i.MX Yocto Proyect: How can I create a new Layer?
It is suggested to create a layer when creating or modifying any metadata file (recipe, configuration file or class). The main reason is simple: modularity. Follow these steps
1. To have access to Yocto scripts, setup the enviroment from the BASE folder
fsl-community-bsp $ . setup-environment build
2. Move to the place you want to create your layer and choose a name (e.g. `fsl-custom`)
sources $ yocto-layer create fsl-custom
# Answer the questions. Make sure the priority is set correctly (higher numbers,
# higher priorities). Set the priority equal to the lowest already present, except
# when you have introduce a new recipe with the same name as other and want to shadow
# the original one.
3. Add any metadata content. Suggestion: Version the layer with Git and upload your local git repo to a server
4. Edit and add the layer to the `build/conf/bblayers.conf` file
5. To verify that your layer is *seen* by BitBake, run the following command under the build folder
build $ bitbake-layers show-layers
This document was generated from the following discussion: i.MX Yocto Proyect: How can I create a new Layer?
%3CLINGO-SUB%20id%3D%22lingo-sub-1103962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX%20Yocto%20Proyect%EF%BC%9A%E5%A6%82%E4%BD%95%E5%88%9B%E5%BB%BA%E6%96%B0%E5%B1%82%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BB%BA%E8%AE%AE%E5%9C%A8%E5%88%9B%E5%BB%BA%E6%88%96%E4%BF%AE%E6%94%B9%E4%BB%BB%E4%BD%95%E5%85%83%E6%95%B0%E6%8D%AE%E6%96%87%E4%BB%B6%EF%BC%88%E9%85%8D%E6%96%B9%E3%80%81%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E6%88%96%E7%B1%BB%EF%BC%89%E6%97%B6%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%B1%82%E3%80%82%E4%B8%BB%E8%A6%81%E5%8E%9F%E5%9B%A0%E5%BE%88%E7%AE%80%E5%8D%95%EF%BC%9A%3CSTRONG%3E%E6%A8%A1%E5%9D%97%E5%8C%96%3C%2FSTRONG%3E%E3%80%82%E8%AF%B7%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E6%93%8D%E4%BD%9C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%20%E8%A6%81%E8%AE%BF%E9%97%AE%20Yocto%20%E8%84%9A%E6%9C%AC%EF%BC%8C%E8%AF%B7%E4%BB%8E%20BASE%20%E6%96%87%E4%BB%B6%E5%A4%B9%E8%AE%BE%E7%BD%AE%E7%8E%AF%E5%A2%83%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Efsl-%E7%A4%BE%E5%8C%BA-bsp%20%24%E3%80%82%E8%AE%BE%E7%BD%AE%E7%8E%AF%E5%A2%83%E6%9E%84%E5%BB%BA%3C%2FP%3E%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%20%E7%A7%BB%E5%8A%A8%E5%88%B0%E8%A6%81%E5%88%9B%E5%BB%BA%E5%9B%BE%E5%B1%82%E7%9A%84%E4%BD%8D%E7%BD%AE%E5%B9%B6%E9%80%89%E6%8B%A9%E4%B8%80%E4%B8%AA%E5%90%8D%E7%A7%B0%EF%BC%88%E4%BE%8B%E5%A6%82%60fsl-custom%60)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E6%9D%A5%E6%BA%90%24%20yocto-layer%E5%88%9B%E5%BB%BAfsl-custom%3C%2FP%3E%0A%3CP%3E%23%20%E5%9B%9E%E7%AD%94%E9%97%AE%E9%A2%98%E3%80%82%E7%A1%AE%E4%BF%9D%E4%BC%98%E5%85%88%E7%BA%A7%E8%AE%BE%E7%BD%AE%E6%AD%A3%E7%A1%AE%EF%BC%88%E6%95%B0%E5%AD%97%E8%B6%8A%E5%A4%A7%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%23%20%E6%9B%B4%E9%AB%98%E7%9A%84%E4%BC%98%E5%85%88%E7%BA%A7%EF%BC%89%E3%80%82%E5%B0%86%E4%BC%98%E5%85%88%E7%BA%A7%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%9C%80%E4%BD%8E%E7%9A%84%E5%B7%B2%E7%BB%8F%E5%AD%98%E5%9C%A8%E7%9A%84%EF%BC%8C%E9%99%A4%E9%9D%9E%3C%2FP%3E%0A%3CP%3E%23%20%E5%BD%93%E4%BD%A0%E5%BC%95%E5%85%A5%E4%B8%80%E4%B8%AA%E4%B8%8E%E5%85%B6%E4%BB%96%E8%8F%9C%E8%B0%B1%E5%90%8C%E5%90%8D%E7%9A%84%E6%96%B0%E8%8F%9C%E8%B0%B1%E5%B9%B6%E6%83%B3%E8%A6%81%E5%A4%8D%E5%88%B6%E6%97%B6%3C%2FP%3E%0A%3CP%3E%23%20%E5%8E%9F%E5%A7%8B%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%20%E6%B7%BB%E5%8A%A0%E4%BB%BB%E4%BD%95%E5%85%83%E6%95%B0%E6%8D%AE%E5%86%85%E5%AE%B9%E3%80%82%E5%BB%BA%E8%AE%AE%EF%BC%9A%E4%BD%BF%E7%94%A8%20Git%20%E5%AF%B9%E5%B1%82%E8%BF%9B%E8%A1%8C%E7%89%88%E6%9C%AC%E6%8E%A7%E5%88%B6%EF%BC%8C%E5%B9%B6%E5%B0%86%E6%9C%AC%E5%9C%B0%20git%20repo%20%E4%B8%8A%E4%BC%A0%E5%88%B0%E6%9C%8D%E5%8A%A1%E5%99%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E4.%E7%BC%96%E8%BE%91%E5%B9%B6%E5%B0%86%E5%B1%82%E6%B7%BB%E5%8A%A0%E5%88%B0%60build%2Fconf%2Fbblayers.conf%60%E6%96%87%E4%BB%B6%E4%B8%AD%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E5.%20%E8%A6%81%E9%AA%8C%E8%AF%81%E4%BD%A0%E7%9A%84%E5%B1%82%E6%98%AF%E5%90%A6%E8%A2%AB%20BitBake%20%E7%9C%8B%E5%88%B0%EF%BC%8C%E8%AF%B7%E5%9C%A8%3CEM%3E%E6%9E%84%E5%BB%BA%3C%2FEM%3E%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%8B%E8%BF%90%E8%A1%8C%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E6%9E%84%E5%BB%BA%20%24%20bitbake-layers%20%E6%98%BE%E7%A4%BA%E5%B1%82%3C%2FP%3E%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%AC%E6%96%87%E6%A1%A3%E7%94%B1%E4%BB%A5%E4%B8%8B%E8%AE%A8%E8%AE%BA%E7%94%9F%E6%88%90%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F310288%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Proyect%EF%BC%9A%E5%A6%82%E4%BD%95%E5%88%9B%E5%BB%BA%E6%96%B0%E5%B1%82%EF%BC%9F%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎08-19-2013 08:20 AM
更新人:
