i.MX31 PDK Board DirectFB
To fix LCD problem:
Download DirectFB patches (click here).
Copy patches and kernel spec to LTIB:
tar zxvf DirectFB-patches-specs.tar.gz
cd specs
cp kernel-imx31_3stack-2.6.24-DirectFB-LCD-fix.patch /opt/freescale/pkgs/
cp kernel.spec.in ~/ltib-imx31pdk-r14/config/platform/imx/
Remove old kernel:
~/ltib-imx31pdk-r14$ rm -rf rpm/BUILD/linux*
Issue LTIB to decompress kernel and apply patches:
~/ltib-imx31pdk-r14$ ./ltib -p kernel -m prep
You will see at end:
+ echo Patch #1 (kernel-imx31_3stack-2.6.24-DirectFB-LCD-fix.patch):
+ patch -p1 -s
+ exit 0
Build time for kernel: 21 seconds
It means which kernel-imx31_3stack-2.6.24-DirectFB-LCD-fix.patch was applied correctly!
Now compile your kernel:
~/ltib-imx31pdk-r14$ ./ltib -p kernel -m scbuild
Install it on your rootfs:
~/ltib-imx31pdk-r14$ ./ltib -p kernel -m scdeploy
To fix Touch-Screen
Copy specs to LTIB:
cd specs
cp tslib.spec ~/ltib-imx31pdk-r14/dist/lfs-5.1/tslib/
cp DirectFB.spec ~/ltib-imx31pdk-r14/dist/lfs-5.1/DirectFB/
Remove old directories:
~/ltib-imx31pdk-r14$ rm -rf rpm/BUILD/tslib-1.0/
~/ltib-imx31pdk-r14$ rm -rf rpm/BUILD/DirectFB-1.1.0/
Edit your pkg_map and change tslib order. DirectFB needs tslib, then this lib needs be compiled first:
[alan@localhost ltib-imx31pdk-r14]$ vi config/userspace/pkg_map
PKG_TSLIB                                      = tslib
PKG_DIRECTFB                               = DirectFB
PKG_DIRECTFB_EXAMPLES            = DirectFB-examples
Now run:
alan@armagedon:~/ltib-imx31pdk-r14$ ./ltib -c
Then select DirectFB and tslib packages.
To test Touch-Screen
mx31# mknod /dev/input/tslib0 c 13 65
mx31# export TSLIB_TSDEVICE=/dev/input/tslib0
mx31# rm -f /etc/pointercal mx31# ts_calibrate
mx31# df_window
评论
Heloo,
How do i download your patches? The link doesnt work. It takes me to the imx community main page.
%3CLINGO-SUB%20id%3D%22lingo-sub-1120483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX31%20PDK%20%E6%9D%BF%20DirectFB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A7%A3%E5%86%B3%20LCD%20%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CHR%20%2F%3E%3CP%3E%E4%B8%8B%E8%BD%BD%20DirectFB%20%E8%A1%A5%E4%B8%81%EF%BC%88%3CA%20class%3D%22text%20external%22%20href%3D%22http%3A%2F%2Felinux.org%2FPorting_DirectFB%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E7%82%B9%E5%87%BB%E6%AD%A4%E5%A4%84%3C%2FA%3E%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%B0%86%E8%A1%A5%E4%B8%81%E5%92%8C%E5%86%85%E6%A0%B8%E8%A7%84%E8%8C%83%E5%A4%8D%E5%88%B6%E5%88%B0%20LTIB%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Etar%20zxvf%20DirectFB-%E8%A1%A5%E4%B8%81-specs.tar.gz%0A%20CD%E8%A7%84%E6%A0%BC%0Acp%20kernel-imx31_3stack-2.6.24-DirectFB-LCD-fix.patch%20%2Fopt%2Ffreescale%2Fpkgs%2F%0A%20cp%20kernel.spec.in%20~%2Fltib-imx31pdk-r14%2Fconfig%2Fplatform%2Fimx%2F%0A%3C%2FPRE%3E%3CP%3E%E5%88%A0%E9%99%A4%E6%97%A7%E5%86%85%E6%A0%B8%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E~%2Fltib-imx31pdk-r14%24%20rm%20-rf%20rpm%2FBUILD%2Flinux*%20%3C%2FPRE%3E%3CP%3E%E5%8F%91%E5%87%BA%20LTIB%20%E6%9D%A5%E8%A7%A3%E5%8E%8B%E7%BC%A9%E5%86%85%E6%A0%B8%E5%B9%B6%3CA%20href%3D%22http%3A%2F%2Fwww.imxdev.org%2Fwiki%2Findex.php%3Ftitle%3DI.MX31_PDK_Board_DirectFB%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22text-decoration%3A%20underline%3B%22%20title%3D%22%E7%94%B1%20Text-Enhance%20%E6%8F%90%E4%BE%9B%E6%94%AF%E6%8C%81%22%20target%3D%22_blank%22%3E%E5%BA%94%E7%94%A8%3C%2FA%3E%E8%A1%A5%E4%B8%81%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E~%2Fltib-imx31pdk-r14%24%20.