i.MX8MP ethernet TFTP transfer speed use case optimization
There are two ethernet ports in i.MX8MP: FEC0 and FEC1(eQOS). Normally we use iperf to test ethernets ports performance.
However, when using tftp test, the result is different in two ports. This document describe how to fine tune parameters to increase speed under tftp test or other use case.
It is suitable for most i.MX serials and most BSP version.
%3CLINGO-SUB%20id%3D%22lingo-sub-1991707%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8MP%20ethernet%20TFTP%20transfer%20speed%20use%20case%20optimization%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1991707%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3EThere%20are%20two%20ethernet%20ports%20in%20i.MX8MP%EF%BC%9A%20FEC0%20and%20FEC1(eQOS).%20Normally%20we%20use%20iperf%20to%20test%20ethernets%20ports%20performance.%3C%2FP%3E%0A%3CP%3EHowever%2C%20when%20using%20tftp%20test%2C%20the%20result%20is%20different%20in%20two%20ports.%20This%20document%20describe%20how%20to%20fine%20tune%20parameters%20to%20increase%20speed%20under%20tftp%20test%20or%20other%20use%20case.%3C%2FP%3E%0A%3CP%3EIt%20is%20suitable%20for%20most%20i.MX%20serials%20and%20most%20BSP%20version.%3C%2FP%3E%0A%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎11-10-2024 11:15 PM
Updated by:
