i.MX51 EVK Changing Env
Changing the storage for U-boot environment variables
U-Boot on Freescale BSP has a compiling option that allows you to choose the storage for environment variables.
1 - Extract the u-boot source using LTIB:
./ltib -m prep -p u-boot
2 - The source will be extracted to <ltib path>/rpm/BUILD/u-boot-2009.08
3 - On u-Boot source locate the i.MXEVK config file, <ltib path>/rpm/BUILD/u-boot-2009.08/include/configs/mx51_bbg.h
4 - To change the storage of variables environment to SD card, on this file, comment out CONFIG_FSL_ENV_IN_SF and define CONFIG_FSL_ENV_IN_MMC:
//#define CONFIG_FSL_ENV_IN_SF
#define CONFIG_FSL_ENV_IN_MMC
5 - Adjust CONFIG_ENV_SECT_SIZE and CONFIG_ENV_OFFSET accordingly. Recall that sd card read block size is 512B.
For example:
#define CONFIG_ENV_SECT_SIZE (256 * 512)
#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE
#if defined(CONFIG_FSL_ENV_IN_MMC)
#define CONFIG_ENV_IS_IN_MMC 1 #define CONFIG_ENV_OFFSET (1023 * 512)
6 - Save the file.
7 - Recompile u-boot:
./ltib -m scbuild -p u-boot
8 - Your new compiled u-boot image will be saved at: <ltib path>/rpm/BUILD/u-boot-2009.08/u-boot.bin
标签 (1)
%3CLINGO-SUB%20id%3D%22lingo-sub-1122750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX51%20EVK%20%E6%9B%B4%E6%94%B9%E7%8E%AF%E5%A2%83%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CH1%20id%3D%22toc-hId-382398481%22%20id%3D%22toc-hId-382398481%22%20id%3D%22toc-hId-1303322713%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E6%9B%B4%E6%94%B9%20U-boot%20%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%E7%9A%84%E5%AD%98%E5%82%A8%3C%2FSPAN%3E%3C%2FH1%3E%26nbsp%3B%20%3CP%3EFreescale%20BSP%20%E4%B8%8A%E7%9A%84%20U-Boot%20%E6%9C%89%E4%B8%80%E4%B8%AA%E7%BC%96%E8%AF%91%E9%80%89%E9%A1%B9%EF%BC%8C%E5%85%81%E8%AE%B8%E6%82%A8%E9%80%89%E6%8B%A9%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%E7%9A%84%E5%AD%98%E5%82%A8%E3%80%82%3C%2FP%3E%26nbsp%3B%20%3CP%3E1-%E4%BD%BF%E7%94%A8%20LTIB%20%E6%8F%90%E5%8F%96%20u-boot%20%E6%BA%90%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E.%2Fltib%20-m%20%E5%87%86%E5%A4%87%20-p%20u-boot%20%3C%2FPRE%3E%26nbsp%3B%20%3CP%3E2%20%E2%80%93%20%E6%BA%90%E4%BB%A3%E7%A0%81%E5%B0%86%E8%A2%AB%E6%8F%90%E5%8F%96%E5%88%B0%20%3CLTIB%20path%3D%22%22%3E%2Frpm%2FBUILD%2Fu-boot-2009.08%3C%2FLTIB%3E%3C%2FP%3E%26nbsp%3B%20%3CP%3E3%20-%20%E5%9C%A8%20u-Boot%20%E6%BA%90%E4%B8%8A%E6%89%BE%E5%88%B0%20i.MXEVK%20%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%EF%BC%8C%3CLTIB%20path%3D%22%22%3E%2Frpm%2FBUILD%2Fu-boot-2009.08%2Finclude%2Fconfigs%2Fmx51_bbg.h%3C%2FLTIB%3E%3C%2FP%3E%26nbsp%3B%20%3CP%3E4%20-%20%E8%A6%81%E5%B0%86%E5%8F%98%E9%87%8F%E7%8E%AF%E5%A2%83%E7%9A%84%E5%AD%98%E5%82%A8%E6%9B%B4%E6%94%B9%E4%B8%BA%20SD%20%E5%8D%A1%EF%BC%8C%E8%AF%B7%E5%9C%A8%E6%AD%A4%E6%96%87%E4%BB%B6%E4%B8%AD%E6%B3%A8%E9%87%8A%E6%8E%89%20CONFIG_FSL_ENV_IN_SF%20%E5%B9%B6%E5%AE%9A%E4%B9%89%20CONFIG_FSL_ENV_IN_MMC%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive-quote%22%3E%26nbsp%3B%20%3CP%3E%2F%2F%23%E5%AE%9A%E4%B9%89CONFIG_FSL_ENV_IN_SF%3C%2FP%3E%26nbsp%3B%20%3CP%3E%23%E5%AE%9A%E4%B9%89CONFIG_FSL_ENV_IN_MMC%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E5%20%E2%80%93%20%E7%9B%B8%E5%BA%94%E8%B0%83%E6%95%B4%20CONFIG_ENV_SECT_SIZE%20%E5%92%8C%20CONFIG_ENV_OFFSET%E3%80%82%E5%9B%9E%E6%83%B3%E4%B8%80%E4%B8%8B%EF%BC%8CSD%E5%8D%A1%E8%AF%BB%E5%8F%96%E5%9D%97%E5%A4%A7%E5%B0%8F%E4%B8%BA512B%E3%80%82%3C%2FP%3E%26nbsp%3B%20%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive-quote%22%3E%26nbsp%3B%20%3CP%3E%23%E5%AE%9A%E4%B9%89%20CONFIG_ENV_SECT_SIZE%20(256%20*%20512)%3C%2FP%3E%26nbsp%3B%20%3CP%3E%23%E5%AE%9A%E4%B9%89%20CONFIG_ENV_SIZE%20CONFIG_ENV_SECT_SIZE%3C%2FP%3E%26nbsp%3B%20%3CP%3E%23%E5%A6%82%E6%9E%9C%E5%AE%9A%E4%B9%89%EF%BC%88CONFIG_FSL_ENV_IN_MMC%EF%BC%89%3C%2FP%3E%26nbsp%3B%20%3CP%3E%23%E5%AE%9A%E4%B9%89%20CONFIG_ENV_IS_IN_MMC%201%20%23%E5%AE%9A%E4%B9%89%20CONFIG_ENV_OFFSET%20(1023%20*%20512)%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%26nbsp%3B%20%3CP%3E6%20%E2%80%93%20%E4%BF%9D%E5%AD%98%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%26nbsp%3B%20%3CP%3E7-%E9%87%8D%E6%96%B0%E7%BC%96%E8%AF%91u-boot%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E.%2Fltib%20-m%20scbuild%20-p%20u-boot%20%3C%2FPRE%3E%26nbsp%3B%20%3CP%3E8%20%E2%80%93%20%E6%82%A8%E6%96%B0%E7%BC%96%E8%AF%91%E7%9A%84%20u-boot%20%E6%98%A0%E5%83%8F%E5%B0%86%E4%BF%9D%E5%AD%98%E5%9C%A8%EF%BC%9A%3CLTIB%20path%3D%22%22%3E%2Frpm%2FBUILD%2Fu-boot-2009.08%2Fu-boot.bin%3C%2FLTIB%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1122750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX51%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
无评分
版本历史
最后更新:
‎09-10-2020 02:55 AM
更新人:
