3Dmark test on iMX6 PLEASE!!!
2,484 次查看
edelm
Hello, has anyone tried 3Dmark test on i.MX6q board?
At some reason i cannot get more than 6fps... The libEGL and libGLESv1 and v2 loaded ok, but still no luck to get it working.
标记 (5)
2,262 次查看
SergioSolis
which BSP of Android did you try?, and which test from 3DMark did you do?
2,262 次查看
edelm
I almost gave up..
I use Andorid 4.2.2 latest release, from boundary devices.
the 3Dmart is the one from Play Store. I guess it's the latest too.
Thanks!
2,262 次查看
edelm
Hello, anyone?
It's not hard, just load the test from the Play Store and let it run once.
