i.MX 93: How to read/write a GPIO pin in SPL
This article describes how to enable the GPIO support in SPL for i.MX 93 and how to use the associated library.
Available GPIO banks
Bank Registers' Base Address
GPIO1 0x47400000
GPIO2 0x43810000
GPIO3 0x43820000
GPIO4 0x43830000
Software
Tests performed using the LF6.12.20-2.0.0 BSP, but should work similarly in other versions.
Enable the GPIO support in SPL
Enable the CONFIG_SPL_GPIO through menuconfig.
Configure the GPIO pin
Make sure the chosen GPIO pin is not used by any other peripheral, by checking U-Boot's device tree (example: imx93-11x11-evk.dts and its included files). If used, disable the conflicting peripheral in the device tree.
To identify the exact macro associated to the GPIO functionality, please check the arch/arm/dts/imx93-pinfunc.h file.
  • Example 1: Use an available GPIO pin (e.g. GPIO2_IO05)
This pin is not used by other peripheral, so there is nothing to disable.
To use the pin with the GPIO functionality, the following pin muxing must be added in the iomux node of the imx93-11x11-evk.dts file (located in dts/upstream/src/arm64/freescale/
pinctrl_hog: hoggrp {
    fsl,pins = <
        MX93_PAD_GPIO_IO05__GPIO2_IO05    0x51e
Note: 0x51e represents the value you want in the PAD register (SW_PAD_CTL_PAD_GPIO_IO05). You may configure it as you want.
  •  Example 2: Use the XSPI1_TXC pin as GPIO (GPIO1_IO12)
In our BSP, by default, this pin is used by the SAI1 peripheral. To use this pin as GPIO, SAI1 must be disabled in device tree.
&sai1 {
        status = "disabled";
To use the XSPI1_TXC pin with the GPIO functionality, the following pin muxing must be added in the iomux node of the imx93-11x11-evk.dts file (located in dts/upstream/src/arm64/freescale/
    fsl,pins = <
        MX93_PAD_SAI1_TXC__GPIO1_IO12    0x51e
Include the correct header files
In the file you want to use the GPIO, include the following headers:
#include <asm/arch-mx7ulp/gpio.h>
#include <asm-generic/gpio.h>
Define the GPIO
To define the GPIO's handle, use the IMX_GPIO_NR(bank, index) macro.
  • index = The pin number within the bank.
  • bank = The GPIO bank number, mapped as follows (due to the way they are placed in memory):
GPIO Bank bank value for IMX_GPIO_NR
GPIO1 4
GPIO2 1
GPIO3 2
GPIO4 3
  • Example 1: Compute the handle for GPIO2_IO05
#define TIMED_GPIO IMX_GPIO_NR(1, 5)
  • Example 2: Compute the handle for XSPI1_TXC (GPIO1_IO12)
#define TIMED_GPIO IMX_GPIO_NR(4, 12)
Read the GPIO pin
gpio_request(TIMED_GPIO, "timed_gpio");
gpio_direction_input(TIMED_GPIO);
int val = gpio_get_value(TIMED_GPIO);
printf("GPIO value is %d\n", val);
Write the GPIO pin
// set the pin as output and make it high
gpio_direction_output(TIMED_GPIO, 1);
The driver used is drivers/gpio/gpio-uclass.c.
