2nd Ethernet in the Android
2,765件の閲覧回数
zetta
I'm using i.MX53 QuickStartBoard and android 2.3.4,
does possible to add second ethernet (i.e. USB ethernet adapter, DM9621) in system setting menu?
The driver and init.rc modified for USB ethernet adapter driver are ready, in debug port, i can using "dhcpcd" to probe it and work fine.
but I can not enable second ethernet adapter in system setting menu, only in debug console command can enable it.
thanks.
ラベル(2)
4 返答(返信)
2,490件の閲覧回数
SergioSolis
Are you referring to having the 2nd ethernet adapter option in the android settings menu?. I have never seen that in the android gui.
2,490件の閲覧回数
zetta
no, I try to find the way to added second ethernet option in setting menu, but still not found.
2,490件の閲覧回数
YixingKong
Senior Contributor IV
Zetta
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
2,490件の閲覧回数
YixingKong
Zetta
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
