uboot log not comming
I have imx53 quick sort board i downloaded u-boot-mx53.bin and uImage to loade that into the board and dowloaded rootfs.ext2.gz in the L2.6.35_11.09.01_ERimages and i did partitions on 1GB memory card and loaded that u-boot-mx53.bin,uImage images on to the 500mb of NTFS filesystem and loaded and rootfs.ext2.gz on to the othe 500mb of ext4 file system the i inserted memorycard in to the board but u-boot logs are not comming what will be the solution
%3CLINGO-SUB%20id%3D%22lingo-sub-1107255%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Euboot%20log%20not%20comming%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107255%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin-bottom%3A%200cm%3B%22%3EI%20have%20imx53%20quick%20sort%20board%20i%20downloaded%20u-boot-mx53.bin%20and%20uImage%20to%20loade%20that%20into%20the%20board%20and%20dowloaded%20rootfs.ext2.gz%20in%20the%20L2.6.35_11.09.01_ERimages%20and%20i%20did%20partitions%20on%201GB%20memory%20card%20and%20loaded%20that%20u-boot-mx53.bin%2CuImage%20images%20on%20to%20the%20500mb%20of%20NTFS%20filesystem%20and%20loaded%20and%20rootfs.ext2.gz%20on%20to%20the%20othe%20500mb%20of%20ext4%20file%20system%20the%20i%20inserted%20memorycard%20in%20to%20the%20board%20but%20u-boot%20logs%20are%20not%20comming%20what%20will%20be%20the%20solution%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1107255%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin-bottom%3A%200cm%3B%22%3EI%20have%20imx53%20quick%20sort%20board%20i%20downloaded%20u-boot-mx53.bin%20and%20uImage%20to%20loade%20that%20into%20the%20board%20and%20dowloaded%20rootfs.ext2.gz%20in%20the%20L2.6.35_11.09.01_ERimages%20and%20i%20did%20partitions%20on%201GB%20memory%20card%20and%20loaded%20that%20u-boot-mx53.bin%2CuImage%20images%20on%20to%20the%20500mb%20of%20NTFS%20filesystem%20and%20loaded%20and%20rootfs.ext2.gz%20on%20to%20the%20othe%20500mb%20of%20ext4%20file%20system%20the%20i%20inserted%20memorycard%20in%20to%20the%20board%20but%20u-boot%20logs%20are%20not%20comming%20what%20will%20be%20the%20solution%3C%2FP%3E%3C%2FLINGO-TEASER%3E
No ratings
Version history
Last update:
‎09-05-2013 03:23 AM
Updated by:
