AN15075 Patch can't be applied
376件の閲覧回数
oedze
The relativly new user manual AN15075 metions the file 0001-add-AHAB-check-for-imx
remote-proc-process.patch
Which i found in the  AN15075SW.zip.
This patch files applies the following 3 lines:
+#ifdef CONFIG_IMX_REMOTEPROC_AHAB
+#include <linux/firmware/imx/ele_base_msg.h>
+#include <linux/firmware/imx/se_fw_inc.h>
+#endif
to
drivers/remoteproc/imx_rproc.c from linux-imx
but tthe file linux/firmware/imx/se_fw_inc.h doesn't exist (anywhere on the internet)
And the file ele_base_msg is not placed at that location.
I am working on the linux-imx lf-6.18.y branch https://github.com/nxp-imx/linux-imx/tree/lf-6.18.y
I couldn't find it on the 6.6 or 6.12 either.
To what version of linux-imx should this patch be applied?
P.S. If you add the patch and disable
The linux-imx won't build either because some properties stopped existing because some of the code is guarded under a #ifdef but not all.
6 返答(返信)
342件の閲覧回数
yipingwang
  • Apply AN15075SW’s kernel patch to lf-6.6.36-2.1.0 / BSP lf-6.6.36 .
     $ git clone https://github.com/nxp-imx/linux-imx.git
     $ git checkout -b lf-6.6.36-2.1.0 lf-6.6.36-2.1.0
  • Do not expect it to apply cleanly to lf-6.18.y ; it must be forward-ported.
  • If forward-porting, fix both the include paths and the Kconfig guards. Your PS is consistent with a partial guard bug: disabling CONFIG_IMX_REMOTEPROC_AHAB should leave the existing remoteproc path buildable, but the AN patch appears to leave some non-AHAB code dependent on definitions or fields introduced only inside #ifdef CONFIG_IMX_REMOTEPROC_AHAB .
339件の閲覧回数
oedze
Is there any change NXP will update the patch for Yocto Wrynose (with linux 6.18)?
333件の閲覧回数
yipingwang
The patch we implemented at that time was merely a proof of concept, and the software team did not agree to merge it into the upstream repository.
So it's just a reference implementation.
The subsequent porting was not continued.
231件の閲覧回数
oedze
Is modifying the remoteproc code to use the ELE firmware still the recommended approach to enable AHAB on the second core?
217件の閲覧回数
yipingwang
Yes.
360件の閲覧回数
oedze
Did some more digging:
This patch seems to add these files: [PATCH v4 6/7] firmware: imx: add driver for NXP EdgeLock Enclave
But it was reapplied differently in this commit: LF-13910: firmware: imx: add driver for NXP EdgeLock Enclave · nxp-imx/linux-imx@0eff402
%3CLINGO-SUB%20id%3D%22lingo-sub-2410077%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAN15075%20%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E9%81%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410077%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%AF%94%E8%BC%83%E7%9A%84%E6%96%B0%E3%81%97%E3%81%84%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%ABAN15075%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB0001-add-AHAB-check-for-imx%E3%81%AB%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Eremote-proc-process.patch%3CBR%20%2F%3E%3CBR%20%2F%3EAN15075SW.zip%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE3%E8%A1%8C%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%2B%23ifdef%20CONFIG_IMX_REMOTEPROC_AHAB%0A%2B%23include%20%3CLINUX%3E%0A%2B%23include%20%3CLINUX%3E%0A%2B%23endif%3C%2FLINUX%3E%3C%2FLINUX%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%81%AB%20%3C%2FP%3E%3CDIV%3E%3CSPAN%3ELinux-IMX%E3%81%8B%E3%82%89%E3%81%AEdrivers%2Fremoteproc%2Fimx_rproc.c%3CBR%20%2F%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20linux%2Ffirmware%2Fimx%2Fse_fw_inc.h%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%AA%E3%81%84%EF%BC%88%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E4%B8%8A%E3%81%AE%E3%81%A9%E3%81%93%E3%81%AB%E3%82%82%EF%BC%89%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20ele_base_msg%20%E3%81%AF%E3%81%9D%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E3%81%AF%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3ELinux-imx%20lf-6.18.y%E3%81%AE%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Ftree%2Flf-6.18.y%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Ftree%2Flf-6.18.y%3C%2FA%3E%20%E3%82%92%E6%8B%85%E5%BD%93%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E6.6%E3%82%846.12%E3%81%A7%E3%82%82%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AElinux-imx%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3EPS%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%3CDIV%3E%3CDIV%3E%3CSPAN%3ECONFIG_IMX_REMOTEPROC_AHAB%3CBR%20%2F%3E%3C%2FSPAN%3ELinux-imx%E3%82%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%AA%E3%81%9C%E3%81%AA%E3%82%89%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%20%23ifdef%20%E3%81%A7%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%AA%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