%3CLINGO-SUB%20id%3D%22lingo-sub-2192595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX%2093%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8SPL%E4%B8%AD%E8%AF%BB%E5%8F%96%2F%E5%86%99%E5%85%A5GPIO%E5%BC%95%E8%84%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%E6%9C%AC%E6%96%87%E4%BB%8B%E7%BB%8D%E4%BA%86%E5%A6%82%E4%BD%95%E5%9C%A8i.MX%2093%E7%9A%84SPL%E4%B8%AD%E5%90%AF%E7%94%A8GPIO%E6%94%AF%E6%8C%81%EF%BC%8C%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%85%B3%E5%BA%93%E3%80%82%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId-180478235%22%20id%3D%22toc-hId-202610993%22%3E%E5%8F%AF%E7%94%A8%E7%9A%84GPIO%E7%BB%84%3C%2FH4%3E%0A%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3E%3CSTRONG%3E%E7%BB%84%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3E%3CSTRONG%3E%E5%AF%84%E5%AD%98%E5%99%A8%E5%9F%BA%E5%9C%B0%E5%9D%80%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3EGPIO1%3C%2FTD%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3E0x47400000%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3EGPIO2%3C%2FTD%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3E0x43810000%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3EGPIO3%3C%2FTD%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3E0x43820000%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3EGPIO4%3C%2FTD%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3E0x43830000%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH4%20id%3D%22toc-hId--1626976228%22%20id%3D%22toc-hId--1604843470%22%3E%26nbsp%3B%3C%2FH4%3E%0A%3CH4%20id%3D%22toc-hId-860536605%22%20id%3D%22toc-hId-882669363%22%3E%E8%BD%AF%E4%BB%B6%3C%2FH4%3E%0A%3CP%3E%E6%B5%8B%E8%AF%95%E5%80%9F%E5%8A%A9LF6.12.20-2.0.0%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85(BSP)%E5%AE%8C%E6%88%90%EF%BC%8C%E4%BD%86%E5%85%B6%E4%BB%96%E7%89%88%E6%9C%AC%E4%B9%9F%E5%BA%94%E5%85%B7%E5%A4%87%E7%B1%BB%E4%BC%BC%E7%9A%84%E5%85%BC%E5%AE%B9%E6%80%A7%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH4%20id%3D%22toc-hId--946917858%22%20id%3D%22toc-hId--924785100%22%3E%E5%9C%A8SPL%E4%B8%AD%E5%90%AF%E7%94%A8GPIO%E6%94%AF%E6%8C%81%3C%2FH4%3E%0A%3CP%3E%E9%80%9A%E8%BF%87%E8%8F%9C%E5%8D%95%E9%85%8D%E7%BD%AE%E5%90%AF%E7%94%A8CONFIG_SPL_GPIO%E3%80%82%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId-1540594975%22%20id%3D%22toc-hId-1562727733%22%3E%E9%85%8D%E7%BD%AE%20GPIO%20%E5%BC%95%E8%84%9A%3C%2FH4%3E%0A%3CP%3E%E9%80%9A%E8%BF%87%E6%A3%80%E6%9F%A5U-Boot%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%9A%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eimx93-11x11-evk.dts%3C%2FFONT%3E%E5%8F%8A%E5%85%B6%E5%8C%85%E5%90%AB%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%E7%A1%AE%E4%BF%9D%E6%89%80%E9%80%89GPIO%E5%BC%95%E8%84%9A%E6%9C%AA%E8%A2%AB%E5%85%B6%E4%BB%96%E5%A4%96%E8%AE%BE%E5%8D%A0%E7%94%A8%E3%80%82%E5%A6%82%E5%B7%B2%E5%8D%A0%E7%94%A8%EF%BC%8C%E8%AF%B7%E5%9C%A8%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%AD%E7%A6%81%E7%94%A8%E5%86%B2%E7%AA%81%E7%9A%84%E5%A4%96%E8%AE%BE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E7%A1%AE%E5%AE%9A%E4%B8%8EGPIO%E5%8A%9F%E8%83%BD%E7%9B%B8%E5%85%B3%E7%9A%84%E5%85%B7%E4%BD%93%E5%AE%8F%EF%BC%8C%E8%AF%B7%E6%9F%A5%E7%9C%8B%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Earch%2Farm%2Fdts%2Fimx93-pinfunc.h%3C%2FFONT%3E%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E7%A4%BA%E4%BE%8B1%EF%BC%9A%3C%2FSTRONG%3E%E4%BD%BF%E7%94%A8%E5%8F%AF%E7%94%A8%E7%9A%84GPIO%E5%BC%95%E8%84%9A%EF%BC%88%E4%BE%8B%E5%A6%82GPIO2_IO05%EF%BC%89%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%20class%3D%22lia-indent-padding-left-60px%22%20style%3D%22padding-left%20%3A%2060px%3B%22%20style%3D%22padding-left%20%3A%2060px%3B%22%3E%E8%AF%A5%E5%BC%95%E8%84%9A%E6%9C%AA%E8%A2%AB%E5%85%B6%E4%BB%96%E5%A4%96%E8%AE%BE%E4%BD%BF%E7%94%A8%