8MMINILPD4-EVK, run android CTS media case error
gordon_2025
Hi,NXP:
   when I use 8MMINILPD4-EVK, run android CTS media case error.How should I fix this?
 getprop ro.build.version.release  is  9.The version of CTS used is Android 9.
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at org.junit.runner.JUnitCore.run(JUnitCore.java:137)
at org.junit.runner.JUnitCore.run(JUnitCore.java:115)
at android.support.test.internal.runner.TestExecutor.execute(TestExecutor.java:56)
at android.support.test.runner.AndroidJUnitRunner.onStart(AndroidJUnitRunner.java:389)
at android.app.Instrumentation$InstrumentationThread.run(Instrumentation.java:2145)
[12128.670582] alloc_contig_range: [94d00, 954f9) PFNs busy
[12128.677213] alloc_contig_range: [94e00, 955f9) PFNs busy
[12128.684007] alloc_contig_range: [94e00, 956f9) PFNs busy
[12128.690640] alloc_contig_range: [95000, 957f9) PFNs busy
Error in testHevcMain21(android.media.cts.MediaCodecCapabilitiesTest):
java.io.FileNotFoundException: Cannot find CtsMediaTestCases.dynamic
at com.android.compatibility.common.util.DynamicConfig.getConfigFile(DynamicConfig.java:101)
at com.android.compatibility.common.util.DynamicConfigDeviceSide.<init>(DynamicConfigDeviceSide.java:39)
at com.android.compatibility.common.util.DynamicConfigDeviceSide.<init>(DynamicConfigDeviceSide.java:31)
at android.media.cts.MediaCodecCapabilitiesTest.setUp(MediaCodecCapabilitiesTest.java:77)
at junit.framework.TestCase.runBare(TestCase.java:132)
at junit.framework.TestResult$1.protect(TestResult.java:115)
at android.support.test.internal.runner.junit3.AndroidTestResult.runProtected(AndroidTestResult.java:73)
at junit.framework.TestResult.run(TestResult.java:118)
at android.support.test.internal.runner.junit3.AndroidTestResult.run(AndroidTestResult.java:51)
at junit.framework.TestCase.run(TestCase.java:124)
at android.support.test.internal.runner.junit3.NonLeakyTestSuite$NonLeakyTest.run(NonLeakyTestSuite.java:62)
at junit.framework.TestSuite.runTest(TestSuite.java:243)
at junit.framework.TestSuite.run(TestSuite.java:238)
at android.support.test.internal.runner.junit3.DelegatingTestSuite.run(DelegatingTestSuite.java:97)
at android.support.test.internal.runner.junit3.AndroidTestSuite.run(AndroidTestSuite.java:65)
at android.support.test.internal.runner.junit3.JUnit38ClassRunner.run(JUnit38ClassRunner.java:115)
at org.junit.runners.Suite.runChild(Suite.java:128)
at org.junit.runners.Suite.runChild(Suite.java:27)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
Error in testHevcMain3(android.media.cts.MediaCodecCapabilitiesTest):
Error in testHevcMain31(android.media.cts.MediaCodecCapabilitiesTest):
Error in testHevcMain4(android.media.cts.MediaCodecCapabilitiesTest):
Error in testHevcMain41(android.media.cts.MediaCodecCapabilitiesTest):
Error in testHevcMain5(android.media.cts.MediaCodecCapabilitiesTest):
at junit.framework.TestSuite.run(Te[12133.586809] alloc_contig_range: 20 callbacks suppressed
stSuite.java:238)
at android.su[12133.586821] alloc_contig_range: [94d00, 954f8) PFNs busy
pport.test.internal.runner.junit3.DelegatingTestSuite.run(Delegat[12133.604502] alloc_contig_range: [94e00, 955f8) PFNs busy
at androi[12133.614414] alloc_contig_range: [94e00, 956f8) PFNs busy
d.support.test.internal.runner.ju[12133.622107] alloc_contig_range: [95000, 957f8) PFNs busy
at android.[12133.632033] alloc_contig_range: [95000, 958f8) PFNs busy
support.test.internal.runner.junit3.JUnit38ClassRunner.run(JUnit3[12133.643531] alloc_contig_range: [95200, 959f8) PFNs busy
Error in testHevcMain51(android.media.cts.MediaCodecCapabilitiesTest):
