i.MX 8MM-How to configure the device trees when run RPMsg
danielc
Hello sir,
   Customer uses fsl-imx8mm-evk-m4.dtb to run the RPMsg. but the Camera can't work with the m4.dtb.
In the fsl-imx8mm-evk-m4.dts, there is comment mentions that some IPs was disable because maybe used by M4.
   Is there any user guide can help customer to configure the Cortex-A device tree that maybe some peripherials are dedicated for Cortex-M4 or other? Thanks.
Hi Daniel
one can look at examples in SDK_2.5.0_EVK-MIMX8M Mini  Welcome | MCUXpresso SDK Builder
and general documentation
OpenAMP Porting GuideLine · OpenAMP/open-amp Wiki · GitHub
GitHub - NXPmicro/rpmsg-lite: RPMsg implementation for small MCUs
danielc
Hi Igorpadykov,
Thank you for your information,
customer makes their own i.MX8MM SoM board that use same UART1 for Cypress-CYW43455 (WiFI/BT).
the CYW43455 also not work with fsl-imx8mm-evk-m4.dtb. but the UART1 does not be disable in the fsl-imx8mm-evk-m4.dts. Is anything we need to check? Thanks.
Hi Daniel
please check similar issue
imx8m mini uart4
danielc
Hi Igorpadykov,
It seems they are different. the BT uses UART1 not UART4.
BTW,
Is there any IP used when run RPMsg? Thanks.
Hi Daniel
NXP has special service for help with software customizations :
Commercial Support and Engineering Services | NXP
