Hello,Community
About DDR_PHY_ZQ_CON0 register in i.MX 7 Dual Applications Processor Reference Manual
How many ohms is Receiver termination for Initial Value = 3'h0 in the ZQ_MODE_TERM field?
Best Regards
Goto
Solved! Go to Solution.
module is designed in such way that this value is reserved value,
not used for selection. So behavior may be unpredictable.
What will Receiver termination behave if I don't change this value?
For example, no termination resistor or indefinite ...?
Best Regards
Goto
Why can't I specify the resistance value despite the initial value?
Best Regards
Goto
Hi Goto
this is reserved value not recommended for selection.