Error in testMpeg4DecoderProfileAndLevel(android.media.cts.MediaCodecCapabilitiesTest):
at android.support.test.internal.runner.junit3.NonLeakyTestSuite$NonLeakyTest.run(NonLeakyT[12135.549172] alloc_contig_range: [94d00, 954e9) PFNs busy
estSuite.java:62)
at junit.fram[12135.558139] alloc_contig_range: [94e00, 955e9) PFNs busy
ework.TestSuite.runTest(TestSuite[12135.565784] alloc_contig_range: [94e00, 956e9) PFNs busy
.java:243)
at junit.framework.T[12135.573860] alloc_contig_range: [95000, 957e9) PFNs busy
Error in testSecureCodecsAdvertiseSecurePlayback(android.media.cts.MediaCodecCapabilitiesTest):
android.media.cts.MediaCodecListTest:[12137.166415] type=1400 audit(1545225144.244:7598): avc: denied { getattr } for pid=20386 comm="df" path="/dev/block" dev="tmpfs" ino=13264 scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:object_r:block_device:s0 tclass=dir permissive=0
[12137.189022] type=1400 audit(1545225175.496:7599): avc: denied { getattr } for pid=20451 comm="df" path="/dev/block" dev="tmpfs" ino=13264 scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:object_r:block_device:s0 tclass=dir permissive=0
android.media.cts.MediaCodecTest:[12138.933715] type=1400 audit(1545225175.496:7600): avc: denied { getattr } for pid=20451 comm="df" path="/dev/block" dev="tmpfs" ino=13264 scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:object_r:block_device:s0 tclass=dir permissive=0
[12138.956438] type=1400 audit(1545225177.264:7601): avc: denied { getattr } for pid=20836 comm="df" path="/dev/block" dev="tmpfs" ino=13264 scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:object_r:block_device:s0 tclass=dir permissive=0
[12139.069135] alloc_contig_range: 16 callbacks suppressed
[12139.069143] alloc_contig_range: [94900, 94c88) PFNs busy
[12139.080742] alloc_contig_range: [94a00, 94d88) PFNs busy
[12139.087185] alloc_contig_range: [94b00, 94e88) PFNs busy
[12139.131480] alloc_contig_range: [94b00, 94c00) PFNs busy
[12139.159061] alloc_contig_range: [95100, 952c2) PFNs busy
[12139.168084] alloc_contig_range: [96300, 964c2) PFNs busy
[12139.180889] alloc_contig_range: [95100, 952c2) PFNs busy
[12139.188864] alloc_contig_range: [96300, 964c2) PFNs busy
[12139.200349] alloc_contig_range: [95100, 952c2) PFNs busy
[12139.208643] alloc_contig_range: [96300, 964c2) PFNs busy
[12144.135057] alloc_contig_range: 125 callbacks suppressed
[12144.135063] alloc_contig_range: [94900, 94c88) PFNs busy
[12144.147158] alloc_contig_range: [94a00, 94d88) PFNs busy
[12144.153273] alloc_contig_range: [94b00, 94e88) PFNs busy
[12144.179116] alloc_contig_range: [94b00, 94c00) PFNs busy
[12144.193803] alloc_contig_range: [95100, 952c2) PFNs busy
[12144.201522] alloc_contig_range: [96300, 964c2) PFNs busy
[12144.209801] alloc_contig_range: [95100, 952c2) PFNs busy
[12144.216813] alloc_contig_range: [96300, 964c2) PFNs busy
[12144.225269] alloc_contig_range: [95100, 952c2) PFNs busy
[12144.231990] alloc_contig_range: [96300, 964c2) PFNs busy
[12149.150728] alloc_contig_range: 174 callbacks suppressed
[12149.150733] alloc_contig_range: [94900, 94c88) PFNs busy
[12149.162717] alloc_contig_range: [94a00, 94d88) PFNs busy
[12149.168910] alloc_contig_range: [94b00, 94e88) PFNs busy
[12149.180979] alloc_contig_range: [97500, 97888) PFNs busy
[12149.187394] alloc_contig_range: [97600, 97988) PFNs busy
[12149.193726] alloc_contig_range: [97600, 97a88) PFNs busy
[12149.200882] alloc_contig_range: [97800, 97b88) PFNs busy
[12149.232648] alloc_contig_range: [94b00, 94c00) PFNs busy
[12149.248928] alloc_contig_range: [95100, 952c2) PFNs busy
[12149.257343] alloc_contig_range: [96300, 964c2) PFNs busy
[12154.225351] alloc_contig_range: 212 callbacks suppressed
[12154.225356] alloc_contig_range: [94900, 94c88) PFNs busy
[12154.237657] alloc_contig_range: [94a00, 94d88) PFNs busy
[12154.244040] alloc_contig_range: [94b00, 94e88) PFNs busy
[12154.254810] alloc_contig_range: [97500, 97888) PFNs busy
[12154.261195] alloc_contig_range: [97600, 97988) PFNs busy
[12154.267681] alloc_contig_range: [97600, 97a88) PFNs busy
[12154.274212] alloc_contig_range: [97800, 97b88) PFNs busy
[12154.281835] alloc_contig_range: [97900, 97c88) PFNs busy
[12154.288296] alloc_contig_range: [97a00, 97d88) PFNs busy
[12154.295031] alloc_contig_range: [97a00, 97e88) PFNs busy
[12159.380787] alloc_contig_range: 260 callbacks suppressed
[12159.380792] alloc_contig_range: [94900, 94c88) PFNs busy
[12159.392427] alloc_contig_range: [94a00, 94d88) PFNs busy
[12159.398591] alloc_contig_range: [94b00, 94e88) PFNs busy
[12159.411174] alloc_contig_range: [97500, 97888) PFNs busy
[12159.417589] alloc_contig_range: [97600, 97988) PFNs busy
[12159.424012] alloc_contig_range: [97600, 97a88) PFNs busy
[12159.430781] alloc_contig_range: [97800, 97b88) PFNs busy
[12159.439220] alloc_contig_range: [97900, 97c88) PFNs busy
[12159.446137] alloc_contig_range: [97a00, 97d88) PFNs busy
[12159.452819] alloc_contig_range: [97a00, 97e88) PFNs busy
[12164.581600] alloc_contig_range: 260 callbacks suppressed
[12164.581606] alloc_contig_range: [94900, 94c88) PFNs busy
[12164.593616] alloc_contig_range: [94a00, 94d88) PFNs busy
[12164.599898] alloc_contig_range: [94b00, 94e88) PFNs busy
[12164.612131] alloc_contig_range: [97500, 97888) PFNs busy
[12164.618681] alloc_contig_range: [97600, 97988) PFNs busy
[12164.625380] alloc_contig_range: [97600, 97a88) PFNs busy
[12164.631775] alloc_contig_range: [97800, 97b88) PFNs busy
[12164.640447] alloc_contig_range: [97900, 97c88) PFNs busy
[12164.646927] alloc_contig_range: [97a00, 97d88) PFNs busy
[12164.653606] alloc_contig_range: [97a00, 97e88) PFNs busy
..[12169.626016] alloc_contig_range: 271 callbacks suppressed
[12169.626056] alloc_contig_range: [97500, 98101) PFNs busy
[12169.638595] alloc_contig_range: [97600, 98201) PFNs busy
[12169.646123] alloc_contig_range: [97600, 98301) PFNs busy
[12169.653097] alloc_contig_range: [97800, 98401) PFNs busy
[12169.660122] alloc_contig_range: [97800, 98501) PFNs busy
[12169.667182] alloc_contig_range: [97800, 98601) PFNs busy
[12169.674377] alloc_contig_range: [97800, 98701) PFNs busy
[12169.682034] alloc_contig_range: [97c00, 98801) PFNs busy
[12169.688949] alloc_contig_range: [97d00, 98901) PFNs busy
[12169.696210] alloc_contig_range: [97e00, 98a01) PFNs busy
.............[12174.792052] alloc_contig_range: 250 callbacks suppressed
[12174.792057] alloc_contig_range: [97500, 97d00) PFNs busy
[12174.803817] alloc_contig_range: [97600, 97e00) PFNs busy
[12174.810227] alloc_contig_range: [97600, 97f00) PFNs busy
[12174.816519] alloc_contig_range: [97800, 98000) PFNs busy
[12174.823191] alloc_contig_range: [97800, 98100) PFNs busy
[12174.830315] alloc_contig_range: [97800, 98200) PFNs busy
[12174.837493] alloc_contig_range: [97800, 98300) PFNs busy
[12174.844956] alloc_contig_range: [97c00, 98400) PFNs busy
[12174.852104] alloc_contig_range: [97d00, 98500) PFNs busy
[12174.859652] alloc_contig_range: [97e00, 98600) PFNs busy
android.media.cts.MediaController2Test:
android.media.cts.MediaControllerTest:[12176.881556] type=1400 audit(1545225177.264:7602): avc: denied { getattr } for pid=20836 comm="df" path="/dev/block" dev="tmpfs" ino=13264 scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:object_r:block_device:s0 tclass=dir permissive=0
[12176.904326] type=1400 audit(1545225215.212:7603): avc: denied { getattr } for pid=21434 comm="df" path="/dev/block" dev="tmpfs" ino=13264 scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:object_r:block_device:s0 tclass=dir permissive=0
android.media.cts.MediaDrmClearkeyTest:[12177.216720] type=1400 audit(1545225215.212:7604): avc: denied { getattr } for pid=21434 comm="df" path="/dev/block" dev="tmpfs" ino=13264 scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:object_r:block_device:s0 tclass=dir permissive=0
[12177.239359] type=1400 audit(1545225215.548:7605): avc: denied { getattr } for pid=21435 comm="df" path="/dev/block" dev="tmpfs" ino=13264 scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:object_r:block_device:s0 tclass=dir permissive=0
[12178.309539] type=1400 audit(1545225215.548:7606): avc: denied { getattr } for pid=21435 comm="df" path="/dev/block" dev="tmpfs" ino=13264 scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:object_r:block_device:s0 tclass=dir permissive=0
[12178.331657] type=1400 audit(1545225216.640:7607): avc: denied { create } for pid=21439 comm="ping" scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tclass=icmp_socket permissive=0
[12178.436575] type=1400 audit(1545225216.640:7607): avc: denied { create } for pid=21439 comm="ping" scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tclass=icmp_socket permissive=0
[12178.457362] type=1400 audit(1545225216.768:7608): avc: denied { create } for pid=21441 comm="ping" scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tclass=icmp_socket permissive=0
[12178.478474] type=1400 audit(1545225216.768:7608): avc: denied { create } for pid=21441 comm="ping" scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tclass=icmp_socket permissive=0
[12178.498955] type=1400 audit(1545225216.808:7609): avc: denied { create } for pid=21443 comm="ping" scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tclass=icmp_socket permissive=0
[12178.530164] audit: audit_lost=7361 audit_rate_limit=5 audit_backlog_limit=64
[12178.537471] audit: rate limit exceeded
[12186.407425] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12186.542630] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12246.402476] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12246.537409] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12306.402486] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12306.537419] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12366.402554] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12366.537487] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12396.760604] alloc_contig_range: 267 callbacks suppressed
[12396.760614] alloc_contig_range: [94d00, 954f9) PFNs busy
[12396.772773] alloc_contig_range: [94e00, 955f9) PFNs busy
[12396.780081] alloc_contig_range: [94e00, 956f9) PFNs busy
[12396.790699] alloc_contig_range: [95000, 957f9) PFNs busy
[12396.797145] alloc_contig_range: [95000, 958f9) PFNs busy
[12396.803639] alloc_contig_range: [95200, 959f9) PFNs busy
[12396.850784] alloc_contig_range: [95b00, 962f8) PFNs busy
[12396.858967] alloc_contig_range: [95c00, 963f8) PFNs busy
[12396.866910] alloc_contig_range: [95c00, 964f8) PFNs busy
[12396.876989] alloc_contig_range: [95c00, 965f8) PFNs busy
Error in testClearKeyPlaybackCenc(android.media.cts.MediaDrmClearkeyTest):
java.io.IOException: Failed to instantiate extractor.
at android.media.MediaExtractor.nativeSetDataSource(Native Method)
at android.media.MediaExtractor.setDataSource(MediaExtractor.java:174)
at android.media.cts.MediaCodecClearKeyPlayer.setDataSource(MediaCodecClearKeyPlayer.java:282)
at android.media.cts.MediaCodecClearKeyPlayer.prepare(MediaCodecClearKeyPlayer.java:332)
at android.media.cts.MediaDrmClearkeyTest.testClearKeyPlayback(MediaDrmClearkeyTest.java:409)
at android.media.cts.MediaDrmClearkeyTest.testClearKeyPlaybackCenc(MediaDrmClearkeyTest.java:499)
at java.lang.reflect.Method.invoke(Native Method)
at android.test.InstrumentationTestCase.runMethod(InstrumentationTestCase.java:220)
at android.test.InstrumentationTestCase.runTest(InstrumentationTestCase.java:205)
at android.test.ActivityInstrumentationTestCase2.runTest(ActivityInstrumentationTestCase2.java:192)
at junit.framework.TestCase.runBare(TestCase.java:134)
[12398.281519] type=1400 audit(1545225216.836:7611): avc: denied { create } for pid=21447 comm="ping" scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tclass=icmp_socket permissive=0
[12398.304123] type=1400 audit(1545225436.608:7618): avc: denied { create } for pid=21492 comm="ping" scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tclass=icmp_socket permissive=0
[12398.336921] type=1400 audit(1545225436.608:7618): avc: denied { create } for pid=21492 comm="ping" scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tclass=icmp_socket permissive=0
[12398.358132] type=1400 audit(1545225436.640:7619): avc: denied { create } for pid=21495 comm="ping" scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tclass=icmp_socket permissive=0
[12398.379794] type=1400 audit(1545225436.640:7619): avc: denied { create } for pid=21495 comm="ping" scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tclass=icmp_socket permissive=0
[12398.404662] type=1400 audit(1545225436.680:7620): avc: denied { create } for pid=21497 comm="ping" scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tclass=icmp_socket permissive=0
[12398.417799] audit: audit_lost=7367 audit_rate_limit=5 audit_backlog_limit=64
[12398.417802] audit: rate limit exceeded
[12398.443410] type=1400 audit(1545225436.680:7620): avc: denied { create } for pid=21497 comm="ping" scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tclass=icmp_socket permissive=0
[12398.465906] type=1400 audit(1545225436.688:7621): avc: denied { create } for pid=21499 comm="ping" scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tclass=icmp_socket permissive=0
[12398.489170] type=1400 audit(1545225436.688:7621): avc: denied { create } for pid=21499 comm="ping" scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tclass=icmp_socket permissive=0
[12398.513541] type=1400 audit(1545225436.724:7622): avc: denied { create } for pid=21501 comm="ping" scontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c66,c256,c512,c768 tclass=icmp_socket permissive=0
[12426.409019] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12426.542552] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12486.402341] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12486.537512] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12546.402346] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12546.537416] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12606.402339] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12606.537426] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12666.402339] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12666.537418] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12726.402333] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12726.537443] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12786.402333] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12786.537396] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12846.402326] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12846.537403] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12906.402353] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12906.537421] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12966.402345] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[12966.537387] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[13026.402493] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[13026.537414] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[13086.402337] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[13086.537411] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[13146.402349] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[13146.537410] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[13206.402345] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[13206.537434] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[13266.402346] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[13266.537407] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
^A[13326.402350] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[13326.537411] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
Bio_TICFSL
Here are the possible reasons for the issues you are facing:
  1. Device Presetting should be done in accordance to Google Recommendations:
    1. https://source.android.com/compatibility/cts/setup
  2. Check with the wifi connected to device is consistent during execution
  3. Check out the display doesn't turn off during execution.