%9F%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AN15075%20Patch%20can't%20be%20applied%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BD%93%E6%99%82%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%9F%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E5%8D%98%E3%81%AA%E3%82%8B%E6%A6%82%E5%BF%B5%E5%AE%9F%E8%A8%BC%E3%81%AB%E9%81%8E%E3%81%8E%E3%81%9A%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E4%B8%8A%E6%B5%81%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%8D%98%E3%81%AA%E3%82%8B%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AE%E7%A7%BB%E6%A4%8D%E4%BD%9C%E6%A5%AD%E3%81%AF%E7%B6%99%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410343%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AN15075%20Patch%20can't%20be%20applied%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410343%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EYocto%20Wrynose(Linux%206.18%E5%AF%BE%E5%BF%9C)%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AFNXP%E3%81%A7%E4%BD%95%E3%81%8B%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AN15075%20Patch%20can't%20be%20applied%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CUL%3E%0A%3CLI%3E%3CSTRONG%3EAN15075SW%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92lf-6.6.36-2.1.0%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%2F%20BSP%26nbsp%3Blf-6.6.36%26nbsp%3B%E3%80%82%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%24%20git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx.git%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%24%20git%20checkout%20-b%20lf-6.6.36-2.1.0lf-6.6.36-2.1.0%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3Elf-6.18.y%20%E3%81%AB%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E9%81%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E3%81%AF%E6%9C%9F%E5%BE%85%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%89%8D%E6%96%B9%E7%A7%BB%E6%A4%8D%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E5%89%8D%E6%96%B9%E7%A7%BB%E6%A4%8D%E3%82%92%E8%A1%8C%E3%81%86%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%83%91%E3%82%B9%E3%81%A8Kconfig%E3%82%AC%E3%83%BC%E3%83%89%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSTRONG%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEPS%E3%81%AF%E9%83%A8%E5%88%86%E7%9A%84%E3%81%AA%E3%82%AC%E3%83%BC%E3%83%89%E3%83%90%E3%82%B0%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82CONFIG_IMX_REMOTEPROC_AHAB%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%97%A2%E5%AD%98%E3%81%AE%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%B7%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%91%E3%82%B9%E3%81%8C%E6%A7%8B%E7%AF%89%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81AN%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%AF%E3%80%81%23ifdef%20CONFIG_IMX_REMOTEPROC_AHAB%E5%86%85%E3%81%A7%E3%81%AE%E3%81%BF%E5%B0%8E%E5%85%A5%E3%81%95%E3%82%8C%E3%81%9F%E5%AE%9A%E7%BE%A9%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%99%E3%82%8B%E9%9D%9EAHAB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AN15075%20Patch%20can't%20be%20applied%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E8%AA%BF%E3%81%B9%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%3A%3CA%20href%3D%22https%3A%2F%2Flists.infradead.org%2Fpipermail%2Flinux-arm-kernel%2F2023-July%2F848851.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%5BPATCH%20v4%206%2F7%5D%20firmware%3A%20imx%3A%20add%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20for%20NXP%20EdgeLock%20Enclave%3C%2FA%3E%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E3%81%A7%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%A7%E5%86%8D%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fcommit%2F0eff4025384aab9f93e9f8411e18dbcaac79ce54%23diff-1498ef15b028ef9d8008cb848b61521a7fde0c4d234621585c77c6395e4072a5%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ELF-13910%3A%20firmware%3A%20imx%3A%20add%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20for%20NXP%20EdgeLock%20Enclave%20%C2%B7%20nxp-imx%2FLinux%400eff402%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2412011%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AN15075%20Patch%20can't%20be%20applied%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2412011%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%B7%E3%83%BC%E3%82%B8%E3%83%A3%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%A6ELE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%89%E3%82%B3%E3%82%A2%E3%81%A7AHAB%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2412183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AN15075%20Patch%20can't%20be%20applied%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2412183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
