About imx8mp hdmi clock documentation
ソリューションへジャンプ
3,826件の閲覧回数
Chun1
When I write the hdmi clock of imx8mp, I found that the bit used by Linux does not match the documentation. The bits is called 'hdmi_fdcc_ref' in Linux, and it use the second bit of register HDMI_RTX_CLK_CTL1(0x50). But the bit described in the document is reserved. Is my document not up-to-date? Or is it for some other reason? The document I use is iMX_8M_Plus_RM_RevD.pdf. Thanks.
タグ(1)
3,792件の閲覧回数
joanxie
I just copy the content from IP spec, you just set the same as our bsp does
5 返答(返信)
3,818件の閲覧回数
joanxie
D version is the latest version, could you send the source path you mention 'hdmi_fdcc_ref' in Linux
3,815件の閲覧回数
Chun1
I clone the code from link:https://source.codeaurora.org/external/imx/linux-imx
and  checkout to the branch: imx_5.4.70_2.3.0
the code is in `imx_hdmimix_clk_probe` function of the file `drivers/clk/imx/clk-hdmimix.c`.
 clks[IMX8MP_CLK_HDMIMIX_FDCC_REF_CLK]      = imx_dev_clk_gate(dev, "hdmi_fdcc_ref",    "hdmi_fdcc_tst", base + 0x50, 2);
    clks[IMX8MP_CLK_HDMIMIX_HRV_MWR_APB_CLK]   = imx_dev_clk_gate(dev, "hrv_mwr_apb",       "hdmi_glb_apb", base + 0x50, 3);
3,807件の閲覧回数
joanxie
thanks for your information, I checked the hdmi IP,
FDCC_REF_CLK_EN: FDCC_REF_CLK_EN control
clock enable for the ref_clk input of FDCC
you can refer to this
3,802件の閲覧回数
Chun1
You mean this is the description of bit2 of HDMI_RTX_CLK_CTL1(0x50), not the reserved value?
3,793件の閲覧回数
joanxie
