i.MX31ADS Compiling Uboot
First download and install imx31_ads_20071008-rel5b-ltib.iso.
Download and extract u-boot-1.3.3.tar.bz2.
Place toolchain on PATH:
 $ export PATH="$PATH:/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/"
Export the CROSS_COMPILE name to U-Boot
 $ export CROSS_COMPILE=arm-none-linux-gnueabi-
Enter in the u-boot-1.3.3 directory.
Create configuration to i.MX31ADS board:
 $ make mx31ads_config
Compile U-Boot to selected board:
 $ make
If compilation goes fine you will see the u-boot.bin on current directory.
%3CLINGO-SUB%20id%3D%22lingo-sub-1123224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX31ADS%20Compiling%20Uboot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%20%3CP%3EFirst%20download%20and%20install%20imx31_ads_20071008-rel5b-ltib.iso.%3C%2FP%3E%20%3CP%3EDownload%20and%20extract%20u-boot-1.3.3.tar.bz2.%3C%2FP%3E%20%3CP%3EPlace%20toolchain%20on%20PATH%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%20%24%20export%20PATH%3D%22%24PATH%3A%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.1.2-glibc-2.5-nptl-3%2Farm-none-linux-gnueabi%2Fbin%2F%22%3C%2FPRE%3E%20%3CP%3EExport%20the%20CROSS_COMPILE%20name%20to%20U-Boot%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%20%24%20export%20CROSS_COMPILE%3Darm-none-linux-gnueabi-%20%3C%2FPRE%3E%20%3CP%3EEnter%20in%20the%20u-boot-1.3.3%20directory.%3C%2FP%3E%20%3CP%3ECreate%20configuration%20to%20i.MX31ADS%20board%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%20%24%20make%20mx31ads_config%20%3C%2FPRE%3E%20%3CP%3ECompile%20U-Boot%20to%20selected%20board%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%20%24%20make%20%3C%2FPRE%3E%20%3CP%3EIf%20compilation%20goes%20fine%20you%20will%20see%20the%20u-boot.bin%20on%20current%20directory.%3C%2FP%3E%20%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎09-10-2020 02:57 AM
Updated by:
