
While booting through SD card able to access fw_printenv/setenv by adding below line in image recipe of yocto build.
IMAGE_INSTALL += " u-boot-fw-utils"
u-boot configuration is as below.
CONFIG_ENV_SIZE=0x80000
CONFIG_ENV_OFFSET=0x380000
CONFIG_ENV_IS_NOWHERE=y
CONFIG_ENV_IS_IN_MMC=y
CONFIG_SYS_MMC_ENV_DEV=1
CONFIG_SYS_MMC_ENV_PART=0
 But when executing those commands on target gives below error.
~# fw_printenv
Configuration file wrong or corrupted
Kindly suggest a procedure to make fw_printenv/setenv work.
Kartheek
6 回复数
2,476 次查看
kartheek
After configuring fw_env.config in etc folder and running saveenv in U-Boot, I can access U-Boot environment variables from Linux user space.
However, we plan to remove the serial debugger later. In that case, we won’t be able to execute saveenv at the U-Boot prompt. Is there a way to automatically save the environment during the boot process?
Kartheek
2,286 次查看
vopal
If you carefully read the u-boot documentation, you'll find that u-boot provides a complete solution. During u-boot compilation, `make u-boot-initial-env` generates default u-boot environment variables. `fw_printenv`/`fw_setenv` can use the `-f` parameter on the first run to access this default u-boot environment variable file. This is also the method used by swupate on its first run.
2,275 次查看
vopal
If I remember correctly, yocto generates a default environment variable file for u-boot by default.
2,266 次查看
vopal
2,426 次查看
Zhiming_Liu
You can define a command in uboot env, then run it in mmcboot(include/configs/<board>.h).
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2263773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BB%8E%20linux%20%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4%E8%AE%BF%E9%97%AE%20u-%E5%90%AF%E5%8A%A8%20%E5%8F%98%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2263773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E5%A4%84%E7%90%86%E5%99%A8%3CSTRONG%3EIMX8M%20PLUS%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EYocto%20%3A%3CSTRONG%3E5.15-kirkstone%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E9%80%9A%E8%BF%87%20SD%20%E5%8D%A1%E5%90%AF%E5%8A%A8%E6%97%B6%EF%BC%8C%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E5%9C%A8%20yocto%20%E7%89%88%E6%9C%AC%E7%9A%84%E5%9B%BE%E5%83%8F%E9%85%8D%E6%96%B9%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BB%A5%E4%B8%8B%E8%A1%8C%E6%9D%A5%E8%AE%BF%E9%97%AE%20fw_printenv%2Fsetenv%E3%80%82%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22%22%3EIMAGE_INSTALL%20%2B%3D%20%22%20u-boot-fw-utils%22%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3Eu-boot%20%E9%85%8D%E7%BD%AE%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3ECONFIG_ENV_SIZE%3D0x80000%0ACONFIG_ENV_OFFSET%3D0x380000%0ACONFIG_ENV_IS_NOWHERE%3Dy%0ACONFIG_ENV_IS_IN_MMC%3Dy%0ACONFIG_SYS_MMC_ENV_DEV%3D1%0ACONFIG_SYS_MMC_ENV_PART%3D0%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86%E5%9C%A8%E7%9B%AE%E6%A0%87%E6%9C%BA%E4%B8%8A%E6%89%A7%E8%A1%8C%E8%BF%99%E4%BA%9B%E5%91%BD%E4%BB%A4%E6%97%B6%EF%BC%8C%E5%8D%B4%E5%87%BA%E7%8E%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E~%23%20fw_printenv%0AConfiguration%20file%20wrong%20or%20corrupted%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%E8%AF%B7%E6%8F%90%E4%BE%9B%E4%BD%BF%20fw_printenv%2Fsetenv%20%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E7%9A%84%E7%A8%8B%E5%BA%8F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3EKartheek%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2264347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Access%20u-boot%20varibale%20from%20linux%20user%20space%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E6%AD%A4%E5%A4%84%E7%9A%84%E8%A1%A5%E4%B8%81%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-swupdate-imx%2Fblob%2Fkirkstone_5.15.71_2.2.0%2Frecipes-bsp%2Fu-boot%2Ffiles%2F0001-enable-env_redunand-bootcount-limit-LF_v5.15.71-2.2.0.patch%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-swupdate-imx%2Fblob%2Fkirkstone_5.15.71_2.2.0%2Frecipes-bsp%2Fu-boot%2Ffiles%2F0001-enable-env_redunand-bootcount-limit-LF_v5.15.71-