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%97%A0%E9%9C%80%E7%A6%81%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CP%20class%3D%22lia-indent-padding-left-60px%22%20style%3D%22padding-left%20%3A%2060px%3B%22%20style%3D%22padding-left%20%3A%2060px%3B%22%3E%E8%A6%81%E4%BD%BF%E7%94%A8%E5%85%B7%E5%A4%87GPIO%E5%8A%9F%E8%83%BD%E7%9A%84%E5%BC%95%E8%84%9A%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%B0%86%E4%BB%A5%E4%B8%8B%E5%BC%95%E8%84%9A%E5%A4%9A%E8%B7%AF%E5%A4%8D%E7%94%A8%E6%B7%BB%E5%8A%A0%E5%88%B0%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eiomux%3C%2FFONT%3E%E8%8A%82%E7%82%B9%EF%BC%8C%E6%AD%A4%E8%8A%82%E7%82%B9%E9%9A%B6%E5%B1%9E%E4%BA%8E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eimx93-11x11-evk.dts%3C%2FFONT%3E%E6%96%87%E4%BB%B6%EF%BC%88%E5%85%B7%E4%BD%93%E4%BD%8D%E7%BD%AE%EF%BC%9A%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Edts%2Fupstream%2Fsrc%2Farm64%2Ffreescale%2F%3C%2FFONT%3E%EF%BC%89%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%0A%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Epinctrl_hog%3A%20hoggrp%20%7B%0A%20%20%20%20fsl%2Cpins%20%3D%20%26lt%3B%0A%20%20%20%20%20%20%20%20MX93_PAD_GPIO_IO05__GPIO2_IO05%20%20%20%200x51e%0A%20%20%20%20%26gt%3B%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%20class%3D%22lia-indent-padding-left-60px%22%20style%3D%22padding-left%20%3A%2060px%3B%22%20style%3D%22padding-left%20%3A%2060px%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A0x51e%20%E8%A1%A8%E7%A4%BA%E6%82%A8%E5%B8%8C%E6%9C%9B%20PAD%20%E5%AF%84%E5%AD%98%E5%99%A8%20(SW_PAD_CTL_PAD_GPIO_IO05)%20%E4%B8%AD%E7%9A%84%E5%80%BC%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%A0%B9%E6%8D%AE%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%26nbsp%3B%3CSTRONG%3E%E7%A4%BA%E4%BE%8B2%EF%BC%9A%3C%2FSTRONG%3E%E4%BD%BF%E7%94%A8XSPI1_TXC%E5%BC%95%E8%84%9A%E4%BD%9C%E4%B8%BAGPIO(GPIO1_IO12)%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%20class%3D%22lia-indent-padding-left-60px%22%20style%3D%22padding-left%20%3A%2060px%3B%22%20style%3D%22padding-left%20%3A%2060px%3B%22%3E%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84BSP%E4%B8%AD%EF%BC%8C%E6%AD%A4%E5%BC%95%E8%84%9A%E9%BB%98%E8%AE%A4%E7%94%B1SAI1%E5%A4%96%E8%AE%BE%E4%BD%BF%E7%94%A8%E3%80%82%E8%A6%81%E5%B0%86%E6%AD%A4%E5%BC%95%E8%84%9A%E7%94%A8%E4%BD%9CGPIO%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%9C%A8%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%AD%E7%A6%81%E7%94%A8SAI1%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%26amp%3Bsai1%20%7B%0A%20%20%20%20%20%20%20%20status%20%3D%20%22disabled%22%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%20class%3D%22lia-indent-padding-left-60px%22%20style%3D%22padding-left%20%3A%2060px%3B%22%20style%3D%22padding-left%20%3A%2060px%3B%22%3E%E8%A6%81%E4%BD%BF%E7%94%A8%E5%85%B7%E5%A4%87GPIO%E5%8A%9F%E8%83%BD%E7%9A%84XSPI1_TXC%E5%BC%95%E8%84%9A%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%B0%86%E4%BB%A5%E4%B8%8B%E5%BC%95%E8%84%9A%E5%A4%9A%E8%B7%AF%E5%A4%8D%E7%94%A8%E6%B7%BB%E5%8A%A0%E5%88%B0%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eiomux%3C%2FFONT%3E%E8%8A%82%E7%82%B9%EF%BC%8C%E6%AD%A4%E8%8A%82%E7%82%B9%E9%9A%B6%E5%B1%9E%E4%BA%8E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eimx93-11x11-evk.dts%3C%2FFONT%3E%E6%96%87%E4%BB%B6%EF%BC%88%E5%85%B7%E4%BD%93%E4%BD%8D%E7%BD%AE%EF%BC%9A%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Edts%2Fupstream%2Fsrc%2Farm64%2Ffreescale%2F%3C%2FFONT%3E%EF%BC%89%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Epinctrl_hog%3A%20hoggrp%20%7B%0A%20%20%20%20fsl%2Cpins%20%3D%20%26lt%3B%0A%20%20%20%20%20%20%20%20MX93_PAD_SAI1_TXC__GPIO1_IO12%20%20%20%200x51e%0A%20%20%20%20%26gt%3B%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CH4%20id%3D%22toc-hId--266859488%22%20id%3D%22toc-hId--244726730%22