i.MX27 D1 Capture Kernel 2.6.22
D1 Capture - kernel 2.6.22
diff --exclude CVS -uNr linux-2.6.22/include/asm-arm/arch-mxc/memory.h linux-2.6.22.modified/include/asm-arm/arch-mxc/memory.h
--- linux-2.6.22/include/asm-arm/arch-mxc/memory.h     2009-07-16 16:29:45.000000000 -0300
+++ linux-2.6.22.modified/include/asm-arm/arch-mxc/memory.h     2009-07-15 15:38:34.000000000 -0300
@@ -28,6 +28,7 @@
    /* Size of contiguous memory for DMA and other h/w blocks */
    #define CONSISTENT_DMA_SIZE     SZ_16M
     * @defgroup Memory_MX27 Memory Map
     * @ingroup MSL_MX27
 @@ -48,7 +49,7 @@
    #ifdef CONFIG_DMA_ZONE_SIZE
    #define MXC_DMA_ZONE_SIZE     ((CONFIG_DMA_ZONE_SIZE * SZ_1M) >> PAGE_SHIFT)
    #else
   -#define MXC_DMA_ZONE_SIZE     ((12 * SZ_1M) >> PAGE_SHIFT)
  +#define MXC_DMA_ZONE_SIZE     ((20 * SZ_1M) >> PAGE_SHIFT)
    #endif
    static inline void __arch_adjust_zones(int node, unsigned long *zone_size,
diff --exclude CVS -uNr linux-2.6.22/drivers/media/video/mxc/capture/mxc_v4l2_capture.c linux-2.6.22.modified/drivers/media/video/mxc/capture/mxc_v4l2_capture.c
---    linux-2.6.22/drivers/media/video/mxc/capture/mxc_v4l2_capture.c     2009-07-16 16:29:43.000000000 -0300
+++ linux-2.6.22.modified/drivers/media/video/mxc/capture/mxc_v4l2_capture.c     2009-07-16 16:08:02.000000000 -0300
@@ -1650,9 +1650,9 @@
                /* setup cropping */
                cam->crop_bounds.left = 0;
-             cam->crop_bounds.width = 640;
+             cam->crop_bounds.width = 800;
                cam->crop_bounds.top = 0;
-             cam->crop_bounds.height = 480;
+             cam->crop_bounds.height = 600;
                cam->crop_current = cam->crop_defrect = cam->crop_bounds;
                ipu_csi_set_window_size(cam->crop_current.width,
                                                      cam->crop_current.height);
@@ -1663,7 +1663,7 @@
                cam->standard.id = V4L2_STD_UNKNOWN;
                cam->standard.frameperiod.denominator = 30;
                cam->standard.frameperiod.numerator = 1;
-             cam->standard.framelines = 480;
+             cam->standard.framelines = 600;
                cam->streamparm.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
                cam->streamparm.parm.capture.timeperframe =
                cam->standard.frameperiod; cam->streamparm.parm.capture.capability = V4L2_CAP_TIMEPERFRAME;
diff --exclude CVS -uNr linux-2.6.22/drivers/media/video/mxc/capture/ov2640.c linux-2.6.22.modified/drivers/media/video/mxc/capture/ov2640.c
---    linux-2.6.22/drivers/media/video/mxc/capture/ov2640.c     2009-07-16 16:29:45.000000000 -0300
+++ linux-2.6.22.modified/drivers/media/video/mxc/capture/ov2640.c     2009-07-16 16:07:03.000000000 -0300
@@ -698,12 +698,12 @@
    #endif
                           g_cam->streamparm.parm.capture.capturemode = 1;
                } else {
-          out_width = 640;
-          out_height = 480;
+          out_width = 800;
+          out_height = 600;
                g_cam->crop_bounds.left = 0;
-          g_cam->crop_bounds.width = 640;
+          g_cam->crop_bounds.width = 800;
                g_cam->crop_bounds.top = 0;
-          g_cam->crop_bounds.height = 480;
+          g_cam->crop_bounds.height = 600;
                g_cam->crop_current = g_cam->crop_defrect = g_cam->crop_bounds;
    #ifdef CONFIG_ARCH_MX3
                             ipu_csi_set_window_size(g_cam->crop_current.width ,
タグ(2)
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 03:07 AM
更新者:
