8MPLUSLPD4-EVK .mex
8MPLUSLPD4-EVK .mex
Charlie_Owz
Is there a .mex file available for the 8MPLUSLPD4-EVK to be used with the Config Toolsfos i.MX v9?
Many thanks.
Rita_Wang
Charlie_Owz
Thank for your answer.
We tried in the new v10 but the info that appears is exactly the same. There are several pins but we miss DDR part for example.
We would like to compare some parts of the 8MPLUSLPD4-EVK ".mex" with our project to be sure or to undestand better some behaivours.
Thanks again! Have a nice week.
Rita_Wang
You can using the Pins tool to generate the 8MPLUSLPD4-EVK.mex. Select to "Create a new configuration for a borad or porcessor", then select the board you need.