2.2.0.patch%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-swupdate-imx%2Fblob%2Fkirkstone_5.15.71_2.2.0%2Frecipes-bsp%2Fu-boot%2Fu-boot-imx_%2525.bbappend%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-swupdate-imx%2Fblob%2Fkirkstone_5.15.71_2.2.0%2Frecipes-bsp%2Fu-boot%2Fu-boot-imx_%2525.bbappend%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2265712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Access%20u-boot%20varibale%20from%20linux%20user%20space%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CP%3E%E5%9C%A8%20etc%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E9%85%8D%E7%BD%AE%20fw_env.config%20%E5%B9%B6%E5%9C%A8%20U-Boot%20%E4%B8%AD%E8%BF%90%E8%A1%8C%20saveenv%20%E4%B9%8B%E5%90%8E%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BB%8E%20Linux%20%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4%E8%AE%BF%E9%97%AE%20U-Boot%20%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%88%91%E4%BB%AC%E8%AE%A1%E5%88%92%E7%A8%8D%E5%90%8E%E7%A7%BB%E9%99%A4%E4%B8%B2%E8%A1%8C%E8%B0%83%E8%AF%95%E5%99%A8%E3%80%82%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E6%97%A0%E6%B3%95%E5%9C%A8%20U-Boot%20%E6%8F%90%E7%A4%BA%E7%AC%A6%E4%B8%8B%E6%89%A7%E8%A1%8C%20saveenv%E3%80%82%E6%9C%89%E6%B2%A1%E6%9C%89%E5%8A%9E%E6%B3%95%E5%9C%A8%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E4%B8%AD%E8%87%AA%E5%8A%A8%E4%BF%9D%E5%AD%98%E7%8E%AF%E5%A2%83%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3EKartheek%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Access%20u-boot%20varibale%20from%20linux%20user%20space%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%20uboot%20env%20%E4%B8%AD%E5%AE%9A%E4%B9%89%E5%91%BD%E4%BB%A4%EF%BC%8C%E7%84%B6%E5%90%8E%E5%9C%A8%3CSTRONG%3Emmcboot%3C%2FSTRONG%3E(include%2Fconfigs%2F%3CBOARD%3E.h)%20%E4%B8%AD%E8%BF%90%E8%A1%8C%E5%AE%83%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FBOARD%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2267764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Access%20u-boot%20varibale%20from%20linux%20user%20space%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224056%22%20target%3D%22_blank%22%3E%40kartheek%3C%2FA%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%AA%E9%93%BE%E6%8E%A5%E5%BE%88%E6%9C%89%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fu-boot-environment-preset-for-sdcard-mirror%2Fta-p%2F1702549%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fu-boot-environment-preset-for-sdcard-mirror%2Fta-p%2F1702549%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2267750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Access%20u-boot%20varibale%20from%20linux%20user%20space%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E6%B2%A1%E8%AE%B0%E9%94%99%E7%9A%84%E8%AF%9D%EF%BC%8Cyocto%20%E9%BB%98%E8%AE%A4%E4%BC%9A%E4%B8%BA%20u-boot%20%E7%94%9F%E6%88%90%E4%B8%80%E4%B8%AA%E9%BB%98%E8%AE%A4%E7%9A%84%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2267716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Access%20u-boot%20varibale%20from%20linux%20user%20space%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E4%BB%94%E7%BB%86%E9%98%85%E8%AF%BB%20u-boot%20%E6%96%87%E6%A1%A3%EF%BC%8C%E4%BD%A0%E4%BC%9A%E5%8F%91%E7%8E%B0%20u-boot%20%E6%8F%90%E4%BE%9B%E4%BA%86%E5%AE%8C%E6%95%B4%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%E5%9C%A8%20u-boot%20%E7%BC%96%E8%AF%91%E6%9C%9F%E9%97%B4%EF%BC%8C%3CSTRONG%3Emake%20u-boot-initial-env%3C%2FSTRONG%3E%20%E4%BC%9A%E7%94%9F%E6%88%90%E9%BB%98%E8%AE%A4%E7%9A%84%20u-%E5%90%AF%E5%8A%A8%20%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%E3%80%82%60fw_printenv%60%2F%60fw_setenv%60%E5%8F%AF%E4%BB%A5%E5%9C%A8%E9%A6%96%E6%AC%A1%E8%BF%90%E8%A1%8C%E6%97%B6%E4%BD%BF%E7%94%A8%20%60-f%60%20%E5%8F%82%E6%95%B0%E6%9D%A5%E8%AE%BF%E9%97%AE%E8%BF%99%E4%B8%AA%E9%BB%98%E8%AE%A4%E7%9A%84%20u-boot%20%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%E6%96%87%E4%BB%B6%E3%80%82%E8%BF%99%E4%B9%9F%E6%98%AF%20swupate%20%E9%A6%96%E6%AC%A1%E8%BF%90%E8%A1%8C%E6%97%B6%E4%BD%BF%E7%94%A8%E7%9A%84%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