%2Fltib%20-p%20kernel%20-m%20prep%20%3C%2FPRE%3E%3CP%3E%E6%9C%80%E5%90%8E%E4%BD%A0%E4%BC%9A%E7%9C%8B%E5%88%B0%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%2B%E5%9B%9E%E6%98%BE%E8%A1%A5%E4%B8%81%EF%BC%831%EF%BC%88kernel-imx31_3stack-2.6.24-DirectFB-LCD-fix.patch%EF%BC%89%EF%BC%9A%0A%E8%A1%A5%E4%B8%81%EF%BC%831%EF%BC%88kernel-imx31_3stack-2.6.24-DirectFB-LCD-fix.patch%EF%BC%89%EF%BC%9A%0A%20%2B%E8%A1%A5%E4%B8%81-p1-s%0A%20%2B%20%E5%87%BA%E5%8F%A3%200%0A%E5%86%85%E6%A0%B8%E6%9E%84%E5%BB%BA%E6%97%B6%E9%97%B4%EF%BC%9A21%E7%A7%92%0A%3C%2FPRE%3E%3CP%3E%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E5%93%AA%E4%B8%AA%20kernel-imx31_3stack-2.6.24-DirectFB-LCD-fix.patch%20%E8%A2%AB%E6%AD%A3%E7%A1%AE%E5%BA%94%E7%94%A8%EF%BC%81%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E7%BC%96%E8%AF%91%E4%BD%A0%E7%9A%84%E5%86%85%E6%A0%B8%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E~%2Fltib-imx31pdk-r14%24%20.%2Fltib%20-p%20kernel%20-m%20scbuild%20%3C%2FPRE%3E%3CP%3E%E5%B0%86%E5%85%B6%E5%AE%89%E8%A3%85%E5%9C%A8%E4%BD%A0%E7%9A%84%20rootfs%20%E4%B8%8A%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E~%2Fltib-imx31pdk-r14%24%20.%2Fltib%20-p%20kernel%20-m%20scdeploy%20%3C%2FPRE%3E%3CHR%20%2F%3E%3CP%3E%E4%BF%AE%E5%A4%8D%E8%A7%A6%E6%91%B8%E5%B1%8F%3C%2FP%3E%3CHR%20%2F%3E%3CP%3E%E5%B0%86%E8%A7%84%E6%A0%BC%E5%A4%8D%E5%88%B6%E5%88%B0%20LTIB%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3ECD%E8%A7%84%E6%A0%BC%0Acp%20tslib.spec%E3%80%9C%2F%20ltib-imx31pdk-r14%20%2F%20dist%20%2F%20lfs-5.1%20%2F%20tslib%20%2Fcp%20DirectFB.spec%20~%2Fltib-imx31pdk-r14%2Fdist%2Flfs-5.1%2FDirectFB%2F%0A%3C%2FPRE%3E%3CP%3E%E5%88%A0%E9%99%A4%E6%97%A7%E7%9B%AE%E5%BD%95%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E~%2Fltib-imx31pdk-r14%24%20rm%20-rf%20rpm%2FBUILD%2Ftslib-1.0%2F~%2Fltib-imx31pdk-r14%24%20rm%20-rf%20rpm%2FBUILD%2FDirectFB-1.1.0%2F%0A%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%E7%BC%96%E8%BE%91%E6%82%A8%E7%9A%84%20pkg_map%20%E5%B9%B6%E6%9B%B4%E6%94%B9%20tslib%20%E9%A1%BA%E5%BA%8F%E3%80%82DirectFB%E9%9C%80%E8%A6%81tslib%EF%BC%8C%E9%82%A3%E4%B9%88%E8%BF%99%E4%B8%AAlib%E9%9C%80%E8%A6%81%E5%85%88%E7%BC%96%E8%AF%91%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%5Balan%40localhost%20ltib-imx31pdk-r14%5D%24%20vi%20config%2F%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4%2Fpkg_map%0A%20...%0A%20PKG_TSLIB%20%3D%20tslib%0A%20PKG_DIRECTFB%20%3D%20DirectFB%0A%20PKG_DIRECTFB_EXAMPLES%20%3D%20DirectFB%20%E7%A4%BA%E4%BE%8B%0A...%0A%3C%2FPRE%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E8%BF%90%E8%A1%8C%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Ealan%40armagedon%3A~%2Fltib-imx31pdk-r14%24%20.%2Fltib%20-c%20%3C%2FPRE%3E%3CP%3E%E7%84%B6%E5%90%8E%E9%80%89%E6%8B%A9DirectFB%E5%92%8Ctslib%E5%8C%85%E3%80%82%3C%2FP%3E%3CHR%20%2F%3E%3CP%3E%E6%B5%8B%E8%AF%95%E8%A7%A6%E6%91%B8%E5%B1%8F%3C%2FP%3E%3CHR%20%2F%3E%3CPRE%20class%3D%22jive-pre%22%3Emx31%23%20mknod%20%2Fdev%2Finput%2Ftslib0%20c%2013%2065%0A%20mx31%23%E5%AF%BC%E5%87%BATSLIB_TSDEVICE%3D%2Fdev%2Finput%2Ftslib0%0A%20mx31%23%20rm%20-f%20%2Fetc%2Fpointercal%20mx31%23%20ts_calibrate%0A%20mx31%23%20df_%E7%AA%97%E5%8F%A3%0A%3C%2FPRE%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Ai.MX31%20PDK%20%E6%9D%BF%20DirectFB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHeloo%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%A6%82%E4%BD%95%E4%B8%8B%E8%BD%BD%E6%82%A8%E7%9A%84%E8%A1%A5%E4%B8%81%EF%BC%9F%E8%AF%A5%E9%93%BE%E6%8E%A5%E6%97%A0%E6%95%88%E3%80%82%E5%AE%83%E5%B0%86%E6%88%91%E5%B8%A6%E5%88%B0%20imx%20%E7%A4%BE%E5%8C%BA%E4%B8%BB%E9%A1%B5%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 02:47 AM
更新人:
