4Kx2K HDMI display on i.MX6
2,086 次查看
DipenPatel1z
Dear All,
I was looking at IMX6SDLRM.pdf for HDMI interface and found 4Kx2K format is not listed under Table 34-3. Video Modes.
Documents says HDMI is compliant to v1.4a which supports 4Kx2K@upto 30fps video.
My question is does HDMI on i.MX6 supoprts 4Kx2K video?
Dipen Patel
标签 (2)
标记 (4)
1,145 次查看
SergioSolis
The HDMI PHY does support the format, however the VPU is not able to encode/decode this format, so, no, you cannot play 4k video on the i.MX6
Sergio
1,146 次查看
SergioSolis
Sergio
1,145 次查看
DipenPatel1z
Thank Sergio.
