ASRC on imx 6 ul
ASRC on imx 6 ul
akk1
I am new to imx 6 ul board. I want to use hardware SRC available on the board , kindly tell me how to use it and how to proceed.
Thanks.
Tags (2)
Hi akk
one can try asrc unit test (imx-test 5.2**/*/mxc_asrc_test/):
http://downloads.yoctoproject.org/mirror/sources/imx-test-5.2.tar.gz
check p.231 attached Linux Manual
akk1
I am not able to find p.231 attached manual....
click mouse on red in previous post.
akk1
I make the mxc-asrc folder and run autorun-asrc.sh.
It show following output.
Hi...
Pair A fsl-asrc 2034000.asrc: invalid ioctl cmd!
It generated output audio files but with no content.
Kindly give some tips.
akk1
I have Linux kernel 3.14.38 . i tried to make the provided make file in mxc_asrc_test folder but it says " make: Nothing to be done for `Makefile' "