%3E%E5%8C%85%E5%90%AB%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%A4%B4%E6%96%87%E4%BB%B6%3C%2FH4%3E%0A%3CP%3E%E5%9C%A8%E8%A6%81%E4%BD%BF%E7%94%A8GPIO%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%E5%BC%95%E5%85%A5%E4%BB%A5%E4%B8%8B%E5%A4%B4%E6%96%87%E4%BB%B6%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23include%20%3CASM%3E%0A%23include%20%3CASM-GENERIC%3E%3C%2FASM-GENERIC%3E%3C%2FASM%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CH4%20id%3D%22toc-hId--2074313951%22%20id%3D%22toc-hId--2052181193%22%3E%E5%AE%9A%E4%B9%89GPIO%3C%2FH4%3E%0A%3CP%3E%E8%A6%81%E5%AE%9A%E4%B9%89%20GPIO%20%E7%9A%84%E5%8F%A5%E6%9F%84%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EIMX_GPIO_NR(bank%2C%20index)%3C%2FFONT%3E%20%E5%AE%8F%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E7%B4%A2%E5%BC%95%3C%2FSTRONG%3E%20%3D%20%E5%AD%98%E5%82%A8%E9%98%B5%E5%88%97%E5%86%85%E7%9A%84%E5%BC%95%E8%84%9A%E7%BC%96%E5%8F%B7%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3E%E7%BB%84%3C%2FSTRONG%3E%20%3D%20GPIO%E7%BB%84%E7%BC%96%E5%8F%B7%EF%BC%8C%E6%98%A0%E5%B0%84%E6%96%B9%E5%BC%8F%E5%A6%82%E4%B8%8B%EF%BC%88%E6%A0%B9%E6%8D%AE%E5%86%85%E5%AD%98%E5%B8%83%E5%B1%80%E5%AE%9A%E4%B9%89%EF%BC%89%EF%BC%9A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2226px%22%3E%3CSTRONG%3EGPIO%E7%BB%84%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2226px%22%3E%3CSTRONG%3EIMX_GPIO_NR%E7%9A%84%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E7%BB%84%3C%2FFONT%3E%E5%80%BC%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3EGPIO1%3C%2FTD%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3E4%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3EGPIO2%3C%2FTD%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3E1%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3EGPIO3%3C%2FTD%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3E2%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3EGPIO4%3C%2FTD%3E%0A%3CTD%20width%3D%2250%25%22%20height%3D%2224px%22%3E3%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E7%A4%BA%E4%BE%8B%201%3C%2FSTRONG%3E%EF%BC%9A%E8%AE%A1%E7%AE%97%20GPIO2_IO05%20%E7%9A%84%E5%8F%A5%E6%9F%84%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23define%20TIMED_GPIO%20IMX_GPIO_NR(1%2C%205)%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E7%A4%BA%E4%BE%8B2%3C%2FSTRONG%3E%EF%BC%9A%E8%AE%A1%E7%AE%97XSPI1_TXC%E7%9A%84%E5%8F%A5%E6%9F%84%20(GPIO1_IO12)%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23define%20TIMED_GPIO%20IMX_GPIO_NR(4%2C%2012)%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CH4%20id%3D%22toc-hId-413198882%22%20id%3D%22toc-hId-435331640%22%3E%26nbsp%3B%3C%2FH4%3E%0A%3CH4%20id%3D%22toc-hId--1394255581%22%20id%3D%22toc-hId--1372122823%22%3E%E8%AF%BB%E5%8F%96%20GPIO%20%E5%BC%95%E8%84%9A%3C%2FH4%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Egpio_request(TIMED_GPIO%2C%20%22timed_gpio%22)%3B%0Agpio_direction_input(TIMED_GPIO)%3B%0Aint%20val%20%3D%20gpio_get_value(TIMED_GPIO)%3B%0Aprintf(%22GPIO%20value%20is%20%25d%5Cn%22%2C%20val)%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CH4%20id%3D%22toc-hId-1093257252%22%20id%3D%22toc-hId-1115390010%22%3E%26nbsp%3B%3C%2FH4%3E%0A%3CH4%20id%3D%22toc-hId-516673388%22%20id%3D%22toc-hId-538806146%22%3E%E5%86%99%E5%85%A5GPIO%E5%BC%95%E8%84%9A%3C%2FH4%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Egpio_request(TIMED_GPIO%2C%20%22timed_gpio%22)%3B%0A%2F%2F%20set%20the%20pin%20as%20output%20and%20make%20it%20high%0Agpio_direction_output(TIMED_GPIO%2C%201)%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%89%80%E7%94%A8%E9%A9%B1%E5%8A%A8%E6%98%AF%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Edrivers%2Fgpio%2Fgpio-uclass.c%3C%2FFONT%3E%E3%80%82%3C%2FP%3E%0A%3C%2FLINGO-BODY%3E
100% 有帮助 (1/1)
版本历史
最后更新:
‎10-27-2025 02:03 PM
更新人:
