3G Issue on imx6q
3G Issue on imx6q
2,923 次查看
blurencetin
Hi all,
We are porting Huawei MU509 3G Module to our 6q board on Android JB 4.3
After we add power-on time sequence and set "Wakein" to high, the module works well,  ttyUSB devices could be detected and baseband version is correct.
But, when we plugin sim-card, baseband version shows "unknown", network/signal strength/mobile network type are incorrect.
We checked the log, seems MU509 goes to  “selective suspend” , then resume, and changing the state endlessly.
Anyone meet such issue? any suggestion for it?
Here's the log and huawei option.c
drivers/usb/serial/option.c: option_write_room: 12288
drivers/usb/serial/option.c: option_write: endpoint 1 buf 1
drivers/usb/serial/option.c: option_outdat_callback
fxz-option_suspend entered
drivers/usb/serial/option.c: option_indat_callback: d631f7e0
drivers/usb/serial/option.c: option_indat_callback: nonzero status: -2 on endpoint 02.
drivers/usb/serial/option.c: option_indat_callback: d631f760
drivers/usb/serial/option.c: option_indat_callback: d631f6e0
drivers/usb/serial/option.c: option_indat_callback: d631f660
drivers/usb/serial/option.c: option_instat_callback
drivers/usb/serial/option.c: option_instat_callback: urb d631f860 port d7ace800 has data d63d1860
option: option_instat_callback: error -2
fxz-option_resume entered
drivers/usb/serial/option.c: Submitted interrupt URB for port 0 (result 0)
drivers/usb/serial/option.c: option_resume: No interrupt URB for port 0
drivers/usb/serial/option.c: option_instat_callback: signal x3
drivers/usb/serial/option.c: option_dtr_rts
drivers/usb/serial/option.c: option_send_setup
drivers/usb/serial/option.c: option_chars_in_buffer: 0
drivers/usb/serial/option.c: option_set_termios
drivers/usb/serial/option.c: option_write_room: 16384
drivers/usb/serial/option.c: option_write: endpoint 1 buf 0
Original Attachment has been moved to: option.c.zip
标签 (5)
标记 (5)
2 回复数
1,895 次查看
weidong_sun
Hello blurence ,
      I checked hardware documents of Huawei MU509, I feel the problems you encountered seem to be related to power up sequence, corresponding pins are following:
POWER
WAKEUP_IN
RESET
POWER_ON_OFF
Correct power up sequence is :
POWER-->POWER_ON_OFF(pull it down to LOW and hold 0.5s--1s)-->WAKEUP_IN(pull it up to HIGH, and delay 1s---3s)--->RESET(pull it down to LOW and hold 0.3s--1s, then pull it up to HIGH)
Please modify power up sequence and try again!  If above advice can't resolve your issue, please contact Huawei or distributer and get help !
Weidong
1,895 次查看
blurencetin
Thanks Weidong.
The power up sequence tips is useful, but not the root cause.
I updated the option.c/usb-wwan.c that provided by Huawei, now it works well.
Many thanks!
