AAOS 15 User Switch Crash on i.MX8QM Multi-Display Setup
744件の閲覧回数
harshi03
Hello Team,
We are running Android Automotive OS 15 (AAOS 15) on the i.MX8QuadMax board with a multi-display setup (Main Display + Passenger Display).
We are observing an issue with the default Car Launcher during user switching:
  • System boots normally and the launcher is displayed on both main and passenger displays.
  • When switching from the current user to a new user or guest user, both the main display and passenger display crash and become unusable.
  • The issue is consistently reproducible after user switching.
We would like to know:
  1. Is there any known issue related to user switching in AAOS 15 on i.MX8QM multi-display systems?
  2. Are there any additional configurations required for passenger display handling during user switch?
  3. What logs or debug information should we collect to further analyze this issue?
Any suggestions or guidance would be appreciated.
Thanks.
4 返答(返信)
695件の閲覧回数
AldoG
Are you using NXP MEK board?
If yes, you are using NXP BSP?
Please note that we do not support Android Automotive we can provide asistance if issues are found on our BSP release.
Best regards/Saludos,
Aldo.
691件の閲覧回数
harshi03
Hi @AldoG,
Thanks for the clarification.
We are using the NXP i.MX8QM MEK board with NXP BSP. Since this issue is related to Android Automotive, could you please let us know the correct support channel or forum where we should raise our AAOS-related questions?
Thank you.
597件の閲覧回数
AldoG
Sorry for not being clear enough, we provide AAOS as is, as a way to evaluate the software in our chips, all support, aside from issues found on the BSP, for this OS goes through our PRO-support.
Could you share your logcat and a way to reproduce on our side so I can dig a bit more on the issue?
Aldo.
543件の閲覧回数
harshi03
Hi @AldoG,
Thank you for the response. I have attached the full logcat,the reproduction steps.and changes we made to bring multi displays.
Reproduction Steps:
  1. Boot AAOS 15 on i.MX8QM with center and passenger displays enabled.
  2. Open User Settings on the passenger display.
  3. Create or switch to a new user/guest user on the passenger display.
  4. During the user switch, com.android.car.carlauncher crashes with:
    android.view.WindowManager$InvalidDisplayException:
    Unable to add window -- the specified display can not be found
  5. From the log, it appears that CarLauncher is trying to resume on a display that is no longer available or has an invalid display mapping after the user switch.
  6. Could you please advise:
    • Whether this is a known issue in AAOS 15 multi-user/multi-display scenarios on i.MX8QM?
    • Which component is responsible for assigning the display during user switching (OccupantZone, CarUserService, TaskDisplayArea, or WindowManager)?
    • Are there any known requirements or patches related to MUMD (Multi-User Multi-Display) support for launcher launching on secondary displays?
    • Is there any recommended debug information we should collect to identify why the display becomes invalid after the user switch?
%3CLINGO-SUB%20id%3D%22lingo-sub-2395730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8QM%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%81%AEAAOS%2015%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AE%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%20Android%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20OS%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E15(AAOS%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%2015)%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%92%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%20i.MX8QuadMax%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%20%E4%B8%8A%E3%81%A7%20%E3%83%9E%E3%83%AB%E3%83%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E6%A7%8B%E6%88%90(%20%E3%83%A1%E3%82%A4%E3%83%B3%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%20%2B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E4%B9%97%E5%AE%A2%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4)%E3%81%A7%E5%8B%95%E3%81%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E6%99%82%E3%81%AB%3C%2FSPAN%3E%20%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20Car%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%20Launcher%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AB%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%95%8F%E9%A1%8C%20%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%AD%A3%E5%B8%B8%E3%81%AB%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E8%B5%B7%E5%8B%95%E3%81%97%20%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%A9%E3%83%B3%E3%83%81%E3%83%A3%E3%83%BC%20%E3%81%AF%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%20%E3%81%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%8A%A9%E6%89%8B%E5%B8%AD%E5%81%B4%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E4%B8%A1%E6%96%B9%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AB%20%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%BE%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%8B%E3%82%89%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%E6%96%B0%E8%A6%8F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%E3%82%84%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%20%E3%82%B2%E3%82%B9%E3%83%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AB%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%20%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%82%8B%E3%81%A8%20%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%A1%E3%82%A4%E3%83%B3%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E4%B9%97%E5%AE%A2%20%E7%94%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AE%E4%B8%A1%E6%96%B9%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%97%E3%80%81%20%E4%BD%BF%E7%94%A8%E4%B8%8D%E8%83%BD%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3EThe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eissue%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eis%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Econsistently%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Ereproducible%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eafter%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eswitching.%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%93%E3%81%A8%20%E3%82%92%20%E7%9F%A5%E3%82%8A%20%E3%81%9F%E3%81%84%20%E3%81%AE%E3%81%A7%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3Ei.MX8QM%20%E3%83%9E%E3%83%AB%E3%83%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%A7%E3%81%AE%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%20AAOS%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%2015%20%E3%81%A7%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%20%E3%83%B3%E3%82%B0%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%97%A2%E7%9F%A5%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3EAre%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Ethere%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eany%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eadditional%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Econfigurations%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Erequired%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Efor%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Epassenger%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Edisplay%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Ehandling%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eduring%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Euser%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%3F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%E3%81%93%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E5%95%8F%E9%A1%8C%20%E3%82%92%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%95%E3%82%89%E3%81%AB%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%88%86%E6%9E%90%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AD%E3%82%B0%20%E3%82%84%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E6%83%85%E5%A0%B1%20%E3%82%92%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E5%8F%8E%E9%9B%86%20%E3%81%99%20%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%20%EF%BC%9F%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E4%BD%95%E3%81%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%94%E6%8F%90%E6%A1%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%84%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%3C%2FSPAN%3E%E3%81%82%E3%82%8C%E3%81%B0%3CSPAN%20class%3D%22%22%3E%E3%80%81%E3%81%9C%E3%81%B2%3C%2FSPAN%3E%E3%81%8A%E8%81%9E%E3%81%8B%E3%81%9B%3CSPAN%20class%3D%22%22%3E%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2396181%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AAOS%2015%20User%20Switch%20Crash%20on%20i.MX8QM%20Multi-Display%20Setup%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396181%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F171173%22%20target%3D%22_blank%22%3E%40AldoG%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CDIV%3E%E3%81%94%E8%AA%AC%E6%98%8E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22%22%3E%E5%BC%8A%E7%A4%BE%E3%81%A7%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20NXP%20BSP%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FNXP%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20i.MX8QM%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20MEK%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%82%92%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%97%20%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%93%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E5%95%8F%E9%A1%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AF%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3EAndroid%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3EAAOS%E9%96%A2%E9%80%A3%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%AE%E9%81%A9%E5%88%87%E3%81%AA%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%82%84%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%82%92%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E6%95%99%E3%81%88%20%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%20%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%20%E8%B3%AA%E5%95%8F%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%20%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2396162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AAOS%2015%20User%20Switch%20Crash%20on%20i.MX8QM%20Multi-Display%20Setup%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%20NXP%20MEK%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%81NXP%20BSP%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%AA%E3%81%8A%E3%80%81%E5%BD%93%E3%82%B5%E3%82%A4%E3%83%88%E3%81%AFAndroid%20%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81BSP%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E6%94%AF%E6%8F%B4%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%A2%E3%83%AB%E3%83%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AAOS%2015%20User%20Switch%20Crash%20on%20i.MX8QM%20Multi-Display%20Setup%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F171173%22%20target%3D%22_blank%22%3E%40AldoG%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CDIV%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%94%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E5%9B%9E%E7%AD%94%20%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%20%E3%81%BE%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%AE%8C%E5%85%A8%20%E3%81%AA%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%AD%E3%82%B0%E3%82%AD%E3%83%A3%E3%83%83%E3%83%88%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%86%8D%E7%8F%BE%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%89%8B%E9%A0%86%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%8A%E3%82%88%E3%81%B3%20%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E8%A1%8C%E3%81%A3%E3%81%9F%E5%A4%89%E6%9B%B4%E7%82%B9%20%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%BE%E3%81%97%20%E3%81%9F%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%E5%86%8D%E7%8F%BE%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%89%8B%E9%A0%86%EF%BC%9A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%E3%82%BB%E3%83%B3%E3%82%BF%E3%83%BC%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E5%8A%A9%E6%89%8B%E5%B8%AD%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9F%20%E7%8A%B6%E6%85%8B%E3%81%A7%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20i.MX8QM%20%E4%B8%8A%E3%81%A7%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3EAAOS%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%2015%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3EOpen%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3ESettings%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eon%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Ethe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Epassenger%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Edisplay.%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%E4%B9%97%E5%AE%A2%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A7%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2F%E3%82%B2%E3%82%B9%E3%83%88%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AB%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E6%99%82%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20com.android.car.carlauncher%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AF%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%20%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%8B%95%E4%BD%9C%E3%81%A7%20%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FSPAN%3E%3C%2FSPAN%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eandroid.view.WindowManager%24InvalidDisplayException%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E2%80%95%E2%80%95%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E8%A1%A8%E7%A4%BA%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CDIV%3E%3CSPAN%3E%E3%83%AD%E3%82%B0%E3%82%92%E8%A6%8B%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81CarLauncher%20%E3%81%AF%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%BE%8C%E3%81%AB%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E4%BD%BF%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%88%E3%81%AA%20%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%9F%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%84%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E7%84%A1%E5%8A%B9%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AA%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%A7%E5%86%8D%E9%96%8B%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSPAN%20class%3D%22%22%3ECAN%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eyou%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eplease%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eadvise%3A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%93%E3%82%8C%E3%81%AF%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20i.MX8QM%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20AAOS%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%2015%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%9E%E3%83%AB%E3%83%81%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2F%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%A7%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E6%97%A2%E7%9F%A5%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AA%20%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%99%82%E3%81%AB%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%82%92%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AE%E3%81%AF%20%E3%81%A9%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88(OccupantZone%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20CarUserService%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20TaskDisplayArea%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20WindowManager)%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%E4%BA%8C%E6%AC%A1%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%20%E3%81%A7%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%A9%E3%83%B3%E3%83%81%E3%83%A3%E3%83%BC%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E8%B5%B7%E5%8B%95%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3EMUMD(%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4)%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E6%97%A2%E7%9F%A5%20%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E8%A6%81%E4%BB%B6%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%82%84%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%91%E3%83%83%E3%83%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3EIs%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Ethere%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eany%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Erecommended%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Edebug%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Einformation%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Ewe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eshould%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Ecollect%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eto%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eidentify%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Ewhy%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Ethe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Edisplay%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Ebecomes%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Einvalid%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Eafter%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Ethe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Euser%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%3F%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
